  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Tuya Steckdose offline - Alexa erreichbar
    5.1k
tuyatuya adaptersteckdoseoffline
60 Beiträge 4 Kommentatoren 6.3k Aufrufe 4 Beobachtet
  • M martin
    @ofbeqnpolkkl6mby5e13
    tuya.0
    2022-09-21 12:50:18.108	error	711315732462ab41fd42: connect EHOSTUNREACH 192.168.177.124:6668
    tuya.0
    2022-09-21 12:50:18.104	error	250710602cf432a253ce: connect EHOSTUNREACH 192.168.177.127:6668
    tuya.0
    2022-09-21 12:50:17.943	error	04200408b4e62d192311: connect EHOSTUNREACH 192.168.177.83:6668
    tuya.0
    2022-09-21 12:50:17.912	error	711315732462ab419b76: connect EHOSTUNREACH 192.168.177.122:6668
    tuya.0
    2022-09-21 12:50:17.885	error	bf9585629c6547f571qjqn: connect EHOSTUNREACH 192.168.177.156:6668
    tuya.0
    2022-09-21 12:50:17.880	error	02200513dc4f2219ad01: connect EHOSTUNREACH 192.168.177.88:6668
    tuya.0
    2022-09-21 12:50:17.860	error	71131573c44f33b9ae4c: connect EHOSTUNREACH 192.168.177.123:6668
    tuya.0
    2022-09-21 12:50:17.857	error	01200229600194538c88: connect EHOSTUNREACH 192.168.177.82:6668
    tuya.0
    2022-09-21 12:50:15.051	info	Listen for encrypted local Tuya devices on port 6667
    tuya.0
    2022-09-21 12:50:15.050	info	Listen for local Tuya devices on port 6666
    tuya.0
    2022-09-21 12:50:15.040	info	Existing devices initialized
    tuya.0
    2022-09-21 12:50:15.038	info	250710602cf432a253ce Init with IP=192.168.177.127, Key=4304f000bb61aa08, Version=3.3
    tuya.0
    2022-09-21 12:50:15.036	info	25071060c44f33a64b64 Init with IP=192.168.177.20, Key=073ecce2a61c3436, Version=3.3
    tuya.0
    2022-09-21 12:50:15.034	info	711315732462ab41fd42 Init with IP=192.168.177.124, Key=53ee13dd52c9c8fa, Version=3.3
    tuya.0
    2022-09-21 12:50:15.032	info	bf06509ab67fb98f01zuzt Init with IP=192.168.177.175, Key=c69e56e0c054d79d, Version=3.3
    tuya.0
    2022-09-21 12:50:15.029	info	bfbd7f165f11dacd8eyb0t Init with IP=192.168.177.176, Key=02fc513f01f67533, Version=3.3
    tuya.0
    2022-09-21 12:50:14.945	info	38325110cc50e3262c9d Init with IP=192.168.177.92, Key=a9e51fa781f87443, Version=3.1
    tuya.0
    2022-09-21 12:50:14.941	info	38325110cc50e3d44d56 Init with IP=192.168.177.91, Key=e69a8c527d07591d, Version=3.1
    tuya.0
    2022-09-21 12:50:14.889	info	71131573c44f33b9aab6 Init with IP=192.168.177.136, Key=6b5c1bd579ef3e85, Version=3.3
    tuya.0
    2022-09-21 12:50:14.882	info	04200408b4e62d192311 Init with IP=192.168.177.83, Key=8d1cc9f308d0b281, Version=3.1
    tuya.0
    2022-09-21 12:50:14.850	info	711315732462ab419b76 Init with IP=192.168.177.122, Key=ced061f48b491d45, Version=3.3
    tuya.0
    2022-09-21 12:50:14.803	info	02200513dc4f2219ad01 Init with IP=192.168.177.88, Key=0a2a37818be809b2, Version=3.1
    tuya.0
    2022-09-21 12:50:14.798	info	bf9585629c6547f571qjqn Init with IP=192.168.177.156, Key=5190be1aca9a2914, Version=3.3
    tuya.0
    2022-09-21 12:50:14.779	info	01200229600194538c88 Init with IP=192.168.177.82, Key=48c20967b7dd1bd3, Version=3.1
    tuya.0
    2022-09-21 12:50:14.775	info	71131573c44f33b9ae4c Init with IP=192.168.177.123, Key=1b09e5a634d314e4, Version=3.3
    tuya.0
    2022-09-21 12:50:14.757	info	02200513dc4f22191527 Init with IP=192.168.177.87, Key=20eee215bc384b55, Version=3.1
    tuya.0
    2022-09-21 12:50:12.721	info	starting. Version 3.6.15 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.17.0, js-controller: 4.0.23
    tuya.0
    2022-09-21 12:49:58.619	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    tuya.0
    2022-09-21 12:49:58.617	info	terminating
    tuya.0
    2022-09-21 12:49:55.609	info	Got terminate signal TERMINATE_YOURSELF
    Es geht um die IP 175 + 176
    O Offline
    O Offline
    oFbEQnpoLKKl6mbY5e13
    @martin
    Und haben die beiden Steckdosen noch die konfigurierten IP-Adressen?
    Da können ja diverse IP-Adressen nicht erreicht werden.
    • O oFbEQnpoLKKl6mbY5e13
      @martin
      martin
      In der FritzBox sind sie mit diesen Adressen online.
      Die anderen die nicht erreichbar sind sind ausgesteckt, also definitiv nicht erreichbar.
      O 1 Antwort Letzte Antwort
      • M martin
        O Offline
        O Offline
        @martin
        Kannst du sie von deinem iobroker System aus erreichen?
          @martin
          martin
          Nein, genau das ist ja mein Problem.
          • M martin
            O Offline
            O Offline
            @martin
            Container?
              martin
              Nein. Linux ThinClient.
              • M martin
                O Offline
                O Offline
                @martin
                Und du kannst die schon nicht anpingen? Oder ist nur der Port belegt?
                  @martin
                  martin
                  C:\Users\PC>ping 192.168.177.175
                  Ping wird ausgeführt für 192.168.177.175 mit 32 Bytes Daten:
                  Antwort von 192.168.177.175: Bytes=32 Zeit=74ms TTL=253
                  Antwort von 192.168.177.175: Bytes=32 Zeit=85ms TTL=253
                  Antwort von 192.168.177.175: Bytes=32 Zeit=110ms TTL=253
                  Antwort von 192.168.177.175: Bytes=32 Zeit=128ms TTL=253
                  Ping-Statistik für 192.168.177.175:
                      Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
                      (0% Verlust),
                  Ca. Zeitangaben in Millisek.:
                      Minimum = 74ms, Maximum = 128ms, Mittelwert = 99ms
                  • M martin
                        (0% Verlust),
                    O Offline
                    O Offline
                    @martin
                    Dein iobroker läuft unter Windows?
                      @martin
                      martin
                      Nein, Linux. Habe jetzt nur vom Windows-PC aus den Ping gemacht.
                      O M 2 Antworten Letzte Antwort
                      • M martin
                        O Offline
                        O Offline
                        @martin
                        Was bringt das?
                        Die Frage, die sich stellt, ist doch, ob die sich von deinem iobroker System aus anpingen lässt.
                        • M martin
                          martin
                          /opt/iobroker$ ping 192.168.177.175
                          PING 192.168.177.175 (192.168.177.175) 56(84) bytes of data.
                          64 bytes from 192.168.177.175: icmp_seq=1 ttl=255 time=91.0 ms
                          64 bytes from 192.168.177.175: icmp_seq=2 ttl=255 time=149 ms
                          64 bytes from 192.168.177.175: icmp_seq=3 ttl=255 time=34.4 ms
                          64 bytes from 192.168.177.175: icmp_seq=4 ttl=255 time=56.3 ms
                          64 bytes from 192.168.177.175: icmp_seq=5 ttl=255 time=85.7 ms
                          64 bytes from 192.168.177.175: icmp_seq=6 ttl=255 time=108 ms
                          64 bytes from 192.168.177.175: icmp_seq=7 ttl=255 time=20.9 ms
                          64 bytes from 192.168.177.175: icmp_seq=8 ttl=255 time=7.05 ms
                          64 bytes from 192.168.177.175: icmp_seq=9 ttl=255 time=27.6 ms
                          64 bytes from 192.168.177.175: icmp_seq=10 ttl=255 time=10.1 ms
                          64 bytes from 192.168.177.175: icmp_seq=11 ttl=255 time=7.41 ms
                          64 bytes from 192.168.177.175: icmp_seq=12 ttl=255 time=9.57 ms
                          64 bytes from 192.168.177.175: icmp_seq=13 ttl=255 time=5.77 ms
                          64 bytes from 192.168.177.175: icmp_seq=14 ttl=255 time=5.80 ms
                          64 bytes from 192.168.177.175: icmp_seq=15 ttl=255 time=5.56 ms
                          64 bytes from 192.168.177.175: icmp_seq=16 ttl=255 time=9.18 ms
                          64 bytes from 192.168.177.175: icmp_seq=17 ttl=255 time=5.96 ms
                          64 bytes from 192.168.177.175: icmp_seq=18 ttl=255 time=12.3 ms
                          64 bytes from 192.168.177.175: icmp_seq=19 ttl=255 time=5.50 ms
                          64 bytes from 192.168.177.175: icmp_seq=20 ttl=255 time=7.31 ms
                          64 bytes from 192.168.177.175: icmp_seq=21 ttl=255 time=7.46 ms
                          64 bytes from 192.168.177.175: icmp_seq=22 ttl=255 time=7.15 ms
                          64 bytes from 192.168.177.175: icmp_seq=23 ttl=255 time=23.4 ms
                          64 bytes from 192.168.177.175: icmp_seq=24 ttl=255 time=9.34 ms
                          64 bytes from 192.168.177.175: icmp_seq=25 ttl=255 time=8.35 ms
                          64 bytes from 192.168.177.175: icmp_seq=26 ttl=255 time=7.87 ms
                          • M martin
                            O Offline
                            O Offline
                            @martin
                            Okay, dann belegt vermutlich etwas den Port 6668.
                              @martin
                              martin
                              Bei diesen 2 IPs?? Weil andere Tuya Geräte funktionieren ja einwandfrei.
                              • M martin
                                O Offline
                                O Offline
                                @martin
                                Dann stellt sich die Frage, ob das, was da unter der IP-Adresse antwortet, tatsächlich die Steckdose ist.
                                Hast du die Steckdose einfach mal rausgezogen und wieder reingesteckt?
                                  @martin
                                  martin
                                  Ich verstehe was du meinst.
                                  Kann ich in der App oder über Alexa irgendwie die IP rausfinden?
                                  • M martin
                                    O Offline
                                    O Offline
                                    @martin
                                    Zunächst guckst du in die App. In den Informationen zu der Steckdose findest du die MAC-Adresse.
                                    Diese vergleichst du mit der MAC-Adresse, die in der Fritzbox zu der IP-Adresse angezeigt wird.
                                      martin
                                      MAC Adressen sind in der App und FritzBox unter der IP-Adresse identisch.
                                      • M martin
                                        O Offline
                                        O Offline
                                        @martin
                                        Hattest du die Steckdosen mal vom Strom getrennt?
                                          @martin
                                          martin
                                          Nein. Nur vor ca. 2 Wochen iobroker Updates (nodejs und etliche Adapter) gemacht.
