  4. Zwave2 Adapter startet nicht mehr
    6.3k
27 Beiträge 5 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • Fred FreundF Fred Freund
    @arteck bootable usb sata, zigbee stick
    arteckA Offline
    arteckA Offline
    arteck
    @fred-freund da hast du deine Probleme.. zeigmal die einstellung des adapter ?
    nochmal der kann den Port nicht öffnen ergo den zwave stick nicht finden
    Fred FreundF 1 Antwort Letzte Antwort
      Hallo , muss mich hier anhaengen:
      nach dem update started der Adapter bei mir nicht mehr.
      lsusb
      Bus 002 Device 002: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
      Bus 001 Device 003: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP2102/CP2109 UART Bridge Controller [CP210x family]
      Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
      usbreset gemacht
      host.iobroker1
      	2022-09-06 10:20:28.627	info	Restart adapter system.adapter.zwave2.0 because enabled
      host.iobroker1
      	2022-09-06 10:20:28.627	error	instance system.adapter.zwave2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker1
      	2022-09-06 10:20:28.627	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker1
      	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker1
      	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/MockSerialPort.ts:11:1)
      host.iobroker1
      	2022-09-06 10:20:28.626	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
      host.iobroker1
      	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      host.iobroker1
      	2022-09-06 10:20:28.626	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      host.iobroker1
      	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      host.iobroker1
      	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      host.iobroker1
      	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      host.iobroker1
      	2022-09-06 10:20:28.625	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@zwave-js/serial/src/SerialPortMock.ts:16:37)
      host.iobroker1
      	2022-09-06 10:20:28.624	error	Caught by controller[0]: TypeError: Class extends value undefined is not a constructor or null
      host.iobroker1
      	2022-09-06 10:20:27.233	info	instance system.adapter.zwave2.0 started with pid 5584
      host.iobroker1
      	2022-09-06 10:19:57.038	info	Restart adapter system.adapter.zwave2.0 because enabled
      und das wiederholt sich immer...
      keine updates:
      apt list --upgradable
      Listing... Done
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @fred-freund sagte in Zwave2 Adapter startet nicht mehr:
      Welche Version hast du denn installiert? Sieht mir nicht nach der stable-Version aus.
      • AlCalzoneA AlCalzone
        Fred FreundF Offline
        Fred Freund
        schrieb am zuletzt editiert von Fred Freund
        @alcalzone
        many Thx for your support,
        Vielen Dank!
          @alcalzone
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @fred-freund Seltsam. Du könntest mal auf 3.0.3 aus dem Latest/Beta-Repo upgraden. Da sollte das auf jeden Fall gehen.
          Es kann aber derzeit noch Probleme mit manchen Geräten geben. Fall das der Fall ist, bitte jeweils neu interviewen (nur interviewen, nicht neu anlernen).
          R 1 Antwort Letzte Antwort
          • arteckA arteck
            Fred Freund
            @arteck
            Vielen Dank!
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              Das hat nix mit den Adaptereinstellung oder Node.js zu tun. Da ist eine Abhängigkeit im Adapter krumm, und zwar in einer früheren Version als ich bisher dachte.
                Fred Freund
                @alcalzone
                das komische mit dem beta zeigt er mir den nicht an als update
                hab nach dem adapter gesucht ..dann gehts..
                updating .........................................
                Vielen Dank!
                  @alcalzone
                  Fred Freund
                  Genial, Danke laeuft!!
                  zwave2.0
                  	2022-09-06 13:47:50.872	info	Node 6: ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.766	info	Node 5: ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.709	info	Node 4: ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.655	info	Node 3: ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.558	info	Node 1: ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.318	info	Updating broadcast/multicast node states
                  zwave2.0
                  	2022-09-06 13:47:50.316	info	All nodes are ready to use
                  zwave2.0
                  	2022-09-06 13:47:50.065	info	The driver is ready. Found 5 nodes.
                  zwave2.0
                  	2022-09-06 13:47:41.019	info	starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.zwave2, node: v14.20.0, js-controller: 4.0.23
                  host.iobroker1
                  	2022-09-06 13:47:36.939	info	instance system.adapter.zwave2.0 started with pid 17274
                  host.iobroker1
                  	2022-09-06 13:47:36.796	info	"system.adapter.zwave2.0" enabled
                  Danke fuer die Hilfe und den Adapter!!!!
                  Vielen Dank!
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    zwave2.0
                    host.iobroker1
                    host.iobroker1
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @fred-freund Nicht vergessen das Repo wieder auf Stable zurück zu stellen :)
                      ross0865
                      @alcalzone Danke, der Tipp mit der Version 3.0.3 hat mein Alt-System auch wieder fit gemacht.
                        Fred Freund
                        @alcalzone Das hab ich gleich gemacht, vergessen ist meine Staerke👏
                        Vielen Dank!
