<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error 25 beim Versuch Adapter zu installieren (Gelöst)]]></title><description><![CDATA[<p dir="auto">Ich bin am verzweifeln. Egal was ich versuche, es lässt sich kein Adapter installieren. Folgende Informationen:</p>
<p dir="auto">Raspi 4 mit Bullsey (Aktueller stand)<br />
Ausgabe von<br />
which nodejs &amp;&amp; nodejs -v &amp;&amp; which node &amp;&amp; node -v &amp;&amp; which npm &amp;&amp; npm -v &amp;&amp; apt policy nodejs</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>/opt/iobroker $ which nodejs &amp;&amp; nodejs -v &amp;&amp; which node &amp;&amp; node -v &amp;&amp; which npm &amp;&amp; npm -v &amp;&amp; apt policy nodejs
/usr/bin/nodejs
v12.22.12
/usr/bin/node
v12.22.12
/usr/bin/npm
7.5.2
nodejs:
  Installiert:           12.22.12~dfsg-1~deb11u1
  Installationskandidat: 12.22.12~dfsg-1~deb11u1
  Versionstabelle:
 *** 12.22.12~dfsg-1~deb11u1 500
        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        100 /var/lib/dpkg/status
     12.22.5~dfsg-2~11u1 500
        500 http://deb.debian.org/debian bullseye/main arm64 Packages
     10.24.1-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_10.x bullseye/main arm64 Packages
</code></pre>
<p dir="auto"></p></section></section><br />
iobroker update<br />
<pre><code>/opt/iobroker $ iobroker update
Used repository: stable
Adapter    "admin"        : 6.2.23   , installed 6.2.23
Adapter    "backitup"     : 2.4.12   , installed 2.4.12
Adapter    "discovery"    : 3.0.5    , installed 3.0.5
Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
Adapter    "ical"         : 1.13.1   , installed 1.13.1
Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
Adapter    "jarvis"       : 3.0.15   , installed 3.0.15
Adapter    "javascript"   : 6.0.3    , installed 6.0.3
Controller "js-controller": 4.0.23   , installed 4.0.23
Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
Adapter    "mqtt-client"  : 1.6.3    , installed 1.6.3
Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
Adapter    "ping"         : 1.5.3    , installed 1.5.3
Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
Adapter    "socketio"     : 4.2.0    , installed 4.2.0
Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
Adapter    "upnp"         : 1.0.21   , installed 1.0.21
Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
Adapter    "web"          : 4.3.0    , installed 4.3.0
Adapter    "ws"           : 1.3.0    , installed 1.3.0
</code></pre>
iobroker upgrade self<br />
<pre><code>/opt/iobroker $ iobroker upgrade self
Host    "raspberrypi"    is up to date.
</code></pre>
Ausgabe beim Versuch z.B Shelly zu installieren:<p></p>
<pre><code>/opt/iobroker $ iobroker add shelly --host raspberrypi
NPM version: 7.5.2
Installing iobroker.shelly@6.0.0... (System call)
host.raspberrypi Cannot install iobroker.shelly@6.0.0: 1
</code></pre>
<p dir="auto"></p></section></section><p></p>
<p dir="auto">Hat jemand eine Idee was da schiefläuft?</p>
]]></description><link>https://forum.iobroker.net/topic/59602/error-25-beim-versuch-adapter-zu-installieren-gelöst</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 02:25:10 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/59602.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Nov 2022 19:16:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 12:40:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Erledigt und läuft. Vielen Dank noch einmal.</p>
]]></description><link>https://forum.iobroker.net/post/885021</link><guid isPermaLink="true">https://forum.iobroker.net/post/885021</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 12:40:28 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 11:39:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Dann schmeiß die Zeile für nodeJS19 noch aus der nodesource.list<br />
und installier den 16er-Zweig:</p>
<pre><code>iob stop
sudo apt install nodejs=16.18.0-deb-1nodesource1
sudo apt update
iob start
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884962</link><guid isPermaLink="true">https://forum.iobroker.net/post/884962</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 11:39:34 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 11:33:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">So, hab den Speedtest mal ganz rausgeschmissen und weiß jetzt warum du geschrieben hast das da was fehlt. Hier nun die Gesamte Ausgabe (im Spoiler):</p>
<pre><code>xxxxxx@raspberrypi:/etc/apt/sources.list.d $ uname -m &amp;&amp; test -f /opt/scripts/.docker_config/.thisisdocker &amp;&amp; echo "Docker-Installation" || echo "Kein Docker" &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;&amp; echo $DESKTOP_SESSION &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
aarch64
Kein Docker
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v19.0.0
v19.0.0
8.19.2
4.0.23
xxxxxx
xxxxxx adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
tty
OK:1 http://deb.debian.org/debian bullseye InRelease
OK:2 http://security.debian.org/debian-security bullseye-security InRelease
OK:3 http://archive.raspberrypi.org/debian bullseye InRelease
OK:4 http://deb.debian.org/debian bullseye-updates InRelease
OK:5 https://repos.influxdata.com/debian bullseye InRelease
OK:6 https://packages.grafana.com/oss/deb stable InRelease
OK:7 https://deb.nodesource.com/node_14.x bullseye InRelease
OK:8 https://deb.nodesource.com/node_16.x bullseye InRelease
OK:9 https://deb.nodesource.com/node_19.x bullseye InRelease
Paketlisten werden gelesenâ¦ Fertig
AbhÃ¤ngigkeitsbaum wird aufgebautâ¦ Fertig
Statusinformationen werden eingelesenâ¦ Fertig
Alle Pakete sind aktuell.
nodejs:
 Installiert:           19.0.0-deb-1nodesource1
 Installationskandidat: 19.0.0-deb-1nodesource1
 Versionstabelle:
*** 19.0.0-deb-1nodesource1 500
       500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
    16.18.0-deb-1nodesource1 500
       500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
    14.21.0-deb-1nodesource1 500
       500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884959</link><guid isPermaLink="true">https://forum.iobroker.net/post/884959</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 11:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:15:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a> sagte in <a href="/post/884840">Error 25 beim Versuch Adapter zu installieren (Gelöst)</a>:</p>
<p dir="auto">Die *.list-Datei, wo</p>
<blockquote>
<p dir="auto"><a href="https://ookla.bintray.com/debian" rel="nofollow ugc">https://ookla.bintray.com/debian</a></p>
</blockquote>
<p dir="auto">drin steht muss gelöscht werden.<br />
Findet sich in /etc/apt/sources.list.d/</p>
<p dir="auto">Dann versuch das Installationsskript für die ookla-Speedtest-Quelle auszuführen:</p>
<pre><code>curl -s https://install.speedtest.net/app/cli/install.deb.sh | sudo bash
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884844</link><guid isPermaLink="true">https://forum.iobroker.net/post/884844</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:15:48 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:06:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>xxxxxx@@raspberrypi:/opt/iobroker $ sudo apt update
OK:1 http://security.debian.org/debian-security bullseye-security InRelease
OK:2 http://deb.debian.org/debian bullseye InRelease
Fehl:3 https://ookla.bintray.com/debian generic InRelease
  Could not handshake: Die TLS-Verbindung wurde nicht sauber beendet. [IP: 18.158.82.64 443]
OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
OK:6 https://repos.influxdata.com/debian bullseye InRelease
OK:7 https://packages.grafana.com/oss/deb stable InRelease
OK:8 https://deb.nodesource.com/node_14.x bullseye InRelease
OK:9 https://deb.nodesource.com/node_16.x bullseye InRelease
OK:10 https://deb.nodesource.com/node_19.x bullseye InRelease
Holen:11 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease [24,5 kB]
Fehl:11 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
  Die folgenden Signaturen konnten nicht Ã¼berprÃ¼ft werden, weil ihr Ã¶ffentlicher SchlÃ¼ssel nicht verfÃ¼gbar ist: NO_PUBKEY 8E61C2AB9A6D1557
W: GPG-Fehler: https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease: Die folgenden Signaturen konnten nicht Ã¼berprÃ¼ft werden, weil ihr Ã¶ffentlicher SchlÃ¼ssel nicht verfÃ¼gbar ist: NO_PUBKEY 8E61C2AB9A6D1557
E: Das Depot Â»https://packagecloud.io/ookla/speedtest-cli/debian bullseye InReleaseÂ« ist nicht signiert.
N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgefÃ¼hrt werden, daher ist es standardmÃ¤Ãig deaktiviert.
N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
xxxxxx@raspberrypi
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884840</link><guid isPermaLink="true">https://forum.iobroker.net/post/884840</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:06:36 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:04:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<pre><code>sudo apt update
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884839</link><guid isPermaLink="true">https://forum.iobroker.net/post/884839</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:04:56 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:04:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>xxxxxx@raspberrypi:/opt/iobroker $ sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884837</link><guid isPermaLink="true">https://forum.iobroker.net/post/884837</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:02:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Vollständig zeigen, inkl. der Ein- wie Ausgaben.</p>
<pre><code>sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884833</link><guid isPermaLink="true">https://forum.iobroker.net/post/884833</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 09:01:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Falls du die erste Ausgabe von ln meinst, ja, da kommt das die Datei schon existiert. Bei der Zweiten kommt nicht mehr.</p>
]]></description><link>https://forum.iobroker.net/post/884832</link><guid isPermaLink="true">https://forum.iobroker.net/post/884832</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 09:01:36 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:58:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Da muss mehr kommen.</p>
]]></description><link>https://forum.iobroker.net/post/884829</link><guid isPermaLink="true">https://forum.iobroker.net/post/884829</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:57:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Sorry, es fehlt:</p>
</code></pre>
<p dir="auto">mehr ist nicht drin.</p>
]]></description><link>https://forum.iobroker.net/post/884827</link><guid isPermaLink="true">https://forum.iobroker.net/post/884827</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:57:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Bitte vollständig posten.</p>
<p dir="auto">Und NICHT v19 verwenden. Das ist eine Entwicklerversion und auch noch nicht für den ioBroker vorgesehen.<br />
Installier v16.</p>
]]></description><link>https://forum.iobroker.net/post/884824</link><guid isPermaLink="true">https://forum.iobroker.net/post/884824</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:57:49 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:55:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>aarch64
Kein Docker
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v19.0.0
v19.0.0
8.19.2
4.0.23
xxxxxx
tty
</code></pre>
<p dir="auto">Die Installation klappt wieder.</p>
]]></description><link>https://forum.iobroker.net/post/884823</link><guid isPermaLink="true">https://forum.iobroker.net/post/884823</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:55:05 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:29:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Fein!</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs
</code></pre>
<p dir="auto">sagt nun?</p>
]]></description><link>https://forum.iobroker.net/post/884815</link><guid isPermaLink="true">https://forum.iobroker.net/post/884815</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:29:53 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Thu, 03 Nov 2022 08:13:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Vielen Dank für deine Antwort. Hat super geklappt.</p>
<p dir="auto">Edit: Problem wurde gelöst.</p>
]]></description><link>https://forum.iobroker.net/post/884814</link><guid isPermaLink="true">https://forum.iobroker.net/post/884814</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Thu, 03 Nov 2022 08:13:03 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Wed, 02 Nov 2022 19:37:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a></p>
<p dir="auto">Stop google!</p>
<p dir="auto">Schau in meiner Signatur, da wird's erklärt.</p>
]]></description><link>https://forum.iobroker.net/post/884593</link><guid isPermaLink="true">https://forum.iobroker.net/post/884593</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Nov 2022 19:37:16 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Wed, 02 Nov 2022 19:34:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codierknecht" aria-label="Profile: codierknecht">@<bdi>codierknecht</bdi></a> Danke erstmal. Damit lässt sich schon mehr anfangen. Dann werde ich mal googeln wie man das macht</p>
]]></description><link>https://forum.iobroker.net/post/884591</link><guid isPermaLink="true">https://forum.iobroker.net/post/884591</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Wed, 02 Nov 2022 19:34:17 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Wed, 02 Nov 2022 19:27:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a> Aktuelle Versionen von Node und NPM einsetzen.<br />
An den installierten Versionen hat sich schon etwas Staub abgesetzt ;-)</p>
]]></description><link>https://forum.iobroker.net/post/884584</link><guid isPermaLink="true">https://forum.iobroker.net/post/884584</guid><dc:creator><![CDATA[Codierknecht]]></dc:creator><pubDate>Wed, 02 Nov 2022 19:27:47 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Wed, 02 Nov 2022 19:26:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djmarc75" aria-label="Profile: djmarc75">@<bdi>djmarc75</bdi></a><br />
Weil was? Ich wäre für einen Hinweis wirklich dankbar. Ich bin alles andere als ein Linux Profi versuche es dennoch zu verstehen, aber ohne einen Hinweis auf das was ich scheinbar nicht sehe, oder nicht verstehe, komm ich leider nicht weiter.</p>
]]></description><link>https://forum.iobroker.net/post/884582</link><guid isPermaLink="true">https://forum.iobroker.net/post/884582</guid><dc:creator><![CDATA[Vetinari77]]></dc:creator><pubDate>Wed, 02 Nov 2022 19:26:08 GMT</pubDate></item><item><title><![CDATA[Reply to Error 25 beim Versuch Adapter zu installieren (Gelöst) on Wed, 02 Nov 2022 19:19:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vetinari77" aria-label="Profile: vetinari77">@<bdi>vetinari77</bdi></a> sagte in <a href="/post/884568">Error 25 beim Versuch irgendeinen Adapter zu installieren</a>:</p>
<blockquote>
<p dir="auto">Raspi 4 mit Bullsey (Aktueller stand)</p>
</blockquote>
<p dir="auto">Nicht Dein Ernst jetzt weil:</p>
/usr/bin/nodejs
v12.22.12
/usr/bin/node
v12.22.12
/usr/bin/npm
7.5.2
</code></pre>
]]></description><link>https://forum.iobroker.net/post/884574</link><guid isPermaLink="true">https://forum.iobroker.net/post/884574</guid><dc:creator><![CDATA[DJMarc75]]></dc:creator><pubDate>Wed, 02 Nov 2022 19:19:50 GMT</pubDate></item></channel></rss>
