  4. Error 25 beim Versuch Adapter zu installieren (Gelöst)
    5.7k
21 Beiträge 4 Kommentatoren 1.8k Aufrufe 4 Beobachtet
  • V Offline
    V Offline
    Vetinari77
    schrieb am zuletzt editiert von Vetinari77
    Ich bin am verzweifeln. Egal was ich versuche, es lässt sich kein Adapter installieren. Folgende Informationen:
    Raspi 4 mit Bullsey (Aktueller stand)
    Ausgabe von
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.22.12
    /usr/bin/node
    v12.22.12
    /usr/bin/npm
    7.5.2
    nodejs:
      Installiert:           12.22.12~dfsg-1~deb11u1
      Installationskandidat: 12.22.12~dfsg-1~deb11u1
      Versionstabelle:
     *** 12.22.12~dfsg-1~deb11u1 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
         10.24.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_10.x bullseye/main arm64 Packages
    iobroker update
    /opt/iobroker $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.23
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ical"         : 1.13.1   , installed 1.13.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
    Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
    iobroker upgrade self
    /opt/iobroker $ iobroker upgrade self
    Host    "raspberrypi"    is up to date.
    Ausgabe beim Versuch z.B Shelly zu installieren:
    /opt/iobroker $ iobroker add shelly --host raspberrypi
    NPM version: 7.5.2
    Installing iobroker.shelly@6.0.0... (System call)
    host.raspberrypi Cannot install iobroker.shelly@6.0.0: 1
    Hat jemand eine Idee was da schiefläuft?
    • V Vetinari77
      Ausgabe von
      /usr/bin/nodejs
      v12.22.12
      /usr/bin/node
      v12.22.12
      /usr/bin/npm
      7.5.2
      nodejs:
        Versionstabelle:
      iobroker update
      NPM version: 7.5.2
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @vetinari77 sagte in Error 25 beim Versuch irgendeinen Adapter zu installieren:
      Nicht Dein Ernst jetzt weil:
      /usr/bin/nodejs
      v12.22.12
      /usr/bin/node
      v12.22.12
      /usr/bin/npm
      7.5.2
      Lehrling seit 1975 !!!
      V 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        /usr/bin/nodejs
        v12.22.12
        /usr/bin/node
        v12.22.12
        /usr/bin/npm
        7.5.2
        V Offline
        V Offline
        Vetinari77
        @djmarc75
        Weil was? Ich wäre für einen Hinweis wirklich dankbar. Ich bin alles andere als ein Linux Profi versuche es dennoch zu verstehen, aber ohne einen Hinweis auf das was ich scheinbar nicht sehe, oder nicht verstehe, komm ich leider nicht weiter.
        • V Vetinari77
          @djmarc75
          CodierknechtC Offline
          Codierknecht
          @vetinari77 Aktuelle Versionen von Node und NPM einsetzen.
          An den installierten Versionen hat sich schon etwas Staub abgesetzt ;-)
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • CodierknechtC Codierknecht
            V Offline
            V Offline
            Vetinari77
            @codierknecht Danke erstmal. Damit lässt sich schon mehr anfangen. Dann werde ich mal googeln wie man das macht
            • V Vetinari77
              @vetinari77
              Stop google!
              Schau in meiner Signatur, da wird's erklärt.
                @vetinari77
                Stop google!
                V Offline
                V Offline
                Vetinari77
                @thomas-braun Vielen Dank für deine Antwort. Hat super geklappt.
                Edit: Problem wurde gelöst.
                • V Vetinari77
                  @vetinari77
                  Fein!
                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  sagt nun?
                    @vetinari77
                    Fein!
                    sagt nun?
                    V Offline
                    V Offline
                    Vetinari77
                    aarch64
                    Kein Docker
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v19.0.0
                    v19.0.0
                    8.19.2
                    4.0.23
                    xxxxxx
                    xxxxxx adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    tty
                    Die Installation klappt wieder.
                    • V Vetinari77
                      aarch64
                      Kein Docker
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v19.0.0
                      v19.0.0
                      8.19.2
                      4.0.23
                      xxxxxx
                      tty
                      @vetinari77
                      Bitte vollständig posten.
                      Und NICHT v19 verwenden. Das ist eine Entwicklerversion und auch noch nicht für den ioBroker vorgesehen.
                      Installier v16.
                        @vetinari77
                        Installier v16.
                        V Offline
                        V Offline
                        Vetinari77
                        Sorry, es fehlt:
                        /opt/iobroker
                        mehr ist nicht drin.
                        • V Vetinari77
                          Sorry, es fehlt:
                          /opt/iobroker
                          @vetinari77
                          Da muss mehr kommen.
                            @vetinari77
                            V Offline
                            V Offline
                            Vetinari77
                            Falls du die erste Ausgabe von ln meinst, ja, da kommt das die Datei schon existiert. Bei der Zweiten kommt nicht mehr.
                            • V Vetinari77
                              @vetinari77
                              Vollständig zeigen, inkl. der Ein- wie Ausgaben.
                                @vetinari77
                                V Offline
                                V Offline
                                Vetinari77
                                xxxxxx@raspberrypi:/opt/iobroker $ sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                • V Vetinari77
                                  @vetinari77
                                  sudo apt update
                                    @vetinari77
                                    sudo apt update
                                    V Offline
                                    V Offline
                                    Vetinari77
                                    xxxxxx@@raspberrypi:/opt/iobroker $ sudo apt update
                                    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
                                    OK:2 http://deb.debian.org/debian bullseye InRelease
                                    Fehl:3 https://ookla.bintray.com/debian generic InRelease
                                      Could not handshake: Die TLS-Verbindung wurde nicht sauber beendet. [IP: 18.158.82.64 443]
                                    OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                                    OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                    OK:6 https://repos.influxdata.com/debian bullseye InRelease
                                    OK:7 https://packages.grafana.com/oss/deb stable InRelease
                                    OK:8 https://deb.nodesource.com/node_14.x bullseye InRelease
                                    OK:9 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    OK:10 https://deb.nodesource.com/node_19.x bullseye InRelease
                                    Holen:11 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24,5 kB]
                                    Fehl:11 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                      Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                    Paketlisten werden gelesen⦠Fertig
                                    W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY 8E61C2AB9A6D1557
                                    E: Das Depot »https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease« ist nicht signiert.
                                    N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäÃig deaktiviert.
                                    N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
                                    xxxxxx@raspberrypi
                                    • V Vetinari77
                                      xxxxxx@raspberrypi
                                      @vetinari77 sagte in Error 25 beim Versuch Adapter zu installieren (Gelöst):
                                      Die *.list-Datei, wo
                                      drin steht muss gelöscht werden.
                                      Findet sich in /etc/apt/sources.list.d/
                                      Dann versuch das Installationsskript für die ookla-Speedtest-Quelle auszuführen:
                                      curl -s https://install.speedtest.net/app/cli/install.deb.sh | sudo bash
                                        V Offline
                                        V Offline
                                        Vetinari77
                                        So, hab den Speedtest mal ganz rausgeschmissen und weiß jetzt warum du geschrieben hast das da was fehlt. Hier nun die Gesamte Ausgabe (im Spoiler):
                                        xxxxxx@raspberrypi:/etc/apt/sources.list.d $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        aarch64
                                        Kein Docker
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v19.0.0
                                        v19.0.0
                                        8.19.2
                                        4.0.23
                                        xxxxxx
                                        tty
                                        OK:1 http://deb.debian.org/debian bullseye InRelease
                                        OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                                        OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                        OK:5 https://repos.influxdata.com/debian bullseye InRelease
                                        OK:6 https://packages.grafana.com/oss/deb stable InRelease
                                        OK:7 https://deb.nodesource.com/node_14.x bullseye InRelease
                                        OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        OK:9 https://deb.nodesource.com/node_19.x bullseye InRelease
                                        Abhängigkeitsbaum wird aufgebaut⦠Fertig
                                        Statusinformationen werden eingelesen⦠Fertig
                                        Alle Pakete sind aktuell.
                                        nodejs:
                                         Installiert:           19.0.0-deb-1nodesource1
                                         Installationskandidat: 19.0.0-deb-1nodesource1
                                         Versionstabelle:
                                        *** 19.0.0-deb-1nodesource1 500
                                               500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
                                            16.18.0-deb-1nodesource1 500
                                               500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                            14.21.0-deb-1nodesource1 500
                                               500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                                        • V Vetinari77
                                          aarch64
                                          Kein Docker
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v19.0.0
                                          v19.0.0
                                          8.19.2
                                          4.0.23
                                          xxxxxx
                                          tty
                                          nodejs:
                                           Versionstabelle:
                                          @vetinari77
                                          Dann schmeiß die Zeile für nodeJS19 noch aus der nodesource.list
                                          und installier den 16er-Zweig:
                                          iob stop
                                          sudo apt install nodejs=16.18.0-deb-1nodesource1
                                          sudo apt update
                                          iob start
