<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IOBroker lässt sich nicht starten und nicht restoren]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">ich bekomme immer diese Meldung, wenn ich versuche meinen iobroker aus einem Backup einzuspielen.</p>
<pre><code>Error: Cannot find module './lib/setup'
Require stack:
- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:985:15)
    at Function.Module._load (node:internal/modules/cjs/loader:833:27)
    at Module.require (node:internal/modules/cjs/loader:1057:19)
    at require (node:internal/modules/cjs/helpers:103:18)
    at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
    at Module._compile (node:internal/modules/cjs/loader:1155:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
    at Module.load (node:internal/modules/cjs/loader:1033:32)
    at Function.Module._load (node:internal/modules/cjs/loader:868:12)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/59437/iobroker-lässt-sich-nicht-starten-und-nicht-restoren</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 21:10:32 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/59437.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 28 Oct 2022 20:16:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 23:19:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Ja.<br />
Oder die Version aus dem github angeln, da soll es auch gefixt sein. Warum das noch nicht ordentlich released wurde weiß wohl nur der Maintainer.</p>
]]></description><link>https://forum.iobroker.net/post/881728</link><guid isPermaLink="true">https://forum.iobroker.net/post/881728</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 23:19:07 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 23:18:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> ja habe ich.</p>
<p dir="auto">Du meinst das?</p>
<pre><code>
in file /opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js
change line 44 from
this.getObjectList = this.c2p(adapter.objects.getObjectList).bind(adapter.objects);
to
this.getObjectList = this.c2p(adapter.getObjectList).bind(adapter.objects);
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881727</link><guid isPermaLink="true">https://forum.iobroker.net/post/881727</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 23:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 23:14:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Sind halt nur Hinweise.<br />
Das Issue hast du gelesen?</p>
]]></description><link>https://forum.iobroker.net/post/881724</link><guid isPermaLink="true">https://forum.iobroker.net/post/881724</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 23:14:01 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 23:12:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> wenn ich den neu installiere bekomme ich jede Menge Warnungen</p>
<pre><code>
$ iobroker upgrade systeminfo@0.3.1 --debug
Update systeminfo from @0.3.1 to @0.3.1
Installing iobroker.systeminfo@0.3.1... (System call)
npm WARN skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.lg-thinq.git
npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
npm WARN deprecated debug@4.1.1: Debug versions &gt;=3.2.0 &lt;3.2.7 || &gt;=4 &lt;4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881723</link><guid isPermaLink="true">https://forum.iobroker.net/post/881723</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 23:12:37 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:54:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Das ist der info-Adapter?<br />
Installier den nochmal.</p>
<p dir="auto">Ah, der alte systeminfo-Adapter.<br />
Dürfte das sein:</p>
<p dir="auto"><a href="https://github.com/frankjoke/ioBroker.systeminfo/issues/39" rel="nofollow ugc">https://github.com/frankjoke/ioBroker.systeminfo/issues/39</a></p>
]]></description><link>https://forum.iobroker.net/post/881720</link><guid isPermaLink="true">https://forum.iobroker.net/post/881720</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:54:38 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:42:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>
systeminfo.0
2022-10-29 00:41:32.635	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
systeminfo.0
2022-10-29 00:41:32.634	info	terminating
systeminfo.0
2022-10-29 00:41:32.126	error	Cannot read properties of undefined (reading 'getObjectList')
systeminfo.0
2022-10-29 00:41:32.126	error	TypeError: Cannot read properties of undefined (reading 'getObjectList') at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55) at Adapter.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37) at Adapter.emit (node:events:513:28) at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8226:26
systeminfo.0
2022-10-29 00:41:32.124	error	unhandled promise rejection: Cannot read properties of undefined (reading 'getObjectList')
systeminfo.0
2022-10-29 00:41:32.124	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
systeminfo.0
2022-10-29 00:41:32.123	debug	Adapter systeminfo.0 starting.
systeminfo.0
2022-10-29 00:41:32.109	info	starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v16.18.0, js-controller: 4.0.23
systeminfo.0
2022-10-29 00:41:31.896	debug	States connected to redis: 0.0.0.0:9000
systeminfo.0
2022-10-29 00:41:31.820	debug	States create User PubSub Client
systeminfo.0
2022-10-29 00:41:31.819	debug	States create System PubSub Client
systeminfo.0
2022-10-29 00:41:31.799	debug	Redis States: Use Redis connection: 0.0.0.0:9000
systeminfo.0
2022-10-29 00:41:31.766	debug	Objects connected to redis: 0.0.0.0:9001
systeminfo.0
2022-10-29 00:41:31.762	debug	Objects client initialize lua scripts
systeminfo.0
2022-10-29 00:41:31.700	debug	Objects create User PubSub Client
systeminfo.0
2022-10-29 00:41:31.699	debug	Objects create System PubSub Client
systeminfo.0
2022-10-29 00:41:31.698	debug	Objects client ready ... initialize now
systeminfo.0
2022-10-29 00:41:31.544	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881715</link><guid isPermaLink="true">https://forum.iobroker.net/post/881715</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:41:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Läuft doch:</p>
<pre><code>+ system.adapter.info.0                   : info                  : debian                                   -  enabled
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881714</link><guid isPermaLink="true">https://forum.iobroker.net/post/881714</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:41:48 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> ja hab raspberry als slave laufen<br />
Systeminfo lässt sich nicht starten</p>
]]></description><link>https://forum.iobroker.net/post/881712</link><guid isPermaLink="true">https://forum.iobroker.net/post/881712</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:40:12 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:38:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Multihost-Setup oder was haste mit den hostnames gemacht?</p>
]]></description><link>https://forum.iobroker.net/post/881711</link><guid isPermaLink="true">https://forum.iobroker.net/post/881711</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:38:48 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:37:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/881709">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<blockquote>
<p dir="auto">iob list instances</p>
</blockquote>
<pre><code>iobroker@debian:/opt/iobroker$ iob list instances
+ system.adapter.admin.0                  : admin                 : debian                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.alexa2.0                 : alexa2                : debian                                   -  enabled
+ system.adapter.backitup.0               : backitup              : debian                                   -  enabled
  system.adapter.daswetter.0              : daswetter             : debian                                   -  enabled
  system.adapter.devices.0                : devices               : debian                                   -  enabled
+ system.adapter.discovery.0              : discovery             : debian                                   -  enabled
  system.adapter.dwd.0                    : dwd                   : debian                                   -  enabled
+ system.adapter.enigma2.0                : enigma2               : ioBroker-RasPi                           -  enabled
  system.adapter.feiertage.0              : feiertage             : debian                                   -  enabled
+ system.adapter.fhem.0                   : fhem                  : debian                                   -  enabled, port: 7072
  system.adapter.flot.0                   : flot                  : debian                                   -  enabled
+ system.adapter.history.0                : history               : debian                                   -  enabled
+ system.adapter.hm-rega.0                : hm-rega               : debian                                   -  enabled
+ system.adapter.hm-rpc.0                 : hm-rpc                : debian                                   -  enabled, port: 0
  system.adapter.ical.0                   : ical                  : debian                                   -  enabled
  system.adapter.ical.1                   : ical                  : debian                                   -  enabled
  system.adapter.ical.2                   : ical                  : debian                                   -  enabled
  system.adapter.icons-mfd-png.0          : icons-mfd-png         : debian                                   -  enabled
  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debian                                   -  enabled
+ system.adapter.iot.0                    : iot                   : debian                                   -  enabled
+ system.adapter.javascript.0             : javascript            : debian                                   -  enabled
+ system.adapter.lg-thinq.0               : lg-thinq              : debian                                   -  enabled
+ system.adapter.linux-control.0          : linux-control         : debian                                   -  enabled
+ system.adapter.meross.0                 : meross                : debian                                   -  enabled
+ system.adapter.mihome-vacuum.0          : mihome-vacuum         : debian                                   -  enabled, port: 54321
  system.adapter.mobile.0                 : mobile                : debian                                   -  enabled
+ system.adapter.modbus.0                 : modbus                : debian                                   -  enabled
+ system.adapter.openligadb.0             : openligadb            : debian                                   -  enabled
+ system.adapter.ping.0                   : ping                  : debian                                   -  enabled
+ system.adapter.pollenflug.0             : pollenflug            : debian                                   -  enabled
+ system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi                           -  enabled
+ system.adapter.scenes.0                 : scenes                : debian                                   -  enabled
+ system.adapter.simple-api.0             : simple-api            : debian                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.simple-api.1             : simple-api            : ioBroker-RasPi                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.socketio.0               : socketio              : debian                                   -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.sql.0                    : sql                   : debian                                   -  enabled, port: 3306
  system.adapter.systeminfo.0             : systeminfo            : debian                                   -  enabled
+ system.adapter.tankerkoenig.0           : tankerkoenig          : debian                                   -  enabled
+ system.adapter.telegram.0               : telegram              : debian                                   -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.terminal.0               : terminal              : debian                                   -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
+ system.adapter.text2command.0           : text2command          : debian                                   -  enabled
+ system.adapter.tr-064.0                 : tr-064                : debian                                   -  enabled
+ system.adapter.trashschedule.0          : trashschedule         : debian                                   -  enabled
+ system.adapter.upnp.0                   : upnp                  : debian                                   -  enabled
+ system.adapter.viessmannapi.0           : viessmannapi          : debian                                   -  enabled
  system.adapter.vis-bars.0               : vis-bars              : debian                                   -  enabled
  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : debian                                   -  enabled
  system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian                                   -  enabled
  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : debian                                   -  enabled
  system.adapter.vis-history.0            : vis-history           : debian                                   -  enabled
  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian                                   -  enabled
  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debian                                   -  enabled
  system.adapter.vis-justgage.0           : vis-justgage          : debian                                   -  enabled
  system.adapter.vis-materialdesign.0     : vis-materialdesign    : debian                                   -  enabled
  system.adapter.vis-metro.0              : vis-metro             : debian                                   -  enabled
  system.adapter.vis-plumb.0              : vis-plumb             : debian                                   -  enabled
  system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian                                   -  enabled
  system.adapter.vis-weather.0            : vis-weather           : debian                                   -  enabled
  system.adapter.vis.0                    : vis                   : debian                                   -  enabled
+ system.adapter.web-speedy.0             : web-speedy            : debian                                   -  enabled
+ system.adapter.web.0                    : web                   : debian                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ system.adapter.zigbee.0                 : zigbee                : ioBroker-RasPi                           -  enabled, port: /dev/ttyUSB0
+ instance is alive
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881710</link><guid isPermaLink="true">https://forum.iobroker.net/post/881710</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<pre><code>iob list instances
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881709</link><guid isPermaLink="true">https://forum.iobroker.net/post/881709</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:36:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Den Admin kann ich leider immer noch nicht erreichen,</p>
<p dir="auto">Was ist denn da passiert?</p>
]]></description><link>https://forum.iobroker.net/post/881708</link><guid isPermaLink="true">https://forum.iobroker.net/post/881708</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:36:08 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:33:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/881705">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<blockquote>
<p dir="auto">iob status</p>
</blockquote>
<pre><code>iobroker@debian:/opt/iobroker$ iob status
Objects type: jsonl
States  type: jsonl
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881706</link><guid isPermaLink="true">https://forum.iobroker.net/post/881706</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:32:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Passt.<br />
Läuft das Ding wieder?</p>
<pre><code>iob status
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881705</link><guid isPermaLink="true">https://forum.iobroker.net/post/881705</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:32:39 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/881700">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<blockquote>
<p dir="auto">uname -m &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs</p>
</blockquote>
<pre><code>iobroker@debian:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs
ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
iobroker@debian:/opt/iobroker$ uname -m &amp;&amp; type -P nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
x86_64
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.18.0
v16.18.0
8.19.2
4.0.23
iobroker
iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner
tty
/opt/iobroker
OK:1 http://deb.debian.org/debian buster InRelease
OK:2 http://security.debian.org/debian-security buster/updates InRelease
OK:3 http://deb.debian.org/debian-security buster/updates InRelease
OK:4 http://ftp.de.debian.org/debian buster InRelease
OK:5 http://deb.debian.org/debian buster-updates InRelease
OK:6 https://deb.nodesource.com/node_16.x buster InRelease
OK:7 http://deb.debian.org/debian buster-backports InRelease
OK:8 https://packages.sury.org/php buster InRelease
OK:9 http://ftp.de.debian.org/debian buster-updates InRelease
OK:10 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
nodejs:
  Installiert:           16.18.0-deb-1nodesource1
  Installationskandidat: 16.18.0-deb-1nodesource1
  Versionstabelle:
 *** 16.18.0-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u2 500
        500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
        500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
     10.24.0~dfsg-1~deb10u1 500
        500 http://ftp.de.debian.org/debian buster/main amd64 Packages
        500 http://deb.debian.org/debian buster/main amd64 Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881703</link><guid isPermaLink="true">https://forum.iobroker.net/post/881703</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:28:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto">Sollte eigentlich jetzt wieder laufen.</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs
</code></pre>
<p dir="auto">sagt?</p>
]]></description><link>https://forum.iobroker.net/post/881700</link><guid isPermaLink="true">https://forum.iobroker.net/post/881700</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:28:23 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:25:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/881694">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<blockquote>
<p dir="auto">sudo -H -u iobroker npm install iobroker.js-controller</p>
</blockquote>
<pre><code>iobroker@debian:/opt/iobroker$ sudo systemctl stop iobroker.service
iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
added 1 package, and changed 1195 packages in 2m
109 packages are looking for funding
  run `npm fund` for details
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881698</link><guid isPermaLink="true">https://forum.iobroker.net/post/881698</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:25:17 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:18:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<pre><code>sudo systemctl stop iobroker.service
</code></pre>
<p dir="auto">Dann nochmal</p>
<pre><code>cd /opt/iobroker
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881694</link><guid isPermaLink="true">https://forum.iobroker.net/post/881694</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:18:59 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:17:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> said in <a href="/post/881691">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<blockquote>
<p dir="auto">systemctl status iobroker.service</p>
</blockquote>
<pre><code>iobroker@debian:/opt/iobroker$ systemctl status iobroker.service
● iobroker.service - ioBroker Server
   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
   Active: active (running) since Sat 2022-10-29 00:09:54 CEST; 6min ago
     Docs: http://iobroker.net
 Main PID: 13929 (iobroker.js-con)
    Tasks: 22 (limit: 4915)
   Memory: 365.9M
   CGroup: /system.slice/iobroker.service
           ├─13929 iobroker.js-controller
           └─14061 io.history.0
Okt 29 00:11:56 debian bash[13929]:     at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js:9:15)
Okt 29 00:11:56 debian bash[13929]:     at Module._compile (node:internal/modules/cjs/loader:1155:14)
Okt 29 00:11:56 debian bash[13929]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
Okt 29 00:11:56 debian bash[13929]:     at Module.load (node:internal/modules/cjs/loader:1033:32)
Okt 29 00:11:56 debian bash[13929]:     at Function.Module._load (node:internal/modules/cjs/loader:868:12)
Okt 29 00:11:56 debian bash[13929]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
Okt 29 00:11:56 debian bash[13929]:   code: 'MODULE_NOT_FOUND',
Okt 29 00:11:56 debian bash[13929]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js' ]
Okt 29 00:11:56 debian bash[13929]: }
Okt 29 00:15:00 debian bash[13929]: Cannot find js-controller
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881692</link><guid isPermaLink="true">https://forum.iobroker.net/post/881692</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:17:11 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:16:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a> sagte in <a href="/post/881690">IOBroker lässt sich nicht starten und nicht restoren</a>:</p>
<pre><code>systemctl status iobroker.service
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881691</link><guid isPermaLink="true">https://forum.iobroker.net/post/881691</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:10:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>iobroker@debian:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /opt/iobroker/node_modules/ajv
npm ERR! dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -&gt; '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_02_41_647Z-debug-0.log
iobroker@debian:/opt/iobroker$ ^C
iobroker@debian:/opt/iobroker$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
npm ERR! code 24
npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
npm ERR! command failed
npm ERR! command sh -c -- node iobroker.js setup first
npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
npm ERR!     /home/iobroker/.npm/_logs/2022-10-28T22_08_22_676Z-debug-0.log
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881690</link><guid isPermaLink="true">https://forum.iobroker.net/post/881690</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:10:56 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:10:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/881689</link><guid isPermaLink="true">https://forum.iobroker.net/post/881689</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:10:06 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:09:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Hab ich ausgeführt.</p>
]]></description><link>https://forum.iobroker.net/post/881688</link><guid isPermaLink="true">https://forum.iobroker.net/post/881688</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to IOBroker lässt sich nicht starten und nicht restoren on Fri, 28 Oct 2022 22:06:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a></p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8">https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8</a></p>
]]></description><link>https://forum.iobroker.net/post/881685</link><guid isPermaLink="true">https://forum.iobroker.net/post/881685</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 28 Oct 2022 22:06:37 GMT</pubDate></item></channel></rss>
