  4. Test Adapter TP-Link Tapo
    6.7k
885 Beiträge 123 Kommentatoren 403.8k Aufrufe 107 Beobachtet
  • mrbungle64M mrbungle64
    @tombox
    Mir fällt noch auf, dass bei einem (geplanten) Neustart der Adapter Instanz eine Reihe von Errors und Warnings in's Log geschrieben werden.
    Ist das nur bei mir so?
    tapo.0	2022-09-11 08:41:01.235	info	starting. Version 0.0.1 (non-npm: TA2k/ioBroker.tapo#79dc670bac773e69d6dd6926501e990a54fca102) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.17.0, js-controller: 4.0.23
    host.raspberrypi-3	2022-09-11 08:40:56.401	info	instance system.adapter.tapo.0 started with pid 24616
    host.raspberrypi-3	2022-09-11 08:40:54.647	info	instance system.adapter.tapo.0 terminated with code null ()
    host.raspberrypi-3	2022-09-11 08:40:54.646	warn	instance system.adapter.tapo.0 terminated due to SIGTERM
    host.raspberrypi-3	2022-09-11 08:40:53.913	info	stopInstance system.adapter.tapo.0 killing pid 24609
    host.raspberrypi-3	2022-09-11 08:40:52.910	info	stopInstance system.adapter.tapo.0 send kill signal
    host.raspberrypi-3	2022-09-11 08:40:52.612	info	stopInstance system.adapter.tapo.0 (force=false, process=true)
    host.raspberrypi-3	2022-09-11 08:40:52.163	info	instance system.adapter.tapo.0 started with pid 24609
    host.raspberrypi-3	2022-09-11 08:40:49.957	info	instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    tapo.0	2022-09-11 08:40:49.342	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.17": Connection is closed.
    tapo.0	2022-09-11 08:40:49.341	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.23": Connection is closed.
    tapo.0	2022-09-11 08:40:49.339	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.16": Connection is closed.
    tapo.0	2022-09-11 08:40:49.336	error	Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.16: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
    tapo.0	2022-09-11 08:40:49.335	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.334	warn	Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.15: DB closed
    tapo.0	2022-09-11 08:40:49.333	error	Error: Could not check object existence of tapo.0.8022xxxx4523.past7d03.22: Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.22": Connection is closed.
    tapo.0	2022-09-11 08:40:49.333	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.332	warn	Could not perform strict object check of state tapo.0.8022xxxx4523.past7d03.21: DB closed
    tapo.0	2022-09-11 08:40:49.331	error	Error: Could not check object existence of tapo.0.8022xxxx1CF04.past7d03.15: Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.15": Connection is closed.
    tapo.0	2022-09-11 08:40:49.330	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.329	warn	Could not perform strict object check of state tapo.0.8022xxxx1CF04.past7d03.14: DB closed
    tapo.0	2022-09-11 08:40:49.327	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
    tapo.0	2022-09-11 08:40:49.325	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.22": Connection is closed.
    tapo.0	2022-09-11 08:40:49.324	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.15": Connection is closed.
    tapo.0	2022-09-11 08:40:49.319	error	Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.15: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": DB closed
    tapo.0	2022-09-11 08:40:49.319	error	Error: Could not check object existence of tapo.0.8022xxxx4523.past7d03.21: Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.21": DB closed
    tapo.0	2022-09-11 08:40:49.318	error	Error: Could not check object existence of tapo.0.8022xxxx1CF04.past7d03.14: Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.14": DB closed
    tapo.0	2022-09-11 08:40:49.316	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.316	warn	Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.14: DB closed
    tapo.0	2022-09-11 08:40:49.315	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.314	warn	Could not perform strict object check of state tapo.0.8022xxxx4523.past7d03.20: DB closed
    tapo.0	2022-09-11 08:40:49.312	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.311	warn	Could not perform strict object check of state tapo.0.8022xxxx1CF04.past7d03.13: DB closed
    tapo.0	2022-09-11 08:40:49.308	error	Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": DB closed
    tapo.0	2022-09-11 08:40:49.308	error	Cannot check object existence of "tapo.0.8022xxxx4523.past7d03.21": DB closed
    tapo.0	2022-09-11 08:40:49.306	error	Cannot check object existence of "tapo.0.8022xxxx1CF04.past7d03.14": DB closed
    tapo.0	2022-09-11 08:40:49.300	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.298	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.295	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.255	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.253	warn	get state error: Connection is closed.
    tapo.0	2022-09-11 08:40:49.228	warn	get state error: DB closed
    host.raspberrypi-3
    2022-09-11 08:40:48.630	info	stopInstance system.adapter.tapo.0 send kill signal
    tapo.0	2022-09-11 08:40:48.617	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    tapo.0	2022-09-11 08:40:48.611	info	terminating
    tapo.0	2022-09-11 08:40:48.606	info	Got terminate signal TERMINATE_YOURSELF
    tombox
    @mrbungle64 Welchen Update interval hast du eingestellt
    mrbungle64M 1 Antwort Letzte Antwort
    • T tombox
      mrbungle64M Offline
      mrbungle64M Offline
      mrbungle64
      @tombox sagte in Test Adapter TP-Link Tapo:
      10 Sekunden
      • W0lfNeuzW Offline
        W0lfNeuzW Offline
        W0lfNeuz
        Bei mir läuft er leider gar nicht . Hab ich was falsch eingestellt? Schalten ist nicht möglich und Verbrauchswerte werden mir auch keine dargestellt :)
        tapo.0
        2022-09-11 13:31:16.046	error	Get Device Info failed for 80227D6168D49C1070309E29E7AC115920016034 - TypeError: Cannot read properties of undefined (reading 'request')
        tapo.0
        2022-09-11 13:31:16.044	error	357 Error Code: 9999, Session Timeout 192.168.178.174
        tapo.0
        2022-09-11 13:31:15.922	error	146 Error Code: 9999, Session Timeout 192.168.178.174
        tapo.0
        2022-09-11 13:31:15.630	error	Error Code: 9999, Session Timeout
        • W0lfNeuzW W0lfNeuz
          tapo.0
          tapo.0
          tapo.0
          tapo.0
          tombox
          @w0lfneuz Komisch die Geräte sind aber in der App online? und unter 192.168.178.174 erreichbar?
          W0lfNeuzW 1 Antwort Letzte Antwort
          • T tombox
            W0lfNeuzW Offline
            W0lfNeuzW Offline
            W0lfNeuz
            schrieb am zuletzt editiert von W0lfNeuz
            @tombox Ja, in der App kann den Plug schalten und auch den Verbrauch sehen.
            Unter der IP kommt Meldung
            200 OK
              200 OK
              tombox
              @w0lfneuz Ist denn der iobroker im gleichen Netz wie die Steckdose
              • T tombox
                W0lfNeuzW Offline
                W0lfNeuzW Offline
                W0lfNeuz
                @tombox im selben Mesh Netzwerk
                • Lucas StiefelL Offline
                  Lucas Stiefel
                  Heyho, kann ich mit deinen Adapter meine Kamera C320WS (ganz normale Tapo TP Link Kamera mit Bewegungserkennung), die bewegungserkennung an und ausschalten, oder auch diese Quick Funktionen nutzen wie "ich bin zuhause" "zuhause verlassen", wäre super wichtig um eine Alarmanlage zu realisieren und nicht immer 5 Apps zu öffnen sondern das mit Blocky über ein Datenpunkt regeln zu können.
                  Danke dir vielmals
                  • Lucas StiefelL Lucas Stiefel
                    Danke dir vielmals
                    tombox
                    @lucas-stiefel wird denn irgendwas erkannt wenn du den Adapter installierst und die Login Daten eingibst.
                    • T tombox
                      Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
                      Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                      Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
                      tapo.0.id.ip
                      Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                      Aktuelle Werte:
                      tapo.0.id
                      Motion Detection funktioniert mit Stream User und Password
                      Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
                      Zum Installieren:
                      https://github.com/TA2k/ioBroker.tapo
                      Loginablauf:
                      Die Tapo App Zugangsdaten eingeben
                      Steuern
                      tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
                      Steckdose und Kamerasteuerung aktivieren
                      App auf Handy aufrufen
                      "ich" (rechts unten) aufrufen
                      "Dienste"
                      "Dienste von Drittanbietern"
                      "Kompatibilität mit Drittanbietern" auf "ON"
                      CodierknechtC Offline
                      Codierknecht
                      @tombox
                      So, jetzt komme ich auch endlich mal dazu, den Adapter zu testen.
                      Zuerst einmal vielen Dank für Deine Mühe.
                      Das erste Problem habe ich (wie fast immer) bereits bei der Installation aus GitHub.
                      Mein ioBroker läuft als Docker-Container auf dem NAS (HP ProLiant mit DSM 6.1.7).
                      Eine Installation von Adaptern aus GitHub funktioniert fast nie. Beim letzten Versuch einen Adapter darüber zu installieren, habe ich gefühlte 100 Versuche benötigt. Irgendwann hat's dann auf wundersame Weise mal funktioniert - ohne dass ich etwas geändert hätte.
                      Ach so: Hatte ich schon erwähnt, dass Linux für mich ein Buch mit sieben Siegeln ist? 😕
                      Hier das Log:
                      0 info it worked if it ends with ok
                      1 verbose cli [
                      1 verbose cli   '/usr/bin/node',
                      1 verbose cli   '/usr/bin/npm',
                      1 verbose cli   'install',
                      1 verbose cli   'TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9'
                      1 verbose cli ]
                      2 info using npm@6.14.15
                      3 info using node@v14.18.3
                      4 verbose config Skipping project config: /opt/iobroker/.npmrc. (matches userconfig)
                      5 verbose npm-session 73452b28fa3671ee
                      6 silly install loadCurrentTree
                      7 silly install readLocalPackageData
                      8 silly fetchPackageMetaData error for github:TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9 Error while executing:
                      8 silly fetchPackageMetaData /usr/bin/git ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.tapo.git
                      8 silly fetchPackageMetaData error: cannot run ssh: No such file or directory
                      8 silly fetchPackageMetaData fatal: unable to fork
                      8 silly fetchPackageMetaData exited with error code: 128
                      9 timing stage:rollbackFailedOptional Completed in 2ms
                      10 timing stage:runTopLevelLifecycles Completed in 33447ms
                      11 verbose stack Error: exited with error code: 128
                      11 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/pacote/lib/util/finished.js:12:19)
                      11 verbose stack     at ChildProcess.emit (events.js:400:28)
                      11 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                      11 verbose stack     at Socket.<anonymous> (internal/child_process.js:443:11)
                      11 verbose stack     at Socket.emit (events.js:400:28)
                      11 verbose stack     at Pipe.<anonymous> (net.js:686:12)
                      12 verbose cwd /opt/iobroker
                      13 verbose Linux 3.10.102
                      14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "TA2k/ioBroker.tapo#e99d534ec2420efacc344378ed55391cc8407ca9"
                      15 verbose node v14.18.3
                      16 verbose npm  v6.14.15
                      17 error Error while executing:
                      17 error /usr/bin/git ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.tapo.git
                      17 error
                      17 error error: cannot run ssh: No such file or directory
                      17 error fatal: unable to fork
                      17 error
                      17 error exited with error code: 128
                      18 verbose exit [ 1, true ]
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        @tombox
                        Hier das Log:
                        1 verbose cli [
                        1 verbose cli ]
                        17 error
                        17 error
                        tombox
                        @codierknecht Empfehlung ist hier npm 8 also node 16.
                        Dazu müsstest du dein docker container updaten. der aktuelle buanet container enthält node 16
                        Bei npm 6 muss man 15min warten bei GitHub installation aber der adapter ist jetzt auch im latest enthalten
                        CodierknechtC 2 Antworten Letzte Antwort
                        • T tombox
                          Codierknecht
                          @tombox
                          Danke für den Hinweis!
                          Ich hatte ein anderes Image verwendet. Mit dem Buanet-Image funktioniert's einwandfrei.
                          Ich werde dann mal testen und berichten ...
                          • F Offline
                            Fraenki23
                            schrieb am zuletzt editiert von Fraenki23
                            Hallo
                            Ich habe mehrer Tapo P100 Diese habe ich mit dem Adapter abgerufen und kann wie gewollt den Status loggen.
                            Nun habe ich einen weiteren Tado p100 Acount und habe mit einem zusätzlichen Adapter den zweiten aktiviert. Leider habe ich festgestellt dass man nicht beide gleichzeitug nutzen kann wenn beide normal grün leuchten wird nur der Status von einem geändert.
                            Sollte das funktionieren?
                            Gruss Fränki
                            • F Fraenki23
                              Hallo
                              Gruss Fränki
                              tombox
                              @fraenki23 Nie getestet eigentlich sollte es gehen aber einfacher wäre es mit einem account
                              • T tombox
                                Codierknecht
                                @tombox
                                Der Adapter flutet mein Log.
                                Die Dose mit der genannten IP ist eingeschaltet und im Router nicht gesperrt. Schalten kann ich sowohl mit der App als auch mit dem Adapter.
                                Von den aktuell 4 in der App eingerichteten Dosen ist eine (Lichterkette) aktuell gar nicht gesteckt. Die ist im Log völlig unauffällig.
                                BTW: Von dem Konzept "Anmelden an der Cloud, um die Adressen zu ermitteln" bin ich noch nicht 100% überzeugt.
                                Für meine Begriffe wäre ein manuelles Eintragen der IP dem Anwender durchaus zuzumuten. Natürlich nur, wenn das auch zur Steuerung ausreichen würde.
                                Was passiert denn, wenn die Cloud mal nicht erreichbar ist? Sind die Dosen dann trotzdem schalt- und abfragbar?
                                Kann man dann das Abfragen der Cloud - soweit es denn notwendig ist - per Button in den Instanzeinstellungen nur bei Bedarf ausführen?
                                  @tombox
                                  tombox
                                  @codierknecht Abfrage zur cloud wird nur bei adapter start gemacht dann ist es unabhängig davon könnte man auch noch verbessern wenn die cloud nicht bei adapter start verfügbar ist
                                  CodierknechtC 3 Antworten Letzte Antwort
                                  • T tombox
                                    Codierknecht
                                    @tombox
                                    Mal 'ne Frage aus technischem Interesse:
                                    Habe ich das richtig mitbekommen, dass solche Adapter (Tapo, Meross usw.) intern für die lokale Kommunikation MQTT verwenden?
                                    Wenn ja: Könnte man dann - mit entsprechendem Aufwand - das Ganze auch selbst ohne Adapter einrichten? Oder ist die Kommunikation da mit einem (evtl. zeitlich begrenzten) Secret verschlüsselt?
                                    Grund meiner Frage: Ich habe hier mittlerweile die verschiedensten Hersteller im Einsatz, die aktuell jeweils einen eigenen Adapter benötigen. Vielleicht wäre es da vorteilhafter, das Ganze mit MQTT zu zentralisieren. Wenn eine Anmeldung an der Cloud nicht wirklich nötig ist und die Kommunikation dadurch rein lokal möglich ist, hätte das für mich einen gewissen Charme.
                                    • T tombox
                                      Codierknecht
                                      Dann darf das für meine Begriffe gerne ins Log geschrieben werden und der Adapter arbeitet nur mit den Geräten, die bereits eingerichtet sind.
                                      Dabei darfst Du gerne einen DP vorsehen, mit dem man ein Gerät auch mal logisch deaktivieren könnte, um z.B. vergebliche Verbindungsversuche bei ausgesteckten Geräten zu unterbinden.
                                      Dann wäre es natürlich auch praktisch, wenn man Geräte auch manuell hinzufügen könnte, um die Cloud komplett zu umgehen.
                                      Wenn die IP (evtl. auch die MAC) ausreichen sollte, bräuchte man theoretisch auch gar keine Cloud.
                                      • S schuellerf
                                        @tombox Hat bei mir auf Anhieb geklappt. Ich habe drei P110 und bin soweit sehr happy, danke! 🥳
                                        Zwei Kleinigkeiten:
                                        • Die Liste der remotes functions sollte offensichtlich vom Attribut "category" abhängen. Bei der P100 ist category: plug und da macht natürlich setBrightness, setColor und setColorTemp keinen Sinn
                                          (aber setPowerState schon, ... und geht wunderbar!)
                                        • Einer meiner drei P110 Stecker ist in einem anderen LAN. Das finde ich auch ok wenn ich das nicht steuern kann. (Eine cloudsteuerung sollte sowieso optional und per default off sein IMHO). Aber ein Status, dass er offensichtlich diese eine Dose nicht gefunden hat wäre nett, oder ich hab den übersehen
                                        DANKE nochmals!
                                        Codierknecht
                                        @schuellerf sagte in Test Adapter TP-Link Tapo:
                                        Zwei Kleinigkeiten:
                                        Die Liste der DP je Gerät ist reichlich lang.
                                        Hätte ich natürlich auch so gemacht. Erst mal alles holen was man kriegen kann. Wer weiß, wofür man es noch brauchen kann.
                                        Wenn der Adapter ins Repo wandert, könnte man auf einige der DP sicher verzichten.
                                        Auch von mir zunächst mal vielen Dank für Deine Mühe! 👍 👏
                                        • T tombox
                                          Codierknecht
                                          @tombox
                                          Aktuell zeigt sich bei mir folgendes Bild:
                                          • Der Adapter benötigt bei mir mehrere Neustarts, bevor er nicht nur grün wird, sondern sich die DP auch tatsächlich schalten lassen
                                          • Nach einer Weile fängt er dann wieder an, das Log voll zu schreiben. Synchron zum eingestellten Updateintervall. Dann lassen sich die Dosen auch nicht mehr schalten.
