  4. [gelöst] Fehler beim Start Javascript ASdapter
    5.8k
19 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • O Offline
    O Offline
    ostseeskipper
    schrieb am zuletzt editiert von ostseeskipper
    Hallo Zusammen,
    Beim Neustart des Javascript Adapters auf dem Slave iobroker kommt dieses Fehlerprotokoll
    javascript.1
    	2022-09-21 15:24:13.587	info	requesting all objects
    javascript.1
    	2022-09-21 15:24:13.585	info	requesting all states
    javascript.1
    	2022-09-21 15:24:13.451	error	Cannot install npm packet: Serialport
    javascript.1
    	2022-09-21 15:24:13.450	error	Cannot install Serialport: 1
    javascript.1
    	2022-09-21 15:24:13.427	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_24_07_766Z-debug-0.log
    javascript.1
    	2022-09-21 15:24:13.424	error
    javascript.1
    	2022-09-21 15:24:13.418	error	npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
    javascript.1
    	2022-09-21 15:24:13.416	error	ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm ERR! 404 This package name is not valid, because
    javascript.1
    	2022-09-21 15:24:13.413	error	ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm
    javascript.1
    	2022-09-21 15:24:13.411	error
    javascript.1
    	2022-09-21 15:24:13.408	error	npm
    javascript.1
    	2022-09-21 15:24:13.401	error	code E404
    javascript.1
    	2022-09-21 15:24:13.390	error	ERR!
    javascript.1
    	2022-09-21 15:24:13.387	error
    javascript.1
    	2022-09-21 15:24:13.384	error	npm
    javascript.1
    	2022-09-21 15:24:07.879	error	WARN config production Use `--omit=dev` instead.
    javascript.1
    	2022-09-21 15:24:07.876	error	npm
    javascript.1
    	2022-09-21 15:24:05.868	info	npm install Serialport --production (System call)
    javascript.1
    	2022-09-21 15:24:05.866	error	Cannot install Serialport: 1
    javascript.1
    	2022-09-21 15:24:05.843	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_24_00_006Z-debug-0.log
    javascript.1
    	2022-09-21 15:24:05.840	error
    javascript.1
    	2022-09-21 15:24:05.834	error	ERR! 404 This package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
    javascript.1
    	2022-09-21 15:24:05.830	error	ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm
    javascript.1
    	2022-09-21 15:24:05.828	error	npm
    javascript.1
    	2022-09-21 15:24:05.817	error	ERR! code E404
    javascript.1
    	2022-09-21 15:24:05.815	error	npm
    javascript.1
    	2022-09-21 15:24:00.120	error	WARN config production Use `--omit=dev` instead.
    javascript.1
    	2022-09-21 15:24:00.116	error	npm
    javascript.1
    	2022-09-21 15:23:58.024	info	npm install Serialport --production (System call)
    javascript.1
    	2022-09-21 15:23:58.021	error	Cannot install Serialport: 1
    javascript.1
    	2022-09-21 15:23:57.950	error	npm ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm ERR! 404 This package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_23_52_161Z-debug-0.log
    javascript.1
    	2022-09-21 15:23:57.918	error	npm ERR! code E404
    javascript.1
    	2022-09-21 15:23:52.294	error	WARN config production Use `--omit=dev` instead.
    javascript.1
    	2022-09-21 15:23:52.291	error	npm
    javascript.1
    	2022-09-21 15:23:50.240	info	npm install Serialport --production (System call)
    javascript.1
    	2022-09-21 15:23:50.163	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
    javascript.1
    	2022-09-21 15:23:49.923	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    Kann mir bitte jemand helfen wo und was hier nicht stimmt.
    Lieben Dank und viele Grüsse von Küste
    Thomas BraunT paul53P 2 Antworten Letzte Antwort
    • O ostseeskipper
      Hallo Zusammen,
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      javascript.1
      @ostseeskipper sagte in Fehler beim Start Javascript ASdapter:
      Wenn man sähe, welcher Befehl zu der Ausgabe führt vielleicht.
      Vielleicht im javascript-Adapter den serialport als Zusatzmodul eingetragen? Dann muss das da (wenn überhaupt erforderlich) auch kleingeschrieben werden.
      O 1 Antwort Letzte Antwort
        O Offline
        O Offline
        ostseeskipper
        Ich habe nur auf Neustarten in der der Instanzenoberfläche geklickt
        • O ostseeskipper
          @ostseeskipper
          Der heißt ja auch serialport.
          • O ostseeskipper
            Hallo Zusammen,
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            javascript.1
            @ostseeskipper sagte: was hier nicht stimmt.
            Was hat Serialport mit dem Javascript-Adapter zu tun? Ist ein zusätzliches NPM-Modul integriert, das "serialport" verwendet?
              O Offline
              O Offline
              ostseeskipper
              @paul53 und @Thomas-Braun
              ja ist installiert und notwendig.
              Über den Slave iobroker wird a) ein USB IR Lesekopf fürs Smartmeter und b) eine USB RS485 serielle Modbusinstanz gelesen.
              Eingerichtet hatte ich die Modbus Instanz im Feb und bis März betrieben.
              https://forum.iobroker.net/topic/52284/modbus-über-usb-rs485/31
              Diese wollte ich nun nach längerer Pause wieder in Betrieb nehmen und brachte nur Fehlermeldungen.
              • O ostseeskipper
                @ostseeskipper
                Dann schreibs halt klein.
                  @ostseeskipper
                  O Offline
                  O Offline
                  ostseeskipper
                  leider immer noch ein Fehler drin
                  javascript.1
                  	2022-09-21 16:06:23.123	info	received all states
                  javascript.1
                  	2022-09-21 16:06:22.598	info	received all objects
                  javascript.1
                  	2022-09-21 16:06:16.726	info	requesting all objects
                  javascript.1
                  	2022-09-21 16:06:16.723	info	requesting all states
                  javascript.1
                  	2022-09-21 16:06:16.390	info	found 0 vulnerabilities
                  javascript.1
                  	2022-09-21 16:06:16.386	info	19 packages are looking for funding run `npm fund` for details
                  javascript.1
                  	2022-09-21 16:06:16.381	info	added 19 packages, and audited 106 packages in 16s
                  javascript.1
                  	2022-09-21 16:06:00.061	error	WARN config production Use `--omit=dev` instead.
                  javascript.1
                  	2022-09-21 16:06:00.058	error	npm
                  javascript.1
                  	2022-09-21 16:05:58.054	info	npm install serialport --production (System call)
                  javascript.1
                  	2022-09-21 16:05:57.977	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
                  javascript.1
                  	2022-09-21 16:05:57.671	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
                  • O ostseeskipper
                    @ostseeskipper sagte: a) ein USB IR Lesekopf fürs Smartmeter und b) eine USB RS485 serielle Modbusinstanz gelesen.
                    Dann haben diese beiden Adapter das NPM-Modul "serialport" integriert und es wird nicht auch noch im Javascript-Adapter benötigt.
                      O Offline
                      O Offline
                      ostseeskipper
                      verstehe ich nicht was du genau meinst.
                      Als ich damals die Modbus Seriel nutzen wollte ging das nicht und hier gab es die lösung indem ich das so installierte
                      • O ostseeskipper
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        javascript.1
                        Wo? Ich seh keinen.
                        Wegen:
                        node: v16.16.0
                        Aktualisier das die Tage mal, da kommt morgen/übermorgen ein Sicherheitsupdate zu rein.
                          Wo? Ich seh keinen.
                          Wegen:
                          node: v16.16.0
                          O Offline
                          O Offline
                          ostseeskipper
                          in der 4 - 5ten Zeile von unten
                          • O ostseeskipper
                            @ostseeskipper
                            Das ist kein Fehler.
                            • O ostseeskipper
                              @ostseeskipper sagte: verstehe ich nicht was du genau meinst.
                              Der Javascript-Adapter benötigt kein "serialport", sondern die beiden Adapter "Modbus" und "Smartmeter". Lösche es aus der Javascript-Konfiguration raus.
                                @ostseeskipper
                                O Offline
                                O Offline
                                ostseeskipper
                                ok, wenn du das sagst, war nur wegen "error" irritiert
                                  O Offline
                                  O Offline
                                  ostseeskipper
                                  heisst ich lösch jetzt im Javascriptadapter den Eintrag "serialport" und füge "Modbus" und "Smartmeter" hinzu. Dieses mal großer Anfangsbuchstabe?
                                  • O ostseeskipper
                                    Das ist deswegen so, weil Ausgaben von npm über STDOUT ohne nähere Klassifikation vom js-controller als 'Error' aufgefasst werden. Das ist aber ja eigentlich nur eine 'Überschrift' für die weiteren Meldungen.
                                    • O ostseeskipper
                                      @ostseeskipper sagte: heisst ich lösch jetzt im Javascriptadapter den Eintrag "serialport" und füge "Modbus" und "Smartmeter" hinzu. Dieses mal großer Anfangsbuchstabe?
                                      Nein, nur in Javascript löschen!
                                      Wenn Du in das von Dir verlinkte Thema schaust, siehst Du, dass die beiden Adapter "serialport" verwenden.
                                      Mit diesem Befehl wurde "serialport" global installiert.
                                        O Offline
                                        O Offline
                                        ostseeskipper
                                        ok, hab das nun im JS Adapter rausgenommen.
                                        Nun versuche ich den Modbusadapter mit seriel mal ans laufen zu bringen, Hatte den schön gelöscht um das neu aufzustezen.
                                        Danke euch Beiden
