  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • S Sammydk
    Ich meine den Error der an dieser Stelle aufgetreten ist
    Sammydk
    schrieb am zuletzt editiert von Sammydk
    #2369
    @sammydk
    Und hier die Config.ini
    [MakeImage]
    ;LogImageLocation = /log/source
    WaitBeforeTakingPicture = 5
    ;LogfileRetentionInDays = 15
    Brightness = 0
    Contrast = 1
    Saturation = 0
    LEDIntensity = 8
    ImageQuality = 12
    ImageSize = VGA
    FixedExposure = false
    [Alignment]
    InitialRotate = 179
    InitialMirror = false
    SearchFieldX = 20
    SearchFieldY = 20
    AlignmentAlgo = default
    FlipImageSize = false
    /config/ref0.jpg 122 222
    /config/ref1.jpg 236 22
    [Digits]
    Model = /config/dig-class100_s1d-md-v1.0_q.tflite
    CNNGoodThreshold = 0.5
    ;LogImageLocation = /log/digit
    ;LogfileRetentionInDays = 3
    main.dig1 205 101 33 55 false
    main.dig2 240 101 37 56 false
    main.dig3 279 102 32 54 false
    main.digi4 313 102 37 54 false
    [Analog]
    Model = /config/ana-class100_i32s100dr-v1.0_q.tflite
    ;LogImageLocation = /log/analog
    main.ana1 398 174 99 99 false
    main.ana2 354 280 98 96 false
    main.ana3 250 323 97 97 false
    main.ana4 139 277 98 95 false
    [PostProcessing]
    main.DecimalShift = 0
    PreValueUse = true
    PreValueAgeStartup = 720
    AllowNegativeRates = false
    ;main.MaxRateValue = 0.5
    ;main.MaxRateType = AbsoluteChange
    ;main.ExtendedResolution = false
    ;main.IgnoreLeadingNaN = true
    ErrorMessage = true
    CheckDigitIncreaseConsistency = false
    [MQTT]
    Uri = mqtt://192.168.###.8:1883
    MainTopic = #############
    ClientID = ##############
    user = #########
    password = #########
    ;SetRetainFlag = true
    ;[InfluxDB]
    ;Uri = undefined
    ;Database =
    ;Measurement = undefined
    ;user = undefined
    ;password = undefined
    ;[GPIO]
    ;IO0 = input disabled 10 false false
    ;IO1 = input disabled 10 false false
    ;IO3 = input disabled 10 false false
    ;IO4 = built-in-led disabled 10 false false
    ;IO12 = input-pullup disabled 10 false false
    ;IO13 = input-pullup disabled 10 false false
    LEDType = WS2812
    LEDNumbers = 2
    LEDColor = 150 150 150
    [AutoTimer]
    AutoStart = true
    Intervall = 4.85
    [Debug]
    Logfile = false
    [System]
    ;TimeZone = CET-1CEST,M3.5.0,M10.5.0/3
    TimeServer = 192.168.###.1
    ;AutoAdjustSummertime = false
    ;Hostname = undefined
    SetupMode = false
    Jens MeyerJ 1 Antwort Letzte Antwort
    • J jomjol
      @fubak-0 Er findet dann die Referenz nicht (vermutlich m³). Du könntest es im Zweifelsfall durch einen weißen Aufkleber mit schwarzen Symbol ersetzen.
      Fubak 0
      #2370
      @jomjol Okay, mir war nicht klar das er sich die Punkte neu suchen muss.
      • S Sammydk
        @sammydk
        [MakeImage]
        Brightness = 0
        Contrast = 1
        Saturation = 0
        LEDIntensity = 8
        ImageQuality = 12
        ImageSize = VGA
        [Alignment]
        InitialRotate = 179
        SearchFieldX = 20
        SearchFieldY = 20
        [Digits]
        [Analog]
        [PostProcessing]
        PreValueUse = true
        ErrorMessage = true
        [MQTT]
        user = #########
        ;[InfluxDB]
        ;Uri = undefined
        ;Database =
        ;user = undefined
        ;[GPIO]
        LEDType = WS2812
        LEDNumbers = 2
        [AutoTimer]
        AutoStart = true
        Intervall = 4.85
        [Debug]
        Logfile = false
        [System]
        SetupMode = false
        Jens MeyerJ Offline
        Jens MeyerJ Offline
        Jens Meyer
        schrieb am zuletzt editiert von Jens Meyer
        #2371
        @sammydk
        Setz mal CheckDigitIncreaseConsistency = false
        Auf true
        Das sollte dein Problem eleminieren
        • Jens MeyerJ Jens Meyer
          @sammydk
          Auf true
          Sammydk
          #2372
          @jens-meyer
          Hallo Jens, danke für den TIP, ich werde es beobachten.
          • J jomjol
            Jens MeyerJ Offline
            Jens MeyerJ Offline
            Jens Meyer
            #2373
            @jomjol
            Hallo,ich muss aber auch mal fragen.. wie läuft das Setup für einen gaszähler ab?
            Was für ein file gibt es da? (Referenzbild) ? Kann ja nicht das selbe wie für die Wasseruhr sein? Und nach dem Komma sind ja auch dig und keine Analogen Zeiger.. muss man da auch die digitalen Zähler zum einstellen nehmen und erkennt er dann die 3 zahlen nach dem Komma? Oder wie habt ihr das gemacht?
              @jomjol
              jomjol
              #2374
              @jens-meyer sagte in Wasserzähler - Version 2 - all-in-device:
              @jomjol
              Ich verstehe deine Frage nicht ganz. Das läuft wie beim Wasserzähler, nur dass du eben die analogen Zähler deaktivierst. Die Position des Kommas kannst du dann in der Konfiguration festlegen.
              Hoffe, dass hilft.
              • J jomjol
                @jomjol
                Hoffe, dass hilft.
                Jens MeyerJ Offline
                Jens MeyerJ Offline
                Jens Meyer
                #2375
                @jomjol
                ja so ist das ok, danke für die info... wo und wie kann ich den die position des kommas festlegen in der config?
                  @jomjol
                  jomjol
                  #2376
                  @jomjol
                  Hast du die Konfiguration schonmal durchgeführt? Ist eigentlich kaum zu übersehen:
                  • J jomjol
                    @jomjol
                    Jens MeyerJ Offline
                    Jens MeyerJ Offline
                    Jens Meyer
                    #2377
                    @jomjol
                    Vielen Dank, hat mir sehr geholfen
                      @jomjol
                      Jens MeyerJ Offline
                      Jens MeyerJ Offline
                      Jens Meyer
                      #2378
                      @jens-meyer
                      das passt doch hinten und vorn nicht, ich bin schon seit stunden am hin und her probieren mit den dig und dem referenzbild , es will einfach nicht... bei der wasseruhr gibts keine probleme, da wird alles korekt angezeigt wie es soll
                      nur der blöde gaszähler macht probleme
                        @jens-meyer
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        #2379
                        @jens-meyer deine Zahlenrahmen sind alle unterschiedlich groß.
                        Du kannst deren Größe in Pixeln angeben - mache die alle gleich groß.
                        Achte beim Referenzbild darauf die Zahlen genau gerade auszurichten,
                        Dann die Kästen alle gleich groß - und die müssten dann alle auf dem gleichen Y-Wert liegen
                        Und vergiss die letzte Zahl mit den vielen Strichen, lass die einfach weg
                        Jens MeyerJ 2 Antworten Letzte Antwort
                        • BananaJoeB BananaJoe
                          Jens MeyerJ Offline
                          Jens MeyerJ Offline
                          Jens Meyer
                          #2380
                          @bananajoe
                          danke für die tips... probiere ich dann gleich und melde mich
                            @bananajoe
                            JoergH
                            schrieb am zuletzt editiert von JoergH
                            #2381
                            @bananajoe
                            Der innere Rahmen muss exakt die Zahlen umfassen, der äußere sollte dann auch nicht über die Walzen hinauslangen. Ich habe den gleichen Zähler und bei mir funktioniert es inzwischen einwandfrei.
                            Auch die Wasserzähler habe ich in den letzten Tagen durch viel getüftel endlich alle zum Laufen gebracht.
                            Zunächst habe ich die Gehäuse alle aus schwarem Filament gedruckt und gedacht es wäre hilfreich, wenn diese Licht schlucken um Blendungen zu vermeiden. Wie sich herausstellte, ist das genau falsch!
                            Inzwischen habe ich alle aus weissem Filament gedruckt und das funktioniert erheblich besser!
                            Nachdem ich von Thingiverse zunächst die Druckvorlagen runtergeladen hatte und mit denen nicht glücklich wurde, habe ich meine eigenen entworfen und diese gedruckt. Dabei habe ich bei unterschiedlichen Zählern auch mit dem Abstand gespielt und festgestellt, dass ein Abstand von eher 8 cm zum Zähler besser funktioniert, als wenn er größer ist. Selbst mein Zisternenzähler, der durch Schwebeteilchen ziemlich getrübt ist, funktioniert so bestens!
                            • J JoergH
                              @bananajoe
                              Jens MeyerJ Offline
                              Jens MeyerJ Offline
                              Jens Meyer
                              #2382
                              @joergh
                              ja das mit den Rahmen um die Ziffern weiss ich, mein Wasserzähler läuft ja korrekt
                              aber ich werde erstmal alles in einer Grösse machen und auf einer Achse anordnen (y)
                              und mal sehen...ich denke die Spiegelungen kommen vom Spiegel selbst... (spiegelvariante vom Wasserzähler)
                                Jens MeyerJ Offline
                                Jens MeyerJ Offline
                                Jens Meyer
                                #2383
                                @bananajoe
                                wenn ich die Rahmen alle gleich gross habe und alle auf einer y-Achse liegen , liegt der Rahmen aber nicht mehr genau um die Zahl
                                da ja die Zahlen im Zähler mal etwas weiter oben und eine andere wieder etwas weiter unten steht
                                so nochmal nachjustiert... sieht aber auch nicht besser aus...
                                  @bananajoe
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  #2384
                                  @jens-meyer irgendwie bist du ziemlich schräg, sowohl horizontal als auch vertikal
                                  und 91.88 ist doch gut? (wenn auch 0.01 daneben)
                                    Jens MeyerJ Offline
                                    Jens MeyerJ Offline
                                    Jens Meyer
                                    #2385
                                    @bananajoe
                                    ist nicht der raw wert entscheidend? habs nun einigermassen hinbekommen
                                    musste auf eine stelle nach dem komma , die letzten 2 will er nicht
                                      Jens MeyerJ Offline
                                      Jens MeyerJ Offline
                                      Jens Meyer
                                      #2386
                                      @bananajoe
                                      Hallo, ich hab da mal noch ne Frage..
                                      Mit einer Komma Stelle zeigt es den Wert richtig an… nach neu Ausrichtung
                                      Sobald ich aber 2 Komma stellen einstelle , und einem zusätzlichen dig stimmt der raw Wert garnicht mehr der richtige Wert ist 091.9 das wird mir bei einer Komma stelle auch angezeigt.. bei allen werten gleich und wenn ich die 2 kommastelle aktiviere zeigt mir der raw Wert 970,19 an versteh ich nicht.. Spiegelungen?
                                      Mehrmals probiert.. Wechsel ich zurück auf eine kommastelle ist alles wieder richtig 2 kommastelle falsche werte
                                      Ps: das Referenzbild sieht gerade aus mit dem gitterlinien
                                        @bananajoe
                                        BananaJoeB Offline
                                        BananaJoeB Offline
                                        BananaJoe
                                        #2387
                                        @jens-meyer Eventuell bewegen sich die hinteren Stellen auch einfach zu schnell. Wenn die Anzeige zwischen den Zahlen steht geht es regelmäßig schief. Ich hab meinen Gaszähler nur auf die m³, mir reicht das (sind dann halt ca. 11kWh Schritte)
                                          Jens MeyerJ Offline
                                          Jens MeyerJ Offline
                                          Jens Meyer
                                          #2388
                                          @bananajoe
                                          Ok, danke für die info… da ist eine kommastelle schon gut denke ich , könnte ja auch ein Sensor dran bauen, ist mir aber zu umständlich das mit der Cam ist ne gute Lösung,vielleicht druck ich mir noch ne Schablone.. oder ne gerade Variante wo die Camera ohne Spiegel davor sitzt… mal sehen
                                          Aber danke für deine Hilfe
