  4. coronavirus-statistics v0.8.7 | MELDUNGEN
    5.7k
8 Beiträge 5 Kommentatoren 300 Aufrufe 3 Beobachtet
  • I Offline
    I Offline
    ioBrokerMike
    schrieb am zuletzt editiert von ioBrokerMike
    |Hardwaresystem:| Pi3|
    |Arbeitsspeicher:| 120GB |
    |Festplattenart:| SSD |
    |Betriebssystem:| 10 (buster) |
    |Nodejs-Version:| 16.18.0 |
    |NPM-Version:| 8.19.2 |
    Moin
    Bekomme folgende Meldungen :
    coronavirus-statistics.0
    2022-10-23 16:51:03.347 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:51:03.343 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:50:03.300 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:50:03.296 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:49:03.376 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:49:03.371 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:48:03.422 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:48:03.417 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:47:03.282 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:47:03.278 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:46:03.251 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:46:03.246 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:45:03.364 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:45:03.359 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    2022-10-23 16:44:03.372 warn This object will not be created in future versions. Please report this to the developer.
    2022-10-23 16:44:03.368 warn Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    Mfg
    IOBrokerMike
    Achtung ! Sehkraft 25% | 60% , kein scherz
    Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
    • I ioBrokerMike
      Moin
      crunchipC Abwesend
      crunchipC Abwesend
      @iobrokermike welche Version?
      I 1 Antwort Letzte Antwort
        I Offline
        I Offline
        ioBrokerMike
        @crunchip v0.8.7
        Steht in der Überschrift. ;-)
        Mfg
        IOBrokerMike
        • I ioBrokerMike
          @crunchip v0.8.7
          crunchipC Abwesend
          crunchipC Abwesend
          @iobrokermike überlesen
          der DP sieht bei mir wie folgt aus
          stell das loglevel auf Error, dann sind die Einträge im Log ausgeblendet
            @crunchip sagte in coronavirus-statistics v0.8.7 | MELDUNGEN:
            dann stimmt ja was im log steht.
            @iobrokermike
            dann mach das mal
            @iobrokermike sagte in coronavirus-statistics v0.8.7 | MELDUNGEN:
              @iobrokermike
              dann mach das mal
              I Offline
              I Offline
              ioBrokerMike
              @homoran sagte in coronavirus-statistics v0.8.7 | MELDUNGEN:
              @iobrokermike
              dann mach das mal
              Hier schaue ich noch nicht ganz durch.
              Wie erreiche ich den developer (Modulautor) ? :-(
              Mfg
              IOBrokerMike
              Horst BöttcherH Thomas BraunT 2 Antworten Letzte Antwort
              • I ioBrokerMike
                @iobrokermike
                dann mach das mal
                Horst BöttcherH Offline
                Horst Böttcher
                schrieb am zuletzt editiert von Horst Böttcher
                @iobrokermike z.b hier https://github.com/DrozmotiX/ioBroker.coronavirus-statistics
                ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                • I ioBrokerMike
                  @iobrokermike
                  dann mach das mal
                  @iobrokermike
                  Da bist du zu langsam:
                  https://github.com/DrozmotiX/ioBroker.coronavirus-statistics/issues/350
