<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] Fehler beim Start Javascript ASdapter]]></title><description><![CDATA[<p dir="auto">Hallo Zusammen,</p>
<p dir="auto">Beim Neustart des Javascript Adapters auf dem Slave iobroker kommt dieses Fehlerprotokoll</p>
<pre><code>javascript.1
	2022-09-21 15:24:13.587	info	requesting all objects
javascript.1
	2022-09-21 15:24:13.585	info	requesting all states
javascript.1
	2022-09-21 15:24:13.451	error	Cannot install npm packet: Serialport
javascript.1
	2022-09-21 15:24:13.450	error	Cannot install Serialport: 1
javascript.1
	2022-09-21 15:24:13.427	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_24_07_766Z-debug-0.log
javascript.1
	2022-09-21 15:24:13.424	error
javascript.1
	2022-09-21 15:24:13.418	error	npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
javascript.1
	2022-09-21 15:24:13.416	error	ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm ERR! 404 This package name is not valid, because
javascript.1
	2022-09-21 15:24:13.413	error	ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm
javascript.1
	2022-09-21 15:24:13.411	error
javascript.1
	2022-09-21 15:24:13.408	error	npm
javascript.1
	2022-09-21 15:24:13.401	error	code E404
javascript.1
	2022-09-21 15:24:13.390	error	ERR!
javascript.1
	2022-09-21 15:24:13.387	error
javascript.1
	2022-09-21 15:24:13.384	error	npm
javascript.1
	2022-09-21 15:24:07.879	error	WARN config production Use `--omit=dev` instead.
javascript.1
	2022-09-21 15:24:07.876	error	npm
javascript.1
	2022-09-21 15:24:05.868	info	npm install Serialport --production (System call)
javascript.1
	2022-09-21 15:24:05.866	error	Cannot install Serialport: 1
javascript.1
	2022-09-21 15:24:05.843	error	npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_24_00_006Z-debug-0.log
javascript.1
	2022-09-21 15:24:05.840	error
javascript.1
	2022-09-21 15:24:05.834	error	ERR! 404 This package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url.
javascript.1
	2022-09-21 15:24:05.830	error	ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm
javascript.1
	2022-09-21 15:24:05.828	error	npm
javascript.1
	2022-09-21 15:24:05.817	error	ERR! code E404
javascript.1
	2022-09-21 15:24:05.815	error	npm
javascript.1
	2022-09-21 15:24:00.120	error	WARN config production Use `--omit=dev` instead.
javascript.1
	2022-09-21 15:24:00.116	error	npm
javascript.1
	2022-09-21 15:23:58.024	info	npm install Serialport --production (System call)
javascript.1
	2022-09-21 15:23:58.021	error	Cannot install Serialport: 1
javascript.1
	2022-09-21 15:23:57.950	error	npm ERR! 404 Not Found - GET https://registry.npmjs.org/Serialport - Not found npm ERR! 404 npm ERR! 404 'Serialport@*' is not in this registry. npm ERR! 404 This package name is not valid, because npm ERR! 404 1. name can no longer contain capital letters npm ERR! 404 npm ERR! 404 Note that you can also install from a npm ERR! 404 tarball, folder, http url, or git url. npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-09-21T13_23_52_161Z-debug-0.log
javascript.1
	2022-09-21 15:23:57.918	error	npm ERR! code E404
javascript.1
	2022-09-21 15:23:52.294	error	WARN config production Use `--omit=dev` instead.
javascript.1
	2022-09-21 15:23:52.291	error	npm
javascript.1
	2022-09-21 15:23:50.240	info	npm install Serialport --production (System call)
javascript.1
	2022-09-21 15:23:50.163	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
javascript.1
	2022-09-21 15:23:49.923	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
</code></pre>
<p dir="auto">Kann mir bitte jemand helfen wo und was hier nicht stimmt.<br />
Lieben Dank und viele Grüsse von Küste</p>
]]></description><link>https://forum.iobroker.net/topic/58185/gelöst-fehler-beim-start-javascript-asdapter</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 15:46:28 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/58185.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Sep 2022 13:51:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:31:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul53" aria-label="Profile: paul53">@<bdi>paul53</bdi></a><br />
ok, hab das nun im JS Adapter rausgenommen.<br />
Nun versuche ich den Modbusadapter mit seriel mal ans laufen zu bringen, Hatte den schön gelöscht um das neu aufzustezen.</p>
<p dir="auto">Danke euch Beiden</p>
]]></description><link>https://forum.iobroker.net/post/861183</link><guid isPermaLink="true">https://forum.iobroker.net/post/861183</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:31:18 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:28:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte: heisst ich lösch jetzt im Javascriptadapter den Eintrag "serialport" und füge "Modbus" und "Smartmeter" hinzu. Dieses mal großer Anfangsbuchstabe?</p>
<p dir="auto">Nein, nur in Javascript löschen!<br />
Wenn Du in das von Dir <a href="https://forum.iobroker.net/post/758135">verlinkte Thema</a> schaust, siehst Du, dass die beiden Adapter "serialport" verwenden.</p>
<p dir="auto">Mit <a href="https://forum.iobroker.net/post/758142">diesem Befehl</a> wurde "serialport" global installiert.</p>
]]></description><link>https://forum.iobroker.net/post/861181</link><guid isPermaLink="true">https://forum.iobroker.net/post/861181</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:21:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte in <a href="/post/861175">Fehler beim Start Javascript ASdapter</a>:</p>
<blockquote>
<p dir="auto">ok, wenn du das sagst, war nur wegen "error" irritiert</p>
</blockquote>
<p dir="auto">Das ist deswegen so, weil Ausgaben von npm über STDOUT ohne nähere Klassifikation vom js-controller als 'Error' aufgefasst werden. Das ist aber ja eigentlich nur eine 'Überschrift' für die weiteren Meldungen.</p>
]]></description><link>https://forum.iobroker.net/post/861179</link><guid isPermaLink="true">https://forum.iobroker.net/post/861179</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:21:36 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:21:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul53" aria-label="Profile: paul53">@<bdi>paul53</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/861178</link><guid isPermaLink="true">https://forum.iobroker.net/post/861178</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:19:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/861175</link><guid isPermaLink="true">https://forum.iobroker.net/post/861175</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:18:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte: verstehe ich nicht was du genau meinst.</p>
<p dir="auto">Der Javascript-Adapter benötigt kein "serialport", sondern die beiden Adapter "Modbus" und "Smartmeter". Lösche es aus der Javascript-Konfiguration raus.</p>
]]></description><link>https://forum.iobroker.net/post/861173</link><guid isPermaLink="true">https://forum.iobroker.net/post/861173</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:18:09 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:18:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a></p>
<p dir="auto">Das ist kein Fehler.</p>
]]></description><link>https://forum.iobroker.net/post/861172</link><guid isPermaLink="true">https://forum.iobroker.net/post/861172</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:17:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
in der 4 - 5ten Zeile von unten</p>
]]></description><link>https://forum.iobroker.net/post/861170</link><guid isPermaLink="true">https://forum.iobroker.net/post/861170</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:17:25 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:17:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte in <a href="/post/861163">Fehler beim Start Javascript ASdapter</a>:</p>
<blockquote>
<p dir="auto">leider immer noch ein Fehler drin</p>
</blockquote>
<p dir="auto">Wo? Ich seh keinen.</p>
<p dir="auto">Wegen:<br />
node: v16.16.0<br />
Aktualisier das die Tage mal, da kommt morgen/übermorgen ein Sicherheitsupdate zu rein.</p>
]]></description><link>https://forum.iobroker.net/post/861169</link><guid isPermaLink="true">https://forum.iobroker.net/post/861169</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:17:41 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:13:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul53" aria-label="Profile: paul53">@<bdi>paul53</bdi></a><br />
verstehe ich nicht was du genau meinst.<br />
Als ich damals die Modbus Seriel nutzen wollte ging das nicht und hier gab es die lösung indem ich das so installierte<br />
<a href="https://forum.iobroker.net/topic/52284/modbus-%C3%BCber-usb-rs485/31">https://forum.iobroker.net/topic/52284/modbus-über-usb-rs485/31</a></p>
]]></description><link>https://forum.iobroker.net/post/861168</link><guid isPermaLink="true">https://forum.iobroker.net/post/861168</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:13:35 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:08:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte: a) ein USB IR Lesekopf fürs Smartmeter und b) eine USB RS485 serielle Modbusinstanz gelesen.</p>
<p dir="auto">Dann haben diese beiden Adapter das NPM-Modul "serialport" integriert und es wird nicht auch noch im Javascript-Adapter benötigt.</p>
]]></description><link>https://forum.iobroker.net/post/861165</link><guid isPermaLink="true">https://forum.iobroker.net/post/861165</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:07:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
	2022-09-21 16:06:23.123	info	received all states
javascript.1
	2022-09-21 16:06:22.598	info	received all objects
javascript.1
	2022-09-21 16:06:16.726	info	requesting all objects
javascript.1
	2022-09-21 16:06:16.723	info	requesting all states
javascript.1
	2022-09-21 16:06:16.390	info	found 0 vulnerabilities
javascript.1
	2022-09-21 16:06:16.386	info	19 packages are looking for funding run `npm fund` for details
javascript.1
	2022-09-21 16:06:16.381	info	added 19 packages, and audited 106 packages in 16s
javascript.1
	2022-09-21 16:06:00.061	error	WARN config production Use `--omit=dev` instead.
javascript.1
	2022-09-21 16:06:00.058	error	npm
javascript.1
	2022-09-21 16:05:58.054	info	npm install serialport --production (System call)
javascript.1
	2022-09-21 16:05:57.977	info	starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v16.16.0, js-controller: 4.0.23
javascript.1
	2022-09-21 16:05:57.671	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
</code></pre>
]]></description><link>https://forum.iobroker.net/post/861163</link><guid isPermaLink="true">https://forum.iobroker.net/post/861163</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:07:20 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:05:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a></p>
<p dir="auto">Dann schreibs halt klein.</p>
]]></description><link>https://forum.iobroker.net/post/861160</link><guid isPermaLink="true">https://forum.iobroker.net/post/861160</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:05:13 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:04:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paul53" aria-label="Profile: paul53">@<bdi>paul53</bdi></a> und <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
ja ist installiert und notwendig.<br />
<img src="/assets/uploads/files/1663768697918-117e4b9b-c02b-40bd-a673-11cf99f035f4-grafik.png" alt="117e4b9b-c02b-40bd-a673-11cf99f035f4-grafik.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Über den Slave iobroker wird a) ein USB IR Lesekopf fürs Smartmeter und b) eine USB RS485 serielle Modbusinstanz gelesen.<br />
Eingerichtet hatte ich die Modbus Instanz im Feb und bis März betrieben.<br />
<p dir="auto">Diese wollte ich nun nach längerer Pause wieder in Betrieb nehmen und brachte nur Fehlermeldungen.</p>
]]></description><link>https://forum.iobroker.net/post/861159</link><guid isPermaLink="true">https://forum.iobroker.net/post/861159</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:04:37 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 14:01:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte: was hier nicht stimmt.</p>
<p dir="auto">Was hat Serialport mit dem Javascript-Adapter zu tun? Ist ein zusätzliches NPM-Modul integriert, das "serialport" verwendet?</p>
]]></description><link>https://forum.iobroker.net/post/861154</link><guid isPermaLink="true">https://forum.iobroker.net/post/861154</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Wed, 21 Sep 2022 14:01:03 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 13:56:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a></p>
<pre><code>Cannot install npm packet: Serialport
</code></pre>
<p dir="auto">Der heißt ja auch serialport.</p>
]]></description><link>https://forum.iobroker.net/post/861153</link><guid isPermaLink="true">https://forum.iobroker.net/post/861153</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 13:56:02 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 13:53:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Ich habe nur auf Neustarten in der der Instanzenoberfläche geklickt</p>
]]></description><link>https://forum.iobroker.net/post/861149</link><guid isPermaLink="true">https://forum.iobroker.net/post/861149</guid><dc:creator><![CDATA[ostseeskipper]]></dc:creator><pubDate>Wed, 21 Sep 2022 13:53:54 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Fehler beim Start Javascript ASdapter on Wed, 21 Sep 2022 13:54:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ostseeskipper" aria-label="Profile: ostseeskipper">@<bdi>ostseeskipper</bdi></a> sagte in <a href="/post/861146">Fehler beim Start Javascript ASdapter</a>:</p>
<blockquote>
<p dir="auto">Kann mir bitte jemand helfen</p>
</blockquote>
<p dir="auto">Wenn man sähe, welcher Befehl zu der Ausgabe führt vielleicht.</p>
<p dir="auto">Vielleicht im javascript-Adapter den serialport als Zusatzmodul eingetragen? Dann muss das da (wenn überhaupt erforderlich) auch kleingeschrieben werden.</p>
]]></description><link>https://forum.iobroker.net/post/861147</link><guid isPermaLink="true">https://forum.iobroker.net/post/861147</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 21 Sep 2022 13:54:59 GMT</pubDate></item></channel></rss>
