  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • G guergen
    @gregors Wenn stable eingestellt ist, zeigt er die Beta-Adapter auch nicht mit an
    Nach welcher Anleitung hast du denn iobroker installiert?
    GregorSG Offline
    GregorSG Offline
    GregorS
    #1319
    @guergen
    Hier mit der Einstellung Stable + Beta
    pi@Promox-ioBroker:~$ iobroker update
    Used repositories: Stable (default), Beta (latest)
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "alexa2"       : 3.19.9   , installed 3.19.9
    Adapter    "backitup"     : 2.4.14   , installed 2.4.12 [Updatable]
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.3  [Updatable]
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.2.1  [Updatable]
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.3  [Updatable]
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
    Adapter    "hm-rega"      : 3.0.43   , installed 3.0.40 [Updatable]
    Adapter    "hm-rpc"       : 1.15.15  , installed 1.15.12 [Updatable]
    Adapter    "hs100"        : 2.1.2    , installed 2.1.2
    Adapter    "info"         : 1.9.21   , installed 1.9.19 [Updatable]
    Adapter    "iot"          : 1.12.2   , installed 1.11.9 [Updatable]
    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
    Adapter    "jeelink"      : 1.0.3    , installed 0.1.4  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "linux-control": 1.1.5    , installed 1.1.3  [Updatable]
    Adapter    "modbus"       : 5.0.8    , installed 5.0.5  [Updatable]
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "parser"       : 1.2.1    , installed 1.1.8  [Updatable]
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.4  [Updatable]
    Adapter    "radar2"       : 2.0.3    , installed 2.0.3
    Adapter    "simple-api"   : 2.7.1    , installed 2.7.1
    Adapter    "snmp"         : 2.1.10   , installed 1.0.0  [Updatable]
    Adapter    "socketio"     : 6.1.10   , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.8  [Updatable]
    Adapter    "statistics"   : 2.2.0    , installed 2.2.0
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis"          : 1.4.15   , installed 1.2.12 [Updatable]
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
    Adapter    "web"          : 5.2.5    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.1.5    , installed 1.3.0  [Updatable]
    pi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v
    x86_64
    /usr/bin/node
    /usr/bin/npm
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    G 1 Antwort Letzte Antwort
    • GregorSG GregorS
      @guergen
      x86_64
      /usr/bin/node
      /usr/bin/npm
      guergen
      #1320
      @gregors Nach welcher Anleitung hast du denn iobroker installiert?
      GregorSG 1 Antwort Letzte Antwort
      • Thomas BraunT Online
        #1321
        @gregors
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Der sourceanalytix ist bis dato nur über das Beta-Repo zu beziehen.
        • G guergen
          GregorSG Offline
          GregorSG Offline
          GregorS
          #1322
          @guergen
          Über die Anleitung in www.iobroker.net
            @gregors
            GregorSG Offline
            GregorSG Offline
            GregorS
            #1323
            @guergen
            Habe jetzt die aktuelle Version 0.4.14
            • GregorSG GregorS
              @guergen
              #1324
              @gregors
              Was sagt
              denn nun?
                @gregors
                Was sagt
                denn nun?
                GregorSG Offline
                GregorSG Offline
                GregorS
                #1325
                Habe deinen Code eingegeben, und dann hatte ich u.a auch den sourceanalytix dabei und konnte ihn über die Oberfläche updaten.
                Habe jetz noch ein anderes Problem, aber da mache ich mal ein neues Topic auf.
                • GregorSG GregorS
                  #1326
                  @gregors
                  Was sagt
                  denn nun?
                    @gregors
                    Was sagt
                    denn nun?
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    #1327
                    @thomas-braun said in [SourceAnalytix 0.4.8-Final] Released !:
                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                    code_tpi@Promox-ioBroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    x86_64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.0
                    v16.17.0
                    8.15.0
                    4.0.23
                    pi
                    pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                    /home/pi
                    OK:1 http://deb.debian.org/debian bullseye InRelease
                    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
                    OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                    OK:4 http://security.debian.org/debian-security bullseye-security InRelease
                    Aktualisierung für 57 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                    nodejs:
                      Installiert:           16.17.0-deb-1nodesource1
                      Installationskandidat: 16.17.1-deb-1nodesource1
                      Versionstabelle:
                         16.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                     *** 16.17.0-deb-1nodesource1 100
                         12.22.12~dfsg-1~deb11u1 500
                            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                         12.22.5~dfsg-2~11u1 500
                            500 http://deb.debian.org/debian bullseye/main amd64 Packagesext
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "parser"       : 1.2.1    , installed 1.2.1
                    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
                    Adapter    "socketio"     : 6.1.10   , installed 6.1.10
                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 5.2.5    , installed 5.2.5
                    Adapter    "ws"           : 2.1.5    , installed 2.1.5
                    • GregorSG GregorS
                      x86_64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      4.0.23
                      pi
                      /home/pi
                      nodejs:
                        Versionstabelle:
                      #1328
                      @gregors sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      Zieh die hoch. Und deaktivier das Beta-Repository wieder.
                        GregorSG Offline
                        GregorSG Offline
                        GregorS
                        #1329
                        Kann ich die 57 Pakete mit iob update aktualisieren?
                          #1330
                          Natürlich nicht. Die kommen vom Betriebssystem...
                          Notieren und künftig regelmäßig machen:
                          iob stop
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                            iob stop
                            sudo apt update
                            sudo reboot
                            GregorSG Offline
                            GregorSG Offline
                            GregorS
                            #1331
                            x86_64
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.17.1
                            v16.17.1
                            8.15.0
                            4.0.23
                            pi
                            /home/pi
                            [sudo] Passwort für pi:
                            OK:2 http://security.debian.org/debian-security bullseye-security InRelease
                            OK:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Alle Pakete sind aktuell.
                            nodejs:
                              Installiert:           16.17.1-deb-1nodesource1
                              Versionstabelle:
                             *** 16.17.1-deb-1nodesource1 500
                            Ok, sieht jetzt besser aus.
                            Lucifor1976L 1 Antwort Letzte Antwort
                            • GregorSG GregorS
                              x86_64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.1
                              v16.17.1
                              8.15.0
                              4.0.23
                              pi
                              /home/pi
                              nodejs:
                                Versionstabelle:
                              Lucifor1976L Offline
                              Lucifor1976
                              #1332
                              Einen schönen guten Samstag.. :)
                              Ich habe heute ein Problem mit Sourceanalytix
                              Wir hatten heute Nacht einen mehrstündigen Stromausfall. Dieser war heute nacht um halb drei behoben.
                              Heute sehe ich nun das bei den Analytix Auswertungen für Strom und Wasser falsche Daten berechnet werden.
                              Bei Wasser zum Beispiel soll ich 507 m3 Wasser verbraucht haben und das um 11 Uhr.. :) Wird heute wohl ein teuerer Tag.
                              Bei Strom ebenfalls, witzigerweise hat er bei Strom DIe Daten von Donnerstag als Grundwert genommen und rechnet den Verbrauch von heute obendrauf...
                              Wie bekomme ich das korrigiert?
                              Strom:
                              Wasser:
                              Wasser:
                              ioBroker@Debian 12 VM auf Proxmox 8.4.1 | HP Proliant DL380G9 | DS923+ 10TB | RS4021+ 144TB | Unifi Netzwerk 6AP, 3 EtagenSwitche | Anycubic MegaS+Kossel+Chiron, Elektroniker und Funkamateur
                              • Lucifor1976L Lucifor1976
                                Strom:
                                Wasser:
                                Wasser:
                                ManfredHi
                                #1333
                                @lucifor1976
                                Ich hab auch gelegentlich dieses Problem.
                                In meinem Logfile tauchen dann solche Einträge auf:
                                Device reset detected for alias.0.Strom.Steckdosen.AVM.TV-Schlafzimmer store current cumulatedReading 301.182 as valueAtDeviceReset (previous valueAtDeviceReset : -147.477)
                                Ich beende dann SA, wechsle in den Administrator mode und stelle den Eintrag "valueAtDeviceReset" wieder auf den vorherigen Wert, der in Klammer angeführt ist). Nach dem STart vom SA passt es dann wieder.
                                • M ManfredHi
                                  @lucifor1976
                                  Lucifor1976
                                  schrieb am zuletzt editiert von Lucifor1976
                                  #1334
                                  @manfredh-1
                                  Ich verstehe Deinen Lösungansatz, hilft mir leider nicht da die Rohdaten nicht falsch sind:
                                  Wasser:
                                  Strom:
                                  Hier sieht man schön den Stromausfall von Freitag 22:16 bis heute Nacht 2:00 Uhr.
                                  • Lucifor1976L Offline
                                    Lucifor1976
                                    #1335
                                    Ich habe den Wasserzähler nun neu eingerichtet.. ist nicht schlimm der Zähler ist erst seit zwei Tagen smart.. und die Verbrauchsperiode kommt erst noch, kann ich mit leben.
                                    Bei Strom möchte ich das nun aber nicht gerne tun, sonst sind die Daten der letzen zwei Jahre weg, was ich nicht will..
                                    • JB_SullivanJ Offline
                                      JB_Sullivan
                                      #1336
                                      @Dutchman
                                      Besteht die Möglichkeit, das man SA um die Einheit Kilometer (km) erweitert?
                                      Immer mehr Fahrzeuge sind ja via ioBroker integrierbar. D.h. man könnte mit SA und einem sich ändernden Gesamt Kilometerstand, leicht via SA, entsprechende Fahrhistorien erstellen lassen.
                                      Was hälst du von der Idee?
                                        @manfredh-1
                                        Wasser:
                                        Strom:
                                        crunchipC Offline
                                        crunchipC Offline
                                        #1337
                                        @lucifor1976 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                        und was genau ist falsch, bzw wo liegt das Problem?
                                        • JB_SullivanJ JB_Sullivan
                                          @Dutchman
                                          FredFF Online
                                          FredFF Online
                                          FredF
                                          Most Active Forum Testing
                                          #1338
                                          @jb_sullivan
                                          Hätte ich auch Interesse dran... aber der Adapter analysiert Verbräuche.
                                          Datenpunkte für km passt da irgenwie gar nicht rein
                                          JB_SullivanJ crunchipC 2 Antworten Letzte Antwort
