  4. Test Netatmo 2.0.0 Alpha (GitHub)
100 Beiträge 19 Kommentatoren 17.1k Aufrufe 18 Beobachtet
  • Hot-Air-BalloonH Hot-Air-Balloon
    @apollon77 said in Test Netatmo 2.0.0 Alpha (GitHub):
    6.2.14 o
    I'm ready 4 testing :)
    Edit: Gefunden ...
    Die Daten sehen erstmal gut aus, ich blätter mal durch die Objekte.
    Kurzer Auszug:
    https://i.imgur.com/lOuZHsP.png
    https://i.imgur.com/lQEa2gb.png
    Authentifizierung muss ich noch testen
    Edit:
    netatmo.0
    	2022-09-07 19:08:20.044	info	Successfully authenticated with Netatmo with individual client-ID 62xxxx146
    netatmo.0
    	2022-09-07 19:08:19.845	info	Authenticating with Netatmo using individual client-ID 62xxxx146
    netatmo.0
    	2022-09-07 19:08:19.843	info	Using stored tokens to initialize ... {"access_token":"53xxxe59|8e6xxxx4e2","refresh_token":"53xxxxe59|4c0xxxxa192","scope":"read_station","client_id":"62xxx146"}
    netatmo.0
    	2022-09-07 19:08:19.805	info	starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
    netatmo.0
    	2022-09-07 19:08:14.412	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    netatmo.0
    	2022-09-07 19:08:14.409	info	terminating
    netatmo.0
    	2022-09-07 19:08:14.408	info	cleaned everything up...
    netatmo.0
    	2022-09-07 19:08:14.406	info	Got terminate signal TERMINATE_YOURSELF
    netatmo.0
    	2022-09-07 19:08:04.555	info	Successfully authenticated with Netatmo with individual client-ID 62xxxx146
    netatmo.0
    	2022-09-07 19:08:04.360	info	Authenticating with Netatmo using individual client-ID 62xxxx146
    netatmo.0
    	2022-09-07 19:08:04.358	info	Using stored tokens to initialize ... {"access_token":"53xxxx2e59|8e6xxxxb4e2","refresh_token":"53xxxxx2e59|4c0xxxx192","scope":"read_station","client_id":"62xxxx146"}
    netatmo.0
    	2022-09-07 19:08:04.320	info	starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
    netatmo.0
    	2022-09-07 19:07:59.366	error	DB closed
    netatmo.0
    	2022-09-07 19:07:59.365	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:757:14)
    netatmo.0
    	2022-09-07 19:07:59.355	error	unhandled promise rejection: DB closed
    netatmo.0
    	2022-09-07 19:07:59.354	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    netatmo.0
    	2022-09-07 19:07:58.836	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    netatmo.0
    	2022-09-07 19:07:58.834	info	terminating
    netatmo.0
    	2022-09-07 19:07:58.832	info	cleaned everything up...
    netatmo.0
    	2022-09-07 19:07:58.831	info	Got terminate signal TERMINATE_YOURSELF
    netatmo.0
    	2022-09-07 19:07:58.794	info	Update data in adapter configuration ... restarting ...
    netatmo.0
    	2022-09-07 19:07:58.792	info	Save OAuth data: {"access_token":"53xxxxx4e2","refresh_token":"53xxxxe59|4c0xxxxa192","scope":"read_station","client_id":"62xxx146"}
    Bin mir nicht sicher, ob das alles passt, aber cih habe beim Authentifizieren zumindest keine Fehlermeldung bekommen.
    Wenn ich noch was spezielles testen soll. Gerne melden !
    @hot-air-balloon cool. Bitte einfach schauen ob alles tut wie es soll. Daten so aktualisiert werden wie es soll und. So. Und keine Fehler kommen. ;-)) nur ne “Station“ ist so bissl der easy Case ;-)
    Hot-Air-BalloonH 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Hot-Air-BalloonH Offline
      Hot-Air-Balloon
      Wenn du mir weitere Aktoren Sponsorst kann ich die auch testen :D
      Ich melde mich, ob mir was auffällt.
        @hot-air-balloon hehe ... Danke!
          Aktuelle Test Version 2.0.0
          Veröffentlichungsdatum 07.09.2022
          Github Link https://github.com/PArns/ioBroker.netatmo
          aufgrund von nötigen Anpassungen bei Netatmo (Abschaltung der bisherigen Authentication Logik die der Adapter genutzt hat, siehe unten) habe ich mich mal umfangreich dem Netatmo Adapter angenommen. Aus gegebenem Anlass und weiterer Überlegungen ist das Update sehr groß geworden. Daher brauche ich Eure Unterstützung beim Testing.
          ACHTUNG Admin Version vor Test prüfen!
          Diese Version des Adapters benötigt Admin 6.2.14 oder höher! Unter dieses Kann die Konfiguration nicht erfolgen! An sich sollte Admin das prüfen, bei einem GitHub Adaptertest geht das allerdings nicht, also bitte selbst vorab sicherstellen!
          ACHTUNG Objekt-Struktur ändert sich vollständig!
          Bisher wurden die bei Netatmo vergebenen Namen für das "Heim" und die Module und Geräte für die Objekt-Struktur genutzt. Bei Namensänderungen gab es daher bisher immer neue Objekte. Keine Ahnung in wieweit die Geräte Namen haben müssen oder Eindeutigkeit geprüft wird bei Netatmo. Damit konnte es ggf zu Überschneidungen kommen was zu komischen Mischeffekten führt.
          Ich habe daher entschieden die Objektstruktur, wie eigentlich üblich, in Zukunft auf den eindeutigen IDs der Entitäten aufzubauen. Daher bitte Objekte im Vorfeld prüfen und löschen und dann Skripte oder Logiken entsprechend anpassen!
          ACHTUNG API Umstellungen ändern teilweise Daten
          Der Adapter hat bisher auch noch einige als "Deprecated" gekennzeichneten APIs genutzt, welche ich in dem Zuge mit ausgetauscht habe, wo es möglich war bzw sinnvoll zusammengefasst habe. Das bringt ggf Daten-Änderungen mit sich indem sich Werte ggf ändern. Wenn hier Probleme bestehen - oder vor allem Daten fehlen die bisher da waren und wichtig waren - bitte melden!
          ACHTUNG Authentication-Änderung bei Netatmo zu Oktober 2022
          Netatmo will im Oktober 2022 die bisher vom Adapter genutzte Authentication Variante abschalten. Der neue Adapter unterstützt das künftig nötige Verfahren (daher auch die neue Admin-version welche nötig ist). In wieweit der alte Adapter ab Oktoiber noch tut ist unklar ... daher haben wir für den Test nicht so viel Zeit :-)
          Changelog
          neben den "nervigen Änderungen die alles anders machen" oben gibts aber auch ein paar neue Features :-) Hier der Changelog:
          • BREAKING: Object structure changes completely and now uses unique IDs instead of names!
          • (Apollon77) Change the Authentication method as requested by Netatmo till October 2022
          • (Apollon77) Doorbell integration
          • (Apollon77) Converted to new APIs, values of several objects might be different
          • (Apollon77) Fix crash cases reported by Sentry
          • (Apollon77) Adjust setAway to the current API
          • (Apollon77) Added setHome function (Welcome only) to mark all or specific persons as home (requires your own API key!)
          • (Apollon77) setAway and setHome now also return the result of the call as callback tzo the message
          • (Apollon77) Allow to edit floodlight and monitoring-state
          Was ist zu testen
          Das geht ganz kurz: ALLES :-)
          Da ich kein einziges Netatmo-Gerät habe und bisher nur mit einigen Geräten mit Accounts testen konnte zu denen mir netterweise Zugangsdaten zur Verfügung gestellt wurden (Vielen Dank dafür!) ist bestimmt einiges noch ungetestet und die Änderungen waren sehr umfangreich ...
          Wenn Probleme bestehen, es Crahes gibt, Daten fehlen bitte GuitHub Issues anlegen und Debug Logs anhängen oder mir mit Angabe des GitHub issues per E-Mail an iobroker@fischer-ka.de senden!
          Happy Testing!
          Ingo
          M Online
          M Online
          mrjeschke
          @apollon77
          Erster Eindruck: Perfekt👍
          Ich habe nur die Wetterstation, die läuft aber ohne Auffälligkeiten.
          • JohGreJ Offline
            JohGreJ Offline
            JohGre
            @apollon77 Soweit mal alles klar. Daten werden geholt. Habe die Station mit Außenmodul und zusätzliche 3 Innenmodule sowie Regen- und Windsensor.
            nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
            • JohGreJ Offline
              JohGreJ Offline
              JohGre
              schrieb am zuletzt editiert von JohGre
              @apollon77 Hatte eben den ersten Absturz des Adapters, läuft aber weiter. Soll ich den Loglevel auf Info stellen, derzeit bin ich nur im warn unterwegs.
              2022-09-08 14:39:22.960 - error: netatmo.0 (19841) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2022-09-08 14:39:22.960 - error: netatmo.0 (19841) unhandled promise rejection: homesdata error: No response
              2022-09-08 14:39:22.962 - error: netatmo.0 (19841) Error: homesdata error: No response
              at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
              at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
              at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              at Request.emit (node:events:513:28)
              at Request.emit (node:domain:489:12)
              at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
              at ClientRequest.emit (node:events:525:35)
              at ClientRequest.emit (node:domain:489:12)
              at TLSSocket.socketErrorListener (node:_http_client:481:9)
              at TLSSocket.emit (node:events:513:28)
              2022-09-08 14:39:22.963 - error: netatmo.0 (19841) homesdata error: No response
              2022-09-08 14:39:22.974 - warn: netatmo.0 (19841) Terminated (UNCAUGHT_EXCEPTION): Without reason
              2022-09-08 14:39:33.072 - error: host.VM-Slave Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
              2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: Error: homesdata error: No response
              2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at netatmo.handleRequestError (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:98:19)
              2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoLib.js:1126:25)
              2022-09-08 14:39:33.075 - error: host.VM-Slave Caught by controller[1]: at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:events:513:28)
              2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.emit (node:domain:489:12)
              2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
              2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:events:525:35)
              2022-09-08 14:39:33.076 - error: host.VM-Slave Caught by controller[1]: at ClientRequest.emit (node:domain:489:12)
              2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.socketErrorListener (node:_http_client:481:9)
              2022-09-08 14:39:33.077 - error: host.VM-Slave Caught by controller[1]: at TLSSocket.emit (node:events:513:28)
              2022-09-08 14:39:33.077 - error: host.VM-Slave instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              • S Abwesend
                S Abwesend
                Shadowhunter23
                Installiert, soweit keine Probleme.
                Innen-, Außen- und Regensensor
                Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                ioBroker Backup Analyzer
                  Changelog
                  Was ist zu testen
                  Happy Testing!
                  Ingo
                  O Abwesend
                  O Abwesend
                  oFbEQnpoLKKl6mbY5e13
                  @apollon77
                  Ich habe vier Stationen...
                  • JohGreJ JohGre
                    @johgre bitte nochmal von github updaten. Da gab es mal keinen response. Da hatte ich gestern Abend noch was gefixt.
                    • O oFbEQnpoLKKl6mbY5e13
                      @apollon77
                      @ofbeqnpolkkl6mby5e13 und auch alles ok? Ist die Objekt Struktur auch sinnvoll so wie Sie jetzt ist?
                      O 2 Antworten Letzte Antwort
                        O Abwesend
                        O Abwesend
                        @apollon77
                        Gute Frage, es wäre ein riesen Aufwand, die ganzen Aliase anzupassen, bei so vielen Modulen...
                        Müsste mir erst wieder ein Testsystem erstellen...
                        Im Moment leider wenig Zeit...
                          O Abwesend
                          O Abwesend
                          @apollon77
                          Puh... wenn man zwei Module mit der Bezeichnung Badezimmer hat, weiß man jetzt nicht mehr, welches welches ist (Obergeschoss, Erdgeschoss)... es muss unbedingt erst nach Station unterschieden werden!
                          Und das crashed nach dem Konfigurieren:
                          2022-09-08 22:44:35.676  - info: netatmo.0 (3932) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
                          2022-09-08 22:44:35.722  - info: netatmo.0 (3932) Authenticating with Netatmo using individual client-ID xxx
                          2022-09-08 22:44:35.724  - warn: netatmo.0 (3932) API Error: Please Authenticate manually once using the Admin UI of this instance.
                          2022-09-08 22:47:26.586  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                          2022-09-08 22:47:31.624  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                          2022-09-08 22:47:36.631  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                          2022-09-08 22:47:41.691  - warn: netatmo.0 (3932) API Error: Authenticate "client_id" not set.
                          2022-09-08 22:47:53.588  - info: netatmo.0 (3932) Successfully authenticated with Netatmo with individual client-ID xxx
                          2022-09-08 22:47:53.597  - info: netatmo.0 (3932) Save OAuth data: {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
                          2022-09-08 22:47:53.623  - info: netatmo.0 (3932) Update data in adapter configuration ... restarting ...
                          2022-09-08 22:47:53.659  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 (force=false, process=true)
                          2022-09-08 22:47:53.668  - info: netatmo.0 (3932) Got terminate signal TERMINATE_YOURSELF
                          2022-09-08 22:47:53.667  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 send kill signal
                          2022-09-08 22:47:53.671  - info: netatmo.0 (3932) cleaned everything up...
                          2022-09-08 22:47:53.673  - info: netatmo.0 (3932) terminating
                          2022-09-08 22:47:53.677  - info: netatmo.0 (3932) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2022-09-08 22:47:54.196  - warn: netatmo.0 (3932) Could not perform strict object check of state netatmo.0.5e85b1dc9da0e8304e2becfc.70-ee-50-06-97-ea.Temperature.TemperatureMin: DB closed
                          2022-09-08 22:47:54.197  - warn: netatmo.0 (3932) get state error: Connection is closed.
                          2022-09-08 22:47:54.200  - error: netatmo.0 (3932) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2022-09-08 22:47:54.201  - error: netatmo.0 (3932) unhandled promise rejection: DB closed
                          2022-09-08 22:47:54.572  - error: netatmo.0 (3932) Error: DB closed
                              at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                              at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
                              at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:657:40)
                              at Adapter.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:6485:35)
                          2022-09-08 22:47:54.573  - error: netatmo.0 (3932) DB closed
                          2022-09-08 22:47:54.673  - info: host.iobroker-test stopInstance system.adapter.netatmo.0 killing pid 3932
                          2022-09-08 22:47:54.688  - info: host.iobroker-test instance system.adapter.netatmo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2022-09-08 22:47:56.703  - info: host.iobroker-test instance system.adapter.netatmo.0 started with pid 4117
                          2022-09-08 22:47:58.928  - info: netatmo.0 (4117) starting. Version 2.0.0 (non-npm: PArns/ioBroker.netatmo#4fc7576c43e782e34bf464b63196a4af85a242d1) in /opt/iobroker/node_modules/iobroker.netatmo, node: v16.17.0, js-controller: 4.0.23
                          2022-09-08 22:47:58.985  - info: netatmo.0 (4117) Using stored tokens to initialize ... {"access_token":"xxx","refresh_token":"xxx","scope":"read_station","client_id":"xxx"}
                          2022-09-08 22:47:58.987  - info: netatmo.0 (4117) Authenticating with Netatmo using individual client-ID xxx
                          2022-09-08 22:47:59.245  - info: netatmo.0 (4117) Successfully authenticated with Netatmo with individual client-ID xxx
                            @apollon77
                            @ofbeqnpolkkl6mby5e13 Ok, dann bitte vollständiges Debug Log mir per E-Mails senden und genau beschreiben was das issue ist.
                            An Sich sollte die struktur homeID.moduleId.weiteres sein, damit sollte an sich doch jede Station ne andere Module die haben oder? Früher war es doch dann aber schlimmer weil früher alle "Badezimmer" in eins geworfen wurden und damit hattest Du doch gar keine unterscheidung oder?
                            Zu dem "crash" ... Am ENde kein Crash sondern ein restart nach Konfigänderung. ja der DB fehler ist anzusehen
                            O 1 Antwort Letzte Antwort
                              O Abwesend
                              O Abwesend
                              @apollon77
                              Bisher:
                              Alt
                              v2.0.0
                              Neu
                                @apollon77
                                Bisher:
                                Alt
                                v2.0.0
                                Neu
                                @ofbeqnpolkkl6mby5e13 ja ok ist mehr. Über die Objektnamens hast du das gleiche ja. Wo waren denn Module wie Nordseite und so bisher? Nur unter Haus. Richtig?
                                  O Abwesend
                                  O Abwesend
                                  @apollon77
                                  Nein, die sind unter den zugehörigen Stationen.
                                  Unter Haus ist nichts Brauchbares:
                                  Vielleicht sollte ich das näher erklären, da du selbst ja keine Station besitzt:
                                  Pro Station können maximal 3 Innenmodule, 1 Außenmodul, 1 Windmesser und 1 Regenmesser angeschlossen werden. Wenn man also mehr als 3 zusätzliche Innenmodule benötigt (die Stationen selbst dienen auch als Innenmodul!), dann braucht man eine weitere Station, die nun wieder u. a. auch ein Außenmodul mitbringt. Daher Nord- und Südseite.
                                  Bei der neuen Struktur kann man nun nicht mehr erkennen, zu welchen Stationen z. B. Badezimmer gehört.
                                    @apollon77
                                    @ofbeqnpolkkl6mby5e13 ok. Damit volles debug log bitte. Muss schauen wie das auf der datenebene aussieht.
                                    • S Online
                                      S Online
                                      Schimi
                                      schrieb am zuletzt editiert von Schimi
                                      Ich finde die Ordnerstruktur besser als vorher... Gerade wen man mal die Bezeichnung ändert sollte es nun ja trotzdem "gleich" bleiben :-)
                                      Da ich noch nicht "klingeln" darf (die kleine schläft :-) ), kann ich nur dazusagen das der Name der Klingel nicht übernommen wird?
                                      edit
                                      Bekomme das im Log... vielleicht liegt da der Fehler beim "Namen"
                                      netatmo.0
                                      2022-09-11 15:35:05.075	warn	Object 5eea11c3c20743509886b280.70-ee-50-6e-bb-74 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                      apollon77A 2 Antworten Letzte Antwort
                                      • JohGreJ Offline
                                        JohGreJ Offline
                                        JohGre
                                        Bei mir läuft der Adapter nun seit 4 Tagen ohne Probleme. Finde auch das die Ordnerstruktur besser ist. War zwar einmal etwas Aufwand bzgl. der Scripte anpassen, aber halb so wild. Jetzt ist ja dann Ruhe damit.
                                        • S Schimi
                                          edit
                                          netatmo.0
                                          @schimi bitte debug log per email mit Verweis auf den post bitte
