lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • M Matze_HH
    @armilar
    Wie peinlich :) Hoffe das bleibt jetzt bei der einen Peinlichkeit. Vielen Dank.
    Jetzt habe ich deutlich weniger Warnungen... Aber auch da fummel ich mich zu tode...
    Magst du dir das bitte nochmal anschauen?
    23.10.2022, 12:45:00.042	[warn ]: javascript.0 (2143)     at SendToPanel (script.js.NSPanel.Panel1:1667:13)
    23.10.2022, 12:45:00.042	[warn ]: javascript.0 (2143)     at SendTime (script.js.NSPanel.Panel1:1824:9)
    23.10.2022, 12:45:00.042	[warn ]: javascript.0 (2143)     at Object.<anonymous> (script.js.NSPanel.Panel1:846:9)
    23.10.2022, 12:45:21.368	[info ]: javascript.0 (2143) Stop script script.js.NSPanel.Panel1
    23.10.2022, 12:45:21.447	[info ]: javascript.0 (2143) script.js.NSPanel.Panel1: compiling TypeScript source...
    23.10.2022, 12:45:22.357	[info ]: javascript.0 (2143) script.js.NSPanel.Panel1: source code did not change, using cached compilation result...
    23.10.2022, 12:45:22.443	[warn ]: javascript.0 (2143)     at SendToPanel (script.js.NSPanel.Panel1:1667:13)
    23.10.2022, 12:45:22.443	[warn ]: javascript.0 (2143)     at ScreensaverDimmode (script.js.NSPanel.Panel1:608:17)
    23.10.2022, 12:45:22.443	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:719:21
    23.10.2022, 12:45:22.444	[warn ]: javascript.0 (2143)     at step (script.js.NSPanel.Panel1:33:23)
    23.10.2022, 12:45:22.444	[warn ]: javascript.0 (2143)     at Object.next (script.js.NSPanel.Panel1:14:53)
    23.10.2022, 12:45:22.444	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:8:71
    23.10.2022, 12:45:22.444	[warn ]: javascript.0 (2143)     at __awaiter (script.js.NSPanel.Panel1:4:12)
    23.10.2022, 12:45:22.445	[warn ]: javascript.0 (2143)     at InitDimmode (script.js.NSPanel.Panel1:660:12)
    23.10.2022, 12:45:22.445	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:730:1
    23.10.2022, 12:45:22.476	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:935:1
    23.10.2022, 12:45:22.478	[warn ]: javascript.0 (2143)     at get_current_tasmota_ip_address (script.js.NSPanel.Panel1:1214:34)
    23.10.2022, 12:45:22.478	[warn ]: javascript.0 (2143)     at get_tasmota_status0 (script.js.NSPanel.Panel1:1304:35)
    23.10.2022, 12:45:22.479	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:936:1
    23.10.2022, 12:45:22.479	[warn ]: javascript.0 (2143) script.js.NSPanel.Panel1: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    23.10.2022, 12:45:22.482	[info ]: javascript.0 (2143) script.js.NSPanel.Panel1: registered 12 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
    23.10.2022, 12:45:22.548	[warn ]: javascript.0 (2143)     at get_current_tasmota_ip_address (script.js.NSPanel.Panel1:1214:34)
    23.10.2022, 12:45:22.549	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:1193:99
    23.10.2022, 12:45:22.549	[warn ]: javascript.0 (2143)     at step (script.js.NSPanel.Panel1:33:23)
    23.10.2022, 12:45:22.549	[warn ]: javascript.0 (2143)     at Object.next (script.js.NSPanel.Panel1:14:53)
    23.10.2022, 12:45:22.549	[warn ]: javascript.0 (2143)     at fulfilled (script.js.NSPanel.Panel1:5:58)
    23.10.2022, 12:45:22.550	[warn ]: javascript.0 (2143) script.js.NSPanel.Panel1: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    23.10.2022, 12:45:22.616	[warn ]: javascript.0 (2143)     at get_current_tasmota_ip_address (script.js.NSPanel.Panel1:1214:34)
    23.10.2022, 12:45:22.616	[warn ]: javascript.0 (2143)     at get_current_berry_driver_version (script.js.NSPanel.Panel1:1268:35)
    23.10.2022, 12:45:22.616	[warn ]: javascript.0 (2143)     at script.js.NSPanel.Panel1:1197:21
    23.10.2022, 12:45:22.616	[warn ]: javascript.0 (2143)     at step (script.js.NSPanel.Panel1:33:23)
    23.10.2022, 12:45:22.617	[warn ]: javascript.0 (2143)     at Object.next (script.js.NSPanel.Panel1:14:53)
    23.10.2022, 12:45:22.617	[warn ]: javascript.0 (2143)     at fulfilled (script.js.NSPanel.Panel1:5:58)
    23.10.2022, 12:45:22.618	[warn ]: javascript.0 (2143) script.js.NSPanel.Panel1: function get_current_tasmota_ip_address: Cannot read properties of null (reading 'Info2')
    23.10.2022, 12:45:22.645	[warn ]: javascript.0 (2143) script.js.NSPanel.Panel1: get_current_berry_driver_version: Unexpected token u in JSON at position 0
    23.10.2022, 12:45:22.755	[warn ]: javascript.0 (2143) script.js.NSPanel.Panel1: get_tasmota_status0Unexpected token u in JSON at position 0
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #391
    @matze_hh
    Wird schon etwas angezeigt? Buchstabendreher können vorkommen ;-)
    Zeige nochmal deine aktuelle Config und einen Blick auf mqtt.1.
    So wie ich das aktuell sehe, wird der Empfangskanal nicht korrekt ausgewertet
    Ein Blick auf stat und tele sollte dabei zeigen, ob STATUS0 und INFO2 vorhanden sind.
    Info2 und Status0 wird eigentlich mit Start des Panels versendet. Ansonsten kurz rebooten
    EDIT:
    die Meldungen: "Unexpected token u in JSON at position 0" dürften die einzigen bleiben die für einen Zeitraum noch erhalten bleiben. Durch die vielen Script-Starts ist das Abfragelimit bei github überschritten. Die Daten dürften aber bereits in 0_userdata.0 vorhanden sein.
    • ArmilarA Armilar
      @matze_hh
      EDIT:
      Matze_HH
      #392
      @armilar
      Vielen Dank für deinen Einsatz :)
      Das Display zeigt nur "Waiting for Content"
      • M Matze_HH
        @armilar
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #393
        @matze_hh
        hatte ich mir schon gedacht:
        setzte mal tele hinter das NSPanel:
        mqtt.1.NSPanel.NSPanel.tele.RESULT
        Ich wette dann funktioniert es
        • ArmilarA Armilar
          @matze_hh
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #394
          @armilar
          In dem Zusammenhang solltest du die beiden Schalter ein paar Zeilen tiefer ebenfalls auf mqtt.1. setzen:
          mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.1.NSPanel.NSPanel.stat.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: Off  },
          mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.1.NSPanel.NSPanel.stat.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: Off  },
          • ArmilarA Armilar
            @armilar
            Matze_HH
            #395
            @armilar Es funktioniert :) Ich habe keinen Plan, warum ich den Pfad drehen sollte...aber das Ergebnis zählt.
            Vielen vielen Dank!!!
            Jetzt sicher ich die Config und fange an zu spielen :)
            • M Matze_HH
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #396
              @matze_hh
              Ja cool. War dich gar nicht so schwer... 👍
              Das drehen der Config dürfte jetzt der tatsächliche Pfad im mqtt.1. sein, denn der hat sich mit dem Versetzen des %prefix% im FullTopic ja ebenfalls geändert.
              Viel Spaß damit...
              Die Wiki kennst du schon?
              • ArmilarA Armilar
                @matze_hh
                Viel Spaß damit...
                Matze_HH
                #397
                @armilar War fast nicht schwer. :) =)
                Ja die Wiki lese ich gerade. Hänge, ja schon wieder am nächsten "Problemchen"
                Vielen Dank!!!
                • M Matze_HH
                  Vielen Dank!!!
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #398
                  @matze_hh
                  Na evtl kann ich ja gleich helfen 😂
                  Erzähle mal...
                  • ArmilarA Armilar
                    @matze_hh
                    Erzähle mal...
                    Matze_HH
                    #399
                    @armilar Ich habe ein kleines Script welches bei Tastendruck auf dem NSPanel, Räume schaltet. Soweit so gut...aber ich kann selbigen Raum auch per Alexa schalten... dann schaltet er aber den Status nicht auf dem NSPanel. Ich muss 2 mal drücken um den Status zu ändern.
                    Einen "True" / "false" Status hätte ich hinbekommen, aber er ändern das OFF zwar im Iobroker aber sendet es nicht an das Panel...
                    Denkfehler?
                    • M Matze_HH
                      Denkfehler?
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #400
                      @matze_hh
                      Brauche etwas mehr Kontent
                      • Hardwarebutton oder Alias Taste?
                      • ArmilarA Armilar
                        @matze_hh
                        Matze_HH
                        #401
                        @armilar Hardware...bzw. das Relais ist nicht angeschlossen. Das Relais zieht an aber ohne physischen Anschluss an einen Verbraucher.
                        • M Matze_HH
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #402
                          @matze_hh
                          SetOption114 1
                          entkoppelt das Relay vom Button
                          Die Hardwarebuttons sind schon mal vom TS-Script völlig losgelöst. Das sieht nur auf die Zustände des POWER1 true/false oder POWER2 true/false
                          Also wenn du einen Zustand (Datenpunkt wo auch immer) via Alexa schaltest, dann sollte sich auch der POWER1 oder POWER2 ändern. Das müsste das Raum-Script dem mqtt.1. dann mitteilen (Synchronisieren)
                          Falls du aber einen Taster möchtest, so ist das auch möglich:
                          https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#14--switchmode
                          Dann könntest du auf Button-Events zugreifen und mit jeder Zustandsänderung auch auf den anderen Datenpunkt toggeln.
                          EDIT:
                          Die beiden Zustandsvisualisierungen im oberen Teil des Screensavers können auch auf andere Datenpunkte zeigen.
                          https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#relais-status-icons
                          • ArmilarA Armilar
                            @matze_hh
                            SetOption114 1
                            EDIT:
                            Matze_HH
                            #403
                            @armilar said in SONOFF NSPanel mit Lovelace UI:
                            Genau das Synchronisieren klappt nicht.
                            "Steuere Power1 mit OFF" das macht er nicht.
                            • M Matze_HH
                              ArmilarA Offline
                              ArmilarA Offline
                              Armilar
                              #404
                              @matze_hh
                              Zeige mal wie du das machst...
                              • ArmilarA Armilar
                                @matze_hh
                                Matze_HH
                                #405
                                @armilar
                                  <block type="on_ext" id="zbF=]``Z_f9BOK=6aGaF" x="263" y="188">
                                    <value name="OID0">
                                      <shadow type="field_oid" id="Y`@2ogLO,hQ--mKc!7/w">
                                        <field name="oid">mqtt.1.NSPanel.NSPanel.stat.POWER1</field>
                                      </shadow>
                                    </value>
                                    <statement name="STATEMENT">
                                      <block type="comment" id="VC@YvSLSTxFD/JGBfJ(a">
                                        <field name="COMMENT">Schlafzimmer</field>
                                        <next>
                                          <block type="controls_if" id="kX=JSOY+e1%z[=El_ila">
                                            <value name="IF0">
                                              <block type="logic_compare" id=".b~Cq~ub?4zv_#?^]Ikx">
                                                <field name="OP">EQ</field>
                                                <value name="A">
                                                  <block type="get_value" id="R-6+7KxwiOqso1W0rF}r">
                                                    <field name="OID">mqtt.1.NSPanel.NSPanel.stat.POWER1</field>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="text" id="{whC:BULzG1eMBk]Z3;m">
                                                    <field name="TEXT">OFF</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <statement name="DO0">
                                              <block type="control" id="QCXHHwi,m1g!lR]/XB`N">
                                                <field name="OID">alexa2.0.Smart-Home-Devices.728d22e0-c81a-4411-a199-43e6aa18b0fa.powerState</field>
                                                <value name="VALUE">
                                                  <block type="logic_boolean" id="ytT#en`B9EAK/F+@y=B}">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="bqlcl*a}s=;3Md!:cd+2">
                                                    <field name="OID">zigbee.0.54ef4410003a2c30.position</field>
                                                      <block type="math_number" id="3S|7QecK33R*dX9$Gj#g">
                                                        <field name="NUM">100</field>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                            <value name="IF1">
                                              <block type="logic_compare" id=")ks*+,-tMt3(VA]zf9vF">
                                                <value name="A">
                                                  <block type="get_value" id="^0lk+IS6!rsu2k]+xa?Y">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <block type="text" id="2e:vwnfBN7P=4$9s6JV]">
                                                    <field name="TEXT">ON</field>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <statement name="DO1">
                                              <block type="control" id="qk#$`eoUcW3kjOT`O4|q">
                                                  <block type="logic_boolean" id=".?ldBl7#EPpPvGyvV:?|">
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="control" id="ds=%@~E@/;Jb++akQL5B">
                                                      <block type="math_number" id="+hTgj{R|}Szw4S+9r9G4">
                                                        <field name="NUM">0</field>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                    <next>
                                      <block type="on_ext" id="FuF62q)9`,AeSw-w}8I2">
                                        <value name="OID0">
                                          <shadow type="field_oid" id="M9:DOr]Roc.)3pIAFu_g">
                                            <field name="oid">mqtt.1.NSPanel.NSPanel.stat.POWER2</field>
                                          </shadow>
                                        </value>
                                          <block type="comment" id="Xk2pP6%V=Ux]NZA{2cmj">
                                            <field name="COMMENT">Wohnzimmer</field>
                                            <next>
                                              <block type="controls_if" id="BaZO=vzXt-[?G#t1`BQ}">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="pcV8Z7{6g?J:KmMw*Y.z">
                                                    <value name="A">
                                                      <block type="get_value" id=";;S!ZKU1%UBCU|^#67-N">
                                                        <field name="OID">mqtt.1.NSPanel.NSPanel.stat.POWER2</field>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="text" id="`8dFxM/rAI8dI6P?}a{[">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="@qkkt,*HhqkoFV2fHp9,">
                                                    <field name="OID">alexa2.0.Smart-Home-Devices.fc61908a-f44b-4fd1-a9ee-7117b46e62e7.powerState</field>
                                                      <block type="logic_boolean" id="/=[wWpgJXm3`/Ew?TQJn">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="control" id="iu$nzLXd5{.Pq6GhHa%Q">
                                                        <field name="OID">zigbee.0.bc33acfffe5a971f.brightness</field>
                                                          <block type="math_number" id="3rP4,{O:$).NhlYFneVV">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                  <block type="logic_compare" id="HPoT/Nd~HqK53J$.P%qN">
                                                    <value name="A">
                                                      <block type="get_value" id="K?8{pZy:%6RM~:E.8AOG">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="text" id="{8InX+?F#%@k(Bw;V;u+">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="8NsAJ6fZCzq.@%v#,*nu">
                                                      <block type="logic_boolean" id="~k3Fp^K*[HSVh?f5,c__">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </next>
                                          </block>
                                        </statement>
                                        <next>
                                          <block type="on_ext" id="Qw`J?+L=v/I2.#!%^3kq">
                                            <value name="OID0">
                                              <shadow type="field_oid" id="LxBy_B5JHPzB7URGG!-H">
                                                <field name="oid">alexa2.0.Smart-Home-Devices.728d22e0-c81a-4411-a199-43e6aa18b0fa.powerState</field>
                                              </shadow>
                                            </value>
                                              <block type="controls_if" id="JjXs[PZXAreo}K]~Q13d">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="{YlcEmWpuu[+^O!ShV;Y">
                                                    <value name="A">
                                                      <block type="get_value" id="%G~sYz!O7gPufPpLS~Ap">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="logic_boolean" id="d@+W^TI4)v4qcA]l#Vnf">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="lYu{T({c1x#uv3uO]k]k">
                                                      <block type="text" id="?n`d/K;of?o;VSaRh!AX">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                                <value name="IF1">
                                                  <block type="logic_compare" id="n_Jk9T[;XfT-!05Wf+FA">
                                                    <value name="A">
                                                      <block type="get_value" id="hTM)H^TCGDM7XC`_YIGK">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="logic_boolean" id="bh+v[OPZJFgW{Ux{R4?[">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="control" id="=9w+#1kwV.r2ef=]q9.!">
                                                      <block type="text" id="*wd(g(]Ua^$tXkLGgW[$">
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </xml>
                                • M Matze_HH
                                  @armilar
                                      <value name="OID0">
                                        </shadow>
                                      </value>
                                          <next>
                                              <value name="IF0">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                              <value name="IF1">
                                                  <value name="A">
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                      <next>
                                          <value name="OID0">
                                            </shadow>
                                          </value>
                                              <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                      <next>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </next>
                                            </block>
                                          </statement>
                                          <next>
                                              <value name="OID0">
                                                </shadow>
                                              </value>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <value name="IF1">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #406
                                  @matze_hh
                                  Ändere mal den mqtt - Datenpunkt von stat auf cmnd beim schreiben
                                  • G Offline
                                    Gre4t0ne
                                    #407
                                    Bei mir ist auf der Screensaver Seite beim 1. großen Weather-Icon (das hier am Bsp.Foto das Mondicon hat) nur ein Ausrufezeichen!?
                                    Die rest. kleineren Wochentage, da wird ein Icon angezeigt...
                                    • G Gre4t0ne
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #408
                                      @gre4t0ne
                                      Geh mal in den Wetter-Alias und zeig mal den Wert
                                      Der ist für das Icon zuständig
                                      G 1 Antwort Letzte Antwort
                                        Tom_W
                                        schrieb am zuletzt editiert von Tom_W
                                        #409
                                        erstmal vielen Dank für diese tolle Arbeit, das ist echt irre.
                                        Trotzdem bleiben bei mir selbst nach langem lesen und testen 2 Fragen:
                                        Ich habe alles nach Anleitung installiert und erstemal alle Beispielseiten und Pages im Array auskommentiert. Trotzdem zeigt mir das Skript beim Starten und jedem Übertragen Warnungen an. Ist dies normal, kann ich das irgnorieren oder habe ich etwas falsch gemacht?
                                        Zweite Frage: Ich würde das Panel gerne anstatt meines Raumthermostates einbauen (da sonst nirgends Platz)
                                        Ich habe geschafft, dass ich eine Seite Thermo erstelle und dort kann ich auch Temperatur einstellen (welche ich in einen eigenen Datenpunkt schreiben kann)
                                        Nun meine Frage: Muss ich ein extra Skript machen, welches dann das Relays 1 schaltet, oder kann das Display es nativ, einen Ausgang dafür zu verwenden?
                                        Vielen Dank für Eure Hilfe.
                                        Thomas
                                        • T Tom_W
                                          Thomas
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #410
                                          @tom_w
                                          Zur ersten Frage:
                                          Ich denke es gibt in der Config noch eine kleine Unschärfe zu lösen. Leider ist die Zeilenangabe sehr ungenau, so dass man etwas länger nach den Fehlern sucht. Könnte die anbieten mal schnell über die Config zu sehen.
                                          Zur zweiten Frage:
                                          Leider sind Hardware und HMI voneinander getrennt. So, dass du bei einer Entkoppelung der Hardware (d.h. ohne Tasmota-Rule 2) tatsächlich den Weg über ein externes Script gehen solltest um das Relay an oder aus zu schalten.
