  4. Sourceanalytix Error Log - [gelöst]
    5.6k
7 Beiträge 3 Kommentatoren 714 Aufrufe 3 Beobachtet
  • NicolomaN Offline
    NicolomaN Offline
    Nicoloma
    schrieb am zuletzt editiert von Nicoloma
    ich habe zur Zeit ein Problem mit dem Source-analytix.
    Ich verstehe den Error nicht :-/
    Node.js: v16.18.1
    NPM: 8.19.2
    sourceanalytix.1
    2022-11-11 11:25:43.656	error	(COMPACT) Initialization of 0_userdata.0.Gas.verbrauch_kwh failed, check warn messages !
    sourceanalytix.1
    2022-11-11 11:25:43.654	error	(COMPACT) Cannot handle calculations for 0_userdata.0.Gas.verbrauch_kwh, check log messages and adjust settings!
    sourceanalytix.1
    2022-11-11 11:25:43.654	error	(COMPACT) Troubleshoot Data 0_userdata.0.Gas.verbrauch_kwh custom Data : {"common":{"name":"verbrauch_kwh","desc":"Manuell erzeugt","role":"state","type":"number","read":true,"write":true,"def":0,"custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.1":{"enabled":true,"selectedUnit":"kWh","start_day":222.92000000002736,"start_week":169.7000000000262,"start_month":0,"start_quarter":0,"start_year":0,"alias":"gasverbrauchkwh_source","selectedPrice":"Gas Leistung","costs":true,"consumption":true,"meter_values":false,"valueAtDeviceReset":225.1300000000192,"valueAtDeviceInit":0,"cumulativeValue":222.92000000002736}}},"type":"state","native":{},"_id":"0_userdata.0.Gas.verbrauch_kwh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.1","user":"system.user.admin","ts":1666327122208}
    sourceanalytix.1
    2022-11-11 11:25:43.653	error	(COMPACT) Check settings for 0_userdata.0.Gas.verbrauch_kwh ! Known valueAtDeviceReset : (225.1300000000192) > known cumulative value (225.02000000001863) cannot proceed
    • NicolomaN Nicoloma
      Node.js: v16.18.1
      NPM: 8.19.2
      sourceanalytix.1
      sourceanalytix.1
      sourceanalytix.1
      sourceanalytix.1
      crunchipC Offline
      crunchipC Offline
      @nicoloma sehe ich es richtig, dein Zählerstand war zu Beginn des Monats höher als diese Woche?
      Deine Unit für Gas ist kWh? Was hast du unter Preisdefinition hinterlegt für Gas
      die Werte stimmen ja gar nicht überein
      du hast daher ein
      NicolomaN 2 Antworten Letzte Antwort
        du hast daher ein
        NicolomaN Offline
        NicolomaN Offline
        Nicoloma
        @crunchip danke für deine Erklärung. Super..
        Bei dem Log handelt es sich tatsächlich um einen anderen Datenpunkt "PEINLICH"
          du hast daher ein
          NicolomaN Offline
          NicolomaN Offline
          Nicoloma
          @crunchip
          sourceanalytix.1
          2022-11-11 11:41:11.749	info	(COMPACT) Successfully activated SourceAnalytix for 18 of 18 states, will do my Job until you stop me!
            @crunchip
            sourceanalytix.1
            crunchipC Offline
            crunchipC Offline
            @nicoloma also passt jetzt?
            NicolomaN 1 Antwort Letzte Antwort
              NicolomaN Offline
              NicolomaN Offline
              Nicoloma
              @crunchip jawoll.. aber dein Tipp hat es dan endgültig gelöst
              AndreiosA 1 Antwort Letzte Antwort
                AndreiosA Offline
                AndreiosA Offline
                Andreios
                Forum Testing
                @nicoloma Anstatt "ERLEDIGT-BITTE LÖSCHEN" kannst Du einfach [gelöst] vorne vor schreiben, das machen die Meisten so.
                Wenn es gelöscht würde, könnte kein Anderer mehr auf die Lösung zurückgreifen.
                Schöne Grüße
                Andreas
                ioBroker auf Raspberry 4 mit SSD. Homematik IP mit CCU 3. Shelly. MySQL. Arduino. ...
                Meine Posts sind subjektiv und manipulativ, erheben Anspruch auf Allwissenheit und können Spuren von Ironie oder Sarkasmus enthalten. ;-)
