  4. Test Adapter Z-Wave 2 v2.3.x
    6.8k
soft resetz-wave 2
24 Beiträge 7 Kommentatoren 4.1k Aufrufe 11 Beobachtet
  • Christian WernerC Christian Werner
    @alcalzone
    Cool danke, müsste dann schon eine Weile her sein.
    Mache ich nach dem Update dann ein neues Interview der Geräte?
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    @christian-werner Dürfte nötig sein, ja.
    Christian WernerC 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      Christian WernerC Offline
      Christian Werner
      @alcalzone
      Nun habe ich dies
      pi@geosmart:/opt/iobroker# npm ls zwave-js @zwave-js/config
      iobroker.inst@2.0.3 /opt/iobroker
      +-- iobroker.zwave2@2.4.1
        +-- zwave-js@8.7.4
          +-- @zwave-js/config@8.7.4
      pi@geosmart:~ $ node -v
      v12.22.7
      aber auch leider das ?
      2021-11-04 23:51:56.834	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-11-04 23:51:56.834	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/src/main.ts:87:8)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      2021-11-04 23:51:56.833	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      2021-11-04 23:51:56.832	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      2021-11-04 23:51:56.832	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      2021-11-04 23:51:56.832	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zwave2/src/lib/objects.ts:161:17)
      2021-11-04 23:51:56.831	error	Caught by controller[0]: TypeError: Cannot read property 'S2_AccessControl' of undefined
        @alcalzone
        Nun habe ich dies
          +-- zwave-js@8.7.4
        v12.22.7
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        Ok vermutlich ist da noch mehr durcheinander...
        Was gibt das aus?
        cd /opt/iobroker
        npm ls zwave-js @zwave-js/config @zwave-js/core @zwave-js/shared @zwave-js/serial
        Und am besten zeigst du mal deine komplette Datei /opt/iobroker/package.json
          Was gibt das aus?
          cd /opt/iobroker
          Christian Werner
          @alcalzone said in Test Adapter Z-Wave 2 v2.3.x:
          Ja da schein auch was zu sein - kann ich so was auch global auflisten lassen?
          pi@geosmart:/opt/iobroker $ npm ls zwave-js @zwave-js/config @zwave-js/core @zwave-js/shared @zwave-js/serial
          ├── @zwave-js/serial@4.0.6  extraneous
          └─┬ iobroker.zwave2@2.4.1
            └─┬ zwave-js@8.7.4
              ├─┬ @zwave-js/config@8.7.4
              │ ├─┬ @zwave-js/core@8.7.4
              │ │ └── @zwave-js/shared@8.7.3  deduped
              ├─┬ @zwave-js/serial@8.7.4
              │ ├── @zwave-js/core@8.7.4  deduped
          npm ERR! extraneous: @zwave-js/serial@4.0.6 /opt/iobroker/node_modules/@zwave-js/serial
          Also Hosen runter xD
            "name": "iobroker.inst",
            "version": "2.0.3",
            "private": true,
            "description": "Automation platform in node.js",
            "scripts": {
              "install": "node lib/checkVersions.js",
              "postinstall": "node lib/install.js",
              "test": "node node_modules/mocha/bin/mocha --exit"
            "dependencies": {
              "colors": "^1.3.3",
              "fs-extra": "^7.0.1",
              "iobroker": "^2.0.3",
              "iobroker.admin": "^5.1.25",
              "iobroker.alexa2": "^3.11.2",
              "iobroker.cloud": "^4.1.0",
              "iobroker.daswetter": "^3.0.8",
              "iobroker.discovery": "^2.7.3",
              "iobroker.fakeroku": "^0.2.1",
              "iobroker.fritzbox": "^0.2.1",
              "iobroker.harmony": "^1.2.2",
              "iobroker.history": "^1.9.13",
              "iobroker.hue": "^3.5.28",
              "iobroker.icons-ultimate-png": "^1.0.1",
              "iobroker.info": "^1.9.10",
              "iobroker.iot": "^1.8.24",
              "iobroker.jarvis": "^2.2.3",
              "iobroker.javascript": "^5.2.13",
              "iobroker.js-controller": "^3.3.18",
              "iobroker.linkeddevices": "^1.4.3",
              "iobroker.material": "^1.0.6",
              "iobroker.mobile": "^1.0.1",
              "iobroker.mqtt": "^2.4.0",
              "iobroker.node-red": "^2.4.1",
              "iobroker.openhab": "^1.1.0",
              "iobroker.ping": "^1.5.0",
              "iobroker.scenes": "^2.3.8",
              "iobroker.simple-api": "^2.6.1",
              "iobroker.socketio": "^3.1.5",
              "iobroker.telegram": "^1.10.0",
              "iobroker.tr-064": "^4.2.14",
              "iobroker.unifi": "^0.5.10",
              "iobroker.weatherunderground": "^3.3.1",
              "iobroker.web": "^3.4.13",
              "iobroker.yahka": "^0.13.1",
              "iobroker.yamaha": "^0.4.0",
              "iobroker.zwave2": "^2.4.1",
              "semver": "^5.6.0",
              "yargs": "^7.0.2"
              └─┬ zwave-js@8.7.4
              "version": "2.0.3",
              "private": true,
              "scripts": {
              "dependencies": {
                "colors": "^1.3.3",
                "semver": "^5.6.0",
                "yargs": "^7.0.2"
            Christian Werner
            Bin es mit
            npm prune @zwave-js/serial@4.0.6
            los geworden und es läuft alles wieder.
            Tausend Dank!
            Für die Hilfe und den Adapter.
            Z-Wave scheint mir keine einfaches Protokoll zu sein - daher Hut ab!
              Bin es mit
              Tausend Dank!
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @christian-werner Der Rest sieht übrigens unauffällig aus
                Marsx79
                schrieb am zuletzt editiert von Marsx79
                @AlCalzone
                Der Datenpunkt "Door_Lock.targetMode" fehlt . Dieser wird nach dem Interview gelöscht (steht im log). Kannst du da helfen? Node 231
                zwavejs_2022-08-15.log ff82afe2.metadata.jsonl
                • M Marsx79
                  @AlCalzone
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @marsx79 Ich verstehe nicht 100% warum der bei dir fehlt, aber das Problem ist in der neuesten Version der Library behoben. Ich hab noch ein paar Dinge gerade zu ziehen, dann mache ich ein neues Adapter-Update.
                    Marsx79
                    @alcalzone
                    Ok danke.
                    • S Online
                      S Online
                      spike2
                      Gibt es ein Script bzw. Blockly welches die Statistik vom Z-Wave Adapter auswertet und nicht gesendete/fehlerhafte Pakete ermittelt und eine Meldung per Push versendet?
