<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sourceanalytix Error Log - [gelöst]]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
ich habe zur Zeit ein Problem mit dem Source-analytix.<br />
Ich verstehe den Error nicht :-/<br />
Node.js: v16.18.1<br />
NPM: 8.19.2</p>
<pre><code>
sourceanalytix.1
2022-11-11 11:25:43.656	error	(COMPACT) Initialization of 0_userdata.0.Gas.verbrauch_kwh failed, check warn messages !
sourceanalytix.1
2022-11-11 11:25:43.654	error	(COMPACT) Cannot handle calculations for 0_userdata.0.Gas.verbrauch_kwh, check log messages and adjust settings!
sourceanalytix.1
2022-11-11 11:25:43.654	error	(COMPACT) Troubleshoot Data 0_userdata.0.Gas.verbrauch_kwh custom Data : {"common":{"name":"verbrauch_kwh","desc":"Manuell erzeugt","role":"state","type":"number","read":true,"write":true,"def":0,"custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.1":{"enabled":true,"selectedUnit":"kWh","start_day":222.92000000002736,"start_week":169.7000000000262,"start_month":0,"start_quarter":0,"start_year":0,"alias":"gasverbrauchkwh_source","selectedPrice":"Gas Leistung","costs":true,"consumption":true,"meter_values":false,"valueAtDeviceReset":225.1300000000192,"valueAtDeviceInit":0,"cumulativeValue":222.92000000002736}}},"type":"state","native":{},"_id":"0_userdata.0.Gas.verbrauch_kwh","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.1","user":"system.user.admin","ts":1666327122208}
sourceanalytix.1
2022-11-11 11:25:43.653	error	(COMPACT) Check settings for 0_userdata.0.Gas.verbrauch_kwh ! Known valueAtDeviceReset : (225.1300000000192) &gt; known cumulative value (225.02000000001863) cannot proceed
</code></pre>
<p dir="auto"><img src="/assets/uploads/files/1668162732332-ad3885d9-3f41-494c-a145-fb016125f489-image.png" alt="ad3885d9-3f41-494c-a145-fb016125f489-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/topic/59895/sourceanalytix-error-log-gelöst</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:10:32 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/59895.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Nov 2022 10:33:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 11:07:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nicoloma" aria-label="Profile: nicoloma">@<bdi>nicoloma</bdi></a> Anstatt "ERLEDIGT-BITTE LÖSCHEN" kannst Du einfach [gelöst] vorne vor schreiben, das machen die Meisten so.<br />
Wenn es gelöscht würde, könnte kein Anderer mehr auf die Lösung zurückgreifen.</p>
]]></description><link>https://forum.iobroker.net/post/890120</link><guid isPermaLink="true">https://forum.iobroker.net/post/890120</guid><dc:creator><![CDATA[Andreios]]></dc:creator><pubDate>Fri, 11 Nov 2022 11:07:51 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 10:51:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> jawoll.. aber dein Tipp hat es dan endgültig gelöst</p>
]]></description><link>https://forum.iobroker.net/post/890108</link><guid isPermaLink="true">https://forum.iobroker.net/post/890108</guid><dc:creator><![CDATA[Nicoloma]]></dc:creator><pubDate>Fri, 11 Nov 2022 10:51:06 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 10:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nicoloma" aria-label="Profile: nicoloma">@<bdi>nicoloma</bdi></a> also passt jetzt?</p>
]]></description><link>https://forum.iobroker.net/post/890107</link><guid isPermaLink="true">https://forum.iobroker.net/post/890107</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Fri, 11 Nov 2022 10:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 10:48:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<pre><code>
sourceanalytix.1
2022-11-11 11:41:11.749	info	(COMPACT) Successfully activated SourceAnalytix for 18 of 18 states, will do my Job until you stop me!
</code></pre>
]]></description><link>https://forum.iobroker.net/post/890105</link><guid isPermaLink="true">https://forum.iobroker.net/post/890105</guid><dc:creator><![CDATA[Nicoloma]]></dc:creator><pubDate>Fri, 11 Nov 2022 10:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 10:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> danke für deine Erklärung. Super..</p>
<p dir="auto">Bei dem Log handelt es sich tatsächlich um einen anderen Datenpunkt <strong>"<em>PEINLICH</em>"</strong></p>
]]></description><link>https://forum.iobroker.net/post/890103</link><guid isPermaLink="true">https://forum.iobroker.net/post/890103</guid><dc:creator><![CDATA[Nicoloma]]></dc:creator><pubDate>Fri, 11 Nov 2022 10:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Sourceanalytix Error Log - [gelöst] on Fri, 11 Nov 2022 10:44:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nicoloma" aria-label="Profile: nicoloma">@<bdi>nicoloma</bdi></a> sehe ich es richtig, dein Zählerstand war zu Beginn des Monats höher als diese Woche?<br />
Deine Unit für Gas ist kWh? Was hast du unter Preisdefinition hinterlegt für Gas<br />
die Werte stimmen ja gar nicht überein</p>
<pre><code>"selectedUnit":"kWh","start_day":222.92000000002736,"start_week":169.7000000000262,
</code></pre>
<p dir="auto">du hast daher ein</p>
<pre><code>valueAtDeviceReset":225.1300000000192
</code></pre>
]]></description><link>https://forum.iobroker.net/post/890099</link><guid isPermaLink="true">https://forum.iobroker.net/post/890099</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Fri, 11 Nov 2022 10:44:49 GMT</pubDate></item></channel></rss>
