  4. IOBroker lässt sich nicht starten und nicht restoren
    5.7k
33 Beiträge 2 Kommentatoren 3.3k Aufrufe 2 Beobachtet
    @djsirius
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    sagt?
    djsirius
    @thomas-braun said in IOBroker lässt sich nicht starten und nicht restoren:
    iobroker@debian:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden:        Die Datei existiert bereits
    iobroker@debian:/opt/iobroker$ uname -m && type -P nodejs node npm && nodejs -v        && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &&        pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.18.0
    v16.18.0
    8.19.2
    node:internal/modules/cjs/loader:988
      throw err;
    Error: Cannot find module './lib/setup'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15        )
        at Function.Module._load (node:internal/modules/cjs/loader:833:27)
        at Module.require (node:internal/modules/cjs/loader:1057:19)
        at require (node:internal/modules/cjs/helpers:103:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js:1:1)
        at Module._compile (node:internal/modules/cjs/loader:1155:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
        at Module.load (node:internal/modules/cjs/loader:1033:32)
        at Function.Module._load (node:internal/modules/cjs/loader:868:12)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:81:12) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js        ' ]
    djsirius
    • D djsirius
      x86_64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.18.0
      v16.18.0
      8.19.2
        throw err;
      Require stack:
      @djsirius
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
        @djsirius
        cd /opt/iobroker
        djsirius
        iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/ajv
        npm ERR! dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -> '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
        npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_02_41_647Z-debug-0.log
        djsirius
        • D djsirius
          npm ERR! errno -39
          @djsirius
          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
            @djsirius
            djsirius
            @thomas-braun Hab ich ausgeführt.
            djsirius
            • D djsirius
              @djsirius
              Dann nochmal
              cd /opt/iobroker
                @djsirius
                Dann nochmal
                cd /opt/iobroker
                djsirius
                npm ERR! errno -39
                iobroker@debian:/opt/iobroker$ ^C
                iobroker@debian:/opt/iobroker$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                npm WARN skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.lg-thinq.git
                npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm ERR! code 24
                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! command failed
                npm ERR! command sh -c -- node iobroker.js setup first
                npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_08_22_676Z-debug-0.log
                djsirius
                • D djsirius
                  npm ERR! errno -39
                  npm ERR! code 24
                  @djsirius sagte in IOBroker lässt sich nicht starten und nicht restoren:
                  systemctl status iobroker.service
                    djsirius
                    iobroker@debian:/opt/iobroker$ systemctl status iobroker.service
                    ● iobroker.service - ioBroker Server
                       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                       Active: active (running) since Sat 2022-10-29 00:09:54 CEST; 6min ago
                         Docs: http://iobroker.net
                     Main PID: 13929 (iobroker.js-con)
                        Tasks: 22 (limit: 4915)
                       Memory: 365.9M
                       CGroup: /system.slice/iobroker.service
                               ├─13929 iobroker.js-controller
                               └─14061 io.history.0
                    Okt 29 00:11:56 debian bash[13929]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js:9:15)
                    Okt 29 00:11:56 debian bash[13929]:     at Module._compile (node:internal/modules/cjs/loader:1155:14)
                    Okt 29 00:11:56 debian bash[13929]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
                    Okt 29 00:11:56 debian bash[13929]:     at Module.load (node:internal/modules/cjs/loader:1033:32)
                    Okt 29 00:11:56 debian bash[13929]:     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
                    Okt 29 00:11:56 debian bash[13929]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                    Okt 29 00:11:56 debian bash[13929]:   code: 'MODULE_NOT_FOUND',
                    Okt 29 00:11:56 debian bash[13929]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js' ]
                    Okt 29 00:11:56 debian bash[13929]: }
                    Okt 29 00:15:00 debian bash[13929]: Cannot find js-controller
                    djsirius
                    • D djsirius
                         Memory: 365.9M
                      @djsirius
                      sudo systemctl stop iobroker.service
                      Dann nochmal
                      cd /opt/iobroker
                        @djsirius
                        Dann nochmal
                        cd /opt/iobroker
                        djsirius
                        iobroker@debian:/opt/iobroker$ sudo systemctl stop iobroker.service
                        added 1 package, and changed 1195 packages in 2m
                        109 packages are looking for funding
                          run `npm fund` for details
                        djsirius
                        • D djsirius
                          @djsirius
                          Sollte eigentlich jetzt wieder laufen.
                          sagt?
                            @djsirius
                            sagt?
                            djsirius
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.18.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            iobroker
                            iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
                            tty
                            /opt/iobroker
                            OK:1 http://deb.debian.org/debian buster InRelease
                            OK:2 http://security.debian.org/debian-security buster/updates InRelease
                            OK:3 http://deb.debian.org/debian-security buster/updates InRelease
                            OK:4 http://ftp.de.debian.org/debian buster InRelease
                            OK:5 http://deb.debian.org/debian buster-updates InRelease
                            OK:6 https://deb.nodesource.com/node_16.x buster InRelease
                            OK:7 http://deb.debian.org/debian buster-backports InRelease
                            OK:8 https://packages.sury.org/php buster InRelease
                            OK:9 http://ftp.de.debian.org/debian buster-updates InRelease
                            OK:10 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
                            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                            nodejs:
                              Installiert:           16.18.0-deb-1nodesource1
                              Installationskandidat: 16.18.0-deb-1nodesource1
                              Versionstabelle:
                             *** 16.18.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
                                 10.24.0~dfsg-1~deb10u2 500
                                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                                    500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
                                 10.24.0~dfsg-1~deb10u1 500
                                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                                    500 http://deb.debian.org/debian buster/main amd64 Packages
                            djsirius
                            • D djsirius
                              x86_64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.18.0
                              v16.18.0
                              8.19.2
                              4.0.23
                              iobroker
                              tty
                              /opt/iobroker
                              nodejs:
                                Versionstabelle:
                              @djsirius
                              Passt.
                              Läuft das Ding wieder?
                              iob status
                              D 2 Antworten Letzte Antwort
                                @djsirius
                                Passt.
                                iob status
                                djsirius
                                iob status
                                iobroker@debian:/opt/iobroker$ iob status
                                Objects type: jsonl
                                States  type: jsonl
                                djsirius
                                  @djsirius
                                  Passt.
                                  iob status
                                  djsirius
                                  @thomas-braun Den Admin kann ich leider immer noch nicht erreichen,
                                  Was ist denn da passiert?
                                  djsirius
                                  • D djsirius
                                    @djsirius
                                    iob list instances
                                      @djsirius
                                      iob list instances
                                      djsirius
                                      iob list instances
                                      iobroker@debian:/opt/iobroker$ iob list instances
                                      + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
                                      + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
                                        system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
                                        system.adapter.devices.0                : devices               : debian                                   -  enabled
                                      + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
                                        system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
                                      + system.adapter.enigma2.0                : enigma2               : ioBroker-RasPi                           -  enabled
                                        system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
                                      + system.adapter.fhem.0                   : fhem                  : debian                                   -  enabled, port: 7072
                                        system.adapter.flot.0                   : flot                  : debian                                   -  enabled
                                      + system.adapter.history.0                : history               : debian                                   -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
                                        system.adapter.ical.0                   : ical                  : debian                                   -  enabled
                                        system.adapter.ical.1                   : ical                  : debian                                   -  enabled
                                        system.adapter.ical.2                   : ical                  : debian                                   -  enabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
                                      + system.adapter.info.0                   : info                  : debian                                   -  enabled
                                      + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
                                      + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
                                      + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
                                      + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
                                      + system.adapter.meross.0                 : meross                : debian                                   -  enabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
                                        system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
                                      + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
                                      + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
                                      + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
                                      + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi                           -  enabled
                                      + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
                                      + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.simple-api.1             : simple-api            : ioBroker-RasPi                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                                      + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
                                        system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
                                      + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                      + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
                                      + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
                                      + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
                                        system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
                                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
                                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
                                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
                                        system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
                                        system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
                                        system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
                                        system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
                                        system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
                                        system.adapter.vis.0                    : vis                   : debian                                   -  enabled
                                      + system.adapter.web-speedy.0             : web-speedy            : debian                                   -  enabled
                                      + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.zigbee.0                 : zigbee                : ioBroker-RasPi                           -  enabled, port: /dev/ttyUSB0
                                      + instance is alive
                                      djsirius
                                      • D djsirius
                                        iob list instances
                                        + instance is alive
                                        @djsirius
                                        Multihost-Setup oder was haste mit den hostnames gemacht?
                                          @djsirius
                                          djsirius
                                          @thomas-braun ja hab raspberry als slave laufen
                                          Systeminfo lässt sich nicht starten
                                          djsirius
