  4. Zigbee Neustart bei Firmwareupdatesüberprüfung
zigbeeabsturzfirmwareupdate
29 Beiträge 6 Kommentatoren 3.3k Aufrufe 6 Beobachtet
  • tugsiT tugsi
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3 (Slave und Zigbee-Adapter) und Docker (Master)
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/HDD
    Betriebssystem: Ubuntu/Docker
    Node-Version: 14.20.0
    Nodejs-Version: 14.20.0
    NPM-Version: 6.14.17
    Es gibt ja die Möglichkeit im Zigbee-Adapter oben rechts auf den Button zu klicken "Auf Firmwareupdates überprüfen".
    Immer wenn ich dies mache, stürzt der Adapter ab und startet neu.
    Hier das Log dazu:
    2022-08-30 11:26:07.549 - info: zigbee.0 (26364) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
    2022-08-30 11:26:07.582 - info: zigbee.0 (26364) Failed to check if update available for '0x94deb8fffe4c0e07' (No image available for imageType '5634')
    2022-08-30 11:26:35.624 - info: zigbee.0 (26364) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
    2022-08-30 11:26:35.631 - error: zigbee.0 (26364) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-08-30 11:26:35.633 - error: zigbee.0 (26364) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:26:35.696 - error: zigbee.0 (26364) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    at listOnTimeout (internal/timers.js:557:17)
    at processTimers (internal/timers.js:500:7)
    2022-08-30 11:26:35.697 - error: zigbee.0 (26364) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:26:35.742 - info: zigbee.0 (26364) cleaned everything up...
    2022-08-30 11:26:36.115 - info: zigbee.0 (26364) Zigbee: disabling joining new devices.
    2022-08-30 11:26:36.143 - info: zigbee.0 (26364) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
    2022-08-30 11:26:36.265 - info: zigbee.0 (26364) terminating
    2022-08-30 11:26:36.269 - warn: zigbee.0 (26364) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-08-30 11:26:37.433 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-08-30 11:26:37.446 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:26:37.448 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    2022-08-30 11:26:37.449 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
    2022-08-30 11:26:37.450 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
    2022-08-30 11:26:37.451 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-08-30 11:26:37.453 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
    2022-08-30 11:27:08.116 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27006
    2022-08-30 11:27:19.448 - info: zigbee.0 (27006) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.20.0, js-controller: 4.0.23
    2022-08-30 11:27:19.730 - info: zigbee.0 (27006) Starting Zigbee npm ...
    Und hier der Log im Debug-Modus (hab es mal auf vermeintlich wesentliche gekürzt):
    2022-08-30 11:31:25.011 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-30EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2022-08-30 11:31:25.040 - debug: zigbee.0 (27006) Is new image available for '0xb4e3f9fffea54848', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
    2022-08-30 11:31:25.041 - debug: zigbee.0 (27006) Update available for '0xb4e3f9fffea54848': YES
    2022-08-30 11:31:25.042 - debug: zigbee.0 (27006) Firmware update for 0xb4e3f9fffea54848 is available
    2022-08-30 11:31:25.694 - debug: zigbee.0 (27006) ZigbeeOTA: downloaded main index
    2022-08-30 11:31:25.697 - info: zigbee.0 (27006) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
    2022-08-30 11:31:25.698 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
    2022-08-30 11:31:25.706 - debug: zigbee.0 (27006) Is new image available for '0x0c4314fffe1f2ffa', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
    2022-08-30 11:31:25.707 - debug: zigbee.0 (27006) Update available for '0x0c4314fffe1f2ffa': YES
    2022-08-30 11:31:25.708 - debug: zigbee.0 (27006) Firmware update for 0x0c4314fffe1f2ffa is available
    2022-08-30 11:31:25.709 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
    2022-08-30 11:31:25.734 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-10EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2022-08-30 11:31:25.750 - debug: zigbee.0 (27006) No converter available for 'ICPSHC24-30EU-IL-1' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2022-08-30 11:31:25.798 - debug: zigbee.0 (27006) Is new image available for '0xb4e3f9fffe66dff7', current '{"fieldControl":1,"manufacturerCode":4476,"imageType":16641,"fileVersion":304371058}', latest meta '{"fileVersion":587753009,"url":"http://fw.ota.homesmart.ikea.net/global/GW1.0/01.19.032/bin/159495-TRADFRI-transformer-2.3.086.ota.ota.signed"}'
    2022-08-30 11:31:25.799 - debug: zigbee.0 (27006) Update available for '0xb4e3f9fffe66dff7': YES
    2022-08-30 11:31:25.800 - debug: zigbee.0 (27006) Firmware update for 0xb4e3f9fffe66dff7 is available
    2022-08-30 11:31:53.133 - info: zigbee.0 (27006) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
    2022-08-30 11:31:53.135 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
    2022-08-30 11:31:53.143 - error: zigbee.0 (27006) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-08-30 11:31:53.144 - error: zigbee.0 (27006) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:31:53.205 - error: zigbee.0 (27006) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:31:53.206 - error: zigbee.0 (27006) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:31:53.250 - info: zigbee.0 (27006) cleaned everything up...
    2022-08-30 11:31:53.256 - debug: zigbee.0 (27006) DeviceAvailability:Publish available for 0x588e81fffe016ba4 = false
    2022-08-30 11:31:53.261 - debug: zigbee.0 (27006) DeviceAvailability:Publish LQ for 0x588e81fffe016ba4 = 0
    2022-08-30 11:31:53.656 - debug: zigbee.0 (27006) DeviceAvailability:Publish available for 0x14b457fffe91707c = false
    2022-08-30 11:31:53.662 - debug: zigbee.0 (27006) DeviceAvailability:Publish LQ for 0x14b457fffe91707c = 0
    2022-08-30 11:31:53.676 - info: zigbee.0 (27006) Zigbee: disabling joining new devices.
    2022-08-30 11:31:53.721 - info: zigbee.0 (27006) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
    2022-08-30 11:31:53.722 - silly: zigbee.0 (27006) sendTo "checkOtaAvail" to system.adapter.admin.0 from system.adapter.zigbee.0
    2022-08-30 11:31:53.754 - info: zigbee.0 (27006) terminating
    2022-08-30 11:31:53.757 - debug: zigbee.0 (27006) Plugin sentry destroyed
    2022-08-30 11:31:53.758 - warn: zigbee.0 (27006) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-08-30 11:31:54.950 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-08-30 11:31:54.952 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
    2022-08-30 11:31:54.953 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
    2022-08-30 11:31:54.954 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
    2022-08-30 11:31:54.956 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
    2022-08-30 11:31:54.957 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-08-30 11:31:54.958 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
    2022-08-30 11:32:25.621 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 27279
    Ich sehe noch, dass bei einigen Geräten auf der Kachel ein Update angeboten wird, aber durch den Reset, kann ich das nicht durchführen.
    Ich hatte vor kurzem erst den Stick gewechselt und Zigbee neu installiert und auch die Shepard-DB gelöscht, also sollte alles clean sein. Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc.
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link Systemdata Bitte Ausfüllen
    Hier das Log dazu:
    arteckA Offline
    arteckA Offline
    arteck
    @tugsi ja da ist ein bug in der Version.. installier mal bitte von GIT ..
    tugsiT 1 Antwort Letzte Antwort
    • arteckA arteck
      tugsiT Offline
      tugsiT Offline
      tugsi
      @arteck Ok, aber da bekomme ich ja auch nur die v1.7.6, wie ich bisher hatte und klappt nicht.
      Oder muss ich von GIT eine andere Adresse Benutzerdefiniert eingeben und nicht auf die "Katze" klicken und den Zigbee auswählen?
      Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
      • tugsiT tugsi
        @tugsi
        Schau ob der Adapter aus git stammt:
        cd /opt/iobroker/ && npm ls | grep zigbee
          @tugsi
          tugsiT Offline
          tugsiT Offline
          tugsi
          @thomas-braun Das ist meine Antwort, sind die Errors alle so ok? Ich weiss das mit dem coffee ist alt, aber irgendwie wirkt das so viele...
          pi@raspberrypi:~ $ cd /opt/iobroker/ && npm ls | grep zigbee
          ├─┬ iobroker.zigbee@1.7.6 (github:ioBroker/ioBroker.zigbee#eea83037ea5f0cd3020a9e16154c6980c70f492f)
          │ ├─┬ zigbee-herdsman@0.14.49
          │ └─┬ zigbee-herdsman-converters@14.0.608
          │   └── zigbee-herdsman@0.14.49 deduped
          npm ERR! extraneous: @abandonware/noble@1.9.2-5 /opt/iobroker/node_modules/@abandonware/noble
          npm ERR! extraneous: @apollon/frankjoke-myadapter@1.2.5 /opt/iobroker/node_modules/@apollon/frankjoke-myadapter
          npm ERR! extraneous: @types/request@2.48.3 /opt/iobroker/node_modules/@types/request
          npm ERR! extraneous: iobroker.admin /opt/iobroker/node_modules/iobroker.admin
          npm ERR! error in /opt/iobroker/node_modules/iobroker.admin: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.admin/package.json'
          npm ERR! extraneous: areq@0.2.0 /opt/iobroker/node_modules/areq
          npm ERR! extraneous: better-queue@3.8.10 /opt/iobroker/node_modules/better-queue
          npm ERR! extraneous: cc-znp@0.5.0 /opt/iobroker/node_modules/cc-znp
          npm ERR! extraneous: chai@4.2.0 /opt/iobroker/node_modules/chai
          npm ERR! extraneous: coffee-compiler@0.3.2 /opt/iobroker/node_modules/coffee-compiler
          npm ERR! extraneous: coffee-script@1.12.7 /opt/iobroker/node_modules/coffee-script
          npm ERR! extraneous: fsevents@2.1.2 /opt/iobroker/node_modules/fsevents
          npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
          npm ERR! extraneous: netmask@1.0.6 /opt/iobroker/node_modules/netmask
          npm ERR! extraneous: node-pre-gyp@0.12.0 /opt/iobroker/node_modules/node-pre-gyp
          npm ERR! extraneous: node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
          npm ERR! extraneous: objectbox@0.3.0 /opt/iobroker/node_modules/objectbox
          npm ERR! extraneous: osx-temperature-sensor@1.0.4 /opt/iobroker/node_modules/osx-temperature-sensor
          npm ERR! extraneous: ping@0.2.2 /opt/iobroker/node_modules/ping
          npm ERR! extraneous: proving@0.1.0 /opt/iobroker/node_modules/proving
          npm ERR! extraneous: queue@6.0.1 /opt/iobroker/node_modules/queue
          npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
          npm ERR! extraneous: typescript@3.7.2 /opt/iobroker/node_modules/typescript
          npm ERR! extraneous: virtual-tsc@0.4.6 /opt/iobroker/node_modules/virtual-tsc
          npm ERR! extraneous: vm2@3.8.4 /opt/iobroker/node_modules/vm2
          npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
          npm ERR! extraneous: xpc-connection@0.1.4 /opt/iobroker/node_modules/xpc-connection
          npm ERR! extraneous: zcl-packet@0.2.4 /opt/iobroker/node_modules/zcl-packet
          npm ERR! extraneous: zstack-constants@0.2.0 /opt/iobroker/node_modules/zstack-constants
          npm ERR! extraneous: zwave-js@7.2.3 /opt/iobroker/node_modules/zwave-js
          npm ERR! peer dep missing: @zwave-js/core@>=10.0.0, required by @zwave-js/log-transport-json@3.0.0
          npm ERR! peer dep missing: @zwave-js/shared@>=10.0.0, required by @zwave-js/log-transport-json@3.0.0
          • tugsiT tugsi
            @tugsi sagte in Zigbee Neustart bei Firmwareupdatesüberprüfung:
            Errors sind grundsätzlich nie okay, sonst wäre es Warnings und keine Errors.
            Insbesondere der sieht komisch aus:
            Installier den admin nochmal drüber. Und bring deine nodejs-Installation auf Stand 16, du bist da offenbar noch mit was altem unterwegs.
            tugsiT 2 Antworten Letzte Antwort
              tugsiT Offline
              tugsiT Offline
              tugsi
              @thomas-braun sagte in Zigbee Neustart bei Firmwareupdatesüberprüfung:
              Es gibt aber auch Errors, die man getrost ignorieren kann, deswegen meine Frage ;)
              • tugsiT tugsi
                Erzähl mir mehr...
                Nein, Errors schaut man sich an und fixt sie, damit die Fehler ausgemerzt werden.
                  tugsiT Offline
                  tugsiT Offline
                  tugsi
                  Ich denke der fehlende admin kommt weil dies im Multihost ein Slave ist?
                  Nodejs auf 16, heißt aber auch, dass ich dann beim Master auf 16 gehen sollte oder? Gibt es denn dann auch so eine Reihenfolge wie beim JS-Controller, erst Master dann Slave?
                  Zum Thema beseitigen der Errors, habe gerade mal geschaut, das liegt daran, dass unter node_modules Pakete liegen, die nicht in der package.json gelistet sind.
                  Der Befehl
                  rm -rf node_modules
                  würde alle löschen und mit
                  npm install
                  die benötigten erneut installieren.
                  Kannst das bestätigen oder eher anders vorgehen (abgesehen von V16 updaten)?
                  Auf 16 mache ich nicht mehr heute, da brauche ich Ruhe und Zeit, wenn mal was nicht so rundläuft, also was für das Wochenende :-)
                  • tugsiT tugsi
                    Der Befehl
                    rm -rf node_modules
                    npm install
                    Da du die beiden Systeme eh währenddessen runterfährst: Kein Problem der Reihenfolge.
                    • tugsiT tugsi
                      Der Befehl
                      rm -rf node_modules
                      npm install
                      Das sollte eigentlich nicht der Fall sein. Zusätzliches Zeug ist i.d. R. unter dem javascript-Adapter zu finden.
                      • David G.D Online
                        David G.D Online
                        David G.
                        Ich habe auch die 1.7.6 drauf.
                        Habe die Tage noch ein paar Firmwareupdates eingespielt.
                        ├── iobroker.zigbee@1.7.6 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#6e5ff46b6464c71c20f8fe099c0600b3cca68c07)
                          tugsiT Offline
                          tugsiT Offline
                          tugsi
                          Ich hab mir das gerade mal angeschaut und ich habe einen Verdacht, dass ich damals wohl schlampig gearbeitet hatte. Kann mich nicht mehr so recht dran erinnern, aber ich hatte zuerst ioBroker auf den Pi, dann wurde das alles zu knapp da und bin umgezogen auf Docker als Master und den Pi als Slave, eventuell habe ich keine reine Neuinstallation da gemacht oder zum testen noch was anderes zusätzlich, dann als Slave eingebunden und alles lief und never change a running System ... so gelassen.
                          Ist ja auch an meinem Touchscreen dran und das damals einzurichten war auch alles nicht simpel...
                          Hab da Leichen im Keller 😆
                          Vieleicht wirklich mal ein guter Anlass alles mal auf den aktuellsten Stand zu ziehen und den Raspberry neu aufzusetzen. Muss nur gerade den Pi alles zusammensuchen wegen dem Monitor, manchmal ist einiges Try&Error, weil man nicht das passende im Netz findet und am Ende des Tages freust Dich und bist froh, aber machst keine Doku für später.... (Kenn ich von der Arbeit, bin SPS-Programmierer... und Doku ist das langweiligste was es gibt, aber man ärgert sich später immer wieder, dass man es nicht sofort getan hat)
                          • tugsiT tugsi
                            Was für ein Monitor?
                            ssh und go...
                              ssh und go...
                              tugsiT Offline
                              tugsiT Offline
                              tugsi
                              ssh und go...
                              ssh ist kein Problem, das war irgendwas mit der Auflösung und der Config für X... wie gesagt, kein Hexenwerk, muss aber nochmal die Dinge zusammensuchen und wenn ich damit anfange, sollte es auch in einem Rutsch gemacht werden, ansonsten habe ich hier eine Frau die sich a) fragt, warum ich wieder so lange am Laptop sitze und b) warum ihr doch mittlerweile geliebter Screen nix anzeigt
                              Aber vielleicht kannst Du mir das beantworten, auch wenn der Thread hier gerade abdriftet.
                              Muss ich den Slave erstmal beim Master abmelden, bevor ich den dann neu aufsetze oder?
                              • tugsiT tugsi
                                ssh und go...
                                Was für ein X? Man lässt da kein X laufen.
                                  tugsiT Offline
                                  tugsiT Offline
                                  tugsi
                                  Das mag Deine Sichtweise sein.
                                  Ich habe auf den Pi ein X laufen, weil das meinen Monitor als Visualisierung befeuert und da der zentral liegt, läuft darauf ein ioBroker im Slavemodus mit Zigbee und ZWave.
                                  Mir wäre neu, dass man auf einem Pi mit ioBroker nichts anderes laufen lassen darf, zumal wie gesagt es ein Slavesystem ist. Mir erstellt sich nicht der Sinn, warum ich extra für meine Visualisierung einen extra Rechner und somit Stromfresser hinsetzen muss.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    @tugsi @david-g
                                    leute .. nur weil ihr die Version 1.7.6 drauf habt heisst es nicht das diese aktuell ist..
                                    ich mach täglich ein update auf GIT der Version 1.7.6 ..
                                    also GIT Version installieren JETZT und nochmal schauen..bitte
                                    • tugsiT Offline
                                      tugsiT Offline
                                      tugsi
                                      @arteck Keep calm, ich habe das schon verstanden, ich komm doch selber aus der Programmierecke, auch wenn es Automatisierung ist, aber man macht nicht immer für kleine Zwischenschritte sofort eine Versionsänderung.
                                      Ich hatte Deine Bitte für eine Neuinstallation über GIT befolgt und hatte ja das gleiche Problem, deswegen kam meine Nachfrage, ob es so richtig war mit der Installation...
                                      Aber jetzt weiß ich ja, wo ich nachschauen muss, ob er es genommen hat, ich sehe ja Deine Versionsänderungen von herdsman und schaue bei Github welche Du in der package.json gepackt hast.
                                      Gerade upgedatet und nachgeschaut, das aktuelle von Dir drauf:
                                      ├─┬ iobroker.zigbee@1.7.6 (github:ioBroker/ioBroker.zigbee#4e4143cee5b8affa73b2b1e1ed6f9fb91201f078)
                                      │ ├─┬ zigbee-herdsman@0.14.51
                                      │ └─┬ zigbee-herdsman-converters@14.0.610
                                      │   └── zigbee-herdsman@0.14.51 deduped
                                      Aber Problem besteht immer noch:
                                      2022-09-01 08:06:06.531 - info: zigbee.0 (8913) Failed to check if update available for '0x540f57fffe3f5cde' (No image available for imageType '5634')
                                      2022-09-01 08:06:06.607 - info: zigbee.0 (8913) Failed to check if update available for '0x94deb8fffe4c0e07' (No image available for imageType '5634')
                                      2022-09-01 08:06:34.439 - info: zigbee.0 (8913) Failed to check if update available for '0x14b457fffeca020d' (Device didn't respond to OTA request)
                                      2022-09-01 08:06:34.446 - error: zigbee.0 (8913) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2022-09-01 08:06:34.447 - error: zigbee.0 (8913) unhandled promise rejection: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                      2022-09-01 08:06:34.449 - error: zigbee.0 (8913) Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                      2022-09-01 08:06:34.450 - error: zigbee.0 (8913) Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                      2022-09-01 08:06:34.470 - info: zigbee.0 (8913) cleaned everything up...
                                      2022-09-01 08:06:34.819 - info: zigbee.0 (8913) Zigbee: disabling joining new devices.
                                      2022-09-01 08:06:34.846 - info: zigbee.0 (8913) Failed to check if update available for '0x14b457fffe91707c' (Device didn't respond to OTA request)
                                      2022-09-01 08:06:34.972 - info: zigbee.0 (8913) terminating
                                      2022-09-01 08:06:34.975 - warn: zigbee.0 (8913) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2022-09-01 08:06:36.082 - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2022-09-01 08:06:36.084 - error: host.raspberrypi Caught by controller[1]: Error: Timeout - 63764 - 1 - null - 25 - 1 after 30000ms
                                      2022-09-01 08:06:36.091 - error: host.raspberrypi Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
                                      2022-09-01 08:06:36.093 - error: host.raspberrypi Caught by controller[1]: at listOnTimeout (internal/timers.js:557:17)
                                      2022-09-01 08:06:36.093 - error: host.raspberrypi Caught by controller[1]: at processTimers (internal/timers.js:500:7)
                                      2022-09-01 08:06:36.095 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2022-09-01 08:06:36.096 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                      • tugsiT tugsi
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @tugsi Um dem weiter nachzugehen musst du heraus finden welches Gerät betroffen ist.
                                        Dazu bitte die Geräte durch nutzen des Ein/Ausschalt Icons auf der Kachel deaktivieren bevor du den Firmware check machst. Deaktivierte Geräte werden im Firmwarecheck ignoriert.
                                        Zur Nutzung musst du die Geräte im Nachgang natürlich wieder aktivieren.
                                        A.
                                        • tugsiT Offline
                                          tugsiT Offline
                                          tugsi
                                          @asgothian
                                          Danke, ich habe den Übeltäter gefunden.
                                          Bin hingegangen und habe erstmal alle OTA-fähigen Geräte deaktiviert und da lief er durch.
                                          Dann bin ich hingegangen und habe jede Gerätegruppe nach und nach zugeschaltet und geschaut was passiert.
                                          Der Absturz passiert immer, wenn der IKEA Styrbar-Schalter aktiv ist (https://www.zigbee2mqtt.io/devices/E2001_E2002.html), deaktiviere ich, dann läuft der Firmwarecheck ohne Probleme durch.
                                          Ok, jetzt weiß ich das und kann den für den Fall deaktivieren, aber ist ja nicht Sinn.
                                          Soll ich bei Github ein Issue dafür aufmachen?
