  3. Einsteigerfragen
  4. Installation
  5. Keine Adapter Neuinsatllation oder Updgrades mehr möglich
37 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • E exe203
    Hallo zusammen ,
    bei mir laufen seit geraumer Zeit keine Adapter-Upgrades mehr durch.
    Auch Neuinstallationen sind nicht mehr möglich.
    Beispiel vom Upgrade-Versuch:
    pi@raspberrypi:~ $ iobroker upgrade alexa2
    This upgrade of "alexa2" will at least introduce the following changes:
    -> 3.20.1:
    make sure caching works correctly with multiple instances of the adapter
    -> 3.20.0:
    Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
    Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
    -> 3.19.10:
    Fix issue in retry handling when rate limit exceeded is returned by Amazon
    Do not clean up Smart Home Device objects for now - delete manually if you remove a device
    -> 3.19.9:
    Receive the correct player status again when musik is stopped
    -> 3.19.8:
    Add safeguard for too high intervals
    -> 3.19.7:
    Fix doNotDisturb when using a time string
    -> 3.19.6:
    Would you like to upgrade alexa2 from @3.11.2 to @3.20.1 now? [(y)es, (n)o]: y
    Update alexa2 from @3.11.2 to @3.20.1
    NPM version: 8.19.3
    Installing iobroker.alexa2@3.20.1... (System call)
    host.raspberrypi Cannot install iobroker.alexa2@3.20.1: 217
    Danke für eure Unterstützung. Ich komme schlicht nicht mehr weiter.
    @exe203
    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    sagt?
    • E Offline
      exe203
      Hallo Thomas,
      verfummelt kann sehr gut sein. Ich hoffe du kannst mir helfen, zu entknoten.
      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      -bash: pi@raspberrypi:~: Kommando nicht gefunden.
      pi@raspberrypi:~ $ ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      -bash: ln:: Kommando nicht gefunden.
      pi@raspberrypi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      armv7l
      Kein Docker
      /usr/bin/nodejs
      /home/pi/.nvm/versions/node/v19.0.1/bin/node
      /home/pi/.nvm/versions/node/v19.0.1/bin/npm
      v10.24.1
      v19.0.1
      8.19.2
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      tty
      /home/pi
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_10.x buster InRelease
      nodejs:
        Installiert:           10.24.1-1nodesource1
        Installationskandidat: 10.24.1-1nodesource1
        Versionstabelle:
       *** 10.24.1-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u2 500
      pi@raspberrypi:~ $
      • E exe203
        Hallo Thomas,
        armv7l
        Kein Docker
        /usr/bin/nodejs
        v10.24.1
        v19.0.1
        8.19.2
        4.0.23
        pi
        tty
        /home/pi
        nodejs:
          Versionstabelle:
        pi@raspberrypi:~ $
        @exe203 sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
        Warum???????
        Macht man so nicht, wenn man einen funktionierenden Paketmanager hat. Wie kommt man auf sowas?
        Schau in meiner Signatur wie man nodejs RICHTIG installiert.
        Und zwar im Moment die Version 16!
        E 1 Antwort Letzte Antwort
          Warum???????
          exe203
          Das Warum kann ich dir nicht beantworten.
          Meine Installation basiert hauptsächlich auf zusammenkopierten Bestandteilen aus diversen Tutorials.
          Ich bin mir ziemlich sicher, dass du im System noch den ein oder anderen Augenverdreher oder Kopfschüttler finden würdest.
          Ich hangel mich mal durch den Post aus deiner Signatur und versuch das zu bereinigen.
          Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
          • E exe203
            @exe203
            Kann ja nicht lange her sein, die bei dir installierte reingepfuschte nodeJS 19.0.1 ist HEUTE veröffentlicht worden.
            • E exe203
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @exe203
              oder du machst alles neu. Dürfte evtl. einfacher sein.
              Dann kannst du auch gleich buster auf bullseye updaten.
              Wie man installiert findest du in der Doku auf der iob Webseite.
              youtube ist hier weniger sinnvoll.
              Danke.
              Thomas BraunT E 2 Antworten Letzte Antwort
                @exe203
                exe203
                ich hatte vermutet, dass es an einer veralteten nodejs Version liegen konnte und mich hieran gehalten:
                https://phoenixnap.com/kb/update-node-js-version
                • bahnuhrB bahnuhr
                  @exe203
                  @bahnuhr sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                  Eigentlich muss nur der per nvm reingedübelte Mumpitz gelöscht werden und die nodesource.list auf 16 umgestellt werden. Und dann ordentlich mit dem Paketmanager arbeiten.
                  • bahnuhrB bahnuhr
                    @exe203
                    exe203
                    @bahnuhr
                    Ich habe ein bisschen Bammel, dabei meine Vis und die komplette Adapter-Config samt Skripten zu verlieren. Backup hab ich natürlich trommelwirbel keins...
                    bahnuhrB Thomas BraunT 2 Antworten Letzte Antwort
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @thomas-braun sagte in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                      Ja, das glaub ich dir. Wenn man weiß wie es geht.
                      Ich bin ja auch schon ne Weile dabei; und wüsste dies jetzt nicht.
                      Danke.
                      • E exe203
                        @bahnuhr
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        Skripten
                        Das intensivste sind doch die Scripte.
                        Spiegel die im (Einstellung js. Adapter) und dann weg sichern.
                        Und die Adapter config kannst du in den meinsten Fälle auch speichern.
                        Danke.
                        • E exe203
                          Alles nicht falsch (je nach Verwendungszweck und der sonstigen Installation), allerdings bricht dir das den Hals in Verbindung mit dem ioBroker, der setzt nämlich auf die übliche Installation via apt.
                          • bahnuhrB bahnuhr
                            Dann hast du noch nie mein node-HowTo gelesen.
                            Da steht das nämlich alles drin und auch wie man das alles bereinigt.
                            • E exe203
                              @bahnuhr
                              Und warum nicht? Wou ist der Backitup-Adapter nochmal da?
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Hab ich schon einmal reingeschaut.
                                Allerdings brauchte ich dies bisher nicht.
                                Danke.
                                  exe203
                                  ich bin ja einsichtig. Nützt jetzt halt auch nix mehr.
                                  • E exe203
                                    Dann ran. Link zum HowTo hast du ja.
                                      exe203
                                      @thomas-braun said in Keine Adapter Neuinsatllation oder Updgrades mehr möglich:
                                      Bevor ich es damit nur noch mehr verknote: Muss ich die jetzige Installation erstmal bereinigen oder installiert sich das nach dem How To sauber drüber?
                                      • E exe203
                                        @exe203
                                        iobroker stop
                                        Dann kannste gefahrlos mit nodejs kämpfen...
                                        Steht aber auch im HowTo drin. :-)
                                          @exe203
                                          iobroker stop
                                          exe203
                                          @exe203
                                          iobroker stop
                                          Habe die fehlerhaften Verzeichnisse jetzt rausbekommen, allerdings bekomme ich keine V16 installiert:
                                          pi@raspberrypi:~ $ apt policy nodejs
                                          nodejs:
                                            Versionstabelle:
                                           *** 10.24.1-1nodesource1 100
                                          armv7l
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v10.24.1
                                          v10.24.1
                                          6.14.12
                                          /opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser/build/index.cjs:1013
                                                  throw Error(`yargs parser supports a minimum Node.js version of ${minNodeVersion}. Read our version support policy: https://github.com/yargs/yargs-parser#supported-nodejs-versions`);
                                          Error: yargs parser supports a minimum Node.js version of 12. Read our version support policy: https://github.com/yargs/yargs-parser#supported-nodejs-versions
                                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs-parser/build/index.cjs:1013:15)
                                              at Module._compile (internal/modules/cjs/loader.js:778:30)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                              at Module.load (internal/modules/cjs/loader.js:653:32)
                                              at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                              at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                              at Module.require (internal/modules/cjs/loader.js:692:17)
                                              at require (internal/modules/cjs/helpers.js:25:18)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:59195)
                                          Was überseh ich?
