  4. IOBroker lässt sich nicht starten und nicht restoren
    5.7k
33 Beiträge 2 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • D djsirius
    iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/ajv
    npm ERR! dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -> '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
    npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_02_41_647Z-debug-0.log
    iobroker@debian:/opt/iobroker$ ^C
    iobroker@debian:/opt/iobroker$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    npm WARN skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.lg-thinq.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 24
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_08_22_676Z-debug-0.log
    @djsirius sagte in IOBroker lässt sich nicht starten und nicht restoren:
    systemctl status iobroker.service
      djsirius
      @thomas-braun said in IOBroker lässt sich nicht starten und nicht restoren:
      iobroker@debian:/opt/iobroker$ systemctl status iobroker.service
      ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: active (running) since Sat 2022-10-29 00:09:54 CEST; 6min ago
           Docs: http://iobroker.net
       Main PID: 13929 (iobroker.js-con)
          Tasks: 22 (limit: 4915)
         Memory: 365.9M
         CGroup: /system.slice/iobroker.service
                 ├─13929 iobroker.js-controller
                 └─14061 io.history.0
      Okt 29 00:11:56 debian bash[13929]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js:9:15)
      Okt 29 00:11:56 debian bash[13929]:     at Module._compile (node:internal/modules/cjs/loader:1155:14)
      Okt 29 00:11:56 debian bash[13929]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
      Okt 29 00:11:56 debian bash[13929]:     at Module.load (node:internal/modules/cjs/loader:1033:32)
      Okt 29 00:11:56 debian bash[13929]:     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
      Okt 29 00:11:56 debian bash[13929]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
      Okt 29 00:11:56 debian bash[13929]:   code: 'MODULE_NOT_FOUND',
      Okt 29 00:11:56 debian bash[13929]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js' ]
      Okt 29 00:11:56 debian bash[13929]: }
      Okt 29 00:15:00 debian bash[13929]: Cannot find js-controller
      djsirius
      • D djsirius
           Memory: 365.9M
        @djsirius
        sudo systemctl stop iobroker.service
        Dann nochmal
        cd /opt/iobroker
          @djsirius
          Dann nochmal
          cd /opt/iobroker
          djsirius
          iobroker@debian:/opt/iobroker$ sudo systemctl stop iobroker.service
          added 1 package, and changed 1195 packages in 2m
          109 packages are looking for funding
            run `npm fund` for details
          djsirius
          • D djsirius
            @djsirius
            Sollte eigentlich jetzt wieder laufen.
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            sagt?
              @djsirius
              sagt?
              djsirius
              iobroker@debian:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
              ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
              iobroker@debian:/opt/iobroker$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.0
              v16.18.0
              8.19.2
              4.0.23
              iobroker
              iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
              tty
              /opt/iobroker
              OK:1 http://deb.debian.org/debian buster InRelease
              OK:2 http://security.debian.org/debian-security buster/updates InRelease
              OK:3 http://deb.debian.org/debian-security buster/updates InRelease
              OK:4 http://ftp.de.debian.org/debian buster InRelease
              OK:5 http://deb.debian.org/debian buster-updates InRelease
              OK:6 https://deb.nodesource.com/node_16.x buster InRelease
              OK:7 http://deb.debian.org/debian buster-backports InRelease
              OK:8 https://packages.sury.org/php buster InRelease
              OK:9 http://ftp.de.debian.org/debian buster-updates InRelease
              OK:10 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
              Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
              nodejs:
                Installiert:           16.18.0-deb-1nodesource1
                Installationskandidat: 16.18.0-deb-1nodesource1
                Versionstabelle:
               *** 16.18.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
                   10.24.0~dfsg-1~deb10u2 500
                      500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                      500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
                   10.24.0~dfsg-1~deb10u1 500
                      500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                      500 http://deb.debian.org/debian buster/main amd64 Packages
              djsirius
              • D djsirius
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.18.0
                v16.18.0
                8.19.2
                4.0.23
                iobroker
                tty
                /opt/iobroker
                nodejs:
                  Versionstabelle:
                @djsirius
                Passt.
                Läuft das Ding wieder?
                iob status
                D 2 Antworten Letzte Antwort
                  @djsirius
                  Passt.
                  iob status
                  djsirius
                  iob status
                  iobroker@debian:/opt/iobroker$ iob status
                  Objects type: jsonl
                  States  type: jsonl
                  djsirius
                    @djsirius
                    Passt.
                    iob status
                    djsirius
                    @thomas-braun Den Admin kann ich leider immer noch nicht erreichen,
                    Was ist denn da passiert?
                    djsirius
                    • D djsirius
                      @djsirius
                      iob list instances
                        @djsirius
                        iob list instances
                        djsirius
                        iob list instances
                        iobroker@debian:/opt/iobroker$ iob list instances
                        + system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
                        + system.adapter.backitup.0               : backitup              : debian                                   -  enabled
                          system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
                          system.adapter.devices.0                : devices               : debian                                   -  enabled
                        + system.adapter.discovery.0              : discovery             : debian                                   -  enabled
                          system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
                        + system.adapter.enigma2.0                : enigma2               : ioBroker-RasPi                           -  enabled
                          system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
                        + system.adapter.fhem.0                   : fhem                  : debian                                   -  enabled, port: 7072
                          system.adapter.flot.0                   : flot                  : debian                                   -  enabled
                        + system.adapter.history.0                : history               : debian                                   -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
                          system.adapter.ical.0                   : ical                  : debian                                   -  enabled
                          system.adapter.ical.1                   : ical                  : debian                                   -  enabled
                          system.adapter.ical.2                   : ical                  : debian                                   -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
                        + system.adapter.info.0                   : info                  : debian                                   -  enabled
                        + system.adapter.iot.0                    : iot                   : debian                                   -  enabled
                        + system.adapter.javascript.0             : javascript            : debian                                   -  enabled
                        + system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
                        + system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
                        + system.adapter.meross.0                 : meross                : debian                                   -  enabled
                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
                          system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
                        + system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
                        + system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
                        + system.adapter.ping.0                   : ping                  : debian                                   -  enabled
                        + system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
                        + system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi                           -  enabled
                        + system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
                        + system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.simple-api.1             : simple-api            : ioBroker-RasPi                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
                        + system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
                          system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
                        + system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                        + system.adapter.text2command.0           : text2command          : debian                                   -  enabled
                        + system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
                        + system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
                        + system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
                        + system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
                          system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
                          system.adapter.vis.0                    : vis                   : debian                                   -  enabled
                        + system.adapter.web-speedy.0             : web-speedy            : debian                                   -  enabled
                        + system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.zigbee.0                 : zigbee                : ioBroker-RasPi                           -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        djsirius
                        • D djsirius
                          iob list instances
                          + instance is alive
                          @djsirius
                          Multihost-Setup oder was haste mit den hostnames gemacht?
                            @djsirius
                            djsirius
                            @thomas-braun ja hab raspberry als slave laufen
                            Systeminfo lässt sich nicht starten
                            djsirius
                            • D djsirius
                              @djsirius
                              Läuft doch:
                                @djsirius
                                Läuft doch:
                                djsirius
                                systeminfo.0
                                2022-10-29 00:41:32.635	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                systeminfo.0
                                2022-10-29 00:41:32.634	info	terminating
                                systeminfo.0
                                2022-10-29 00:41:32.126	error	Cannot read properties of undefined (reading 'getObjectList')
                                systeminfo.0
                                2022-10-29 00:41:32.126	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8226:26
                                systeminfo.0
                                2022-10-29 00:41:32.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
                                systeminfo.0
                                2022-10-29 00:41:32.124	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                systeminfo.0
                                2022-10-29 00:41:32.123	debug	Adapter systeminfo.0 starting.
                                systeminfo.0
                                2022-10-29 00:41:32.109	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v16.18.0, js-controller: 4.0.23
                                systeminfo.0
                                2022-10-29 00:41:31.896	debug	States connected to redis: 0.0.0.0:9000
                                systeminfo.0
                                2022-10-29 00:41:31.820	debug	States create User PubSub Client
                                systeminfo.0
                                2022-10-29 00:41:31.819	debug	States create System PubSub Client
                                systeminfo.0
                                2022-10-29 00:41:31.799	debug	Redis States: Use Redis connection: 0.0.0.0:9000
                                systeminfo.0
                                2022-10-29 00:41:31.766	debug	Objects connected to redis: 0.0.0.0:9001
                                systeminfo.0
                                2022-10-29 00:41:31.762	debug	Objects client initialize lua scripts
                                systeminfo.0
                                2022-10-29 00:41:31.700	debug	Objects create User PubSub Client
                                systeminfo.0
                                2022-10-29 00:41:31.699	debug	Objects create System PubSub Client
                                systeminfo.0
                                2022-10-29 00:41:31.698	debug	Objects client ready ... initialize now
                                systeminfo.0
                                2022-10-29 00:41:31.544	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
                                djsirius
                                • D djsirius
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  systeminfo.0
                                  @djsirius
                                  Das ist der info-Adapter?
                                  Installier den nochmal.
                                  Ah, der alte systeminfo-Adapter.
                                  Dürfte das sein:
                                  https://github.com/frankjoke/ioBroker.systeminfo/issues/39
                                    @djsirius
                                    Dürfte das sein:
                                    djsirius
                                    @thomas-braun wenn ich den neu installiere bekomme ich jede Menge Warnungen
                                    $ iobroker upgrade systeminfo@0.3.1 --debug
                                    Update systeminfo from @0.3.1 to @0.3.1
                                    Installing iobroker.systeminfo@0.3.1... (System call)
                                    djsirius
                                    • D djsirius
                                      @djsirius
                                      Sind halt nur Hinweise.
                                      Das Issue hast du gelesen?
                                        @djsirius
                                        djsirius
                                        @thomas-braun ja habe ich.
                                        Du meinst das?
                                        in file /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
                                        change line 44 from
                                        this.getObjectList = this.c2p(adapter.objects.getObjectList).bind(adapter.objects);
                                        to
                                        this.getObjectList = this.c2p(adapter.getObjectList).bind(adapter.objects);
                                        djsirius
                                        • D djsirius
                                          Du meinst das?
                                          change line 44 from
                                          to
                                          @djsirius
                                          Ja.
                                          Oder die Version aus dem github angeln, da soll es auch gefixt sein. Warum das noch nicht ordentlich released wurde weiß wohl nur der Maintainer.
