4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • Damrak2022D Damrak2022
    @mickym Ja, das ist klar. Das heißt also ich brauche den Datenpunkt nur in eine iobroker in Node zu setzen. Aber mit welche Node verbindest Du das, damit Dir auch eine Karte angezeigt wird?
    mickymM Online
    mickymM Online
    mickym
    #1231
    @damrak2022 Hier mein Flow aus meiner Wetterseite:
           "id": "2b9b2f47.850d6",
           "type": "ui_template",
           "z": "c36e56fc.dc8418",
           "group": "37fea952.872756",
           "name": "DWD Karte",
           "order": 6,
           "width": "6",
           "height": 8,
           "format": "",
           "storeOutMessages": true,
           "fwdInMessages": true,
           "resendOnRefresh": true,
           "templateScope": "local",
           "x": 4110,
           "y": 2620,
           "wires": [
           "id": "c30d69b6.d65ca8",
           "type": "ioBroker in",
           "name": "Link to chart",
           "topic": "dwd.0.warning.map",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "true",
           "x": 3450,
           "y": 2640,
           "wires": [
                   "a93d4f80.63b6f"
           "id": "2c4cf151.880e9e",
           "type": "template",
           "name": "",
           "field": "template",
           "fieldType": "msg",
           "format": "handlebars",
           "syntax": "mustache",
           "template": "<img src={{payload}} alt=\"n/a\" >",
           "output": "str",
           "x": 3920,
           "y": 2660,
           "wires": [
                   "2b9b2f47.850d6"
           "id": "4577f07f.ad0a9",
           "type": "change",
           "name": "clear map",
           "rules": [
                   "t": "set",
                   "p": "template",
                   "pt": "msg",
                   "to": "",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 3920,
           "y": 2600,
           "wires": [
                   "2b9b2f47.850d6"
           "id": "a93d4f80.63b6f",
           "type": "switch",
           "name": "",
           "property": "payload",
           "propertyType": "msg",
           "rules": [
                   "t": "empty"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 2,
           "x": 3740,
           "y": 2640,
           "wires": [
                   "4577f07f.ad0a9"
                   "2c4cf151.880e9e"
           "id": "37fea952.872756",
           "type": "ui_group",
           "name": "Aktuell",
           "tab": "b971cfe1.624ad",
           "order": 1,
           "disp": true,
           "width": "33",
           "collapse": false
           "id": "b971cfe1.624ad",
           "type": "ui_tab",
           "name": "Wetter",
           "icon": "dashboard",
           "order": 2,
           "disabled": false,
           "hidden": false
    • mickymM mickym
             "order": 6,
             "width": "6",
             "height": 8,
             "format": "",
             "x": 4110,
             "y": 2620,
             "wires": [
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 3450,
             "y": 2640,
             "wires": [
                     "a93d4f80.63b6f"
             "type": "template",
             "name": "",
             "fieldType": "msg",
             "output": "str",
             "x": 3920,
             "y": 2660,
             "wires": [
                     "2b9b2f47.850d6"
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "template",
                     "pt": "msg",
                     "to": "",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 3920,
             "y": 2600,
             "wires": [
                     "2b9b2f47.850d6"
             "type": "switch",
             "name": "",
             "rules": [
                     "t": "empty"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 2,
             "x": 3740,
             "y": 2640,
             "wires": [
                     "4577f07f.ad0a9"
                     "2c4cf151.880e9e"
             "type": "ui_group",
             "name": "Aktuell",
             "order": 1,
             "disp": true,
             "width": "33",
             "collapse": false
             "type": "ui_tab",
             "name": "Wetter",
             "order": 2,
             "disabled": false,
             "hidden": false
      Damrak2022D Offline
      Damrak2022D Offline
      Damrak2022
      #1232
      @mickym Danke, die erste Node habe mir fast gedacht. Wenn ich irgendwas mit einer URL mache muss ich eine Get Node nehmen.
      Mit besten Grüßen
      Andy
        mickymM Online
        mickymM Online
        mickym
        #1233
        @damrak2022 Wie kommst Du denn da drauf? Was willst Du denn mit der URL machen. Das ist eine URL zu einem Bild.
        Du kannst auch einfach nach der iobroker-In Node die template Node mit der URL bestücken.
        <img src={{msg.payload}} alt="Keine Karte verfügbar">
        • mickymM mickym
          Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #1234
          @mickym Diese Beschriftung bei Dir Link zu Url hat mich irgendwie dazu verleitet zu denken es wäre eine Get Node. Also Kommando zurück und meinen Kommentar vergessen
          Mit besten Grüßen
          Andy
            mickymM Online
            mickymM Online
            mickym
            #1235
            @damrak2022 Mit der template Node - kannst Du normalen HTML Code in Dein Dashboard einbinden.
            Hier mal die W3Schools Seite zum Einbinden von Bildern in eine Webseite:
            https://www.w3schools.com/html/html_images.asp
            Wenn Du zum Beispiel aus diesen Beispielen das Bild in dein Dashboard einbinden willst, wie das aussieht - kannst du einfach die URL in die payload einspeisen.
            Wenn Du im Dashboard die Template Node genügend hoch machst wird das Bild dann automatisch richtig skaliert:
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #1236
              @mickym Danke, bei W3 schools arbeite ich mich langsam voran.
              Mir ist gerade aufgefallen das mir bei unserem ersten Flow (Geofency) keine Orte mehr mit den farbigen Markierungen angezeigt werden. Auf den ersten Blick sieht aber im Flow alles korrekt aus. Aber das schaue ich mir heute Abend an.
              Mit besten Grüßen
              Andy
                mickymM Online
                mickymM Online
                mickym
                #1237
                Wahrscheinlich hast Du einfach den Layer weggeklickt. (Ich glaub wir haben den damals Andys Favoriten oder so ähnlich genannt). Wenn ein Flow mal läuft, dann ändert sich der nicht, ausser Du änderst die Quellen.
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #1238
                  @mickym Blöde Frage, wo finde ich den?
                  Mit besten Grüßen
                  Andy
                    mickymM Online
                    mickymM Online
                    mickym
                    #1239
                    @damrak2022 auf der Karte in dem Menü in den Du die Kartentypen auswählen kannst
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #1240
                      @mickym Ja, hatte ich auch so in Erinnerung, aber das ist er nicht mehr.
                      Mit besten Grüßen
                      Andy
                        mickymM Online
                        mickymM Online
                        mickym
                        #1241
                        @damrak2022 Tja dann hast Du entweder was verändert oder musst refreshen.
                        Da draufklicken:
                        und dann sollten die layer dort auftauchen
                        bei mir taucht das aber auch nicht immer auf. Vielleicht hat sich da auch was mit dem Update getan. Weiß nicht.
                        In Deiner letzten Change Node vor der WorldMap Node hast Du den layer definiert:
                           "name":name,
                           "lat":lat,
                           "lon":lon,
                           "layer":"Andy's Favoriten",
                           "icon":"circle",
                           "iconColor":color,
                           "popup": table
                        Du kannst auch mal versuchen den layer dort weg zu lassen.
                        • mickymM mickym
                          Da draufklicken:
                             "name":name,
                             "lat":lat,
                             "lon":lon,
                             "icon":"circle",
                             "iconColor":color,
                             "popup": table
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #1242
                          @mickym Das ist auch noch da, wird aber nicht angezeigt. Habe ihn auch mal von der Worldmap getrennt, deployed und wieder verbunden und deployed. Keine Chance, er taucht auf der Karte nicht auf.
                          Bildschirmfoto 2022-10-24 um 19.54.23.png Bildschirmfoto 2022-10-24 um 19.53.12.png
                          Mit besten Grüßen
                          Andy
                            mickymM Online
                            mickymM Online
                            mickym
                            #1243
                            @damrak2022 Hast Du die Node aktualisiert?
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #1244
                              @mickym Wie aktualisiert man eine Node? Ich habe den Flow neugestartet.
                              Mit besten Grüßen
                              Andy
                                mickymM Online
                                mickymM Online
                                mickym
                                #1245
                                Im Palettenmanager schauen, ob Aktualisierungen vorhanden sind.
                                • mickymM mickym
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #1246
                                  @mickym Bei der Worlmap gibt es keine Aktualisierung. Das ist die installierte Version:
                                  Mit besten Grüßen
                                  Andy
                                    mickymM Online
                                    mickymM Online
                                    mickym
                                    #1247
                                    @damrak2022 Ja ist die aktuelle Version. Hast ja auch nichts geändert. Mach halt hinter die Change NOde mal eine Debug NOde und schau ob was rauskommt. - Aber wie gesagt schau erst mal ob der layer angehakt ist. Taucht denn der layer in dem Kartenmenü auf?
                                    • mickymM mickym
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #1248
                                      @mickym Also in der Karte schaute so so aus:
                                      Warte mal, der meldet mir einen unauthorisierten Zugriff
                                      Das bezieht sich auf die Influx Node
                                      Die sieht so aus:
                                      Mit besten Grüßen
                                      Andy
                                        Die sieht so aus:
                                        mickymM Online
                                        mickymM Online
                                        mickym
                                        #1249
                                        @damrak2022 Na vielleicht bekommst keine Daten mehr aus der Influx DB - weil Du irgendwas dort geändert hast. Token oder keine Ahnung was.
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #1250
                                          @mickym Ja, warte mal, ich schaue mir das an und gebe Dir danach Bescheid
                                          Mit besten Grüßen
                                          Andy
