  4. js-controller lässt sich nicht updaten...
    5.7k
35 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • Mr. BurnsM Offline
    Mr. BurnsM Offline
    Mr. Burns
    Guten Abend,
    nach einem update von node v14 auf v16 und npm v6 auf v8.15 läßt sich der js-controler (4.0.21 -->4.0.23) nicht updaten.
    Den fixer hab ich schon ein paar mal drüber laufen lassen, neu gestartet sowie den Befehl:
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    im Verzeichnis /opt/iobroker/node_modules ausgeführt.
    Nachfolgend hab ich den Ausdruck des debug modus angehängt.
    Für einen Hinweis wäre ich dankbar.
    pi@ioBroker:/opt/iobroker/node_modules $ iobroker upgrade self --debug
    Update js-controller from @4.0.21 to @4.0.23
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.15.0
    Installing iobroker.js-controller@4.0.23... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated appdirectory@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh /tmp/install-fb22f918.sh
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@9.0.0
    npm ERR! gyp info using node@16.17.1 | linux | arm
    npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.17.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.17.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.17.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8.h:30,
    npm ERR!                  from ../src/openzwave.hpp:27,
    npm ERR!                  from ../src/callbacks.cc:18:
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’
    npm ERR!              !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
    npm ERR!                                       ^~~~~~~~~~~
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:38: note: suggested alternative: ‘remove_cv’
    npm ERR!                                       remove_cv
    npm ERR!                                       remove_cv
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
    npm ERR!                                                   ^
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
    npm ERR!        ^~~~~~~
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:63: note: suggested alternative: ‘perror’
    npm ERR!        ^~~~~~~
    npm ERR!        perror
    npm ERR! make: *** [openzwave_shared.target.mk:148: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 5.10.103-v7l+
    npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    npm ERR! gyp ERR! node -v v16.17.1
    npm ERR! gyp ERR! node-gyp -v v9.0.0
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-24T19_39_48_428Z-debug-0.log
    • Mr. BurnsM Mr. Burns
      Guten Abend,
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.15.0
      npm ERR! code 1
      npm ERR!                                       remove_cv
      npm ERR!                                       remove_cv
      npm ERR!                                                   ^
      npm ERR!        ^~~~~~~
      npm ERR!        ^~~~~~~
      npm ERR!        perror
      @mr-burns
      Das hat mit dem rebuild von openzwave zu tun, nicht mit dem js-controller.
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      cd /opt/iobroker
      sudo -H -u iobroker npm cache clean --force
      apt policy python-dev-is-python3 python-is-python3 libudev-dev libopenzwave*
      Mr. BurnsM 1 Antwort Letzte Antwort
        @mr-burns
        cd /opt/iobroker
        Mr. BurnsM Offline
        Mr. BurnsM Offline
        Mr. Burns
        @thomas-braun das ist das Ergebnis der Abfragen:
        pi@ioBroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.1
        v16.17.1
        8.19.2
        4.0.21
        pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        /home/pi
        OK:1 http://archive.raspberrypi.org/debian buster InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        OK:3 https://repos.influxdata.com/debian stretch InRelease
        OK:4 https://phoscon.de/apt/deconz buster InRelease
        OK:5 https://deb.nodesource.com/node_16.x buster InRelease
        Alle Pakete sind aktuell.
        nodejs:
         Installiert:           16.17.1-deb-1nodesource1
         Installationskandidat: 16.17.1-deb-1nodesource1
         Versionstabelle:
        *** 16.17.1-deb-1nodesource1 500
               500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
            10.24.0~dfsg-1~deb10u1 500
        pi@ioBroker:~ $ cd /opt/iobroker
        pi@ioBroker:/opt/iobroker $ sudo -H -u iobroker npm cache clean --force
        npm WARN using --force Recommended protections disabled.
        pi@ioBroker:/opt/iobroker $ apt policy python-dev-is-python3 python-is-python3 libudev-dev libopenzwave*
        libudev-dev:
         Installiert:           241-7~deb10u8+rpi1
         Installationskandidat: 241-7~deb10u8+rpi1
         Versionstabelle:
        *** 241-7~deb10u8+rpi1 500
        libopenzwave1.5-dev:
         Installiert:           (keine)
         Installationskandidat: 1.5+ds-6
         Versionstabelle:
            1.5+ds-6 500
        libopenzwave1.5:
         Installiert:           1.5+ds-6
         Versionstabelle:
        *** 1.5+ds-6 500
        libopenzwave-doc:
         Versionstabelle:
            1.5+ds-6 500
        N: Paket python-dev-is-python3 kann nicht gefunden werden.
        N: Paket python-is-python3 kann nicht gefunden werden.
        Hilft das weiter?
        DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.17.1
          v16.17.1
          8.19.2
          4.0.21
          pi
          /home/pi
          nodejs:
           Versionstabelle:
          libudev-dev:
           Versionstabelle:
           Versionstabelle:
              1.5+ds-6 500
          libopenzwave1.5:
           Versionstabelle:
          *** 1.5+ds-6 500
          libopenzwave-doc:
           Versionstabelle:
              1.5+ds-6 500
          Hilft das weiter?
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @mr-burns strech ... buster... alles nicht aktuell !
          Lehrling seit 1975 !!!
            armv7l
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.17.1
            v16.17.1
            8.19.2
            4.0.21
            pi
            /home/pi
            nodejs:
             Versionstabelle:
            libudev-dev:
             Versionstabelle:
             Versionstabelle:
                1.5+ds-6 500
            libopenzwave1.5:
             Versionstabelle:
            *** 1.5+ds-6 500
            libopenzwave-doc:
             Versionstabelle:
                1.5+ds-6 500
            Hilft das weiter?
            @mr-burns
            sudo apt install libopenzwave1.5-dev
            Und pass das influx-Repo an.
              @mr-burns
              Mr. BurnsM Offline
              Mr. BurnsM Offline
              Mr. Burns
              @thomas-braun hat was gedauert. Nach dem update war der raspi nicht mehr erreichbar und es hat ein paar Tage gedauert, bis der micro HDMI adapter angekommen ist.
              Netzwerkkarte wieder aktiviert, System läuft wieder aber leider funktioniert es immer noch nicht:
              E: Paket libopenzwave1.5-dev kann nicht gefunden werden.
              E: Mittels des Musters »libopenzwave1.5-dev« konnte kein Paket gefunden werden.
                @mr-burns
                Okay, was wird denn da bei dir dann angeboten?
                sudo apt update
                apt policy libopenzwave*
                Mr. BurnsM 2 Antworten Letzte Antwort
                  @mr-burns
                  sudo apt update
                  Mr. BurnsM Offline
                  Mr. BurnsM Offline
                  Mr. Burns
                  @thomas-braun Das bekomme ich zurück:
                  sudo apt update
                  OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  OK:3 https://repos.influxdata.com/debian bullseye InRelease
                  OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                  OK:5 https://phoscon.de/apt/deconz bullseye InRelease
                  Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                  libopenzwave1.6-dev:
                   Installationskandidat: 1.6.1545+ds-2
                   Versionstabelle:
                      1.6.1545+ds-2 500
                  libopenzwave1.5:
                   Versionstabelle:
                  *** 1.5+ds-6 100
                  libopenzwave1.6:
                   Versionstabelle:
                      1.6.1545+ds-2 500
                  libopenzwave-doc:
                   Versionstabelle:
                      1.6.1545+ds-2 500
                    @mr-burns
                    sudo apt update
                    Mr. BurnsM Offline
                    Mr. BurnsM Offline
                    Mr. Burns
                    Ich hab mal die v1.6 installiert. Leider kann der js-controller immer noch nicht aktualisiert werden...
                    Stopped Objects DB
                    Stopped States DB
                    NPM version: 8.19.2
                    npm ERR! code 1
                    npm ERR! path /opt/iobroker/node_modules/pcap
                    npm ERR! command sh -c -- node-gyp rebuild
                    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
                    npm ERR!   CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
                    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
                    npm ERR! gyp info using node-gyp@9.1.0
                    npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/pcap/build/config.gypi',
                    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/pcap',
                    npm ERR! ../pcap_binding.cc:2:10: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden
                    npm ERR!     2 | #include <pcap/pcap.h>
                    npm ERR!       |          ^~~~~~~~~~~~~
                    npm ERR! compilation terminated.
                    npm ERR! make: *** [pcap_binding.target.mk:112: Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
                    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)
                    npm ERR! gyp ERR! System Linux 5.15.61-v7l+
                    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/pcap
                    npm ERR! gyp ERR! node-gyp -v v9.1.0
                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T15_32_29_851Z-debug-0.log
                    [/s]
                      sudo apt update
                       Versionstabelle:
                          1.6.1545+ds-2 500
                      libopenzwave1.5:
                       Versionstabelle:
                      *** 1.5+ds-6 100
                      libopenzwave1.6:
                       Versionstabelle:
                          1.6.1545+ds-2 500
                      libopenzwave-doc:
                       Versionstabelle:
                          1.6.1545+ds-2 500
                      @mr-burns
                      sudo apt install libpcap0.8-dev
                      Und was genau hast du da jetzt installiert?
                      sudo apt update
                        @mr-burns
                        sudo apt update
                        Mr. BurnsM Offline
                        Mr. BurnsM Offline
                        Mr. Burns
                        sudo apt-get install libopenzwave1.6-dev
                          @mr-burns
                          Ausgaben zeigen...
                            @mr-burns
                            Ausgaben zeigen...
                            Mr. BurnsM Offline
                            Mr. BurnsM Offline
                            Mr. Burns
                              Installiert:           1.6.1545+ds-2
                              Versionstabelle:
                             *** 1.6.1545+ds-2 500
                            libopenzwave1.5:
                              Installationskandidat: (keine)
                              Versionstabelle:
                                 1.5+ds-6 -1
                            libopenzwave1.6:
                              Versionstabelle:
                            libopenzwave-doc:
                              Versionstabelle:
                                 1.6.1545+ds-2 500
                                Versionstabelle:
                              libopenzwave1.5:
                                Versionstabelle:
                                   1.5+ds-6 -1
                              libopenzwave1.6:
                                Versionstabelle:
                              libopenzwave-doc:
                                Versionstabelle:
                                   1.6.1545+ds-2 500
                              @mr-burns
                              libopenzwave sollte passen. Die libpcap0.8-dev ist auch installiert?
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 8.19.2
                                npm ERR! code 1
                                [/s]
                                DJMarc75D Offline
                                DJMarc75D Offline
                                DJMarc75
                                @mr-burns sagte in js-controller lässt sich nicht updaten...:
                                NPM version: 8.19.2
                                Seh ich das richtig dass da immer noch was krumm ist ?
                                Mr. BurnsM Thomas BraunT 2 Antworten Letzte Antwort
                                  @mr-burns
                                  Mr. BurnsM Offline
                                  Mr. BurnsM Offline
                                  Mr. Burns
                                  @thomas-braun ja, ist installiert. versuche gerade noch einmal...
                                  • DJMarc75D DJMarc75
                                    NPM version: 8.19.2
                                    Mr. BurnsM Offline
                                    Mr. BurnsM Offline
                                    Mr. Burns
                                    schrieb am zuletzt editiert von Mr. Burns
                                    @djmarc75 das kann ich nicht beantworten. Aber im iobroker gehen 2 wichtige adapter nicht:#
                                    s7 und javascript...aber vielleicht mit dem update welches ich gerade durchgeführt habe.
                                      NPM version: 8.19.2
                                      @djmarc75 sagte in js-controller lässt sich nicht updaten...:
                                      Siehst du richtig.
                                      @Mr-Burns
                                        Siehst du richtig.
                                        @Mr-Burns
                                        Mr. BurnsM Offline
                                        Mr. BurnsM Offline
                                        Mr. Burns
                                        Das Ergebnis des update Versuchs vor dem neuen update:
                                        Stopped Objects DB
                                        Stopped States DB
                                        NPM version: 8.19.2
                                        npm ERR! code 1
                                        npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
                                        npm ERR!   492 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
                                        npm ERR!       |                                      remove_cv
                                        npm ERR!       |                                                  ^
                                        npm ERR!       |                                                               ^~~~~~~
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T16_58_37_038Z-debug-0.log
                                        Teil 2:
                                        armv7l
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.17.1
                                        v16.17.1
                                        8.19.2
                                        4.0.21
                                        pi
                                        /home
                                        OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                                        OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        nodejs:
                                         Versionstabelle:
                                               500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                            12.22.12~dfsg-1~deb11u1 500
                                        [/s]
                                        Thomas BraunT 3 Antworten Letzte Antwort
                                          Stopped Objects DB
                                          Stopped States DB
                                          NPM version: 8.19.2
                                          npm ERR! code 1
                                          npm ERR!       |                                                  ^
                                          npm ERR!       |                                                               ^~~~~~~
                                          Teil 2:
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v16.17.1
                                          v16.17.1
                                          8.19.2
                                          4.0.21
                                          pi
                                          /home
                                          nodejs:
                                           Versionstabelle:
                                          [/s]
                                          @mr-burns
                                          Interessanter wäre:
