  4. SD Speicher läuft voll
    5.8k
33 Beiträge 7 Kommentatoren 6.1k Aufrufe 7 Beobachtet
    @brur1250
    mount | sort
    sagt?
    BruR1250
    pi@raspberrypi:~ $ mount | sort
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelega        te,memory_recursiveprot)
    configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmod        e=000)
    /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,ioc        harset=ascii,shortname=mixed,flush,errors=remount-ro)
    /dev/sda2 on / type ext4 (rw,noatime)
    /dev/sdb1 on /mnt/usb0 type exfat (rw,nosuid,nodev,noexec,relatime,fmask=0000,dm        ask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=1800152k,nr_inodes=84204,mode=7        55)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatim        e)
    mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
    proc on /proc type proc (rw,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relat        ime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,time        out=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=786008k,nr_inodes=819200,mode=755        )
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=393000k,nr_ino        des=98250,mode=700,uid=1000,gid=1000)
    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
      @brur1250 sagte in SD Speicher läuft voll:
      trotzdem wird auf dem Pi eine Sicherung angelegt
      wenn du natürlich prüfst während der mount aktiv ist, siehst du auch die Daten vom NAS über den mount
      Eigentlich sollten die Dateien gelöscht werden aber ich habe nicht gefunden wann oder nach wie vielen Einträgen
      das steht in den Einstellungen bei "iobroker Backup"
      Aber wahrscheinlich speichert deine RING die Fotos in einem Verzeichnis, dass mit gesichert wird.
      BruR1250
      @homoran Also in den Einstellungen bei Backup steht 15 Sicherungen . Ich denke der RING Adapter speichert die Snapshots und Livestream in : /opt/iobroker/iobroker-data/files/ring.0/doorbell_98487415 . Aber ich sehe nicht wie man das verhindern kann .
      • B BruR1250
        @homoran Ja das ist ja so eingestellt in Backup steht Sicherung nur NAS/Kopieren und darunter dann Copy auf /mnt/usb0/iobroker und trotzdem wird auf dem Pi eine Sicherung angelegt . Im Ring Adapter sieht das so aus
        Eigentlich sollten die Dateien gelöscht werden aber ich habe nicht gefunden wann oder nach wie vielen Einträgen . Habe nur die Usb Karte gelöscht und mal schauen wie sich das Backup entwickelt und ich denke tägliches Backup ist auch nicht nötig
        crunchipC Abwesend
        crunchipC Abwesend
        Laut git
        You can use special variables for your livestream and snapshort path and filename. This variables will be replaced with a counter, timestamp, ring id or kind of ring.
        %d : Unix timestamp. Example: test_%d -> test_1588331430061
        %i : Id of your ring device: Example: test_%i -> test_234567890
        %n : Counter since ring instance start. Example: test_%n -> test_1
        %k : Kind of your ring device: Example: test_%k -> test_doorbel
        Desweiteren ist mir aufgefallen das bei deiner Pfadangabe der "/" am ende fehlt
        • OpenSourceNomadO Offline
          OpenSourceNomad
          Most Active Gesperrt
          @brur1250 said in SD Speicher läuft voll:
          Ich habe hier schon viele Einträge zu dem Thema "SD Karte läuft voll" gelesen
          Unabhängig warum deine SD Karte (permanent) voll läuft hält deine SD Karte (wenn nicht ein teures endurance/industrial Modell) das übrigens nicht sehr lange durch.
          Typische MLC/TLC Flashzellen wie sie sich heute in üblichen SD Karten finden halten meist keine 1000 Lösch/Schreibvorgänge durch. Wenn Mensch also z.B drei Backups täglich (über)schreibt und diese wie bei dir fast die komplette Größe belegen liegt die zu erwartende Lebenszeit bei nur etwa einem Jahr.
          Für permanente und große backups sind (normale) SD Karten die denkbar schlechteste Wahl.
          • OpenSourceNomadO OpenSourceNomad
            BruR1250
            @opensourcenomad Hallo Inzwischen habe ich auf SSD gewechselt
              Laut git
              BruR1250
              @crunchip Hallo Meinst du in der Einstellung vom Ring Adapter : snapshot%i_%d.jpg das hier ?
              • B BruR1250
                crunchipC Abwesend
                crunchipC Abwesend
                @brur1250 eher die Pfadangabe
                • liv-in-skyL liv-in-sky
                  @brur1250
                  installier dir sudu apt install ncdu - aufruf dann mit ncdu /
                  dann kannst du mal checken, wo die masse ist
                  evtl /opt/iobroker/baackups
                  oder /var/log
                  TobiasF78
                  @liv-in-sky
                  ich hoffe mir kann jemand helfen. hab ebenfalls das problem dass meine sd-karte plötzlich voll ist.
                  hab mit ncdu geschaut und folgendes gefunden. kann ich das einfach löschen? wie konnte das passieren dass sich dort so viele daten ansammeln. wird das wieder passieren?
                  -- /var/log ----------------------------------------------------------------------------------------------------------- /..
                  22,1 GiB [##########] syslog.1
                  21,9 GiB [######### ] kern.log.1
                  Thomas BraunT liv-in-skyL 2 Antworten Letzte Antwort
                  • T TobiasF78
                    @liv-in-sky
                    @tobiasf78
                    Da musst du mal reinschauen was da alles geloggt wird. Das ist jedenfalls nicht normal. Irgendwas ruft da um Hilfe.
                      @tobiasf78
                      TobiasF78
                      vielen dank für die schnelle antwort. wie gehe ich da jetzt am besten vor?
                      • T TobiasF78
                        @tobiasf78
                        tail -n 100 /var/log/Dateiname
                        Zeigt die letzten 100 Zeilen.
                          @tobiasf78
                          TobiasF78
                          danke
                          pi@SmarthomeRaspi:/var/log $ tail -n 100 /var/log/kern.log.1
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.261876] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.261917] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.261959] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262000] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262040] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262081] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262122] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262163] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262203] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262244] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262284] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262325] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262365] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262406] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262446] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262487] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262528] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262568] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262609] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262649] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262690] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262730] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262773] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262813] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262854] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262894] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262935] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.262976] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263016] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263057] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263097] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263138] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263178] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263219] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263260] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263301] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263342] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263383] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263424] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263465] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263506] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263547] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263588] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263628] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263668] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263709] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263750] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263791] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263831] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263872] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263913] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263954] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.263995] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264036] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264077] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264118] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264159] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264200] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264241] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264281] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264324] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264366] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264407] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264449] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264492] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264534] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264575] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264616] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264656] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264697] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264738] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264778] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264819] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264860] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264901] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264942] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.264982] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265023] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265064] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265106] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265146] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265188] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265229] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265271] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265313] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265353] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265394] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265434] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265475] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265517] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265560] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265604] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265647] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265689] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 05:14:45 SmarthomeRaspi kernel: [1708648.265731] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                          Aug 27 10:29:09 SmarthomeRaspi kernel: [1727511.952912] Alignment trap: not handling instruction e1910f9f at [<009ac5ec>]
                          Aug 27 10:29:09 SmarthomeRaspi kernel: [1727511.952927] 8<--- cut here ---
                          Aug 27 10:29:09 SmarthomeRaspi kernel: [1727511.952944] Unhandled fault: alignment exception (0x221) at 0x325c003a
                          Aug 27 10:29:09 SmarthomeRaspi kernel: [1727511.952960] pgd = 97bf7909
                          Aug 27 10:29:09 SmarthomeRaspi kernel: [1727511.952973] [325c003a] *pgd=0403c003, *pmd=82b5d003
                          das sind hier die einträge. lässt sich daraus was schließen?
                          • T TobiasF78
                            danke
                            @tobiasf78
                            Schaut nach Hardwaretrouble aus. Irgendwas geändert? Nimm Mal alles von den USB-Ports runter.
                            Oder läuft da eine SSD drauf?
                              @tobiasf78
                              TobiasF78
                              hab keine ssd laufen. am usb von raspi läuft nur ein cc1352P-2 Zigbee Coordinator.
                              hatte dort nur kürzlich ne aktuelle FW geflasht. ansonsten gab es keine änderungen.
                              • T TobiasF78
                                @tobiasf78
                                Dann zieh den Stick mal ab. Aktuelles log dabei beobachten.
                                  @tobiasf78
                                  TobiasF78
                                  hab die usb-verbindung getrennt. im log kommt dann folgendes:
                                  zigbee.0
                                  2022-08-28 01:24:07.659	info	Installed Version: iobroker.zigbee@1.7.6
                                  zigbee.0
                                  2022-08-28 01:24:07.635	error	Error herdsman start
                                  zigbee.0
                                  2022-08-28 01:24:07.634	error	Failed to start Zigbee
                                  zigbee.0
                                  2022-08-28 01:24:07.633	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L43001IJ-if00'"
                                  zigbee.0
                                  2022-08-28 01:24:07.618	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-08-28 01:24:07.617	info	Try to reconnect. 1 attempts left
                                  zigbee.0
                                  2022-08-28 01:23:57.641	info	Installed Version: iobroker.zigbee@1.7.6
                                  zigbee.0
                                  2022-08-28 01:23:57.614	error	Error herdsman start
                                  zigbee.0
                                  2022-08-28 01:23:57.613	error	Failed to start Zigbee
                                  zigbee.0
                                  2022-08-28 01:23:57.612	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L43001IJ-if00'"
                                  zigbee.0
                                  2022-08-28 01:23:57.604	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-08-28 01:23:57.604	info	Try to reconnect. 2 attempts left
                                  zigbee.0
                                  2022-08-28 01:23:47.617	info	Installed Version: iobroker.zigbee@1.7.6
                                  zigbee.0
                                  2022-08-28 01:23:47.602	error	Error herdsman start
                                  zigbee.0
                                  2022-08-28 01:23:47.602	error	Failed to start Zigbee
                                  zigbee.0
                                  2022-08-28 01:23:47.600	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L43001IJ-if00'"
                                  zigbee.0
                                  2022-08-28 01:23:47.594	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-08-28 01:23:47.593	info	Try to reconnect. 3 attempts left
                                  zigbee.0
                                  2022-08-28 01:23:37.613	info	Installed Version: iobroker.zigbee@1.7.6
                                  zigbee.0
                                  2022-08-28 01:23:37.591	error	Error herdsman start
                                  zigbee.0
                                  2022-08-28 01:23:37.591	error	Failed to start Zigbee
                                  zigbee.0
                                  2022-08-28 01:23:37.590	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L43001IJ-if00'"
                                  zigbee.0
                                  2022-08-28 01:23:37.583	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-08-28 01:23:37.582	info	Try to reconnect. 4 attempts left
                                  zigbee.0
                                  2022-08-28 01:23:27.605	info	Installed Version: iobroker.zigbee@1.7.6
                                  zigbee.0
                                  2022-08-28 01:23:27.579	error	Error herdsman start
                                  zigbee.0
                                  2022-08-28 01:23:27.579	error	Failed to start Zigbee
                                  zigbee.0
                                  2022-08-28 01:23:27.578	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.20__Embed_with_CMSIS-DAP_L43001IJ-if00'"
                                  zigbee.0
                                  2022-08-28 01:23:27.550	info	Starting Zigbee npm ...
                                  zigbee.0
                                  2022-08-28 01:23:27.549	info	Try to reconnect. 5 attempts left
                                  zigbee.0
                                  2022-08-28 01:23:17.520	error	Adapter disconnected, stopping
                                  • T TobiasF78
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    @tobiasf78
                                    Ich meinte syslog bzw kernel.log
                                      @tobiasf78
                                      TobiasF78
                                      in der kern.sys gab es nur den eintrag
                                      Aug 28 01:23:17 SmarthomeRaspi kernel: [1781160.801697] usb 1-1.4: USB disconnect, device number 5
                                      in der syslog bekomme ich nur einträge dass der speicher voll ist und influx nicht schreiben kann
                                      Aug 28 01:42:34 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:34.754211Z lvl=info msg="Error writing snapshot" log_id=0c9s68JG000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/iobroker/autogen/320/_00007.wal: no space left on device"
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.386858Z lvl=info msg="Cache snapshot (start)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QooUW000 op_name=tsm1_cache_snapshot op_event=start
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.387006Z lvl=info msg="Cache snapshot (end)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QooUW000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=0.167ms
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.387083Z lvl=info msg="Error writing snapshot" log_id=0c9s68JG000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/_internal/monitor/325/_00010.wal: no space left on device"
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.753870Z lvl=info msg="Cache snapshot (start)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QopvG000 op_name=tsm1_cache_snapshot op_event=start
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.753947Z lvl=info msg="Cache snapshot (end)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QopvG000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=0.090ms
                                      Aug 28 01:42:35 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:35.753992Z lvl=info msg="Error writing snapshot" log_id=0c9s68JG000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/iobroker/autogen/320/_00007.wal: no space left on device"
                                      Aug 28 01:42:36 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:36.386623Z lvl=info msg="Cache snapshot (start)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QosOW000 op_name=tsm1_cache_snapshot op_event=start
                                      Aug 28 01:42:36 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:36.386754Z lvl=info msg="Cache snapshot (end)" log_id=0c9s68JG000 engine=tsm1 trace_id=0c_QosOW000 op_name=tsm1_cache_snapshot op_event=end op_elapsed=0.152ms
                                      Aug 28 01:42:36 SmarthomeRaspi influxd-systemd-start.sh[783]: ts=2022-08-27T23:42:36.386833Z lvl=info msg="Error writing snapshot" log_id=0c9s68JG000 engine=tsm1 error="error opening new segment file for wal (1): write /var/lib/influxdb/wal/_internal/monitor/325/_00010.wal: no space left on device"
                                      • T TobiasF78
                                        @liv-in-sky
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @tobiasf78
                                        die dateien mit .1 am ende kannst du löschen - um wieder platz zu haben
                                        falls das syslog file (ohne 1) auch groß ist kannst du das so klein bekommen
                                        sudo echo > /var/log/syslog
                                        sudo echo > /var/log/kernlog
                                        um mal zu beobachten was da so vor geht kannst du
                                        tail -f /var/log/syslog
                                        tail -f /var/log/kern.log
                                        aufrufen - dann siehst du , was da so viel loggt
                                          @tobiasf78
                                          TobiasF78
                                          @liv-in-sky
                                          vielen Dank.
                                          also einfach mit rm löschen?!
                                          dann werd ich das Log mal im Auge behalten.
