  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 678.8k Aufrufe 146 Beobachtet
  • da_WoodyD da_Woody
    @oelison sagte in [Neuer Adapter] Reolink Kamera:
    Gerade ein paar neue Funktionen integriert.
    gerade über den link update gemacht, jetzt werden beide instanzen kurz grün, dann rot...
    host.ioBroker
    2022-09-16 07:34:18.619	error	instance system.adapter.reolink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    reolink.0
    2022-09-16 07:34:17.973	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    reolink.0
    2022-09-16 07:34:17.964	error	this.setValue is not a function
    reolink.0
    2022-09-16 07:34:17.964	error	TypeError: this.setValue is not a function at TestProject.onReady (/opt/iobroker/node_modules/iobroker.reolink/main.js:83:9)
    reolink.0
    2022-09-16 07:34:17.963	error	unhandled promise rejection: this.setValue is not a function
    reolink.0
    2022-09-16 07:34:17.962	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    host.ioBroker
    2022-09-16 07:34:04.314	error	instance system.adapter.reolink.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
    reolink.1
    2022-09-16 07:34:03.592	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    reolink.1
    2022-09-16 07:34:03.588	error	this.setValue is not a function
    reolink.1
    2022-09-16 07:34:03.588	error	TypeError: this.setValue is not a function at TestProject.onReady (/opt/iobroker/node_modules/iobroker.reolink/main.js:83:9)
    reolink.1
    2022-09-16 07:34:03.587	error	unhandled promise rejection: this.setValue is not a function
    reolink.1
    2022-09-16 07:34:03.585	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    oelisonO Offline
    oelisonO Offline
    oelison
    #127
    @da_woody bugfix ist drauf. Ich hoffe der hilft, da bei mir sich nichts geändert hat.
    I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
    • oelisonO oelison
      da_WoodyD Offline
      da_WoodyD Offline
      #128
      @oelison jep, die bleiben wieder grün. 👍
      allerdings bekomm ich von einer ptz keine daten...
      oelisonO 1 Antwort Letzte Antwort
        oelisonO Offline
        oelisonO Offline
        oelison
        #129
        @da_woody Bitte stelle mal bei allen adaptern den Kameratyp auf others. Dann Adapter neu starten.
        • oelisonO oelison
          da_WoodyD Offline
          da_WoodyD Offline
          #130
          bei allen adaptern
          du meinst instanzen...
          OK, hab ich gemacht. hat sich aber nichts geändert bei settings. immer nur anzeige bei (null)
          hab da 3 presets.
            bei allen adaptern
            hab da 3 presets.
            oelisonO Offline
            oelisonO Offline
            oelison
            #131
            @da_woody Ich glaube jetzt habe ich Dich verstanden. Sorry. Einfach die (null) anklicken und eine Zahl von 0-63 eintippen. Das ist die Preset nummer. Ich habe die Presetnamen noch nicht geholt und dann als auswahl da rein getan.
            • oelisonO Offline
              oelisonO Offline
              oelison
              #132
              Wenn einer den JavaScript adapter hat, kann er mit dem folgenden Script rumspielen um neue Befehle aus zu probieren.
              const http = require('http');
              const init = { host: '192.168.aaa.bbb', path: '/api.cgi?user=admin&password=123456', port: 80, method: 'POST' };
              const callback = function(response) {
                let result = Buffer.alloc(0);
                response.on('data', function(chunk) {
                  result = Buffer.concat([result, chunk]);
                response.on('end', function() {
                  console.log(result.toString());
              const req = http.request(init, callback);
              const body = `[{"cmd": "SetPtzGuard","action": 0,"param": {"PtzGuard": {"channel": 0, "cmdStr": "", "benable":1, "bexistPos":1, "timeout":60, "bSaveCurrentPos": 1}}}]`;
              req.write(body);
              req.end();
              Leider habe ich den Guard befehl nicht zum laufen gebracht. Ist jetzt erstmal drin, vielleicht geht der ja bei jemanden.
              -cs-- 1 Antwort Letzte Antwort
              • oelisonO oelison
                da_WoodyD Offline
                da_WoodyD Offline
                #133
                @oelison 👍 k, das funzt! allerdingx ist nach wie vor alles in rot gehalten...
                • oelisonO oelison
                  req.write(body);
                  req.end();
                  -cs-- Offline
                  -cs-- Offline
                  -cs-
                  schrieb am zuletzt editiert von -cs-
                  #134
                  @oelison, so, sitze jetzt auch kurz am PC und sehe Ihr seid Aktiv ;-)
                  Mir ist es auch lieber hier zu schreiben als auf GitHub.
                  Habe soeben den Adapter Aktualisiert und es erscheinen die weiteren Datenpunkte.
                  Was kann/hab ich getestet?
                  • ptzPreset, funktionierte ja bereits
                  • PTZ-Guard, hier bewegt sich nichts und die Timeout geht auch nicht. Sorry, aber ich weis nicht ob PTZ-Guard überhaupt der Datenpunkt für den Wachpunkt ist, wobei die Timeout- Einstellung dazugehörend passen würde aber hier wird auch nichts durchgereicht.
                    Edit: es schaut so aus, als wenn ptzEnableGuard gesetzt, dann fährt er nach der angegebenen Wartezeit in die Stellung des Wachpunktes. Da in der App aber keinerlei Änderungen der Datenpunkte sichtbar, ist es nur Vermutung.
                  • playAlarm, funktioniert wenn wert auf 1, dann 1x wenn Wert auf z.B. 3 gesetzt, dann spielt er den Alarmton in 3-facher länge
                  • swich LED, funktioniert LED schaltet, aber wenn LED per App ausgeschaltet wird, bleibt der Datenpunkt dennoch auf true
                  • IR, kann ich nicht sehen, noch zu hell da Automatisch, wird in der App aber auch nicht geändert, wenn hier geändert
                  • setZoomFocus, hier wird gezoomt, weis aber die Schritte/Zahl nicht genau gefühlt von 0 - 25, aber auch keine änderung in der App, nur die Kamera zoomt
                  • ledBrightness, hier kann ich keine Änderung feststellen, wüsste aber auch nicht, ob die in der E1 Outdoor steuerbar ist
                  • autoFocus, wenn ich zwischen false und true wechsele focusiert die Kamera dennoch richtig, weis leider nicht was das bewirken sollte
                  Ansonsten werde ich mir das Script vom vorletzten Beitrag mal zu herzen nehmen, wenn ich wieder Zeit habe.
                  Christian
                  Edit bei PTZ-Guard
                    oelisonO Offline
                    oelisonO Offline
                    oelison
                    schrieb am zuletzt editiert von oelison
                    #135
                    @da_woody Ja, das ist alles Rot, da die nur zum Steuern gedacht sind. Rücklesen tuen wir noch nicht. Ist dann auch wieder die Frage wie oft. @cs @da_Woody Danke für die schnellen Reports.
                    PTZ-Guard liefert im Log warscheinlich auch einen Fehler. Geht bei mir auch nicht, aber ich wusste nicht ob das ein Problem bei mir ist. Habe in einem anderen Forum mal gefragt, ob das schon jemand geschafft hat.
                    AutoFocus hat bei mir auch keine Wirkung. Werde ich dann wohl wieder raus werfen, es sei denn es findet einer den richtigen Befehl und dann sollte man auch die Fokusposition einstellen können, sonst macht das keinen Sinn. (Leider den Befehl noch nicht entdeckt). Wireshark und GoogleChrome sniffing geht nicht mehr, da die den Datenkontent verschlüsseln. (auch bei http)
                    LedBrighnes geht bei meiner RLC-823A sehr gut. (Steuert nur die weiße LED).
                    P.s.: Zu: "Mir ist es auch lieber hier zu schreiben als auf GitHub." Ja, diskutieren über ein Thema ist hier besser. Ich dachte es kommen mehr Tickets. Dann wäre das hier caotisch geworden. Und am liebsten ist mir eigentlich Discord. Das geht am Handy besser.
                    • oelisonO oelison
                      @audiojoy : So wie das aussieht, kann nur mit der App aufgezeichnet werden und dann in einen Ordner. Aber das die Kamera von außen getriggert auf die SD-Karte aufzeichnet sehe ich nicht. Dann können wir das auch nicht nachbauen.
                      Audiojoy
                      #136
                      @oelison Danke für die Antwort. Es sieht wohl so aus, als ob das keine Kamera so wirklich kann...nicht nur nicht die REOS...Das ist schade...in meinem Fall.
                      • nukleuzN Offline
                        nukleuzN Offline
                        nukleuz
                        #137
                        Hier geht es ja ordentlich voran 😎
                        Werde am Wochenende mit testen!
                        Greets
                        Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                          Kopterframe
                          #138
                          Servus in die Runde,
                          habe den Adapter mit dem angegebenen Link installiert. Leider kann ich ihn in den Instanzen nicht finden.
                          In den Objekten habe ich genau einen Datenpunkt.
                          brauch mal eine Hilfestellung.
                          vielen Dank
                          W da_WoodyD 2 Antworten Letzte Antwort
                          • K Kopterframe
                            vielen Dank
                            W Offline
                            W Offline
                            Wolfi
                            #139
                            @kopterframe
                            gehe auf das Installierte Adapter dann hinten auf das + Instanz hinzufügen
                            Gruss
                            • K Kopterframe
                              vielen Dank
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #140
                              @kopterframe wenn du über github installiert, musst du selber die instanzen anlegen.
                              • Gerke EckhoffG Offline
                                Gerke Eckhoff
                                #141
                                ich habe auch mal gewagt den Adapter zu installieren. Mal schauen ob es das ist was ich suche. Ich habe eine RLC-410W. Ich bekomme auch die Datenpunkte über device, info, network geliefert. Nur bei motion tut sich nichts... Bewegungserkennung ist in der Kamera selber auch aktiviert (mache das sonst eigentlich über ne Diskstation), aber da ändert sich kein Wert.... habe das Abfrageintervall mal auf 1 Sekunde gestellt....aber da tut sich nichts.
                                • Gerke EckhoffG Gerke Eckhoff
                                  oelisonO Offline
                                  oelisonO Offline
                                  oelison
                                  #142
                                  Hallo @gerke-eckhoff, schade dass das mit motion nicht geht. Ich werde mir das mal anschauen, was da alles erwartet wird und werde ggf. den Adapter oder die Readme anpassen. Heute schaffe ich das nicht mehr. Ich werde schon mal ein Bug-Ticket anlegen. Gruß Christian
                                  • oelisonO Offline
                                    oelisonO Offline
                                    oelison
                                    #143
                                    https://github.com/aendue/ioBroker.reolink/issues/12
                                    Bug Ticket angelegt.
                                    • W Wolfi
                                      @kopterframe
                                      Gruss
                                      Kopterframe
                                      #144
                                      @wolfi ; @da_Woody , vielen Dank
                                      • oelisonO Offline
                                        oelisonO Offline
                                        oelison
                                        #145
                                        v0.0.4 is now released on github and npm.
                                        Movement detection is working again.
                                        Gerke EckhoffG 1 Antwort Letzte Antwort
                                        • oelisonO oelison
                                          Gerke Eckhoff
                                          #146
                                          @oelison Ich habe es gerade mit meiner RLC-410W getestet. Motion-Status funktioniert. Damit ich es sinnvoll auswerten kann muss ich den Abfragewert in der Instanz auf eine Sekunde setzen. Mal schauen was das für Auswirkungen hat wenn man sooft die Kamera abfragt. Aber für einfachere Überwachungen/Informationen ersetzt mir das so schonmal die Surveillance Station von Synology (und spart mir Lizenzen). Danke für die Arbeit!
