  4. ehemalige Historydaten finden
148 Beiträge 7 Kommentatoren 14.3k Aufrufe 7 Beobachtet
    @mcu gerne
      "_id": "hm-rega.0.KEQ1065589.0.DUTY_CYCLE",
      "type": "state",
      "common": {
        "name": "hm-rega.0.KEQ1065589.0.DUTY_CYCLE",
        "type": "number",
        "read": true,
        "write": false,
        "role": "value",
        "min": 0,
        "max": 100,
        "unit": "%",
        "desc": "Dutycycle",
        "custom": {
          "history.0": {
            "enabled": true,
            "aliasId": "hm-rega.0.43579",
            "changesOnly": true,
            "debounce": "1000",
            "changesRelogInterval": "1800",
            "changesMinDelta": "0",
            "maxLength": "10",
            "retention": "0"
      "native": {
        "ID": "DUTYCYCLE",
        "TYPE": "INTEGER",
        "MIN": 0,
        "MAX": 100,
        "UNIT": "%",
        "DEFAULT": 0,
        "CONTROL": "NONE"
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
      "from": "system.adapter.hm-rega.0",
      "user": "system.user.admin",
      "ts": 1667374580666
    { "_id": "hm-rega.0.43579", "type": "state", "common": { "name": "DC_Groundplane", "type": "number", "read": true, "write": true, "role": "state", "min": 0, "max": 1000, "custom": { "history.0": { "enabled": true, "changesOnly": true, "debounce": "1000", "maxLength": "10", "retention": 0, "changesRelogInterval": "1800", "changesMinDelta": 0, "aliasId": "" } } }, "native": { "Name": "DC_Groundplane", "TypeName": "VARDP", "DPInfo": "", "ValueMin": 0, "ValueMax": 1000, "ValueUnit": "", "ValueType": 4, "ValueSubType": 0, "ValueList": "" }, "from": "system.adapter.hm-rega.0", "ts": 1667374581466, "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" }, "user": "system.user.admin" }
    MCU
    #85
    @homoran Der Unterschied ist write: false bei hm-rega.0.KEQ1065589.0.DUTY_CYCLE und write: true bei hm-rega.0.43579. Was das mit dem getEnabledDPs (history) zu tun hat?
      @mcu gerne
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": false,
          "role": "value",
          "min": 0,
          "max": 100,
          "unit": "%",
          "custom": {
            "history.0": {
              "enabled": true,
              "debounce": "1000",
              "maxLength": "10",
              "retention": "0"
        "native": {
          "ID": "DUTYCYCLE",
          "TYPE": "INTEGER",
          "MIN": 0,
          "MAX": 100,
          "UNIT": "%",
          "DEFAULT": 0,
          "CONTROL": "NONE"
        "acl": {
          "object": 1636,
          "state": 1636,
        "ts": 1667374580666
      MCU
      #86
      @homoran Hab jetzt nochmal eine Version v1.0.4, mit der kann man zwischen alias-Verwendung und normale DPs umschalten -> useAliasIdInEnabled: true.
      Weiterhin kann man nur die enabled_DPs erstellen lassen (fillEnabled_DPs) und auch ein Array mit history-DPs, die aliasIds (fillWithAliasId) verwenden.
      Welche Werte sind dann unterschiedlich in dem Array, insbesondere die angesprochenen DPs ?
      • M MCU
        MCU
        #87
        @homoran Meinst du diesen Link?
        https://mcuiobroker.gitbook.io/jarvis-infos/tipps/scripte-blockly-javascript/javascript/history-adapter/nicht-mehr-geloggte-dps-in-history-verzeichnissen-finden
          #88
          @mcu sagte in ehemalige Historydaten finden:
          sorry ich hatte alle deine Posts nicht mehr gesehen. hatte dir ne PN geschrieben und dich dabei irrtümlich blockiert
          SORRY
          • M MCU
            #89
            @mcu
            im fill with alias findet er zwei DPs
                "dpId": "luftdaten.0.28288.SDS_P1",
                "aliasId": "luftdaten.1.28288.SDS_P1"
                "dpId": "luftdaten.0.28288.SDS_P2",
                "aliasId": "luftdaten.1.28288.SDS_P2"
            die Rega sind nicht dabei
            unter enabled sind die "nicht-alias DPs"
              "luftdaten.0.34499.SDS_P1",
              "luftdaten.0.34499.SDS_P2",
              @mcu
              MCU
              #90
              Bei dem hm-rega.0.43579 verstehe ich es, er hat kein aliasId.
              Aber bei dem hm-rega.0.KEQ1065589.0.DUTY_CYCLE der müsste drin sein.
              Aber den hatte er ja auch schon nicht in der enabledDPs-Liste.
              Setzt den bitte manl testweise write auf true und lass nochmal fillWithAliasId laufen.
              Der getEndabledDPs(history-Adapter) holt den anscheinend nicht, warum auch immer?
              Das ist so, wenn der useAliasIdInEnabled auf false steht.
              • M MCU
                #91
                enabled
                 "hm-rega.0.12770",
                  "hm-rega.0.1995",
                  "hm-rega.0.41216",
                  "hm-rega.0.43096",
                  "hm-rega.0.50371",
                  "hm-rega.0.56705",
                  "hm-rega.0.58388",
                  "hm-rega.0.58979",
                  "hm-rega.0.5996",
                  "hm-rega.0.6318",
                und fillwithAlias
                    "dpId": "hm-rega.0.KEQ1065589.0.DUTY_CYCLE",
                ist jetzt in beiden drin
                  enabled
                   "hm-rega.0.12770",
                    "hm-rega.0.1995",
                    "hm-rega.0.41216",
                    "hm-rega.0.43096",
                    "hm-rega.0.50371",
                    "hm-rega.0.56705",
                    "hm-rega.0.58388",
                    "hm-rega.0.58979",
                    "hm-rega.0.5996",
                    "hm-rega.0.6318",
                  und fillwithAlias
                  MCU
                  #92
                  @homoran Lag es am write = true?
                  Dann hat der Adapter "history" einen Fehler.
                  Man kann ja trotzdem (write:false) über den Adapter Werte in den State schreiben oder?
                  • M MCU
                    #93
                    im Prinzip müssten der aktuelle und der alias (weil alter DP) in enabled stehen damit die gesamte History , auch über Gerätetausvh/Adapter wechseln erhalten bleibt, oder?
                      MCU
                      #94
                      @homoran Im enabled muss der aliasID , falls vorhanden, drin stehen, da die Dateien mit dem aliasId-Namen gesetzt werden.
                      • M MCU
                        #95
                        sieht so aus!
                        dann muss da @apollon77 mal nachsehen, dann kan der das vielleicht auch mit den history-Alias-DPs klären
                          sieht so aus!
                          MCU
                          #96
                          Das einzige offene Problem ist jetzt, dass der getEnabledDPs (history) die DPs nicht einfängt, wenn write vom DP:false ist.
                          Gibt es sonst noch Probleme?
                          HomoranH apollon77A 2 Antworten Letzte Antwort
                          • M MCU
                            #97
                            zumindest keine offensichtlichen!
                            mit den Alias muss ich nochmal drüber schlafen. Deine Idee nur die AliasID als enabled zu nehmen kann ich noch nicht so recht nachvollziehen. schließlich ist der neue Datenpunkt ja wirklich enabled.
                              MCU
                              #98
                              @homoran Der alte ist DUTY_CYCLE und der neue ist 43579.
                              Der alte hat einen aliasID und der neue nicht. Somit würde nur noch der neue im enabledDPs-Array stehen, der einmal über den alias erkannt wird und einmal als eigenständiger enabled DP.
                              history schreibt aber nur in den Neuen (43579).
                              • M MCU
                                apollon77A Online
                                apollon77A Online
                                #99
                                @mcu das kann aber nicht sein. Kein Code an den ich mich erinnere in History achtet auf das write flag.
                                Wenn in den custom Settings dercstate forget History an ist dann sollte erneut adapterstart gelistet sein dancer geloggt wird und dann enthält auch getEnabled den
                                Wenn man in den History settings einen Alia’s angegeben hat kann es vllt nur sein das diese alias id in getEnabled gelistet ist anstelle vom echten state??
                                • M MCU
                                  #100
                                  nein umgekehrt!
                                  hoffe ich doch mich richtig zu erinnern.
                                  43579 heisst groundplane, das war ein umgebauter LAN-Configadapter mit externer Groundplane. Der DUTY CYCKE müsste Das LAN-Gateway sein, das an die Stelle des alten Config Adapter gekommen ist
                                  • apollon77A apollon77
                                    MCU
                                    #101
                                    @apollon77 sagte in ehemalige Historydaten finden:
                                    Wo ist der?
                                    Adapter-Instanz:
                                    customSettings:
                                    Da kommt schon der echte, was ja auch richtig ist.
                                    Nur warum hat er den DP erst mit write:true gefunden?
                                    • M MCU
                                      Wo ist der?
                                      Adapter-Instanz:
                                      customSettings:
                                      apollon77A Online
                                      apollon77A Online
                                      #102
                                      @mcu Mist Handy typo. „State für History an ist“. Was meinst du mit „erst gefunden wenn write true ist“?
                                        MCU
                                        #103
                                        @apollon77 Im Objekt stand: (suehe oben)
                                          "type": "state",
                                          "common": {
                                            "type": "number",
                                            "read": true,
                                            "write": false,
                                            "role": "value",
                                        write:false erst als er es umgestellt hat auf write:true wurde der DP gefunden
                                        aliasSuche
                                        function listHistoryDPsWithaliasId(adp){
                                            let arr =[];
                                            sendTo(adp, 'getEnabledDPs', {}, function (result) {
                                                let count = 0;
                                                for ( let dp in result){
                                                    let dpHistoryAlias = getObject(dp).common.custom[adp].aliasId;
                                                    if (dpHistoryAlias != '' && dpHistoryAlias != undefined){
                                                        arr.push({'dpId':dp,'aliasId':dpHistoryAlias});
                                                        count++;
                                                log('Anzahl der aktiv geloggten DPs mit aliasId: '+count);
                                                // setStateAsync(findOldDPs_Enabled,JSON.stringify(arr),false);
                                                //log(JSON.stringify(arr));
                                                setState(findoldDPs_withAliasId,JSON.stringify(arr),false);
                                          @mcu parallel dazu habe ich einen gefunden
                                          hier ist ein alias eingetragen.
                                          dIeser DP existiert allerdings noch (oder etwa weil er als alias verwendet wird? )
                                          in deinem Array ist nur der Alias drin
                                          #104
                                          @apollon77
                                          dieser Datenpunkt wurdenicht gefunden
                                          @homoran sagte in ehemalige Historydaten finden:
                                          erst nachdem ich in den Objektdaten write:false auf true geändert habe
