  4. Nach restore Adapter in der Konsole aber nicht ...
    5.7k
57 Beiträge 6 Kommentatoren 5.1k Aufrufe 4 Beobachtet
  • H HiHo
    in gekürzter Version :
    pi@iobroker:~ $ iobroker upload all
    INFO: Directory "for cloud.admin" was not found! Nothing was uploaded or deleted.
    Cannot find io-package.json for "cloud"
    INFO: Directory "for cloud" was not found! Nothing was uploaded or deleted.
    INFO: Directory "for iot.admin" was not found! Nothing was uploaded or deleted.
    Cannot find io-package.json for "iot"
    INFO: Directory "for iot" was not found! Nothing was uploaded or deleted.
    INFO: Directory "for telegram.admin" was not found! Nothing was uploaded or deleted.
    Cannot find io-package.json for "telegram"
    INFO: Directory "for telegram" was not found! Nothing was uploaded or deleted.
    Alle anderen Adapter sind normal geuploaded worden
    @hiho
    Und wenn du die Bengel ganz doof einfach nochmal installierst?
    Z. B. so:
    iobroker upgrade iot@1.11.9
    iobroker upgrade cloud@4.2.2
    iobroker upgrade telegram@1.14.1
    H 1 Antwort Letzte Antwort
      @hiho
      Z. B. so:
      HiHo
      nichts, scheint mit irgendwelchen Leserechten zu tun zu haben ???👨‍🎨 😕
      pi@iobroker:~ $ iobroker upgrade telegram@1.14.1
      This upgrade of "telegram" will at least introduce the following changes:
      -> 1.14.1:
      Fixed warnings for `botSendChatId`
      -> 1.14.0:
      Ported config Gui to Admin 6
      -> 1.13.0:
      Added Admin 5 UI config
      Added rule block for javascript as plugin
      -> 1.12.6:
      Fix crash cases reported by Sentry
      -> 1.12.5:
      -> 1.12.4:
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade telegram from @0.0.0 to @1.14.1 now? [(y)es, (n)o]: y
      Update telegram from @0.0.0 to @1.14.1
      Cannot upgrade: Cannot read properties of undefined (reading 'enabled')
      N 1 Antwort Letzte Antwort
      • H HiHo
        -> 1.14.1:
        -> 1.14.0:
        -> 1.13.0:
        -> 1.12.6:
        -> 1.12.5:
        -> 1.12.4:
        N Offline
        N Offline
        Nordischerjung
        @hiho Moin hast du mal iobroker fix laufen lassen?
        Gruß Nordischerjung
        sonnige Grüße von der Ostsee
        H 2 Antworten Letzte Antwort
        • N Nordischerjung
          HiHo
          @nordischerjung
          Moin,moin,
          ich habe gefühlt alles laufen lassen, das es gibt... kann ich aber noch einmal machen
          • N Nordischerjung
            HiHo
            @nordischerjung
            pi@iobroker:~ $ iobroker fix
            library: loaded
            Library version=2022-06-15
                Welcome to the ioBroker installation fixer!
                Script version: 2022-06-03
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            OK:3 https://deb.nodesource.com/node_16.x buster InRelease
            Es wurden 15,0 kB in 1 s geholt (14,8 kB/s).
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/3)
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            • H HiHo
              @nordischerjung
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              N Offline
              N Offline
              Nordischerjung
              @hiho da scheint ja auch etwas mit der Telegramversion nicht zu stimmen telegram from @0.0.0
              Hast du mal versucht Telegramm zu deinstallieren und dann neu zu installieren?
              Gruß Nordischerjung
              • N Nordischerjung
                HiHo
                @nordischerjung
                es bleibt dasselbe, ich kann keinen neuen Telegram Adapter installieren. Es kommt wieder dieselbe Fehlermeldung
                • H HiHo
                  @nordischerjung
                  @hiho
                  iobroker upgrade telegram@1.14.1 --debug
                    @hiho
                    HiHo
                    kann ich jetzt noch nach dem löschen ein upgrade machen?
                    • H HiHo
                      @hiho
                      Ja, versuch mal.
                      Alternativ mit
                      iobroker add telegram@1.14.1 --debug
                        @hiho
                        Ja, versuch mal.
                        Alternativ mit
                        HiHo
                        pi@iobroker:~ $ iobroker add telegram@1.14.1 --debug
                        adapter "telegram" cannot be installed: Cannot read properties of undefined (reading 'enabled')
                        bleibt gleich...
                        • H HiHo
                          bleibt gleich...
                          HiHo
                          @Thomas-Braun
                          gibt es noch eine andere Möglichkeit die Adapter wieder ins System zu bekommen?
                          Bin ziemlich ratlos gerade... 😢
                          • H HiHo
                            @Thomas-Braun
                            @hiho
                            Ich weiß es nicht.
                              @hiho
                              Ich weiß es nicht.
                              HiHo
                              gibt es irgendwelche Bugs, die bekannt für einen solchen Fehler sind?
                              • H HiHo
                                @hiho
                                Ist mir nicht bekannt.
                                  @hiho
                                  crunchipC Offline
                                  crunchipC Offline
                                  @thomas-braun da gibt es aber 2 Threads mit dieser Meldung
                                  https://forum.iobroker.net/search?term=Cannot read properties of undefined (reading 'enabled')&in=titlesposts
                                  ein elster backup und ein node falsch, so wie ich auf die schnelle überflogen hatte
                                    @crunchip sagte in Nach restore Adapter in der Konsole aber nicht ...:
                                    Wieder die Klassiker?
                                    @HiHo
                                    Was sagt dann
                                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      @HiHo
                                      Was sagt dann
                                      HiHo
                                      hier die Ausgabe :
                                      pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                      pi@iobroker:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.0
                                      v16.18.0
                                      8.19.2
                                      4.0.23
                                      pi
                                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                      tty
                                      /home/pi
                                      bin fast so weit, dass ich iobroker neu aufsetze und das Backup einspiele... ob das dann funktioniert?
                                      • H HiHo
                                        hier die Ausgabe :
                                        armv7l
                                        Kein Docker
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.18.0
                                        v16.18.0
                                        8.19.2
                                        4.0.23
                                        pi
                                        tty
                                        /home/pi
                                        @hiho
                                        Da hängen Updates in der Pipeline...
                                        sudo apt update
                                          @hiho
                                          sudo apt update
                                          HiHo
                                          pi@iobroker:~ $ sudo apt update
                                          Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                                          Holen:3 https://deb.nodesource.com/node_16.x buster InRelease [4.584 B]
                                          Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB           ]
                                          Holen:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,           0 MB]
                                          Holen:6 https://deb.nodesource.com/node_16.x buster/main armhf Packages [781 B]
                                          Es wurden 52,2 kB in 6 s geholt (9.426 B/s).
                                          Aktualisierung für 11 Pakete verfügbar. Führen Sie »apt list --upgradable« aus,            um sie anzuzeigen.
                                          pi@iobroker:~ $ apt list --upgradable
                                          Auflistung... Fertig
                                          ffmpeg/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+deb10u1           +rpt1]
                                          libavcodec58/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+d           eb10u1+rpt1]
                                          libavdevice58/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+           deb10u1+rpt1]
                                          libavfilter7/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+d           eb10u1+rpt1]
                                          libavformat58/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+           deb10u1+rpt1]
                                          libavresample4/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0           +deb10u1+rpt1]
                                          libavutil56/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+de           b10u1+rpt1]
                                          libpostproc55/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+           deb10u1+rpt1]
                                          libswresample3/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0           +deb10u1+rpt1]
                                          libswscale5/oldstable 7:4.1.10-0+deb10u1 armhf [aktualisierbar von: 7:4.1.9-0+de           b10u1+rpt1]
                                          nodejs/unbekannt 16.18.1-deb-1nodesource1 armhf [aktualisierbar von: 16.18.0-deb           -1nodesource1]
                                          pi@iobroker:~ $
