  4. Backitup kein JavaScript Restore möglich!
103 Beiträge 7 Kommentatoren 11.2k Aufrufe 7 Beobachtet
  • simatecS simatec
    @benjamincz also dein NAS kann NFS.
    Dann würde ich es an deiner Stelle auch nutzen.
    CIFS ist nur ein Notfall
    BenjaminCz
    schrieb am zuletzt editiert von BenjaminCz
    @simatec
    pi@raspberrypi:~ $ mount
    /dev/mmcblk0p2 on / type ext4 (rw,noatime)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=1800664k,nr_inodes=84204,mode=755)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786212k,nr_inodes=819200,mode=755)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
    /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=2.0,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1)
    //192.168.178.58/IOBroker-Backup/IOBroker on /opt/iobroker/backups type cifs (rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.58,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393104k,nr_inodes=98276,mode=700,uid=1000,gid=1000)
    pi@raspberrypi:~ $
    • B BenjaminCz
      @simatec
      pi@raspberrypi:~ $
      @benjamincz
      5 Freigaben auf den gleichen Mountpunkt kann nicht funktionieren.
      • simatecS simatec
        BenjaminCz
        @simatec OK vielen dank. Wie stelle ich das dann genau im Backitup um auf Kopieren ?
          @benjamincz
          BenjaminCz
          @thomas-braun ok was mache ich falsch ? Soll ich auf NFS umsteigen ?
          • B BenjaminCz
            @benjamincz sagte in Backitup kein JavaScript Restore möglich!:
            Du stapelst da wohl 5 Freigaben übereinander.
            Ich würde es tun. @simatec auch.
            sudo umount /opt/iobroker/backups && mount | sort
            sagt?
            B 2 Antworten Letzte Antwort
              sagt?
              BenjaminCz
              pi@raspberrypi:~ $ sudo umount /opt/iobroker/backups && mount | sort
              pi@raspberrypi:~ $
                sagt?
                BenjaminCz
                @thomas-braun Ich würde es dann mit NFS Probieren. Hat von euch einer eine Idee ob ich da dann im Adapter NAS/Kopieren eingestellt haben muss so wie jetzt auch oder dann FTP ?
                • B BenjaminCz
                  pi@raspberrypi:~ $
                  @benjamincz
                  Schalt mal den ganzen anderen Kram da aus. Also NT-LAN-Manager bis LLTD. Das sind offenbar die ganzen unnötigen Freigaben da bei dir.
                  Oder halt komplett auf NFS gehen.
                  • B BenjaminCz
                    oder dann FTP
                    Warum FTP? Das ist ein komplett anderes Protokoll. Hat mit NFS nix zu schaffen. Who wants to use FTP anyway?
                      oder dann FTP
                      BenjaminCz
                      @thomas-braun Habe es auf NFS umgestellt und gleicher Fehler.
                      Error:
                      {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/tmpScripts/"}
                      • B BenjaminCz
                        Error:
                        @benjamincz
                        Das gleiche Spiel...
                        mount | sort
                          @benjamincz
                          mount | sort
                          BenjaminCz
                          pi@raspberrypi:~ $ mount | sort
                          pi@raspberrypi:~ $
                          Danke für eure gedult!
                          • B BenjaminCz
                            pi@raspberrypi:~ $
                            @benjamincz
                            Da ist noch der komische CIFS/SMB Kram aktiv.
                              @benjamincz
                              BenjaminCz
                              @thomas-braun wie bekomme ich den weg. EInfach IOBRoker neustarten ?
                              • B BenjaminCz
                                @benjamincz
                                Die 'Windows-Dienste' von NT-LAN Manager bis einschließlich LLTD ausstellen.
                                  @benjamincz
                                  BenjaminCz
                                  Ist alles Aus außer den Lan Manager Aus gibts da nicht nur andere Option...
                                  • B BenjaminCz
                                    @benjamincz
                                    Ich hasse GUIs...
                                    Waren die immer aus? Und oben war das DropDown-Menü von smb nur drüber gelegt?
                                      @benjamincz
                                      Ich hasse GUIs...
                                      BenjaminCz
                                      So sieht es normal aus ohne Dropdown.
                                      • B BenjaminCz
                                        @benjamincz
                                        Stell mal das SMB Protokoll auf 'Nur 3'.
                                        Und auf dem Pi:
                                        solange bis die Freigabe nicht mehr in
                                        mount | sort
                                        auftaucht.
                                          @benjamincz
                                          Und auf dem Pi:
                                          mount | sort
                                          auftaucht.
                                          BenjaminCz
                                          @thomas-braun said in Backitup kein JavaScript Restore möglich!:
                                          mount | sort
