  4. iQontrol Vis Support Thread
    6.6k
android app vishow-toios appiqontrolmobile uivis
1.6k Beiträge 143 Kommentatoren 899.9k Aufrufe 122 Beobachtet
  • s.bormannS s.bormann
    @meerkat sagte in iQontrol Vis Support Thread:
    Moin zusammen,
    Hi @s-bormann.
    Ich habe momentan sporadisch mal den Fehler, dass die Kacheln nicht richtig dargestellt werden, Siehe Screenshot
    In der Konsole habe ich dann folgendes stehen:
    AdsContent.js:1 [AdBlock] loadQueryList: e = TypeError: Failed to fetch
    l @ AdsContent.js:1
    (anonym) @ AdsContent.js:1
    await in (anonym) (async)
    layout.js:211 Uncaught TypeError: Cannot read properties of undefined (reading 'left')
        at layout.js:211:43
        at Array.map (<anonymous>)
        at x (layout.js:211:6)
        at u.value (shuffle.js:588:12)
        at u.value (shuffle.js:555:19)
        at u.value (shuffle.js:503:32)
        at u.value (shuffle.js:817:10)
        at u.value (shuffle.js:801:10)
        at index.js:7605:19
        at Array.forEach (<anonymous>)
    (anonym) @ layout.js:211
    x @ layout.js:211
    value @ shuffle.js:588
    value @ shuffle.js:555
    value @ shuffle.js:503
    value @ shuffle.js:817
    value @ shuffle.js:801
    (anonym) @ index.js:7605
    viewShuffleFilterHideDeviceIfInactive @ index.js:7604
    updateFunction @ index.js:6285
    updateState @ index.js:2556
    (anonym) @ index.js:7457
    (anonym) @ index.js:1665
    r.onack @ socket.io.js:8
    r.onpacket @ socket.io.js:8
    (anonym) @ socket.io.js:8
    r.emit @ socket.io.js:6
    r.ondecoded @ socket.io.js:6
    a.add @ socket.io.js:6
    r.ondata @ socket.io.js:6
    r.onPacket @ socket.io.js:6
    (anonym) @ socket.io.js:6
    r.onPacket @ socket.io.js:7
    r.onData @ socket.io.js:7
    ws.onmessage @ socket.io.js:8
        at layout.js:211:43
        at u.value (shuffle.js:841:12)
        at index.js:7769:53
    x @ layout.js:211
    value @ shuffle.js:841
    (anonym) @ index.js:7769
    (anonym) @ index.js:7768
    setTimeout (async)
    (anonym) @ index.js:7766
    viewShuffleReshuffle @ index.js:7775
    (anonym) @ index.js:7655
    (anonym) @ index.js:7623
    attributes (async)
    addClass @ jquery-1.11.3.min.js:5
    updateFunction @ index.js:7224
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
    (anonym) @ index.js:7454
    (anonym) @ index.js:1637
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
    (anonym) @ index.js:1636
        at layout.js:211:43
        at index.js:7605:19
    x @ layout.js:211
        at layout.js:211:43
        at index.js:7769:53
    Hat jemand ne Idee
    Zeige mal bitte die Zeile 7769 in der index.js
    meerkat
    #398
    @s-bormann 7769 ist die mit if (shuffleInstance.isEnabled) shuffleInstance.update(); else shuffleInstance.enable();
    Habe dir mal den kompletten if-Block reinkopiert
    if (!nearbyTimer){
    		(function(){ //Closure--> (everything declared inside keeps its value as ist is at the time the function is created)
    			var _id = setTimeout(function(){
    				console.log("viewShuffleReshuffle: Shuffle! id: " + _id);
    				viewShuffleInstances.forEach(function(shuffleInstance, i){
    				delete viewShuffleReshuffleTimeouts[_id];
    			}, delay);
    			viewShuffleReshuffleTimeouts[_id] = {destinationTime: destinationTime};
    			console.log("viewShuffleReshuffle: set timer id " + _id + " to destinationTime " + destinationTime);
    		})(); //<--End Closure
      meerkat
      #399
      Hi @dslraser,
      Du hattest mal ne Anleitung zu device-counter geschrieben. Kann man den bzw. die device-Ciunter auch unter der wissenschaftlichen URL nutzen? Bei Background URL bekomme ich was angezeigt, aber wenn ich die gleichen Einstellungen unter URL angebe, bleibt es in der Ansicht leer
      • M meerkat
        Hi @dslraser,
        dslraserD Offline
        dslraserD Offline
        dslraser
        #400
        @meerkat
        ich kenne ehrlich gesagt nichtmal den Unterschied von den von Dir genannten URL. 🤷
        • dslraserD dslraser
          @meerkat
          meerkat
          #401
          @dslraser Wenn ich es von @s-bormann richtig in Erinnerung habe, dann wird die Background-URL in der Kachel dargestellt bspw. beim vergrößern. Die Angabe in URL wird im Dialog unterhalb der Additional Infos angezeigt.
          Vielleicht hat s-bormann noch ne Idee
          G 1 Antwort Letzte Antwort
          • M meerkat
            Geesthachter
            schrieb am zuletzt editiert von Geesthachter
            #402
            Moin,
            Ich brauche Hilfe
            ich habe neuerdings ein Problem was ich mir nicht erklären kann.
            Ich will eine neue Zigbee Steckdose in iQontrol einbinden die ich über iQontrol dann einfach nur an und ausschalten will.
            Ich wähle als Gerätetyp wie immer Schalter aus und wähle unter STATE den Datenpunkt Switch aus.
            Speicher alles und rufe den neue angelegten Schalter über iQontrol im WLAN auf.
            So wie es sein soll kann ich die Steckdose AN und AUS schalten.
            Aber jetzt zu meinem Problem, rufe ich iQontrol nicht über WLAN auf sondern übers Internet über die Iobroker.net Cloud auf funktioniert das schalten der Steckdose nicht.
            Alle vorher bereits eingebundenen Steckdosen lassen sich schalten nur die eine neue nicht.
            Ich habe es dann noch einmal mit einer anderen Zigbee Steckdose und auch mit einer Sonoff Steckdose versucht, bei allen dasselbe Problem. Über WLAN funktioniert es aber nicht über die Cloud.
            Hat noch jemand das Problem? Bzw kann jemand mal versuchen ob es bei ihm funktioniert eine neu eingebundene Dose über die Cloud zu schalten.
            Probeweise habe ich eine der Steckdosen mal über VIS eingerichtet und dann per Cloud aufgerufen. Dort funktionier das Schalten sowohl über WLAN als auch über die Iobroker Cloud.
            Kann mir bitte jemand bei meinem Problem helfen? Ich bin echt am Verzweifeln.
            Björn
            • G Geesthachter
              Moin,
              Ich brauche Hilfe
              Björn
              Geesthachter
              #403
              Jetzt machen auch die "alten" Steckdosen über die Cloud Probleme.
              Über die Cloud und VIS funktioniert weiterhin alles aber über die Cloud und iQontrol funktionieren jetzt auch andere Steckdosen nicht mehr die sich bisher immer problemlos schalten ließen.
              Was kann es sein?
              Keiner eine Idee?
              • G Geesthachter
                Was kann es sein?
                Keiner eine Idee?
                da_WoodyD Offline
                da_WoodyD Offline
                #404
                @geesthachter sagte in iQontrol Vis Support Thread:
                Was kann es sein?
                Keiner eine Idee?
                sorry, aber das kann nicht an iQ liegen. da muss der fisch wo anders liegen. wirkt sich halt eventuell da aus.
                in der cloud funktionieren sie, im nächsten satz, in der cloud funktionieren sie nicht? wie soll man das verstehen?
                • G Offline
                  Geesthachter
                  #405
                  Hallo @da_woody
                  ich verstehe es ja auch nicht. Die Dose die ich neu einrichten will funktioniert über iQontrol per WLAN perfekt aber wenn ich die Dose per iQontrol über die Cloud schalten will dann kann ich sie dort, wenn ich sie vorher per WLAN eingeschaltet habe, über die Cloud zwar einmal ausschalten aber nicht wieder einschalten.
                  Versuche ich das ganze über VIS statt über iQontrol dann kann ich die Dose sowohl über WLAN als auch über die Cloud sowohl aus als auch an schalten und das auch nicht nur einmal sondern sooft ich will.
                  Es funktioniert wirklich nur das Zusammenspiel iQontrol - Cloud nicht.
                  Ich habe den Cloud Adapter schon neu installiert, ohne Erfolg.
                  Ich bin echt ratlos
                  da_WoodyD s.bormannS 2 Antworten Letzte Antwort
                  • G Geesthachter
                    Hallo @da_woody
                    Ich bin echt ratlos
                    da_WoodyD Offline
                    da_WoodyD Offline
                    #406
                    @geesthachter da kann ich nicht weiter helfen. verwende den cloud adapter nicht. wenn ich von unterwgs zugreife, dann über VPN, da das mein router selber kann.
                    • M meerkat
                      if (!nearbyTimer){
                      			}, delay);
                      s.bormannS Offline
                      s.bormannS Offline
                      s.bormann
                      #407
                      shuffleInstance
                      Hmm, da werden ja nur Methoden vom Plugin (shuffle.js) aufgerufen ohne Argumente... ich fürchte, da komme ich leider nicht weiter. Ggf. kannst Du den Fehler, wenn er auftritt, in der Konsole näher eingrenzen, wenn Du auf die einzelnen Fehler klickst (z.B. layout.js:211) und schaust, was ihn genau stört und dann im Stack immer weiter verfolgst, wo es her kommt. Aus der Ferne sehe ich da leider keinen Ansatz, sorry.
                      • G Geesthachter
                        Hallo @da_woody
                        Ich bin echt ratlos
                        s.bormannS Offline
                        s.bormannS Offline
                        s.bormann
                        #408
                        Hallo @da_woody
                        Ich bin echt ratlos
                        Hi, bitte mal ein Log aus der Browser-Konsole wenn der Fehler auftritt schicken mit den entsprechenden Zeilen des Fehlers, siehe Troubleshooting in der Readme auf Github. Danke
                        • N Offline
                          N Offline
                          navlis
                          #409
                          Guten Nachmittag euch
                          Ich habe ebend von meiner Frau den input bekommen das ich doch bitte den Inhalt von unserem kühlschrank in iqcontrol abrufbar machen soll 😉
                          Mein Plan war jetzt das ich erstmal halb smart mache.
                          Also ich gehe einkaufen und packen es in den Kühlschrank, nehme mein Handy und tippe alles ein so wie Hackfleisch 500g das würde ich dann gerne auf eine Liste schreiben und wenn ich oder wer auch immer es raus nimmt dad dann automatisch bzw mit klick auf rausgenommen oder so das von der vorhanden liste gelöscht wir und es auf die einkaufsliste geschrieben wird....
                          Gibt es die Möglichkeit eine Liste mit abhark Funktion in Iqontrol zu bauen ?? Wenn ja wie ich finde nur Listen ohne abhaken.
                          Oder habt ihr ne andere Idee 💡
                          LG aus lg
                          Silvan
                            Willkommen im iQontrol-Support-Thread!
                            iQontrol ist ein Visualisierungs-Adapter.
                            Number of Installations
                            Stable version
                            NPM version
                            Known Vulnerabilities
                            • Läuft auf allen Endgeräten - vom PC, über Tablet zu Handy - und passt sich allen Auflösungen dynamisch an
                            • Schnelle Ladezeit
                            • Lässt sich auf dem Handy/Tablet auf dem Homescreen speichern und fühlt sich dann an, wie eine App
                            • Mit den Standard-Einstellungen kommt man schnell zum Ziel
                            • Mit den erweiterten Einstellungen und Widgets hat man hingegen hohe Flexibilität und Anpassungsmöglichkeiten (bei manchen Installationen erkennt man gar nicht mehr, dass es eigentlich iQontrol ist)
                            Dieser Thread dient dem Support
                            Hier wird von allen Teilnehmern tatkräftig geholfen. Wir wissen, dass es unmöglich ist, alle Beiträge durchzulesen und die Suche im Forum manchmal nur bedingt hilft. Also bitte, einfach Fragen stellen und das ganze hier mehr als "Chat" begreifen.
                            Um dennoch zu viele Doppel-Fragen zu vermeiden, wäre es aber super, wenn ihr vorher grob die Readme und das Wiki durchstöbert.
                            Im Fehlerfall bitte immer auch ein Log aus der Browser-Konsole schicken - das geht ganz einfach und ist unter Troubleshooting in der Readme beschrieben.
                            Entwicklung
                            Wer hingegen immer auf dem Neuesten Stand sein will und die neuen Entwicklungen verfolgen oder mitwirken will, sei herzlich in den iQontrol Test-Thread eingeladen:
                            https://forum.iobroker.net/topic/22039
                            Getting started
                            Das Readme auf Github beschreibt die wichtigsten Einstellungen, Troubleshooting etc.:
                            https://github.com/sbormann/ioBroker.iqontrol
                            Video-Tutorials:
                            https://www.youtube.com/playlist?list=PL8epyNz8pGEv6-R8dnfXm-m5aBlZFKOBG
                            Wiki mit einer Sammlung nützlicher Scripte, Widgets etc.:
                            https://github.com/sbormann/ioBroker.iqontrol/wiki
                            Beispiele
                            Weitere Beispiele:
                            https://forum.iobroker.net/topic/32404
                            Und nun viel Spaß und Erfolg,
                            Sebastian
                            Aare 07
                            #410
                            @s-bormann
                            Ich wollte eigentliche zwei identische Widgets konfigurien.
                            Nun fehlt mir auf der Heizkorrektur der rot markierte Wert.
                            Leider finde ich nicht heraus wo ich etwas definiert habe dass diese beim Boiler erscheint, bei der Heizung leider nicht.
                            Any Ideas?
                            Zweite Frage: Kann ich die grösse der A_Info Icons und Schriften anpassen? Welche CSS und wie beeinflussen?
                            Ich hätte generell das blaue 2Haupicon" etwas kleiner und die Schriften der A_Info / B_Info etwas grösser.
                            Möglich mit vernünftigem Aufwand?
                            Raspi 4 SSD ioBroker
                            • A Aare 07
                              @s-bormann
                              Any Ideas?
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #411
                              @aare-07 sagte in iQontrol Vis Support Thread:
                              kopier die boilerkorrektur, ändere namen und die werte, dann sollts gleich sein.
                              icons kannst du selber bauen in der größe wie du magst und dann einfügen.
                              mal als beispiel:
                              • da_WoodyD da_Woody
                                mal als beispiel:
                                Aare 07
                                #412
                                @da_woody
                                Danke Woody.
                                1. Anzeige unten: Ja das dachte ich mir auch schon, ich möchte halt lernen welches Feld die Angabe unten steuert, nicht einfach drüberklatschen. Werde ich nun doch machen
                                2. Icon: Da hab ich nicht sehr weit gedacht und angenommen dass CSS die Grösse skaliert, werde mit Icons verschiedenener Grösse testen.
                                3. Bleibt noch die Frage ob ich den gelben Teil in der Grösse beeinflussen kann...
                                • A Aare 07
                                  @s-bormann
                                  Any Ideas?
                                  s.bormannS Offline
                                  s.bormannS Offline
                                  s.bormann
                                  #413
                                  @aare-07 Das Haupticon kleiner würde ich so machen, wie es @da_Woody vorgeschlagen hat.
                                  Die INFO_A/B Anpassungen gehen über die CSS-Klassen
                                  iQontrolDeviceInfoAIcon, iQontrolDeviceInfoAText und
                                  iQontrolDeviceInfoBIcon, iQontrolDeviceInfoBText.
                                  Im "Big-Mode", d.h. wenn alles bei großen Bildschirmen etwas größer dargestellt wird, geht es über die übergeordnete Klasse html.bigMode,
                                  Also z.B.
                                  .iQontrolDeviceInfoAIcon, .iQontrolDeviceInfoBIcon { width: 15px; }
                                  html.bigMode .iQontrolDeviceInfoAIcon, html.bigMode .iQontrolDeviceInfoBIcon { width: 20px; }
                                    Also z.B.
                                    Aare 07
                                    #414
                                    @s-bormann sagte in iQontrol Vis Support Thread:
                                    Also z.B.
                                    • A Aare 07
                                      @da_woody
                                      Danke Woody.
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #415
                                      @aare-07
                                      na dann öffne beide und vergleiche die einstellungen. irgendwo wird der unterschied zu finden sein. mein vorschlag dient nur der vereinfachung. ;)
                                      hab z.b. 10 heizungs kreise kombiniert shelly h&t, 1pm, andere icons, onlineanzeige, glow (on/off) ... da freut man sich über die kopiermöglichkeit... wird dann auch noch in jedem raum verwendet.
                                      CSS fummeln ist halt so eine sache. wirkt sich halt auf alles aus. nebenbei wirds wahrscheinlich bei einem update wieder flöten gehn.
                                        @aare-07
                                        s.bormannS Offline
                                        s.bormannS Offline
                                        s.bormann
                                        #416
                                        @da_woody sagte in iQontrol Vis Support Thread:
                                        @aare-07
                                        Man kann eigene CSS-Änderungen auch unter Optionen / Sonstiges / CSS eingeben, die bleiben dann auch bei einem Update gespeichert.
                                        • C Offline
                                          Cino
                                          #417
                                          Guten Morgen.
                                          Gibt es mittlerweile eine Möglichkeit eigene Geräte mit Layout zu erstellen?
                                          Als Beispiel habe ich den Alarm Adapter, den könnte man als Vorlage einfügen.
                                          Oder eine Klimaanlagensteuerung.
                                          IOB@RPI4
                                          Shelly, Zigbee, ebus
