  3. Off Topic
  4. Linux für BeeLink BT3 Pro & Einsteiger?
linux mintlinux ubuntudebianlinuxbeelink bt3 pro
46 Beiträge 7 Kommentatoren 4.1k Aufrufe 5 Beobachtet
  • D Dieter_P
    @thomas-braun said in Linux für BeeLink BT3 Pro & Einsteiger?:
    apt policy bluez-firmware
    pi@iobroker:~$ apt policy bluez-firmware
    bluez-firmware:
      Installiert:           (keine)
      Installationskandidat: 1.2-4
      Versionstabelle:
         1.2-4 500
            500 http://deb.debian.org/debian bullseye/non-free amd64 Packages
    @dieter_p
    Dann installier die bluez-firmware mal.
    sudo apt install bluez-firmware
      @dieter_p
      Dieter_P
      Danke. glaube das hat nicht geholfen:
      pi@iobroker:~$ sudo dmesg | grep Bluetooth
      [sudo] Passwort für pi:
      [    7.688100] Bluetooth: Core ver 2.22
      [    7.688204] Bluetooth: HCI device and connection manager initialized
      [    7.688215] Bluetooth: HCI socket layer initialized
      [    7.688221] Bluetooth: L2CAP socket layer initialized
      [    7.688234] Bluetooth: SCO socket layer initialized
      [    7.748712] Bluetooth: HCI UART driver ver 2.3
      [    7.748721] Bluetooth: HCI UART protocol H4 registered
      [    7.748723] Bluetooth: HCI UART protocol BCSP registered
      [    7.748801] Bluetooth: HCI UART protocol LL registered
      [    7.748804] Bluetooth: HCI UART protocol ATH3K registered
      [    7.748832] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [    7.749009] Bluetooth: HCI UART protocol Intel registered
      [    7.749366] Bluetooth: HCI UART protocol Broadcom registered
      [    7.749394] Bluetooth: HCI UART protocol QCA registered
      [    7.749397] Bluetooth: HCI UART protocol AG6XX registered
      [    7.749421] Bluetooth: HCI UART protocol Marvell registered
      [    7.962720] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [    7.962726] Bluetooth: BNEP filters: protocol multicast
      [    7.962737] Bluetooth: BNEP socket layer initialized
      [    8.017674] Bluetooth: hci1: BCM: failed to write clock (-56)
      [    8.017688] Bluetooth: hci1: Failed to set baudrate
      [    8.133685] Bluetooth: hci1: BCM: chip id 107
      [    8.136026] Bluetooth: hci1: BCM: features 0x2f
      [    8.159319] Bluetooth: hci1: BCM4345C0
      [    8.159332] Bluetooth: hci1: BCM4345C0 (003.001.025) build 0000
      [    8.159455] Bluetooth: hci1: BCM: firmware Patch file not found, tried:
      [    8.159461] Bluetooth: hci1: BCM: 'brcm/BCM4345C0.hcd'
      [    8.159465] Bluetooth: hci1: BCM: 'brcm/BCM.hcd'
      Edit: Ist es ein Versuch wert die txt-Datei von Git zu laden wie hier beschrieben: https://forum.iobroker.net/topic/15846/gelöst-iobroker-installation-auf-beelink-bt3-pro/25
      und im Firmware Ordner abzulegen?
      Genau die ...43455 fehlt bei mir jedenfalls.
      Scheiter da aktuell an den Zugriffsrechten per WinSCP. User-Log-In hat da keine Rechte und Root Log-In geht nicht mehr.
      J WalW 2 Antworten Letzte Antwort
      • D Dieter_P
        Jan1
        @dieter_p
        Ich hatte die BT FW bei mir nicht geladen und BT trotzdem mit dem BLE Adapter am Laufen. Teste doch einfach mal ob BT funktioniert oder nicht, dann kannst dem Problem immer noch nachgehen. Bei mir hat allerdings die Installation der BT FW eben funktioniert.
        • D Dieter_P
          WalW Offline
          WalW Offline
          Wal
          @dieter_p ,
          Link.
          Walter
          DoorIO-Adapter
          • WalW Wal
            @dieter_p ,
            Link.
            Dieter_P
            @Jan1 soweit ich das gerade testen konnte ist BT nicht aktiv/funktional
            @wal
            Danke. Am Ende die Lösung für Wifi+BT Kombinationen klingt für mich geanu wie der Link oben hier aus dem Forum wo die gefixte txt Datei in den FirmwareOrdner kopiert wurde und alles lief.
            Scheiter noch beim Zugriff auf Ordner die Root-Rechte haben per WinSCP.
            Mal gucken ob ich drumherum komme-> Kopieren in einen 0815 Ordner per WinSCP und dann per Terminal und sudo die Datei verschieben .....
            • D Dieter_P
              @wal
              Jan1
              @dieter_p sagte in Linux für BeeLink BT3 Pro & Einsteiger?:
              Der einzige Moment bei dem ich mit root was erledige, weil das wohl anders per FTP einfach nicht will ;)
              Warum BT bei Deinem Beelink zickt, ist allerdings etwas seltsam, da ich damit bei meinem noch nie Probleme hatte. Wobei ich den zu Begin auch mehrfach neu eingerichtet hatte, bis ich mir sicher war, dass alles passt.
              Machs einfach noch mal frisch, das bringt Erfahrung und bei dem Wetter hast eh Zeit ;)
              • J Jan1
                Dieter_P
                @jan1 said in Linux für BeeLink BT3 Pro & Einsteiger?:
                Nuja, geht gleich zum Freibad-Closing bis 20h unter Flutlicht 😁
                Aber komisch ist das schon, dass es bei Dir so klappt. Vielleicht die beste Idee nochmal neu zu starten. Aber eine Lösung für den Transfer in Root-Ordner muß ich mir eh ertüfteln. Der Wireguard-Ordner hat auch Root-Rechte und da würde ich doch einfach gerne die Backup-Files reinkopieren.
                Edit: Gerade mit der TXT Datei von Git im Firmware Ordner neu gestartet:
                pi@iobroker:~$ sudo dmesg | grep bluetooth
                [    8.327549] bluetooth hci0: firmware: failed to load brcm/BCM4345C0.hcd (-2)
                [    8.327626] bluetooth hci0: firmware: failed to load brcm/BCM.hcd (-2)
                Thomas BraunT J 2 Antworten Letzte Antwort
                • D Dieter_P
                  @dieter_p
                  sudo mv /pfad/der/quelldatei /pfad/zum/zielverzeichnis
                  • D Dieter_P
                    Jan1
                    Mit Neoprenanzug LOL
                    Ich habs ohne root user aufgegeben etwas per FTP an der Kiste zu machen, da wirst wahnsinnig. Viel mach ich so eh nicht, meist auch nur das Backup in den Backups Ordner schieben, wenn der Adapter nach ner Neuinstallation einfach den NAS nicht mag. Ich nutze dazu aber auch Filzilla, sollte aber auch kein großer Unterschied zu Win SCP sein.
                    Thomas hat ja schon die Konsolen Befehle fürs Kopieren gezeigt, so gehts auf alle Fälle, aber ich bin eben Mausschubser.
                    Thomas BraunT D 2 Antworten Letzte Antwort
                    • J Jan1
                      @jan1 sagte in Linux für BeeLink BT3 Pro & Einsteiger?:
                      Braucht man ja auch beides nicht.
                      • J Jan1
                        Dieter_P
                        ..., aber ich bin eben Mausschubser.
                        ich auch. deswegen den midnight commander mit sudo starten pusht mich etwas in Richtung Wohlfühlumgebung :)
                        • D Dieter_P
                          @dieter_p
                          Aktiviere die debian backports für bullseye. Da liegt eine aktuellere Version der bluez-firmware drin, die hat die richtigen Dateien dabei.
                          sudo nano /etc/apt/sources.list
                          dann dort das einfügen:
                          deb http://deb.debian.org/debian bullseye-backports main contrib non-free
                          deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
                          Dann wie üblich:
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Edit: Es ist möglich, dass die Priority vom backports-Repo niedriger (100) als das Haupt-Repo (500) eingestellt ist. Dann einfach mit
                          die Versionnummern herausfinden und gezielt installieren:
                          Beispiel:
                          bluez-firmware:
                            Installed: 1.2-7~bpo11+1
                            Candidate: 1.2-7~bpo11+1
                            Version table:
                           *** 1.2-7~bpo11+1 100
                                  100 http://deb.debian.org/debian bullseye-backports/non-free arm64 Packages
                                  100 http://deb.debian.org/debian bullseye-backports/non-free armhf Packages
                               1.2-4+rpt8 500
                                  500 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages
                                  500 http://archive.raspberrypi.org/debian bullseye/main armhf Packages
                               1.2-4 500
                                  500 http://deb.debian.org/debian bullseye/non-free arm64 Packages
                                  500 http://deb.debian.org/debian bullseye/non-free armhf Packages
                          Also hier:
                          sudo apt install bluez-firmware=1.2-7~bpo11+1
                          alternativ:
                          sudo apt install bluez-firmware -t bullseye-backports
                          Kein herumgefuhrwerke mit FTP, root shell und sonstigem Krempel, den kein Mensch braucht.
                            @dieter_p
                            Dann wie üblich:
                            sudo apt update
                            sudo reboot
                            Beispiel:
                            bluez-firmware:
                              Version table:
                                 1.2-4+rpt8 500
                                 1.2-4 500
                            Also hier:
                            alternativ:
                            Dieter_P
                            Weil es direkt und genauso mit 1.2.7 funktioniert:
                            [    7.737027] bluetooth hci1: firmware: direct-loading firmware brcm/BCM4345C0.        hcd
                            Danke🙏 👍
                            • D Dieter_P
                              Danke🙏 👍
                              Jan1
                              @dieter_p
                              Erklärt warum das bei mir funktioniert, da ich die Backports eh immer drin habe ;)
                              • J Jan1
                                @dieter_p
                                Dieter_P
                                edit: hat sich geklärt :)
