  4. Server Cannot start inMem-objects on port 9001
429 Beiträge 40 Kommentatoren 132.6k Aufrufe 39 Beobachtet
  • R Rene 3
    @thomas-braun 2802 info run @abandonware/bluetooth-hci-socket@0.5.3-8 install node_modules/@abandonware/bluetooth-hci-socket node-pre-gyp install --fallback-to-build
    2803 info run @abandonware/noble@1.9.2-15 install node_modules/@abandonware/noble node-gyp rebuild
    2804 info run @serialport/bindings-cpp@10.7.0 install node_modules/@serialport/bindings-cpp node-gyp-build
    2805 info run diskusage@1.1.3 install node_modules/diskusage node-gyp rebuild
    2806 info run @serialport/bindings-cpp@10.7.0 install { code: 0, signal: null }
    2807 timing build:run:install:node_modules/@serialport/bindings-cpp Completed in 777ms
    2808 info run iobroker.js-controller@4.0.23 install node_modules/iobroker.js-controller node iobroker.js setup first
    2809 info run @abandonware/noble@1.9.2-15 install { code: 0, signal: null }
    2810 timing build:run:install:node_modules/@abandonware/noble Completed in 5409ms
    2811 info run iobroker.vis@1.4.15 install node_modules/iobroker.vis node main.js --install
    2812 info run diskusage@1.1.3 install { code: 0, signal: null }
    2813 timing build:run:install:node_modules/diskusage Completed in 9604ms
    2814 info run unix-dgram@2.0.4 install node_modules/unix-dgram node-gyp rebuild
    2815 info run @abandonware/bluetooth-hci-socket@0.5.3-8 install { code: 0, signal: null }
    2816 timing build:run:install:node_modules/@abandonware/bluetooth-hci-socket Completed in 11107ms
    2817 info run ursa-optional@0.9.10 install node_modules/ursa-optional node rebuild.js
    2818 info run unix-dgram@2.0.4 install { code: 0, signal: null }
    2819 timing build:run:install:node_modules/unix-dgram Completed in 7218ms
    2820 info run usb@1.9.2 install node_modules/usb node-gyp-build
    2821 info run iobroker.vis@1.4.15 install { code: 0, signal: null }
    2822 timing build:run:install:node_modules/iobroker.vis Completed in 12268ms
    2823 info run ursa-optional@0.9.10 install { code: 0, signal: null }
    2824 timing build:run:install:node_modules/ursa-optional Completed in 7634ms
    2825 info run iobroker.js-controller@4.0.23 install { code: 22, signal: null }
    2826 info run usb@1.9.2 install { code: 1, signal: null }
    2827 verbose reify failed optional dependency /opt/iobroker/node_modules/usb
    2828 silly reify mark deleted [ '/opt/iobroker/node_modules/usb' ]
    2829 verbose reify failed optional dependency /opt/iobroker/node_modules/usb/node_modules/node-addon-api
    2830 silly reify mark deleted [ '/opt/iobroker/node_modules/usb/node_modules/node-addon-api' ]
    2831 timing build:run:install:node_modules/usb Completed in 17022ms
    2832 timing reify:rollback:createSparse Completed in 4803ms
    2833 timing reify:rollback:retireShallow Completed in 0ms
    2834 timing command:i Completed in 111659ms
    2835 verbose stack Error: command failed
    2835 verbose stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:63:27)
    2835 verbose stack at ChildProcess.emit (events.js:400:28)
    2835 verbose stack at maybeClose (internal/child_process.js:1088:16)
    2835 verbose stack at Socket.<anonymous> (internal/child_process.js:446:11)
    2835 verbose stack at Socket.emit (events.js:400:28)
    2835 verbose stack at Pipe.<anonymous> (net.js:686:12)
    2836 verbose pkgid iobroker.js-controller@4.0.23
    2837 verbose cwd /opt/iobroker
    2838 verbose Linux 5.15.61-v7l+
    2839 verbose node v14.20.0
    2840 verbose npm v8.18.0
    2841 error code 22
    2842 error path /opt/iobroker/node_modules/iobroker.js-controller
    2843 error command failed
    2844 error command sh -c -- node iobroker.js setup first
    2845 error No connection to databases possible ...
    2846 verbose exit 22
    2847 timing npm Completed in 111982ms
    2848 verbose unfinished npm timer reify 1661968356534
    2849 verbose unfinished npm timer reify:build 1661968431876
    2850 verbose unfinished npm timer build 1661968431885
    2851 verbose unfinished npm timer build:deps 1661968431886
    2852 verbose unfinished npm timer build:run:install 1661968433965
    2853 verbose unfinished npm timer build:run:install:node_modules/iobroker.js-controller 1661968434911
    2854 verbose code 22
    2855 error A complete log of this run can be found in:
    2855 error /home/iobroker/.npm/_logs/2022-08-31T17_52_36_224Z-debug-0.log
    vielleicht hilft das ( der Pfad ) ?
    #154
    @rene-3
    Bitte CodeTags verwenden. Danke.
    Und wozu gehört die Ausgabe? Zusammenhang?
    R 1 Antwort Letzte Antwort
      @rene-3
      Rene 3
      #155
      @thomas-braun also dachte eigentlich das immer noch gesucht wird wo man genau die Ursachen für den Crash findet ( für alle die, deren Raspi noch nicht wieder läuft )
      Wie stell ich das mit den CodeTags an / finde ich da was dazu in der Doku ?
      Sorry
      GlasfaserG apollon77A 2 Antworten Letzte Antwort
      • R Rene 3
        Sorry
        GlasfaserG Offline
        GlasfaserG Offline
        #156
        @rene-3 sagte in Server Cannot start inMem-objects on port 9001:
        • GlasfaserG Glasfaser
          Rene 3
          #157
          @glasfaser Danke
          • R Rene 3
            Sorry
            #158
            Ja aber DU hast eine Ausgabe gepostet ohne die Infos wie diese zusatdnegekommen ist. Welchen befehl hast Du ausgeführt das die so kam?
            • apollon77A apollon77
              Rene 3
              #159
              @apollon77 also ich suche hier eigentlich sämtliche Log Files auf meinem Raspi ab und werde einfach nicht schlau weshalb der iobroker plötzlich nicht mehr laufen will - der Raspi geht - also ich kann hier Netzteil / USV etc. ausschließen
              • R Rene 3
                2841 error code 22
                #160
                node v14.20.0
                Könntest du schon mal auf die derzeitig empfohlene Version nodejs 16 bringen.
                  node v14.20.0
                  Rene 3
                  #161
                  @thomas-braun es geht nicht nodejs zu aktualisieren
                  cd /opt/iobroker
                  iobroker list instances
                  gibt aus:
                  Server cannot start inMem-Objects on Port 9001: Failed to lock DB " opt/iobroker/iobroker-data/objects.jsonl"!
                  da sollte ja eine andere Ausgabe kommen
                  • R Rene 3
                    #162
                    @rene-3 Na dann beantworte doch mal die Fragen die ich oben gestellt habe und lass es uns strukturiert angehen.
                    jetzt mal zuerst mal "iob stop" und prüfe das nichts mehr läuft.
                    Wenn Du jetzt "iob status" ausführst was kommt? geht das oder kommt ein Fehler?
                    EDIT: Ok das hast Du gerade gezeigt, also weiter mit dem nächsten
                    EDIT2: Oder vllt doch nochmal alles von vorn und vorher iobroker stoppen!!
                    Wenn Fehler dann bitte mal den Inhalt von /opt/iobroker/iobroker-data zeigen (Ausgabe von ssh mti einem "ls -la /opt/iobroker/iobroker-data". Und dazu ein "date".
                    @Thomas-Braun Lass es uns bitte erstmal zum laufen bekommen und nicht mit node.js spass anfangen.
                      Rene 3
                      #163
                      @apollon77 und @Thomas-Braun
                      also nach iob stop
                      und iobroker status
                      erhalte ich als Ausgabe:
                      No connection to database possible ...
                      • R Rene 3
                        also nach iob stop
                        und iobroker status
                        #164
                        @rene-3 Jetzt arbeite bitte meinen letzten Post bis zum Ende durch
                          Rene 3
                          #165
                          @apollon77 ```
                          pi@ReneRaspel:~ $ iob stop
                          pi@ReneRaspel:~ $ iobroker status
                          pi@ReneRaspel:~ $ ls -la /opt/iobroker/iobroker-data
                          insgesamt 1105944
                          drwxrwxr-x+  8 iobroker iobroker       4096  2. Sep 22:49 .
                          drwxrwxr-x+  6 iobroker iobroker       4096  1. Sep 11:58 ..
                          drwxrwxr-x+  2 iobroker iobroker       4096 21. Aug 02:40 backitup
                          drwxrwxr-x+  2 iobroker iobroker      12288 29. Aug 06:40 backup-objects
                          drwxrwxr-x+ 26 iobroker iobroker       4096 27. Jun 19:27 files
                          drwxrwxr-x+ 14 iobroker iobroker       4096 29. Aug 08:24 history
                          drwxrwxr-x+  2 iobroker iobroker       4096 10. Mär 20:00 homekit-controller.0
                          -rw-rwxr--+  1 iobroker iobroker       5087  9. Feb 2022  iobroker.json
                          -rw-rwxr--+  1 iobroker iobroker          3 29. Aug 08:24 notifications.json
                          -rw-rwxr--+  1 iobroker iobroker    6008528  9. Feb 2022  objects.json.bak.migrated
                          -rw-rwxr--+  1 iobroker iobroker 1118225842 29. Aug 08:24 objects.jsonl
                          -rw-rwxr--+  1 iobroker iobroker    6008525  9. Feb 2022  objects.json.migrated
                          -rw-rwxr--+  1 iobroker iobroker      92518  9. Feb 2022  states.json.bak.migrated
                          -rw-rwxr--+  1 iobroker iobroker    1993265 29. Aug 08:24 states.jsonl
                          -rw-rwxr--+  1 iobroker iobroker      92661  9. Feb 2022  states.json.migrated
                          drwxrwxr-x+  2 iobroker iobroker       4096 11. Mär 17:06 yahka.0.hapdata
                          pi@ReneRaspel:~ $
                          Date ist 02.09.2022
                          • R Rene 3
                            @apollon77 ```
                            insgesamt 1105944
                            pi@ReneRaspel:~ $
                            Date ist 02.09.2022
                            #166
                            @rene-3 Wow 1,1GB objects.json ... welcher js-controller ist das denn?
                            Ok, hier sind wir bei timeout seeehr hoch setzen das der erste start das aufräumen kann.
                            Bitte poste mal den Inhalt von /opt/iobroker/iobroker-data/iobroker.json
                              Rene 3
                              #167
                              @apollon77 Zugriff nicht möglich / Datei oder Verzeichnis nicht gefunden
                              mit
                              ls -la
                              und
                              ls -lh
                              probiert oder nur mit
                              ls
                              komme ich einfach nicht zum Inhalt - und fliege da wieder raus
                              • R Rene 3
                                mit
                                ls -la
                                und
                                ls -lh
                                ls
                                Rene 3
                                #168
                                @apollon77 sorry - quatsch muss mit " cd " dahin - dauert noch !
                                • R Rene 3
                                  Rene 3
                                  #169
                                  @apollon77 also ich bin jetzt zwar im richtigen Pfad aber hab keinen Plan wie ich die iobroker.json öffne oder mir den Inhalt irgendwie sichtbar machen kann
                                  R apollon77A 2 Antworten Letzte Antwort
                                  • R Rene 3
                                    Rene 3
                                    #170
                                    @apollon77 ich mache für heute Schluss. Guts Nächtle.
                                    Habe noch mal die gleichen Dateien von @radicalreel herangezogen - es scheint was mit dem Datumsformat teilweise bei mir nicht mehr zu stimmen.
                                    Mal werden diese mit TT MM JJJJ und mal mit TT MM Time angezeigt.
                                    Ob es von diesem ewt. kommt ?
                                    • R Rene 3
                                      #171
                                      @rene-3 „cat iobroker.json“
                                        Rene 3
                                        #172
                                        @apollon77
                                        pi@ReneRaspel:/opt/iobroker/iobroker-data $ cat iobroker.json
                                          "system": {
                                            "memoryLimitMB": 0,
                                            "hostname": "",
                                            "statisticsInterval": 15000,
                                            "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
                                            "checkDiskInterval": 300000,
                                            "checkDiskIntervalComment": "Interval how often the disk size will be checked",
                                            "instanceStartInterval": 2000,
                                            "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
                                            "compact": false,
                                            "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
                                            "allowShellCommands": false,
                                            "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands",
                                            "memLimitWarn": 100,
                                            "memLimitWarnComment": "If the available RAM is below this threshold on adapter start, a warning will be logged.",
                                            "memLimitError": 50,
                                            "memLimitErrorComment": "If the available RAM is below this threshold on adapter start, an error will be logged."
                                          "multihostService": {
                                            "enabled": false,
                                            "secure": true,
                                            "password": ""
                                          "objects": {
                                            "type": "jsonl",
                                            "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
                                            "host": "127.0.0.1",
                                            "port": 9001,
                                            "noFileCache": false,
                                            "maxQueue": 1000,
                                            "connectTimeout": 30000,
                                            "writeFileInterval": 5000,
                                            "dataDir": "",
                                            "options": {
                                              "auth_pass": null,
                                              "retry_max_delay": 5000,
                                              "retry_max_count": 19,
                                              "db": 0,
                                              "family": 0
                                            "backup": {
                                              "disabled": false,
                                              "files": 24,
                                              "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
                                              "hours": 48,
                                              "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
                                              "period": 120,
                                              "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
                                              "path": "",
                                              "pathComment": "Absolute path to backup directory or empty to backup in data directory"
                                          "states": {
                                            "type": "jsonl",
                                            "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
                                            "port": 9000,
                                            "writeFileInterval": 30000,
                                            "dataDir": "",
                                            "options": {
                                              "auth_pass": null,
                                              "db": 0,
                                              "family": 0
                                            "backup": {
                                              "disabled": false,
                                              "files": 24,
                                              "hours": 48,
                                              "period": 120,
                                              "path": "",
                                          "log": {
                                            "level": "info",
                                            "maxDays": 7,
                                            "noStdout": true,
                                            "transport": {
                                              "file1": {
                                                "type": "file",
                                                "enabled": true,
                                                "filename": "log/iobroker",
                                                "fileext": ".log",
                                                "maxsize": null,
                                                "maxFiles": null
                                              "syslog1": {
                                                "type": "syslog",
                                                "enabled": false,
                                                "host": "localhost",
                                                "hostComment": "The host running syslogd, defaults to localhost.",
                                                "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
                                                "protocol": "udp4",
                                                "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
                                                "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
                                                "facilityComment": "Syslog facility to use (Default: local0).",
                                                "localhost": "iobroker",
                                                "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
                                                "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
                                                "app_nameComment": "The name of the application (Default: process.title).",
                                                "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
                                              "seq1": {
                                                "type": "seq",
                                                "enabled": false,
                                                "serverUrl": "http://IP:PORT",
                                                "serverUrlComment": "The http(s) URL including port of the seq server. If you use HTTPS a real certificate is needed; self signed certs are ot accepted.",
                                                "apiKey": "",
                                                "apiKeyComment": "The apiKey of the seq system"
                                          "dataDirComment": "Always relative to iobroker.js-controller/",
                                          "plugins": {},
                                          "dataDir": "../../iobroker-data/"
                                        • R Rene 3
                                          @apollon77
                                            "system": {
                                              "memoryLimitMB": 0,
                                              "hostname": "",
                                              "compact": false,
                                              "enabled": false,
                                              "secure": true,
                                              "password": ""
                                            "objects": {
                                              "type": "jsonl",
                                              "port": 9001,
                                              "maxQueue": 1000,
                                              "dataDir": "",
                                              "options": {
                                                "auth_pass": null,
                                                "db": 0,
                                                "family": 0
                                              "backup": {
                                                "disabled": false,
                                                "files": 24,
                                                "hours": 48,
                                                "period": 120,
                                                "path": "",
                                            "states": {
                                              "type": "jsonl",
                                              "port": 9000,
                                              "dataDir": "",
                                              "options": {
                                                "auth_pass": null,
                                                "db": 0,
                                                "family": 0
                                              "backup": {
                                                "disabled": false,
                                                "files": 24,
                                                "hours": 48,
                                                "period": 120,
                                                "path": "",
                                            "log": {
                                              "level": "info",
                                              "maxDays": 7,
                                              "noStdout": true,
                                              "transport": {
                                                "file1": {
                                                  "type": "file",
                                                  "enabled": true,
                                                  "fileext": ".log",
                                                  "maxsize": null,
                                                  "maxFiles": null
                                                "syslog1": {
                                                  "type": "syslog",
                                                  "enabled": false,
                                                  "protocol": "udp4",
                                                "seq1": {
                                                  "type": "seq",
                                                  "enabled": false,
                                                  "apiKey": "",
                                            "plugins": {},
                                          #173
                                          @rene-3 ok dann bitte noch sagen was „iob Version“ sagt
                                          Dann bitte im iobroker.json unter objects die Zeile mit „connectTimeout“ (Zeile 33 laut deinem post) die Zahl von 30000 auf 600000 ändern (6 hundert tausend).
                                          Dann bitte einmal „iob status“ ausführen und Geduld haben! Kannst ja mal Zeit stoppen wie lange es dauert.
                                          Danach bitte wieder mit „ls -la“ schauen wie groß die objects.jsonl jetzt ist. Müsste deutlich kleiner sein.
                                          R F 2 Antworten Letzte Antwort
