  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Tuya Steckdose offline - Alexa erreichbar
    5.1k
tuyatuya adaptersteckdoseoffline
60 Beiträge 4 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • M martin
    @ofbeqnpolkkl6mby5e13
    Nein, Linux. Habe jetzt nur vom Windows-PC aus den Ping gemacht.
    martin
    /opt/iobroker$ ping 192.168.177.175
    PING 192.168.177.175 (192.168.177.175) 56(84) bytes of data.
    64 bytes from 192.168.177.175: icmp_seq=1 ttl=255 time=91.0 ms
    64 bytes from 192.168.177.175: icmp_seq=2 ttl=255 time=149 ms
    64 bytes from 192.168.177.175: icmp_seq=3 ttl=255 time=34.4 ms
    64 bytes from 192.168.177.175: icmp_seq=4 ttl=255 time=56.3 ms
    64 bytes from 192.168.177.175: icmp_seq=5 ttl=255 time=85.7 ms
    64 bytes from 192.168.177.175: icmp_seq=6 ttl=255 time=108 ms
    64 bytes from 192.168.177.175: icmp_seq=7 ttl=255 time=20.9 ms
    64 bytes from 192.168.177.175: icmp_seq=8 ttl=255 time=7.05 ms
    64 bytes from 192.168.177.175: icmp_seq=9 ttl=255 time=27.6 ms
    64 bytes from 192.168.177.175: icmp_seq=10 ttl=255 time=10.1 ms
    64 bytes from 192.168.177.175: icmp_seq=11 ttl=255 time=7.41 ms
    64 bytes from 192.168.177.175: icmp_seq=12 ttl=255 time=9.57 ms
    64 bytes from 192.168.177.175: icmp_seq=13 ttl=255 time=5.77 ms
    64 bytes from 192.168.177.175: icmp_seq=14 ttl=255 time=5.80 ms
    64 bytes from 192.168.177.175: icmp_seq=15 ttl=255 time=5.56 ms
    64 bytes from 192.168.177.175: icmp_seq=16 ttl=255 time=9.18 ms
    64 bytes from 192.168.177.175: icmp_seq=17 ttl=255 time=5.96 ms
    64 bytes from 192.168.177.175: icmp_seq=18 ttl=255 time=12.3 ms
    64 bytes from 192.168.177.175: icmp_seq=19 ttl=255 time=5.50 ms
    64 bytes from 192.168.177.175: icmp_seq=20 ttl=255 time=7.31 ms
    64 bytes from 192.168.177.175: icmp_seq=21 ttl=255 time=7.46 ms
    64 bytes from 192.168.177.175: icmp_seq=22 ttl=255 time=7.15 ms
    64 bytes from 192.168.177.175: icmp_seq=23 ttl=255 time=23.4 ms
    64 bytes from 192.168.177.175: icmp_seq=24 ttl=255 time=9.34 ms
    64 bytes from 192.168.177.175: icmp_seq=25 ttl=255 time=8.35 ms
    64 bytes from 192.168.177.175: icmp_seq=26 ttl=255 time=7.87 ms
    O 1 Antwort Letzte Antwort
    • M martin
      O Offline
      O Offline
      oFbEQnpoLKKl6mbY5e13
      @martin
      Okay, dann belegt vermutlich etwas den Port 6668.
      • O oFbEQnpoLKKl6mbY5e13
        @martin
        martin
        Bei diesen 2 IPs?? Weil andere Tuya Geräte funktionieren ja einwandfrei.
        • M martin
          O Offline
          O Offline
          @martin
          Dann stellt sich die Frage, ob das, was da unter der IP-Adresse antwortet, tatsächlich die Steckdose ist.
          Hast du die Steckdose einfach mal rausgezogen und wieder reingesteckt?
            @martin
            martin
            Ich verstehe was du meinst.
            Kann ich in der App oder über Alexa irgendwie die IP rausfinden?
            • M martin
              O Offline
              O Offline
              @martin
              Zunächst guckst du in die App. In den Informationen zu der Steckdose findest du die MAC-Adresse.
              Diese vergleichst du mit der MAC-Adresse, die in der Fritzbox zu der IP-Adresse angezeigt wird.
                martin
                MAC Adressen sind in der App und FritzBox unter der IP-Adresse identisch.
                • M martin
                  O Offline
                  O Offline
                  @martin
                  Hattest du die Steckdosen mal vom Strom getrennt?
                    @martin
                    martin
                    Nein. Nur vor ca. 2 Wochen iobroker Updates (nodejs und etliche Adapter) gemacht.
                    • M martin
                      O Offline
                      O Offline
                      @martin
                      Dann mach das mal.
                        @martin
                        Dann mach das mal.
                        martin
                        stehen immer noch auf "Online - false".
                        • M martin
                          O Offline
                          O Offline
                          @martin
                          Das stehen die bei mir auch hin und wieder. Schalten lassen sie sich trotzdem.
                            @martin
                            martin
                            Schalten lassen sie sich leider nicht.
                            • M martin
                              O Offline
                              O Offline
                              @martin
                              Haben die denn überhaupt schon jemals funktioniert?
                                @martin
                                martin
                                Ja, einwandfrei sogar. Und jetzt seit ein paar Tagen nicht mehr.
                                • M martin
                                  O Offline
                                  O Offline
                                  @martin
                                  Dann habe ich keine Idee mehr, außer dass die ein Firmwareupdate erhalten haben, das den Localport abschaltet oder ähnliches.
                                  Hersteller, Modell, Firmwareversion?
                                    @martin
                                    martin
                                    link text
                                    Version: V1.1.12
                                    • M martin
                                      link text
                                      Version: V1.1.12
                                      O Offline
                                      O Offline
                                      @martin
                                      Ich habe jetzt auf Abhieb zu dem Gerär nichts gefunden.
                                      Du kannst entweder den Entwickler des Tuya-Adapters ansprechen, ob er noch einen Tipp hat, oder nutzt den HAM-Adapter mit Tuya-Web-Plugin und steuerst die Geräte darüber.
                                        @martin
                                        O Offline
                                        O Offline
                                        @martin
                                        Du könntest zusätzlich noch die Objektstruktur hier posten,
                                          @martin
                                          martin
