  4. Gigaset G-Tag mit ESP32 erkennen
    5.7k
47 Beiträge 5 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • W WolfgangFB
    Radar2: Version 2.0.3
    Raspberry Pi 3
    pi@raspberrypi:~ $ sudo systemctl status bluetooth.service
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2022-09-18 19:17:16 CEST; 3 weeks 6 days ago
           Docs: man:bluetoothd(8)
       Main PID: 756 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 4915)
            CPU: 69ms
         CGroup: /system.slice/bluetooth.service
                 └─756 /usr/libexec/bluetooth/bluetoothd
    Warning: journal has been rotated since unit was started, output may be incomplete.
    pi@raspberrypi:~ $ bluetoothctl
    Agent registered
    [bluetooth]# show
    Controller DC:A6:32:BA:3C:76 (public)
            Alias: raspberrypi
            Class: 0x002c0000
            Powered: yes
            Discoverable: no
            DiscoverableTimeout: 0x000000b4
            Pairable: yes
            UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
            UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
            UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
            UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
            UUID: Headset                   (00001108-0000-1000-8000-00805f9b34fb)
            UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
            UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
            UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
            UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
            UUID: Headset AG                (00001112-0000-1000-8000-00805f9b34fb)
            Modalias: usb:v1D6Bp0246d0537
            Discovering: no
            Roles: central
            Roles: peripheral
    Advertising Features:
            ActiveInstances: 0x00 (0)
            SupportedInstances: 0x05 (5)
            SupportedIncludes: tx-power
            SupportedIncludes: appearance
            SupportedIncludes: local-name
    [bluetooth]# list
    Controller DC:A6:32:BA:3C:76 raspberrypi [default]
    [bluetooth]# scan on
    Discovery started
    [CHG] Controller DC:A6:32:BA:3C:76 Discovering: yes
    [NEW] Device 54:D2:72:2B:98:0D Nuki_252B980D
    [NEW] Device 64:F6:23:FF:F4:BB 64-F6-23-FF-F4-BB
    [NEW] Device BC:FA:B8:A9:62:2A AQUOS-TVE19C
    [NEW] Device 00:E0:4C:23:99:87 INTEL
    [NEW] Device 00:80:25:08:8F:C5 SMA1d SN: 2100011375 SN2100011375
    [CHG] Device 00:E0:4C:23:99:87 RSSI: -76
    [CHG] Device 00:E0:4C:23:99:87 RSSI: -62
    [CHG] Device 64:F6:23:FF:F4:BB RSSI: -84
    [DEL] Device 00:80:25:08:8F:C5 SMA1d SN: 2100011375 SN2100011375
    [CHG] Device 64:F6:23:FF:F4:BB RSSI: -75
    Was mich wundert ist, dass weder mein Mobiltelefon (98:f6...) noch der G-TAg (7c:2f...) erscheinen.
    Mit der Keeper App die mit dem G-Tag zusammen kommt klappt das Finden des G-Tgs problemlos.
    Der Bluetooth Scanner auf dem Mobiltelefonn zeigt für das G-Tag ein RSSI von -36dBm.
    @wolfgangfb
    hast du die Doku gelesen, und beherzigt?
    u.a.
    • notwendige Hilfsprogramme installiert?
    • In the Adapter-config BT-LE macs should be identified with a '!' before the mac-address to avoid scanning them with normal BT
    W 1 Antwort Letzte Antwort
      @wolfgangfb entziffere ich das richtig, dass du unknown BT nicht speicherst?
      W Offline
      W Offline
      WolfgangFB
      @homoran sagte in Gigaset G-Tag mit ESP32 erkennen:
      Ja, wozu sollte ich die speichern? Ich kenne doch die Devices, die ich erfassen will.
      • W WolfgangFB
        @wolfgangfb sagte in Gigaset G-Tag mit ESP32 erkennen:
        der Adapter auch?
        jetzt wones alles nicht klappt, hast du auch keine Lust das mal anders zu probieren?
          @wolfgangfb
          u.a.
          W Offline
          W Offline
          WolfgangFB
          @wolfgangfb
          Ich habe sie gelesen und versucht zu verstehen, ob ich alles richtig "beherzigt" habe wage ich zu bezweifeln, denn e läuft ja nicht.
          u.a.
          Tja, ich habe das ausgeführt was unter "Installation" steht. Richtig verstanden habe ich es nicht. Ob das alle notwendigen Hilfsprogramme sind kann ich nicht sagen.
          OK, habe ich jetzt auch gemacht.
          radar2.0
          	2022-10-16 20:48:09.919	info	Adapter identified macs: (2c:3a:fd:b4:2c:89), ips: (127.0.0.1,192.168.1.200), bts LE: (7c:2f:80:c4:5d:da,98:f6:21:87:82:bc), bts norm: ()
          radar2.0
          	2022-10-16 20:48:09.917	info	Init item Wolfgang_Redmi_9 with {name: 'Wolfgang_Redmi_9',ip: [],bluetooth: [ '!98:f6:21:87:82:bc' ],enabled: -1,id: 'Wolfgang_Redmi_9',type: 'BT',btVendor: 'Xiaomi Communications Co Ltd'}
          radar2.0
          	2022-10-16 20:48:09.902	info	Init item Forum with {name: 'Forum',ip: [ 'https://forum.iobroker.net' ],bluetooth: [],enabled: -1,id: 'Forum',type: 'URL',lasthere: '2022-10-16T18:47:44.844Z'}
          radar2.0
          	2022-10-16 20:48:09.876	info	Init item Schluessel with {name: 'Schluessel',ip: [],bluetooth: [ '!7c:2f:80:c4:5d:da' ],enabled: -1,id: 'Schluessel',type: 'BT',btVendor: 'Gigaset Communications GmbH'}
          Aus der Tatsache, dass der Adapter sowohl bei Mobiltelefon als auch bei Schlüsselanhänger, den "btVendor" anzeigt schließe ich mal, dass es zumindest einmalig einen Kontakt gibt. Aber in den Objekten sind die Geräte immer noch nicht existent.
          • W WolfgangFB
            @wolfgangfb
            u.a.
            radar2.0
            radar2.0
            radar2.0
            radar2.0
            impliziert, dass du es bisher nicht hattest.
            dann scannt der Adapter es als simples BT, was nicht funktioniert.
            ja, auf BT Ebene, aber ggf. nicht BLE
            EDIT: WENN
            dies der Tag ist, hat doch alles geklappt
              der Adapter auch?
              W Offline
              W Offline
              WolfgangFB
              der Adapter auch?
              Ja, ich habe die beiden Geräte ja explizit eingetragen.
              Doch, das war ja beim ersten Versuch aktiviert, dann habe ich es rausgenommen weil es bei haselchen auch weg war. Jetzt habe ich es wieder aktiviert, aber am Ergebnis hat das nichts geändert.
              Unwissend wie ich bin habe ich mal versucht, den in der Doku angegeben Befehl
              pi@raspberrypi:~ $ hcitool lescan
              Set scan parameters failed: Input/output error
              auszuführen. Ob dieser Fehler jetzt daran liegt, dass ihn falsch eingesetzt habe oder ob lescan ein grundsätzliches Progblem bei mir hat weiß ich nicht.
              • W WolfgangFB
                der Adapter auch?
                aber erst jetzt als BLE Devices deklariert.
                  EDIT: WENN
                  W Offline
                  W Offline
                  WolfgangFB
                  EDIT: WENN
                  Das ist die MAC des G-Tag, aber was nutzt mir ds ganze, wenn in den Objekten steht, dass das Device noch nie da war?
                  HomoranH haselchenH 2 Antworten Letzte Antwort
                  • W WolfgangFB
                    EDIT: WENN
                    ich habe mit dem Adapter noch nicht gearbeitet, aber wo steht das?
                    in deinem screenshot steht ein Timestamp wo er gesehen worden ist.
                    unter not_here ist alles leer, also ist kein bekanntes Gerät nicht da
                    ich habe das damals mit dem Skript hier gemacht.
                    https://forum.iobroker.net/post/2195
                    muss aber die Vorlage für den Adapter gewesen sein.
                    • W WolfgangFB
                      EDIT: WENN
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @wolfgangfb
                      Hast du mal den Expertenmodus angemacht und nochmal die aktuelle Version installiert ?
                      Über die Radar Kachel?
                      Kann sein , dass da doch nochmal wichtige Abhängigkeiten installiert werden.
                      • W Offline
                        W Offline
                        WolfgangFB
                        Siehe Bild
                        notHere sind "Schlüssel" und mein "Mobiltelefon". Ein lastHere gibt es auch nicht bei Schlüssel un Mobiltelefon
                        • W WolfgangFB
                          Siehe Bild
                          ok, das war in dem anderen Screenshot noch anders.
                          wie gesagt würde ich zum Suchen den Tag aus der Liste nehmen j d unbekannte IDs speichern.
                          Da sind ja schon andere unbekannte drin.
                          ich bin mir auch nicht sicher ob ble und bt die selbe MAC haben. heisst aber nichts
                          • haselchenH haselchen
                            @wolfgangfb
                            W Offline
                            W Offline
                            WolfgangFB
                            @haselchen sagte in Gigaset G-Tag mit ESP32 erkennen:
                            @wolfgangfb
                            $ iobroker add radar2 auto --host raspberrypi
                            host.raspberrypi create instance radar2
                            host.raspberrypi object system.adapter.radar2.1.alive created
                            host.raspberrypi object system.adapter.radar2.1.connected created
                            host.raspberrypi object system.adapter.radar2.1.compactMode created
                            host.raspberrypi object system.adapter.radar2.1.cpu created
                            host.raspberrypi object system.adapter.radar2.1.cputime created
                            host.raspberrypi object system.adapter.radar2.1.memHeapUsed created
                            host.raspberrypi object system.adapter.radar2.1.memHeapTotal created
                            host.raspberrypi object system.adapter.radar2.1.memRss created
                            host.raspberrypi object system.adapter.radar2.1.uptime created
                            host.raspberrypi object system.adapter.radar2.1.inputCount created
                            host.raspberrypi object system.adapter.radar2.1.outputCount created
                            host.raspberrypi object system.adapter.radar2.1.eventLoopLag created
                            host.raspberrypi object system.adapter.radar2.1.sigKill created
                            host.raspberrypi object system.adapter.radar2.1.logLevel created
                            host.raspberrypi object radar2.1.info created
                            host.raspberrypi object radar2.1.info.connection created
                            host.raspberrypi Set default value of radar2.1.info.connection: false
                            host.raspberrypi object system.adapter.radar2.1 created
                            Process exited with code 0
                            Ergebnis das gleiche, nHere sind Schlüssel und Mobiltelefon.
                            • W WolfgangFB
                              @wolfgangfb
                              @wolfgangfb dann stell die Instanz mal auf debug und starte neu
                                W Offline
                                W Offline
                                WolfgangFB
                                Das war mein erster Screenshot von Objekten. Verwechselst Du das mit haselchens Screenshot?
                                Habe ich jetzt auch probiert. Ohne Ergebnis.
                                Mein Mobiltelefon zeigt mitr beim G-Tag die gleiche Mac Adresse an
                                7c:2f:80:c4:5d:da (dort aber in Großbuchstaben, das sollte aber nichts machen hoffe ich aml) und als Protokoll: Low Energy (BLE)
                                haselchenH HomoranH 2 Antworten Letzte Antwort
                                • W WolfgangFB
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @wolfgangfb
                                  Wieso hast du 2 Instanzen vom Adapter ?
                                  • W WolfgangFB
                                    der Adapter auch?
                                    den hab ich nicht gefunden, lediglich lescan dev
                                    hast du den mal ausgeführt?
                                    • W WolfgangFB
                                      @wolfgangfb
                                      hast du das jetzt mal ausgeführt?
                                      bitte mit ein und Ausgabe posten.
                                      mein Akku ist gleich leer!
                                        W Offline
                                        W Offline
                                        WolfgangFB
                                        pi@raspberrypi:~ $ lescan dev
                                        -bash: lescan: Kommando nicht gefunden.
                                          @wolfgangfb
                                          W Offline
                                          W Offline
                                          WolfgangFB
                                          @wolfgangfb
                                          Weil ich beim von Dir empfohlenen Installieren nicht aufgepasst habe und eine neue Inszanz installiert habe. Ändert aber nichts am Ergebnis.
