  4. Sonoff mit iobroker
    5.4k
Sonoff mit iobroker
240 Beiträge 33 Kommentatoren 98.9k Aufrufe 2 Beobachtet
  • N Offline
    N Offline
    noxx
    #79
    @e-p-s:
    Könntest Du nochmal kurz zusammen fassen wie jetzt der Stand ist und welche Firmware man nimmt?
    Ich hab mir ein Sonoff abgeschossen glaub ich.
    Da blinkt zumindest nichtmehr. `
    Kannst hier ne fertige Tasmota nehmen:
    https://github.com/arendst/Sonoff-Tasmo … sonoff.bin
    Zum flashen nehme ich das Tool was bei den ESPeasy Images dabei ist
    https://github.com/letscontrolit/ESPEas ... -dev10.zip
    Flashen, Stecker raus/rein, kurz warten, dann 4x kurz auf den Button drücken, dann kann man per WLAN
    auf den AP-Sonoff zugreifen. WLAN anpassen (SSID/Password) und dann konfigurieren.
    Hier die Codes wie man den Sonoff "blind" bedient:
    ` > he main button on a Sonoff-Tasmota flashed module provides the following functionalities:
    1 short press: Toggles the relay either directly or by sending a MQTT message like cmnd/sonoff/1/light on. This will blink the LED twice and sends a MQTT status message like stat/sonoff/LIGHT on. If cmnd/sonoff/ButtonRetain on has been used the MQTT message will also contain the MQTT retain flag.
    2 short presses: Toggles the relay. This will blink the LED twice and sends a MQTT status message like stat/sonoff/POWER on. For Sonoff Dual this will switch relay 2.
    3 short presses: Start Wifi smartconfig allowing for SSID and Password configuration using an Android mobile phone with the ESP8266 SmartConfig app. The MQTT server still needs to be configured in the user_config.h file. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
    4 short presses: Start Wifi manager providing an Access Point with IP address 192.168.4.1 and a web server allowing the configuration of both Wifi and MQTT parameters. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
    5 short presses: Start Wifi Protected Setup (WPS) allowing for SSID and Password configuration using the routers WPS button or webpage. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
    6 short presses: Will restart the module
    7 short presses: Start OTA download of firmware. The green LED is lit during the update
    Pressing the button for over four seconds: Reset settings to defaults as defined in user_config.h and restarts the device `
    • smoker2604xS Offline
      smoker2604x
      #80
      Hat einer von euch die dual im Einsatz . Ich kann die übers Webinterface und über iobroker steuern, aber wenn ich die 2 Hardware Pins benutze habe ich das Problem das immer nur relay 1 geschaltet wird egal ob ich Button 0 oder Button 1 schalte manuell.
      PS. Sorry wollte einen neuen thread aufmachen kann es aber leider auf dem Handy nicht löschen
      Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
      Liebe Grüße Tobias
      • kmxakK Offline
        kmxakK Offline
        kmxak
        #81
        ja hab nen dual aber der hat doch nur einen schalter und der schaltet bei mir nur den 1. kanal.
        GGF kann man ja Buttons über die Pins auf dem board nachrüsten
        Gruß Alex
          smoker2604x
          #82
          @kmxak:
          GGF kann man ja Buttons über die Pins auf dem board nachrüsten `
          Genau die meine ich . Die auf dem Board habe ich mit 4 Kabel nach außen gelegt.
          Liebe Grüße Tobias
          • kmxakK Offline
            kmxakK Offline
            kmxak
            #83
            Welche Software nimmst du denn?
            ESPEasy oder Sonoff oder Sonoff Mod?
            Gruß Alex
            • E Offline
              e-p-s
              #84
              Und wie werden die Kabel angeschlossen. Ich hab da X-Beiträge gefunden und überall sind sie in bisschen anders.
              Ich hab den Adapter hier:
              http://www.gearbest.com/development-boa … 62977.html
              • kmxakK Offline
                kmxakK Offline
                kmxak
                #85
                @e-p-s:
                http://www.gearbest.com/development-boa … 62977.html `
                Du meinst nun aber für das flashen? Dort bei v2 den gpio0 beim Widerstand am ESP Chip holen und gegen Masse legen
                Gesendet von meinem SM-G930F mit Tapatalk
                Gruß Alex
                  Master77
                  #86
                  Wird in diesem Beitrag alles beschrieben. https://www.alefo.de/wiki/anleitungen:s … xa_steuern
                  Ist zwar ein Beitrag bezüglich Alexa jedoch wird dort auch das flashen beschrieben.
                  Die Anleitungen wurden bereits auf Seite sieben gepostet.
                  Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                    smoker2604x
                    #87
                    ich habe gerade vom Entwickler von Tasmota erfahren, das die Buttons auf der Platine vom DUAL immoment nicht von der Software supportet werden.
                    Liebe Grüße Tobias
                    • kmxakK Offline
                      kmxakK Offline
                      kmxak
                      #88
                      Ja aber mit espeasy sollte sich da ggf was machen lassen oder nen Sketch hochladen für die buttons
                      Gruß Alex
                        smoker2604x
                        #89
                        Da bin ich leider noch nicht fit drin. So wie ich Verstanden habe, ist das Problem das die Buttons am ESP vorbei gehen im die relays zu schalten
                        Liebe Grüße Tobias
                        • lobomauL Offline
                          lobomauL Offline
                          lobomau
                          #90
                          @Schubi:
                          Der 1. Teil meiner Anleitung zur Verwendung der Sonoff-Module mit ioBroker
                          FLASHEN von ESPEasy
                          Sehr viel genauer und ausführlicher im FHEM-Wiki zu finden!
                          https://wiki.fhem.de/wiki/Sonoff
                          Als FTDI-Adapter habe ich folgendes Teil in Verwednung:
                          https://www.amazon.de/gp/product/B01CYB … UTF8&psc=1
                          <list type="decimal">4. FTDI-Adapter einmalig an den PC anschließen, damit die Treiber installiert werden (sollte ab WIN7 automatisch funktionieren). Danach wieder abstecken.
                          1. Einlöten einer Stiftleiste in das Modul
                          Host: NUC8i3 mit Proxmox:
                          • Slave: Pi4
                          • SchubiS Offline
                            SchubiS Offline
                            Schubi
                            #91
                            @lobomau:
                            ja das passt - hast du ja mittlerweilen selber herausgefunden. (der Abstand ergibt sich aus der Teilung von einem Inch (Zoll) (1/10 Inch = 2,54mm)
                            Vor dem Löten würde ich nicht zurück schrecken - das ist an dieser Stelle wirklich kein Problem.
                            Sicher ist auch eine temporäre Verbindung ohne löten möglich - würde ich aber nicht machen.
                            Außerdem hast du mit der eingelöteten Stifleiste nach dem Flashen die Möglichkeit, ganz einfach, noch weitere Sensoren an das Modul anzuschließen (z.B. DS18B20).
                            Sehr praktisch sind in diesem Zusammenhang auch die folgenden https://www.amazon.de/Elegoo-Female-Female-Male-Female-Steckbr%C3%BCcken-Drahtbr%C3%BCcken/dp/B01EV70C78/ref=pd_sim_147_6?_encoding=UTF8&psc=1&refRID=491V3XXFPH7K0A9KYXVB.
                            LG und gutes Gelingen!
                            / Synology DS716+ / Logitech Harmony Ultimate / Netatmo / ESP8266 / RPi 3 / 4* Möller Easy 820 / Lupusec XT2 Plus /
                              Master77
                              #92
                              Hallo zusammen.
                              Habe mich gestern nochmal mit dem Thema befasst und
                              auf einen Sonoff die ESP Easy Software geflasht.
                              Dank der ganzen Anleitung hier in dem Beitrag, hat auf Anhieb auch alles direkt funktioniert.
                              Eine Sache irritiert mich jedoch ein wenig.
                              Wenn ich ins Log schaue kommen jede Menge Warnungen die von mqtt aus gehen. Kann mir einer sagen woran das liegen könnte.
                              Gruß Markus
                              • kmxakK Offline
                                kmxakK Offline
                                kmxak
                                #93
                                davon habe ich auch teilweise ein paar aber denke nicht das das vom Sonoff kommt… meine beziehen sich eher auf den fhem und hm adapter
                                Gruß Alex
                                • C Offline
                                  ccc.ggg73
                                  #94
                                  Hallo Master77 hatte am Anfang auch. Nach Neustart von iobroker nicht mehr
                                  Gesendet von meinem SM-G950F mit Tapatalk
                                    Master77
                                    #95
                                    Hallo zusammen.
                                    Auch ein Neustart hat keinen Erfolg gebracht. Habe alles nach der Anleitung in diesem Beitrag konfiguriert. Sobald ich den mqtt Adapter deaktivieren kommen keine Warnungen mehr.
                                    • kmxakK Offline
                                      kmxakK Offline
                                      kmxak
                                      #96
                                      ja aber sonoff ist laut bild nicht an den warnungen schuld.
                                      Ist der MQTT Adapter richtig konfiguriert?
                                      Gruß Alex
                                        Master77
                                        #97
                                        Bin nach der Anleitung von ccc. ggg73 auf Seite drei gegangen. Der Sonoff läuft einwandfrei. Auch die Einbindung in Alexa funktioniert super. Nein nein, der Sonoff ist es nicht schuld. Hatte ja geschrieben das die Warnungen von mqtt Adapter aus gehen.
                                        • C Offline
                                          ccc.ggg73
                                          #98
                                          @Master77:
                                          Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk `
                                          Kannst du ein screenshot von deine MQTT Adapter einstellungen machen?
