  4. IObroker Multihost Slave startet nicht mehr
    5.8k
64 Beiträge 5 Kommentatoren 8.3k Aufrufe 3 Beobachtet
  • R RS_Tobi
    Beim Master trat nun ein Problem auf.
    AHHHH
    pi@ioBrokerMasterPi4:/opt/iobroker $ sudo apt update
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Err:3 https://deb.nodesource.com/node_16.x buster InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_16.x buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    nun, das hatte ich noch nie!
    Folgedessen gehts auch nicht weiter.
    Tobi
    @rs_tobi
    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    R 1 Antwort Letzte Antwort
      @rs_tobi
      RS_Tobi
      Danke, Hat funktioniert.
      Nun, So wie es aussieht hat er NPM nicht auf 8 gezogen.
      pi@ioBrokerMasterPi4:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v16.17.0
      v16.17.0
      6.14.4
      4.0.23
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      /opt/iobroker
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      nodejs:
        Installed: 16.17.0-deb-1nodesource1
        Candidate: 16.17.0-deb-1nodesource1
        Version table:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
           10.24.0~dfsg-1~deb10u1 500
      • R RS_Tobi
        armv7l
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v16.17.0
        v16.17.0
        6.14.4
        4.0.23
        pi
        /opt/iobroker
        nodejs:
          Version table:
        @rs_tobi
        Doch, aber du hast da noch was quer installiert. Falsche Pfade. Siehe mein HowTo.
        • R Offline
          RS_Tobi
          Mir sind die falschen PFade gerade schon aufgefallen, aber ich habe nichts anders gemacht als bei den beiden Node updates bei den beiden SLAVES.
          Das ist jetzt echt komisch.
          Ich arbeite auch schon seit gestern mit deiner ANLEITUNG.
          Danke nochmals dafür, an dieser Stell!
          Nur, kann ich das einfach verschieben oder muss das dort installiert werden?
          Ich habe ja nirgends was ausgewählt...
            @rs_tobi
            RS_Tobi
            Ich bedanke mich jetzt schon mal bei DIR!
            Aber ich muss in 3 Std wieder aufstehen, ich habe es zeitlich schon voll ausgereitzt.
            Ich melde mich morgen wieder.
            • R RS_Tobi
              @rs_tobi
              Löschen. Nix 'verschieben'.
              sudo rm /usr/local/bin/n*
                @rs_tobi
                RS_Tobi
                HAllo.
                Jetzt wollte ich schreiben das seit gestern nach dem "löschen" nichtsmehr
                funktioniert, aber habe eben nochmal einen reboot gemacht und siehe da...
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                4.0.23
                pi
                /home/pi
                nodejs:
                  Version table:
                pi@ioBrokerMasterPi4:~ $
                ABER der Slave ist immer noch offline und IOBROKER ist immer noch "not running"
                • R RS_Tobi
                  HAllo.
                  armv7l
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  pi
                  /home/pi
                  nodejs:
                    Version table:
                  @rs_tobi
                  Sieht das jetzt auf allen drei Systemen gleich aus?
                  funktioniert,
                  Hattest du den ioBroker nicht heruntergefahren beim löschen? Dann hast du dem die Laufzeitumgebung unterm Ar*** weggezogen. Das mag der natürlich nicht.
                    @rs_tobi
                    funktioniert,
                    RS_Tobi
                    doch, der iobroker war gestoppt...
                    und beim reboot war die Ausgabe plötzlich richtig und iobroker startete wieder.
                    Nun sehen alle drei nahezu wenn nicht sogar identisch aus.
                    • R RS_Tobi
                      @rs_tobi sagte in IObroker Multihost Slave startet nicht mehr:
                      Ja, da wird der $PATH neueingelesen.
                      • R RS_Tobi
                        Checken...
                        R 2 Antworten Letzte Antwort
                          Checken...
                          RS_Tobi
                          OK. sind identisch
                            Checken...
                            RS_Tobi
                            sieht immer noch so aus..
                            und starten möchte er nich... :-(
                            • R RS_Tobi
                              @rs_tobi
                              Auf dem Froeling:
                              iob update
                                @rs_tobi
                                Auf dem Froeling:
                                iob update
                                RS_Tobi
                                @thomas-braun sagte in IObroker Multihost Slave startet nicht mehr:
                                iob update
                                PUH... das ist jetzt gerade komisch...
                                habe den FRÖLING nochmal rebootet...
                                seit dem TOT.
                                Ich melde mich wenn ich was weiß.
                                DANKE!
                                  @rs_tobi
                                  Auf dem Froeling:
                                  iob update
                                  RS_Tobi
                                  wieder online...
                                  pi@FroelingSlavePi2:~ $ iob update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.2.22   , installed 6.2.22
                                  Adapter    "backitup"     : 2.4.10   , installed 2.2.2  [Updatable]
                                  Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                                  Controller "js-controller": 4.0.23   , installed 4.0.23
                                  Adapter    "modbus"       : 5.0.5    , installed 3.4.11 [Updatable]
                                  • R RS_Tobi
                                    wieder online...
                                    @rs_tobi
                                    iob upgrade all -y
                                    Danach
                                    iobroker setup custom
                                    und schauen ob die Anbindung an den Master noch korrekt ist.
                                    Siehe auch hier:
                                    https://www.iobroker.net/#de/documentation/config/multihost.md
                                      @rs_tobi
                                      iob upgrade all -y
                                      Danach
                                      Siehe auch hier:
                                      RS_Tobi
                                      @rs_tobi
                                      iob upgrade all -y
                                      Danach
                                      Ausgabe:
                                      pi@FroelingSlavePi2:~ $ iobroker setup custom
                                      Current configuration:
                                      - Objects database:
                                        - Type: jsonl
                                        - Host/Unix Socket: 192.168.178.11
                                        - Port: 9001
                                      - States database:
                                        - Type: jsonl
                                        - Port: 9000
                                      - Data Directory: ../../iobroker-data/
                                      Type of objects DB [(j)sonl, (f)ile, (r)edis, ...], default [jsonl]:
                                      • R RS_Tobi
                                        @rs_tobi
                                        iob upgrade all -y
                                        Danach
                                        Ausgabe:
                                        - Objects database:
                                          - Type: jsonl
                                          - Port: 9001
                                        - States database:
                                          - Type: jsonl
                                          - Port: 9000
                                        192.168.178.11
                                        Und die IP 192.168.178.11 ist vom Master? Vom Slave? Von sonstwem?
                                          192.168.178.11
                                          RS_Tobi
                                          Hallo Thomas,
                                          ich muss mich mal kurz zwischendurch bei dir erklären und bedanken.
                                          Unsere Konversation ist zeitlich sehr zerrissen.
                                          Das ist nicht mein Mangel an Interesse sondern Mangel an Zeit.
                                          Wir haben drei Kinder und ich arbeite Vollzeit.
                                          Somit kommt mir ständig etwas dazwischen.
                                          Danke dafür.
                                          Zurück zum Thema.
                                          Ich bin auch keiner, der, wenn er einen Fehler hat sich gleich ins Forum setzt und sich diesen kostenlos von anderen beheben lässt.
                                          Ich bin schon derjenige, der erst mal versucht sich selber durch Forum zu wühlen, Anleitungen oder HowTO's (wie von dir z.B) zu finden und diese abzuarbeiten.
                                          Und hier kommen wir zum Thema, ich bin kein Programmierer, auch wenn ich es gerne wäre.
                                          Jedoch bin ich jemand den es interessiert und der es auch verstehen möchte.
                                          Ich möchte deine Kompetenz nicht in frage stellen, ich will auch nicht unhöflich sein.
                                          Versteh mich nicht falsch!
                                          Aber kann es sein das wir am falschen Eck nach dem Fehler suchen?
                                          Wenn mir
                                          pi@FroelingSlavePi2:~ $ iob status
                                          iobroker is not running on this host.
                                          antwortet, dann kann die Multihost Einstellung doch stimmen oder nicht...
                                          Wir werden so oder so keine Verbindung bekommen wenn der
                                          iobroker nicht läuft.
                                          Oder verstehe ich hier was falsch?
