  4. Backitup kein JavaScript Restore möglich!
103 Beiträge 7 Kommentatoren 11.2k Aufrufe 7 Beobachtet
  • B BenjaminCz
    pi@raspberrypi:~ $ sudo umount /opt/iobroker/backups && mount | sort
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
    /dev/mmcblk0p2 on / type ext4 (rw,noatime)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
    pi@raspberrypi:~ $
    @benjamincz
    Schalt mal den ganzen anderen Kram da aus. Also NT-LAN-Manager bis LLTD. Das sind offenbar die ganzen unnötigen Freigaben da bei dir.
    Oder halt komplett auf NFS gehen.
    • B BenjaminCz
      @thomas-braun Ich würde es dann mit NFS Probieren. Hat von euch einer eine Idee ob ich da dann im Adapter NAS/Kopieren eingestellt haben muss so wie jetzt auch oder dann FTP ?
      @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
      oder dann FTP
      Warum FTP? Das ist ein komplett anderes Protokoll. Hat mit NFS nix zu schaffen. Who wants to use FTP anyway?
        oder dann FTP
        BenjaminCz
        @thomas-braun Habe es auf NFS umgestellt und gleicher Fehler.
        Error:
        {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
        • B BenjaminCz
          Error:
          @benjamincz
          Das gleiche Spiel...
          mount | sort
            @benjamincz
            mount | sort
            BenjaminCz
            pi@raspberrypi:~ $ mount | sort
            pi@raspberrypi:~ $
            Danke für eure gedult!
            • B BenjaminCz
              pi@raspberrypi:~ $
              @benjamincz
              Da ist noch der komische CIFS/SMB Kram aktiv.
                @benjamincz
                BenjaminCz
                @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
                • B BenjaminCz
                  @benjamincz
                  Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                    @benjamincz
                    BenjaminCz
                    Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                    • B BenjaminCz
                      @benjamincz
                      Ich hasse GUIs...
                      Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                        @benjamincz
                        Ich hasse GUIs...
                        BenjaminCz
                        So sieht es normal aus ohne Dropdown.
                        • B BenjaminCz
                          @benjamincz
                          Stell mal das SMB Protokoll auf 'Nur 3'.
                          Und auf dem Pi:
                          solange bis die Freigabe nicht mehr in
                          mount | sort
                          auftaucht.
                            @benjamincz
                            Und auf dem Pi:
                            mount | sort
                            auftaucht.
                            BenjaminCz
                            schrieb am zuletzt editiert von BenjaminCz
                            @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                            mount | sort
                            • B BenjaminCz
                              mount | sort
                              @benjamincz
                              Weiter umounten. Bis das alles weg ist.
                                @benjamincz
                                BenjaminCz
                                @thomas-braun erledigt
                                siehe oben
                                • B BenjaminCz
                                  siehe oben
                                  @benjamincz
                                  Jetzt mal ein stinknormales Backitup-Backup manuell ausführen.
                                  Währenddessen nochmal in
                                  mount | sort
                                  schauen was da wohin gemountet wird.
                                    @benjamincz
                                    mount | sort
                                    BenjaminCz
                                    bin noch beschäftigt es auszu Probieren da leider error kommt beim mounten. (NFS)
                                    B Thomas BraunT 2 Antworten Letzte Antwort
                                    • B BenjaminCz
                                      BenjaminCz
                                      @benjamincz
                                      Started iobroker ...
                                      [DEBUG] [mount] - nfs-mount command: "sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups"
                                      [ERROR] [mount] - [undefined mount.nfs: Failed to resolve server 192.168.178.58/: Name or service not known
                                      [ERROR] [mount] - Error: Command failed: sudo mount 192.168.178.58/:/IOBroker-Backup/IOBroker /opt/iobroker/backups
                                      • B BenjaminCz
                                        @benjamincz
                                        Jetzt NFS?
                                        Der Freigabepfad ist falsch.
                                        Muss
                                        IOBroker-Backup
                                        lauten. Im Übrigen ist Groß/Kleinschreibung nur ein zusätzlicher Stolperstein. Schreib Verzeichnisnamen durchweg klein.
                                        • B BenjaminCz
                                          @benjamincz
                                          Das muss wohl
                                          192.168.178.58:/IOBroker-Backup
                                          lauten.
