  4. Material Design Widgets: Wetter View
material design widgetsviswetterdaswetterweatherundergroundpollenflugstatusanzeigejavascript
721 Beiträge 82 Kommentatoren 259.0k Aufrufe 91 Beobachtet
  • GlasfaserG Glasfaser
    @akuehnemann73 sagte in Material Design Widgets: Wetter View:
    Der Dialog bleibt leer / ohne Inhalt.
    Nimm dieses neue Dialog Widget und passe nur deine View an .
    [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"360","vibrateOnMobilDevices":"50","buttonStyle":"raised","mdwButtonPrimaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.primary","mdwButtonSecondaryColor":"#mdwTheme:vis-materialdesign.0.colors.button.default.secondary","textFontFamily":"#mdwTheme:vis-materialdesign.0.fonts.button.default.text","textFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.button.default.text","imageColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.button_icon","iconPosition":"left","closingClickOutside":"true","backgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.background","headerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_background","footerBackgroundColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.footer_background","dividerColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.divider","overlayColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.overlay","showTitle":"true","titleFontSize":"#mdwTheme:vis-materialdesign.0.fontSizes.dialog.title","titleFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.title","titleColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.header_text","buttonPosition":"flex-end","buttonSize":"medium","buttonFont":"#mdwTheme:vis-materialdesign.0.fonts.dialog.button","buttonFontColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_text","pressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_press","fullscreenCloseIconColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_icon","fullscreenCloseIconPressColor":"#mdwTheme:vis-materialdesign.0.colors.dialog.close_button_fullscreen_press","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"contains_view":"02","z_index":"900","dialogMaxWidth":"1500","viewHeight":"600","viewDistanceToBorder":"100"},"style":{"left":"97px","top":"411px","width":"151px","height":"71px","z-index":"100"},"widgetSet":"materialdesign"}]
    AKuehnemann73
    #617
    @glasfaser
    danke dafür. Hat aber den gleichen Effekt.
    Der Dialog bleibt leer. Habe jetzt echt schon alles ausprobiert und
    keinen Plan woran das liegen könnte. Die anderen Dialog Widgets
    funktionieren alle so wie sie sollen nur das hier nicht.
    Marc_el_KM 1 Antwort Letzte Antwort
    • OttiliO Offline
      OttiliO Offline
      Ottili
      schrieb am zuletzt editiert von Ottili
      #618
      Hi!
      seitdem ich Probleme mit dem Update des Admin Adpaters auf 3.5.1 hatte und dann ein Backup installiert habe sind alle Material-Design Charts verschwunden.
      Ich kann auch keine mehr importieren.
      Gerade habe noch mal versucht den Vis View von Sigi234 (Speed-Test und Drucker) zu importieren.
      Soweit alles prima, jedoch die Charts wurden nicht mit importiert??
      Das ist das Original von Sigi:
      und so sieht es bei mir aus, nach View Import:
      Die Charts existieren nicht.
      Hat jemand eine Lösung dafür?
      Viele Grüße
      Otti
      OttiliO 1 Antwort Letzte Antwort
      • OttiliO Ottili
        Hi!
        Viele Grüße
        Otti
        OttiliO Offline
        OttiliO Offline
        Ottili
        #619
        @ottili
        Hi hat sich erledigt.
        Anscheinend wurde der Material-Design Widgets Adapter beim Backup nicht richtig übernommen.
        Habe gerade den Adapter gelöscht und reinstalliert.... und schwubs... alle Charts sind wieder da.
        Ciao Otti
          myssv
          schrieb am zuletzt editiert von myssv
          #620
          Moin zusammen,
          vielen Dank für die tolle Arbeit!
          Ich habe das bei mir importiert und es hat fast alles auf Anhieb funktioniert. Ein paar Anpassungen war nötig aber im großen und ganzen funktioniert alles super.
          ABER :-)
          Ich bekomme den Regenradar nicht zu sehen. Nur das hier (wobei "nur" nicht negativ gemeint ist!)
          Was muss ich da noch anpassen?
          • M myssv
            Moin zusammen,
            ABER :-)
            GlasfaserG Offline
            GlasfaserG Offline
            #621
            @myssv sagte in Material Design Widgets: Wetter View:
            https://forum.iobroker.net/post/502920
            M 3 Antworten Letzte Antwort
              myssv
              #622
              @glasfaser Super, vielen Dank! Habe ich nicht gefunden oder übersehen ...
                myssv
                #623
                @glasfaser irgendwie doch zu früh gefreut ...
                Ich habe den View "Wetter_Regenradar" gefunden und angepasst. Da wird es auch angezeigt.
                Wenn ich dann aber auf den View "Wetter" gehe, wird der Regenradar unten nicht angezeigt.
                Wir bekomme ich den unten aktiv?
                  myssv
                  #624
                  @glasfaser habe jetzt weitere View definiert und nun klappt es!
                    myssv
                    #625
                    Wie kann ich die Tagesdetails weiter nach oben bekommen, so dass ich nicht scrollen muss um sie zu sehen:
                    • D3ltoroxpD Offline
                      D3ltoroxpD Offline
                      D3ltoroxp
                      #626
                      Hat sich hier noch mal was geändert ? Ich hatte fast alle Views ausgetauscht, nun sehe ich wieder fast gar nichts mehr auf der Wetter Seite.
                      • D3ltoroxpD D3ltoroxp
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #627
                        @d3ltoroxp
                        Da hat sich nichts verändert .
                        Hast du auch die Zuweisungen dazu in den Datenpunkten geändert , da du ja einen anderen Viewnamen wohl dazu hast !?
                        Beispiel aus dem Original ( Wetter Hauptseite )
                        D3ltoroxpD 1 Antwort Letzte Antwort
                          @d3ltoroxp
                          D3ltoroxpD Offline
                          D3ltoroxpD Offline
                          D3ltoroxp
                          #628
                          @glasfaser Ich hab da eigentlich nichts herum gedreht an der View. Ich schau mir das aber noch mal an die Tage, ob sich da vllt was verändert hat.
                          • R Offline
                            Random 0
                            #629
                            Hallo Leute,
                            finde das Projekt klasse und möchte es gerne auch nutzen.
                            Habe soweit alles nach Anleitung instaliert und eingestellt.
                            Peinlicherweise weiß ich nicht wie es in der Anleitung im Abschnitt Instalation, Punkt 1 funktioniert. Skript herunterladen und unter Skripte anlegen.
                            Lege ich ein neies Skript an? Links im Iobroker Menü (Skripte)? Wenn ja welches Skript? Kein Blockly, deke ich...
                            Muss ich auf der Seite die sich auf Github öffnet, wenn ich auf Skript herunterladen klicke, den Inhalt kopieren und irgendwo einfügen? Da sind ja auch erklärungen neben den Befehlen, wähe blöd die mit zu kopieren.
                            Sorry für die blöde Frage, hab auch versucht im Thread eine Antwort zu finden, aber zwei Jahre durchzuforsten dauert echt lange.
                            Wäre klasse wenn jemand mir erklären könnte wie ich das skript runterladen und Anlegen kann..
                            • R Random 0
                              Hallo Leute,
                              madman1602
                              #630
                              @random-0 sagte in Material Design Widgets: Wetter View:
                              Hallo Leute,
                              Hi , ja genau , du kannst einfach ein neues Javascript erstellen und den RAW content des Github Scriptes Wetter.js dort einfügen.
                              Dann speichern und mindestens einmal das Script starten , stoppen und wieder starten , dann werden die Datenpunkte automatisch erstellt.
                              Ab da sollte alles funktionieren.
                              Schönen Abend
                              R 1 Antwort Letzte Antwort
                              • M madman1602
                                Hallo Leute,
                                Schönen Abend
                                Random 0
                                #631
                                @madman1602
                                Vielen Dank, hat geklappt...
                                • R Offline
                                  Random 0
                                  #632
                                  Funktioniert soweit alles, wie es aussieht.
                                  Nur die Datenpunkte für Temeperatur usw passen wohl noch nicht. Hab auch meine eigenen seonsoren im Script angegeben. Die Mond und Sonnedaten müsste er sich doch auch von daswetter ziehen, oder? Die anderen Daten wie Temperaturen und Luftfeuchte für die nächsten Tage kommen doch auch von daswetter Adapter, oder nicht? Denn die scheinen zu funktionieren...
                                  R GlasfaserG 2 Antworten Letzte Antwort
                                  • R Random 0
                                    Random 0
                                    #633
                                    @random-0
                                    Wie kann ich mir die komplette Übersicht (die Seite inc Popups der Vorschautage) in meine Vis integrieren? Durch das Imprtieren scheint es ein eigenen Projekt zu sein. Möchte es gerne in mein Projekt integrieren...
                                    Sieht echt klasse aus.
                                    Hatte mir mit den Daten aus dem daswetter Adapter selbst eine Übersicht gebastelt aber die kommt bei weitem nicht an das schicke ding von Scrounger ran. Hammer Arbeit.
                                    • R Random 0
                                      @random-0
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      #634
                                      https://forum.iobroker.net/post/468358
                                      • R Random 0
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        #635
                                        Zu diesem Thema lese mal hier und dann meine Antworten darauf :
                                        https://forum.iobroker.net/post/758586
                                          Random 0
                                          #636
                                          @glasfaser
                                          Danke, werde mir dann mal Zeit nehmen und es nach und nach in meine Vis importieren...
