  4. Innogy Adapter im lokalen Netzt bleibt Gelb
    5.7k
118 Beiträge 5 Kommentatoren 16.7k Aufrufe 4 Beobachtet
  • Master67M Master67
    @djmarc75
    das.....
    innogy-smarthome.0
    2022-10-20 12:28:58.707	info	Trying to use local smarthome connection!
    innogy-smarthome.0
    2022-10-20 12:28:58.697	info	starting. Version 0.4.7 in /opt/iobroker/node_modules/iobroker.innogy-smarthome, node: v14.20.1, js-controller: 4.0.23
    host.ioBroker
    2022-10-20 12:28:58.312	info	instance system.adapter.innogy-smarthome.0 started with pid 382009
    host.ioBroker
    2022-10-20 12:28:55.814	info	instance system.adapter.innogy-smarthome.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    admin.0
    2022-10-20 12:28:55.668	info	<== Disconnect system.user.admin from ::ffff:192.168.178.131
    innogy-smarthome.0
    2022-10-20 12:28:55.292	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    innogy-smarthome.0
    2022-10-20 12:28:55.292	info	terminating
    innogy-smarthome.0
    2022-10-20 12:28:55.292	info	cleaned everything up...
    host.ioBroker
    2022-10-20 12:28:55.292	info	stopInstance system.adapter.innogy-smarthome.0 send kill signal
    innogy-smarthome.0
    2022-10-20 12:28:55.291	info	Got terminate signal TERMINATE_YOURSELF
    host.ioBroker
    2022-10-20 12:28:55.290	info	stopInstance system.adapter.innogy-smarthome.0 (force=false, process=true)
    innogy-smarthome.0
    2022-10-20 12:28:51.949	warn	Adapter is still not connected to the Innogy API, restarting!
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #76
    @master67 ok, dann zeig mal was da kommt... komplette ein- und ausgaben bitte
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Lehrling seit 1975 !!!
    Master67M 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      Master67M Offline
      Master67M Offline
      Master67
      #77
      @djmarc75 ... okay, dass (und Danke das du dir die Zeit nimmst mir zu Helfen) 👍
      root@ioBroker:~# sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      x86_64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.20.1
      v14.20.1
      6.14.17
      4.0.23
      root
      root
      /root
      Hit:1 https://deb.nodesource.com/node_14.x jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists... Done
      All packages are up to date.
      nodejs:
        Installed: 14.20.1-deb-1nodesource1
        Candidate: 14.20.1-deb-1nodesource1
        Version table:
       *** 14.20.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x jammy/main amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      root@ioBroker:~#
      Gruß Master67
        x86_64
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v14.20.1
        v14.20.1
        6.14.17
        4.0.23
        root
        root
        /root
        nodejs:
          Version table:
        root@ioBroker:~#
        #78
        @master67 sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
        Mal wieder die Klassiker...
        Root shell:
        root@ioBroker:~#
        und falsche Installation von nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        Log dich NICHT als root ein und bring deine nodejs-Installation sauber auf v16.
          Root shell:
          root@ioBroker:~#
          /usr/local/bin/node
          /usr/local/bin/npm
          Master67M Offline
          Master67M Offline
          Master67
          schrieb am zuletzt editiert von Master67
          #79
          @thomas-braun sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
          Ja... ich weiß, das Erzählst du mir immer 😁
          Und ich mache es immer nicht, sehe keinen Grund dafür, auch nicht, dass die Möglichkeit eines Hack besteht.
          Wenn bei mir die v16 installiert ist bekomme ich keine Updates mehr, warum?... keine Ahnung!
          Ich zitiere mich mal selbst;
          "Das vorletzte Ubuntu 22.04.1 Updates verliefen ohne Probleme, aber letzte Woche gab es ein größeres Update, ich glaube sowas um die 20 Dateien wurden erneuert.
          Danach konnte ich keine Adapter mehr unter dem ioBroker Aktualisieren, "error: process exited with code 25".
          Im ioBroker Forum ist dieser Fehler keine Seltenheit, die Lösungsansätze sind breitgefächert, letztendlich war hier der für mich beste und schnellste Weg auf die Node.js v. 14.20.0 zu Downgrade, das hat geholfen und die Updates gehen wieder durch."
          Gruß Master67
            #80
            Weil deine v14 halt krumm installiert ist.
            Aber offenbar ist deine Lernkurve ja auch äußerst flach.
            Dann hilf dir halt selber.
            Die Kombination von keine Ahnung! und
            root@ioBroker
            ist halt die denkbar schlechteste.
              root@ioBroker
              Master67M Offline
              Master67M Offline
              Master67
              #81
              Sorry.... aber du wirst beleidigend, gehts noch?
              Nur weil ich keine wirkliche Veranlassung sehe, nicht als "root" zu Arbeiten....
              Keine weiteren Hilfen o. Kommentare von dir Erwünscht!
              Gruß Master67
                #82
                @master67
                Keine Beleidung, schlichte Feststellung der Situation.
                  @master67
                  Master67M Offline
                  Master67M Offline
                  Master67
                  #83
                  Bitte Lesen: Keine weiteren Hilfen o. Kommentare von dir Erwünscht!
                  Gruß Master67
                    #84
                    wo?
                    dann hast du die gefühlt tausend Posts mit den Begründungen nicht wirklich gelesen.
                      #85
                      @master67
                      Ich lass mir doch nicht das Kommentieren von dir verbieten.
                        #86
                        jetzt bitte sachlich weiter ihr beiden!
                          #87
                          Ganz sachlich: root login ist falsch, nodejs ist auch falsch installiert.
                            wo?
                            Master67M Offline
                            Master67M Offline
                            Master67
                            #88
                            @homoran sagte in Innogy Adapter im lokalen Netzt bleibt Gelb:
                            wo?
                            Die sehe ich aber einfach nicht als für "mich" zwingend an....
                            So hat jeder seine Meinung/Einstellung dazu und das hat nix mit einer "Lernkurve" zutun, diese Aussage fasse ich als Beleidigung auf und fordere hiermit die Admins auf dagegen etwas zu Unternehmen!
                            Gruß Master67
                              wo?
                              #89
                              @master67
                              Bei Rot über die Ampel zu fahren ist auch keine Meinung, sondern einfach falsch.
                              Und wenn dir das einer sagt ist das immer noch keine Meinung, das Ampeln für einen nicht gelten würden.
                              Es hat ja gute Gründe, warum der root eigentlich in allen Distributionen auf Eis gelegt wurde und nur noch im Hintergrund werkelt.
                                wo?
                                #90
                                also verhält sich dein root anders als alle anderen roots, deren Nutzung durch Verbiegung von Rechten es dem User iobroker unmöglich machen, alle seine Aufgaben zu erfüllen?
                                das ist keine Meinung, das ist Fakt!
                                Wie würdest du ein konsequentes Ignorieren dieser Fakten ("ich mache es immer nicht, sehe keinen Grund dafür") trotz daraus resultierenden Problemen denn bezeichnen?
                                  Master67M Offline
                                  Master67M Offline
                                  Master67
                                  #91
                                  Wie würdest du ein konsequentes Ignorieren dieser Fakten trotz daraus resultierenden Problemen denn bezeichnen?
                                  Als mein Problem, und nicht deines oder das des Thomas_Braun, ich habe doch für mein Handeln auf meinem PC die Konsequenzen zutragen nicht du, nicht das Forum oder der ioBroker!
                                  Warum wollt IHR mich zu etwas Zwingen, wofür nur ich die Verantwortung im Schlimmstenfall tragen muss?, keine Ahung was mit euch Los ist.
                                  Auch hat diese ganze Diskussion nix mit meinem Problem zu tun, oder läuft das dann, wenn ich "sudo" einstelle?... ich denke nicht :-)
                                  Gruß Master67
                                  HomoranH DJMarc75D 2 Antworten Letzte Antwort
                                    #92
                                    das merke ich.
                                    ich versuche es nochmals:
                                    das ist nicht der Punkt! du siehst root immer noch nur als Sicherheitsrisiko.
                                    Das ist aber nur ein Bruchteil der möglichen Probleme.
                                    Das ist uns vollkommen egal!
                                    natürlich, weil dann der User user ist, und nur Rootrechte hat.
                                    Ansonsten ist der User root. und da darf der user anschließend teilweise nicht mehr ran!
                                    ich denke nicht
                                    das hab ich befürchtet!
                                      das merke ich.
                                      ich denke nicht
                                      Master67M Offline
                                      Master67M Offline
                                      Master67
                                      #93
                                      das merke ich.
                                      ich denke nicht
                                      Dann ist das aber eine Anpassung des ioBrokers die an mir vorbei gegangen ist, bei allen anderen Programmen, die ich nutze, ist das nicht so.
                                      Ich habe seit fast zwei Jahren nichts, außer Updaten, mit dem ioBroker mehr zu tun, und so lange habe ich auch nicht mehr ins Forum geschaut, das teil lief halt ohne Probleme bis zur v16.
                                      Und da ich keine neuen Aktoren mehr in mein Smarthome einbaue gab und gibt es für mich keinen Grund mehr mich weiter mit dem ioBroker zu Beschäftigen!
                                      Und so und NUR so, kann es natürlich nicht zu einer Lernkurve kommen, wenn man keine neuen Infos hat oder (glaub) sie nicht braucht!
                                      Also stelle ich auf sudo um und dann läuft das?, na wenns sonst nichts ist :-)
                                      Gruß Master67
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #94
                                        @master67 Damit Adapter vernünftig laufen wird schon ein "ziemlich" aktuelles und vor Allem ein "gerades" System vorausgesetzt. Und das setzt in erster Linie der Adapter voraus !
                                        Falls dies halt nicht gegeben ist und auch nicht korrigiert wird, macht es wenig Sinn seine Freizeit in Ursachenforschungen, warum etwas nicht funktioniert, zu investieren.
                                        Ob das nun mit dem local Smarthome vom Innogy-Adapter so ist, dass das System aktuell sein muss, weiß ich nicht da ich das local Smarthome erst vor knapp 6 Wochen auf einer komplett neuen und aktuellen Installation aktiviert habe. Läuft bei mir.
                                        Ich würde den Adapter mal neu installieren damit die Cloudanbindung auch weg ist und dann nochmal konfigurieren.
                                        HomoranH Master67M 2 Antworten Letzte Antwort
                                          das merke ich.
                                          ich denke nicht
                                          #95
                                          das war etwa 2017/2018
                                          seitdem predigen wir das in den erwähnten tausenden Posts.
                                          undas liegt an deiner unsauberen node Installation die @Thomas-Braun bei mehr Kooperation mit dir geradegezogen hätte.
                                          kann es natürlich nicht zu einer Lernkurve kommen, wenn man ...(glaub) sie nicht braucht!
                                          und das war die von dir monierte Kernaussage.
                                          Natürlich nicht!
                                          Inzwischen dürfte einiges krumm sein, was erst gerichtet werden muss.
                                          Wenn du dann anschließend nur noch mit user und sudo arbeitest solltexes auch so bleiben. Wobei es auch einiges gibt, dass nicht mit sudo angefasst werden darf, weil da auch schon Rechte verbogen werden (aber deutlich weniger)
