  4. Test Netatmo 2.0.0 Alpha (GitHub)
100 Beiträge 19 Kommentatoren 17.1k Aufrufe 18 Beobachtet
  • JohGreJ JohGre
    @apollon77 Hatte eben den ersten Absturz des Adapters, läuft aber weiter. Soll ich den Loglevel auf Info stellen, derzeit bin ich nur im warn unterwegs.
    2022-09-08 14:39:22.960 - error: netatmo.0 (19841) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-09-08 14:39:22.960 - error: netatmo.0 (19841) unhandled promise rejection: homesdata error: No response
    2022-09-08 14:39:22.962 - error: netatmo.0 (19841) Error: homesdata error: No response
    at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
    at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
    at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    at Request.emit (node:events:513:28)
    at Request.emit (node:domain:489:12)
    at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    at ClientRequest.emit (node:events:525:35)
    at ClientRequest.emit (node:domain:489:12)
    at TLSSocket.socketErrorListener (node:_http_client:481:9)
    at TLSSocket.emit (node:events:513:28)
    2022-09-08 14:39:22.963 - error: netatmo.0 (19841) homesdata error: No response
    2022-09-08 14:39:22.974 - warn: netatmo.0 (19841) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-09-08 14:39:33.072 - error: host.VM-Slave Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: Error: homesdata error: No response
    2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
    2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
    2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:events:513:28)
    2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:domain:489:12)
    2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
    2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:events:525:35)
    2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:domain:489:12)
    2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.socketErrorListener (node:_http_client:481:9)
    2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.emit (node:events:513:28)
    2022-09-08 14:39:33.077 - error: host.VM-Slave instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    @johgre bitte nochmal von github updaten. Da gab es mal keinen response. Da hatte ich gestern Abend noch was gefixt.
    • O oFbEQnpoLKKl6mbY5e13
      @apollon77
      Ich habe vier Stationen...
      @ofbeqnpolkkl6mby5e13 und auch alles ok? Ist die Objekt Struktur auch sinnvoll so wie Sie jetzt ist?
      O 2 Antworten Letzte Antwort
      • apollon77A apollon77
        O Abwesend
        O Abwesend
        @apollon77
        Gute Frage, es wäre ein riesen Aufwand, die ganzen Aliase anzupassen, bei so vielen Modulen...
        Müsste mir erst wieder ein Testsystem erstellen...
        Im Moment leider wenig Zeit...
          O Abwesend
          O Abwesend
          @apollon77
          Puh... wenn man zwei Module mit der Bezeichnung Badezimmer hat, weiß man jetzt nicht mehr, welches welches ist (Obergeschoss, Erdgeschoss)... es muss unbedingt erst nach Station unterschieden werden!
          Und das crashed nach dem Konfigurieren:
          2022-09-08 22:44:35.676  - info: netatmo.0 (3932) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
          2022-09-08 22:44:35.722  - info: netatmo.0 (3932) Authenticating with Netatmo using individual client-ID xxx
          2022-09-08 22:44:35.724  - warn: netatmo.0 (3932) API Error: Please Authenticate manually once using the Admin UI of this instance.
          2022-09-08 22:47:26.586  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
          2022-09-08 22:47:31.624  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
          2022-09-08 22:47:36.631  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
          2022-09-08 22:47:41.691  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
          2022-09-08 22:47:53.588  - info: netatmo.0 (3932) Successfully authenticated with Netatmo with individual client-ID xxx
          2022-09-08 22:47:53.597  - info: netatmo.0 (3932) Save OAuth data: {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
          2022-09-08 22:47:53.623  - info: netatmo.0 (3932) Update data in adapter configuration ... restarting ...
          2022-09-08 22:47:53.659  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 (force=false, process=true)
          2022-09-08 22:47:53.668  - info: netatmo.0 (3932) Got terminate signal TERMINATE_YOURSELF
          2022-09-08 22:47:53.667  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 send kill signal
          2022-09-08 22:47:53.671  - info: netatmo.0 (3932) cleaned everything up...
          2022-09-08 22:47:53.673  - info: netatmo.0 (3932) terminating
          2022-09-08 22:47:53.677  - info: netatmo.0 (3932) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-09-08 22:47:54.196  - warn: netatmo.0 (3932) Could not perform strict object check of state netatmo.0.5e85b1dc9da0e8304e2becfc.70-ee-50-06-97-ea.Temperature.TemperatureMin: DB closed
          2022-09-08 22:47:54.197  - warn: netatmo.0 (3932) get state error: Connection is closed.
          2022-09-08 22:47:54.200  - error: netatmo.0 (3932) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2022-09-08 22:47:54.201  - error: netatmo.0 (3932) unhandled promise rejection: DB closed
          2022-09-08 22:47:54.572  - error: netatmo.0 (3932) Error: DB closed
              at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
              at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
              at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
              at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
          2022-09-08 22:47:54.573  - error: netatmo.0 (3932) DB closed
          2022-09-08 22:47:54.673  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 killing pid 3932
          2022-09-08 22:47:54.688  - info: host.iobroker-test instance system.adapter.netatmo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-09-08 22:47:56.703  - info: host.iobroker-test instance system.adapter.netatmo.0 started with pid 4117
          2022-09-08 22:47:58.928  - info: netatmo.0 (4117) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
          2022-09-08 22:47:58.985  - info: netatmo.0 (4117) Using stored tokens to initialize ... {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
          2022-09-08 22:47:58.987  - info: netatmo.0 (4117) Authenticating with Netatmo using individual client-ID xxx
          2022-09-08 22:47:59.245  - info: netatmo.0 (4117) Successfully authenticated with Netatmo with individual client-ID xxx
            @apollon77
            @ofbeqnpolkkl6mby5e13 Ok, dann bitte vollständiges Debug Log mir per E-Mails senden und genau beschreiben was das issue ist.
            An Sich sollte die struktur homeID.moduleId.weiteres sein, damit sollte an sich doch jede Station ne andere Module die haben oder? Früher war es doch dann aber schlimmer weil früher alle "Badezimmer" in eins geworfen wurden und damit hattest Du doch gar keine unterscheidung oder?
            Zu dem "crash" ... Am ENde kein Crash sondern ein restart nach Konfigänderung. ja der DB fehler ist anzusehen
            O 1 Antwort Letzte Antwort
              O Abwesend
              O Abwesend
              @apollon77
              Bisher:
              Alt
              v2.0.0
              Neu
                @apollon77
                Bisher:
                Alt
                v2.0.0
                Neu
                @ofbeqnpolkkl6mby5e13 ja ok ist mehr. Über die Objektnamens hast du das gleiche ja. Wo waren denn Module wie Nordseite und so bisher? Nur unter Haus. Richtig?
                  O Abwesend
                  O Abwesend
                  @apollon77
                  Nein, die sind unter den zugehörigen Stationen.
                  Unter Haus ist nichts Brauchbares:
                  Vielleicht sollte ich das näher erklären, da du selbst ja keine Station besitzt:
                  Pro Station können maximal 3 Innenmodule, 1 Außenmodul, 1 Windmesser und 1 Regenmesser angeschlossen werden. Wenn man also mehr als 3 zusätzliche Innenmodule benötigt (die Stationen selbst dienen auch als Innenmodul!), dann braucht man eine weitere Station, die nun wieder u. a. auch ein Außenmodul mitbringt. Daher Nord- und Südseite.
                  Bei der neuen Struktur kann man nun nicht mehr erkennen, zu welchen Stationen z. B. Badezimmer gehört.
                    @apollon77
                    @ofbeqnpolkkl6mby5e13 ok. Damit volles debug log bitte. Muss schauen wie das auf der datenebene aussieht.
                    • S Online
                      S Online
                      Schimi
                      schrieb am zuletzt editiert von Schimi
                      Ich finde die Ordnerstruktur besser als vorher... Gerade wen man mal die Bezeichnung ändert sollte es nun ja trotzdem "gleich" bleiben :-)
                      Da ich noch nicht "klingeln" darf (die kleine schläft :-) ), kann ich nur dazusagen das der Name der Klingel nicht übernommen wird?
                      edit
                      Bekomme das im Log... vielleicht liegt da der Fehler beim "Namen"
                      netatmo.0
                      2022-09-11 15:35:05.075	warn	Object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                      apollon77A 2 Antworten Letzte Antwort
                      • JohGreJ Offline
                        JohGreJ Offline
                        JohGre
                        Bei mir läuft der Adapter nun seit 4 Tagen ohne Probleme. Finde auch das die Ordnerstruktur besser ist. War zwar einmal etwas Aufwand bzgl. der Scripte anpassen, aber halb so wild. Jetzt ist ja dann Ruhe damit.
                        nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
                        • S Schimi
                          edit
                          netatmo.0
                          @schimi bitte debug log per email mit Verweis auf den post bitte
                          • JohGreJ JohGre
                            @johgre ich bin noch dabei mir wegen Wetterstationen nochmal was anzusehen. Vllt ändert sich nochmal was. Poste aber hier.
                              O Abwesend
                              O Abwesend
                              @apollon77
                              Völlig egal, wieviel sich noch an der neuen Struktur ändert, ich habe über 300 Aliasse, die auf Datenpunkte des Netatmo-Adapters verweisen, soll ich die alle manuell anpassen?
                                @apollon77
                                @ofbeqnpolkkl6mby5e13 megasorry aber ich fürchte das kommt auf die zu, ja :-( in dem Fall doppelt sorry weil die alte Adapterversion Vorauss ab Oktober auch Nicht mehr tut, also bleiben ist dann auch keine Option.
                                • O Abwesend
                                  O Abwesend
                                  @apollon77
                                  Wie du weißt, hat das Eine (Objektstruktur) nichts mit dem Anderen (Authentifizierung) zu tun...
                                    @apollon77
                                    @ofbeqnpolkkl6mby5e13 ja … wie aber oben beschrieben nutzte der Adapter bisher auch als deprecated gekennzeichnete api calls. Keine Ahnung wann die wegfallen. Und in diesen apis gibt es nur limitierte Geräte und einige wie der co2 Sensor oder doorbell sind nur in den neuen apis. Das zu mischen bringt noch mehr Chaos.
                                    Weiterhin habe ich den Adapter jetzt quasi übernommen und die bisherige Struktur war sehr uneinheitlich, gewachsen, überschneidend was verschiedene Geräte anging und potentiell gefährlich für Konflikte wegen gleichen Namen. Jede Namensänderung in netatmo führt im Adapter zu einer neuen Struktur. All das hat mich dazu gebracht das Ganze neu zu strukturieren, Sindbads ich das auch verstehe und künftig weiter betreuen kann.
                                    Das das jetzt mit der Authentifizierungsänderung zusammenfällt ist blöd aber lag daran das ich parallel am doorbell gearbeitet habe und auch letzte Features wie der co2 Sensor und rauchmelder nicht so taten wie sie sollte. Das hat sich alles zeitlich blöderweise überschnitten mit dem Termin when auth Änderung.
                                    Hätte ich eine neue Version machen können basierend auf der letzten veröffentlichten (wo Dinge nicht richtig tun) mit nur neuer auth? Ja vllt … habe mich bisher aber dagegen entschieden weil es nichts wirklich daran ändert wie die Version danach aussehen wird und einige doorbell Änderungen Zum testen schon auf github waren. Wäre also ggf wieder ein schritt zurück für andere User……
                                    Ich verstehe deinen Schmerz durchaus. Ich hoffe du kannst meine Sichtweise auch ein bissl nachvollziehen.
                                    Ingo
                                    • ToonPhantomT Offline
                                      ToonPhantom
                                      Ich bin neu in der ioBroker Welt. Ich bin nun aber etwas verwirrt, wie ich diese Testversion der Netatmo Integration installiere. Ich habe bereits auf den Betachannel im ioBroker gewechselt, aber da ist die Alpha-Version nicht verfügbar.
                                      Muss man das irgendwie händisch installieren, oder gibt es da Wege über die UI?
                                      • ToonPhantomT ToonPhantom
                                        @toonphantom Admin - Expertenmodus - CUstom install icon klicken - von Github wählen und adapter wählen oder CUstoim wählen und URL aus dem ersten post reinkopieren
                                        • apollon77A Offline
                                          Auf GitHub gibt es jetzt die 2.0.1 Alpha ... Unterschied ist nur das die Wetterstationsmodule einer Station jetzt korrekterweise unterhalb der Station gelistet sind. Siehe auch https://forum.iobroker.net/post/854943 (fix dafür)
                                          Bitte checkt alle nochmal die GitHub Version ... dann würde ich die zeitnah so ins Beta packen.
                                          O E 2 Antworten Letzte Antwort
