  4. js-controller lässt sich nicht updaten...
    5.7k
35 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    @mr-burns
    Okay, was wird denn da bei dir dann angeboten?
    sudo apt update
    apt policy libopenzwave*
    Mr. BurnsM Offline
    Mr. BurnsM Offline
    Mr. Burns
    Ich hab mal die v1.6 installiert. Leider kann der js-controller immer noch nicht aktualisiert werden...
    iobroker upgrade self --debug
    Update js-controller from @4.0.21 to @4.0.23
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.19.2
    Installing iobroker.js-controller@4.0.23... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated appdirectory@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/pcap
    npm ERR! command failed
    npm ERR! command sh -c -- node-gyp rebuild
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/pcap/build“ wird verlassen
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@9.1.0
    npm ERR! gyp info using node@16.17.1 | linux | arm
    npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/pcap/build/config.gypi',
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.17.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.17.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.17.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/pcap',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! ../pcap_binding.cc:2:10: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden
    npm ERR!     2 | #include <pcap/pcap.h>
    npm ERR!       |          ^~~~~~~~~~~~~
    npm ERR! compilation terminated.
    npm ERR! make: *** [pcap_binding.target.mk:112: Release/obj.target/pcap_binding/pcap_binding.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 5.15.61-v7l+
    npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/pcap
    npm ERR! gyp ERR! node -v v16.17.1
    npm ERR! gyp ERR! node-gyp -v v9.1.0
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T15_32_29_851Z-debug-0.log
    [/s]
    • Mr. BurnsM Mr. Burns
      @thomas-braun Das bekomme ich zurück:
      sudo apt update
      OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:3 https://repos.influxdata.com/debian bullseye InRelease
      OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
      OK:5 https://phoscon.de/apt/deconz bullseye InRelease
      Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      libopenzwave1.6-dev:
       Installiert:           (keine)
       Installationskandidat: 1.6.1545+ds-2
       Versionstabelle:
          1.6.1545+ds-2 500
      libopenzwave1.5:
       Installiert:           1.5+ds-6
       Installationskandidat: 1.5+ds-6
       Versionstabelle:
      *** 1.5+ds-6 100
      libopenzwave1.6:
       Versionstabelle:
          1.6.1545+ds-2 500
      libopenzwave-doc:
       Versionstabelle:
          1.6.1545+ds-2 500
      @mr-burns
      sudo apt install libpcap0.8-dev
      Und was genau hast du da jetzt installiert?
      sudo apt update
      Mr. BurnsM 1 Antwort Letzte Antwort
        @mr-burns
        sudo apt update
        Mr. BurnsM Offline
        Mr. BurnsM Offline
        Mr. Burns
        sudo apt-get install libopenzwave1.6-dev
          @mr-burns
          Ausgaben zeigen...
            @mr-burns
            Ausgaben zeigen...
            Mr. BurnsM Offline
            Mr. BurnsM Offline
            Mr. Burns
              Installiert:           1.6.1545+ds-2
              Versionstabelle:
             *** 1.6.1545+ds-2 500
            libopenzwave1.5:
              Installationskandidat: (keine)
              Versionstabelle:
                 1.5+ds-6 -1
            libopenzwave1.6:
              Versionstabelle:
            libopenzwave-doc:
              Versionstabelle:
                 1.6.1545+ds-2 500
                Versionstabelle:
              libopenzwave1.5:
                Versionstabelle:
                   1.5+ds-6 -1
              libopenzwave1.6:
                Versionstabelle:
              libopenzwave-doc:
                Versionstabelle:
                   1.6.1545+ds-2 500
              @mr-burns
              libopenzwave sollte passen. Die libpcap0.8-dev ist auch installiert?
                Stopped Objects DB
                Stopped States DB
                NPM version: 8.19.2
                npm ERR! code 1
                [/s]
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @mr-burns sagte in js-controller lässt sich nicht updaten...:
                NPM version: 8.19.2
                Seh ich das richtig dass da immer noch was krumm ist ?
                Lehrling seit 1975 !!!
                Mr. BurnsM Thomas BraunT 2 Antworten Letzte Antwort
                  @mr-burns
                  Mr. BurnsM Offline
                  Mr. BurnsM Offline
                  Mr. Burns
                  @thomas-braun ja, ist installiert. versuche gerade noch einmal...
                  • DJMarc75D DJMarc75
                    NPM version: 8.19.2
                    Mr. BurnsM Offline
                    Mr. BurnsM Offline
                    Mr. Burns
                    schrieb am zuletzt editiert von Mr. Burns
                    @djmarc75 das kann ich nicht beantworten. Aber im iobroker gehen 2 wichtige adapter nicht:#
                    s7 und javascript...aber vielleicht mit dem update welches ich gerade durchgeführt habe.
                      NPM version: 8.19.2
                      @djmarc75 sagte in js-controller lässt sich nicht updaten...:
                      Siehst du richtig.
                      @Mr-Burns
                      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                        Siehst du richtig.
                        @Mr-Burns
                        Mr. BurnsM Offline
                        Mr. BurnsM Offline
                        Mr. Burns
                        Das Ergebnis des update Versuchs vor dem neuen update:
                        Stopped Objects DB
                        Stopped States DB
                        NPM version: 8.19.2
                        npm ERR! code 1
                        npm ERR! path /opt/iobroker/node_modules/openzwave-shared
                        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
                        npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
                        npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
                        npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
                        npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
                        npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8.h:30,
                        npm ERR!                  from ../src/openzwave.hpp:27,
                        npm ERR!                  from ../src/callbacks.cc:18:
                        npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
                        npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
                        npm ERR!   492 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
                        npm ERR!       |                                      remove_cv
                        npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
                        npm ERR!       |                                                  ^
                        npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
                        npm ERR!       |                                                               ^~~~~~~
                        npm ERR! make: *** [openzwave_shared.target.mk:148: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
                        npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
                        npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T16_58_37_038Z-debug-0.log
                        Teil 2:
                        armv7l
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.1
                        v16.17.1
                        8.19.2
                        4.0.21
                        pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                        /home
                        OK:4 https://phoscon.de/apt/deconz bullseye InRelease
                        OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        nodejs:
                         Installiert:           16.17.1-deb-1nodesource1
                         Installationskandidat: 16.17.1-deb-1nodesource1
                         Versionstabelle:
                        *** 16.17.1-deb-1nodesource1 500
                               500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                            12.22.12~dfsg-1~deb11u1 500
                        [/s]
                        Thomas BraunT 3 Antworten Letzte Antwort
                          Stopped Objects DB
                          Stopped States DB
                          NPM version: 8.19.2
                          npm ERR! code 1
                          npm ERR!       |                                                  ^
                          npm ERR!       |                                                               ^~~~~~~
                          Teil 2:
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.17.1
                          v16.17.1
                          8.19.2
                          4.0.21
                          pi
                          /home
                          nodejs:
                           Versionstabelle:
                          [/s]
                          @mr-burns
                          Interessanter wäre:
                            Stopped Objects DB
                            Stopped States DB
                            NPM version: 8.19.2
                            npm ERR! code 1
                            npm ERR!       |                                                  ^
                            npm ERR!       |                                                               ^~~~~~~
                            Teil 2:
                            armv7l
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.17.1
                            v16.17.1
                            8.19.2
                            4.0.21
                            pi
                            /home
                            nodejs:
                             Versionstabelle:
                            [/s]
                            Lass die Finger von individuellen Updates von npm. Egal ob das irgendwo empfohlen wird.
                            iobroker stop
                            sudo apt update
                            sudo apt full-upgrade
                            sudo apt install --reinstall nodejs
                            cd /opt/iobroker
                            sudo -H -u iobroker npm cache clear --force
                            sudo reboot
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 8.19.2
                              npm ERR! code 1
                              npm ERR!       |                                                  ^
                              npm ERR!       |                                                               ^~~~~~~
                              Teil 2:
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.17.1
                              v16.17.1
                              8.19.2
                              4.0.21
                              pi
                              /home
                              nodejs:
                               Versionstabelle:
                              [/s]
                              @mr-burns
                              Warum wird da eigentlich openzwave gebaut?
                              Wenn ich der readme von zwave2 vertrauen darf wird das (anders als iobroker.zwave) da garnicht benötigt?
                              Was haste da also am Start?
                              iob update -i
                                @mr-burns
                                iob update -i
                                Mr. BurnsM Offline
                                Mr. BurnsM Offline
                                Mr. Burns
                                @thomas-braun Das ist ein gute Frage...kann ich nicht beantworten.
                                Ich habe die zwave adapter installiert aber nicht aktiviert (haben nicht funktioniert oder so, weiß nicht mehr genau)
                                  Das Zeug spukt da aber noch herum.
                                  Kein Wunder...
                                    Kein Wunder...
                                    Mr. BurnsM Offline
                                    Mr. BurnsM Offline
                                    Mr. Burns
                                    iob update -i
                                    Used repository: stable
                                    Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                    Adapter    "amazon-dash"  : 1.1.0    , installed 0.3.1  [Updatable]
                                    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                                    Adapter    "ble"          : 0.13.0   , installed 0.13.0
                                    Adapter    "bsblan"       : 0.2.2    , installed 0.2.2
                                    Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                                    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                    Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                    Adapter    "geofency"     : 1.1.1    , installed 1.1.1
                                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                    Adapter    "history"      : 2.2.0    , installed 2.2.0
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                    Adapter    "ical"         : 1.13.1   , installed 1.13.1
                                    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
                                    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
                                    Adapter    "mielecloudservice": 6.3.2, installed 6.3.2
                                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                    Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
                                    Adapter    "modbus"       : 5.0.5    , installed 5.0.5
                                    Adapter    "openweathermap": 0.3.0   , installed 0.3.0
                                    Adapter    "paw"          : 0.3.2    , installed 0.3.2
                                    Adapter    "proxy"        : 1.3.1    , installed 1.3.1
                                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                                    Adapter    "s7"           : 1.3.13   , installed 1.3.13
                                    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                    Adapter    "sonos"        : 2.2.3    , installed 2.2.3
                                    Adapter    "synology"     : 2.1.9    , installed 2.1.9
                                    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                                    Adapter    "terminal"     : 0.2.6    , installed 0.2.6
                                    Adapter    "tinker"       : 1.1.1    , installed 1.1.1
                                    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
                                    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                                    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                                    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                    Adapter    "zwave2"       : 3.0.3    , installed 3.0.3
                                      iob update -i
                                      @mr-burns
                                      Hast du jetzt die Befehle aus Post #21 ausgeführt?
                                        @mr-burns
                                        Mr. BurnsM Offline
                                        Mr. BurnsM Offline
                                        Mr. Burns
                                        Ja...versuche gerade wieder ein update vom js-controller
                                        Ergebnis:
                                        Stopped Objects DB
                                        Stopped States DB
                                        NPM version: 8.15.0
                                        npm ERR! code 1
                                        npm ERR! command sh /tmp/install-568a43d9.sh
                                        npm ERR! gyp info using node-gyp@9.0.0
                                        npm ERR!       |                                                  ^
                                        npm ERR!       |                                                               ^~~~~~~
                                        npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                        npm ERR! gyp ERR! node-gyp -v v9.0.0
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T17_36_01_287Z-debug-0.log
                                        [/s]
                                          Ergebnis:
                                          Stopped Objects DB
                                          Stopped States DB
                                          NPM version: 8.15.0
                                          npm ERR! code 1
                                          npm ERR!       |                                                  ^
                                          npm ERR!       |                                                               ^~~~~~~
                                          [/s]
                                          openzwave-shared
                                          Schmeiß den Kram mal raus.
                                          cd /opt/iobroker
                                          npm ls openzwave-shared
                                          sudo -H -u iobroker npm uninstall openzwave-shared
