2.9k Beiträge 248 Kommentatoren 2.0m Aufrufe 123 Beobachtet
    tscheinik
    #146
    hallo
    habe es installiert. aber bekomme trotzedem einen fehler. aber wohl was anderes
    $ ./iobroker add zwave
    npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call)
    sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog
    debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.)
    debconf: falling back to frontend: Readline
    debconf: unable to initialize frontend: Readline
    debconf: (This frontend requires a controlling tty.)
    debconf: falling back to frontend: Teletype
    dpkg-preconfigure: unable to re-open stdin:
    ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed
    ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
    100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160
    ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720
    100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k
    ! /bin/sh: 1: unzip: not found
    /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e;
    ! Error: Command failed: unzip master.zip && rm master.zip
    ! at checkExecSyncError (child_process.js:481:13)
    at Object.execSync (child_process.js:521:13)
    at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15)
    at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3)
    at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3)
    at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    ! npm
    ERR! Linux 3.10.102
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0
    npm ERR! npm v3.10.10
    npm
    ERR! code ELIFECYCLE
    ! npm
    ERR! iobroker.zwave@0.6.0 preinstall: node lib/preinstall.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'.
    npm ERR!
    Make sure you have the latest version of node.js and npm installed.npm ERR!
    If you do, this is most likely a problem with the iobroker.zwave package,npm
    ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
    npm ERR! node lib/preinstall.js
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs iobroker.zwave
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm owner ls iobroker.zwave
    npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! host.DS415 install adapter zwave
    100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259
    46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k
    100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k
    ! npm
    ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"
    npm ERR! code ELIFECYCLE
    ! npm
    ERR! iobroker.zwave@0.6.0 preinstall: node lib/preinstall.jsnpm ERR! Exit status 1
    npm ERR!
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,
    npm ERR!
    ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave
    100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268
    ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k
    100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k
    ! npm
    npm ERR!
    node v6.11.0npm ERR! npm v3.10.10
    ! npm ERR! iobroker.zwave@0.6.0 preinstall: node lib/preinstall.jsnpm ERR! Exit status 1
    npm ERR!
    npm ERR! not with npm itself.
    ERROR: host.DS415 Cannot install zwave
    ERROR: process exited with code 13</anonymous></anonymous></anonymous>
    habe jetzt mal apt-get install unzip ins terminal eingegeben. versuche jetzt nochmal
    edit:
    es hat geklappt
    • andreA Offline
      andreA Offline
      andre
      #147
      @tscheinik:
      hallo
      ! $ ./iobroker add zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.) debconf: falling back to frontend: Readline debconf: unable to initialize frontend: Readline debconf: (This frontend requires a controlling tty.) debconf: falling back to frontend: Teletype dpkg-preconfigure: unable to re-open stdin: ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160 ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720 100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259 ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k 100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268 ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k 100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave ERROR: host.DS415 Cannot install zwave ERROR: process exited with code 13</anonymous></anonymous></anonymous> `
      Du musst das Logfile schon lesen… Oder es zumindest versuchen...
      Nehme meinen letzte Beitrag und ersetze sudo mit unzip...
      MfG,
      André
      Gesendet mit Tapatalk
        tscheinik
        #148
        haben uns überschnitten. darauf bin ich schon gekommen.
        es hat jetzt geklappt.
        • andreA Offline
          andreA Offline
          andre
          #149
          @tscheinik:
          es hat jetzt geklappt. `
          :) Du hattest jetzt nur sudo und unzip nachinstalliert, richtig?
          Lass es mich bitte wissen ob das Einbinden des USB sticks gelingt, dann würde ich die Pakete mit in das Image aufnehmen.
          MfG,
          André
            tscheinik
            #150
            ja sobald ich den stick bekomme werde ich es testen.
            habe diesen stick Aeotec AEOEZW090-C Aeon Labs USB Stick
            ja genau einmal sudo und einmal unzip
            • G Offline
              gingo79
              #151
              @andre:
              Jetzt habe ich zwei Möglichkeiten: Entweder ich fange diese Meldung, dass ioBroker schon läuft irgendwie im Startup Script ab und reagiere darauf, oder ich identifiziere die Ursache und beseitige sie. Letzteres ist mein Favorit ;)
              Momentan warte ich darauf, dass es bei mir wieder passiert. Allerdings startet meine DiskStation ja nicht so häufig wie bei dir. :)
              Ich bleibe dran.
              MfG,
              André
              Gesendet mit Tapatalk `
              Vielen Dank dafür!
              Gingo79
                tscheinik
                #152
                @andre:
                @tscheinik:
                MfG,
                André
                ich habe es einmal geschafft bei z-wave einen usb port auszuwhälen. war aber kurz danach weg. ich kann nichtmal einen usb port aussuchen.
                bei domoticz wird der stick erkannt.
                  Artem82
                  #153
                  Please add to default to iob container 'cifs-utils'
                  I want mount folder.
                  Thx!!!
                  • andreA Offline
                    andreA Offline
                    andre
                    #154
                    @tscheinik:
                    @andre:
                    @tscheinik:
                    MfG,
                    André
                    bei domoticz wird der stick erkannt. `
                    Versuch mal den Container mit erweiterten Berechtigungen laufen zu lassen. (https://forum.synology.com/enu/viewtopic.php?t=127019)
                    Container stoppen, Container bearbeiten, Allgemeine Einstellungen: "Container mit hoher Priorität ausführen". Vielleicht hast du dann Zugriff auf die USB-Geräte.
                    Falls nicht kenne ich nur den Weg wie man USB-Devices beim Start des Containers per Kommandozeile durch reicht… Habe es selbst aber noch nicht praktiziert...
                    MfG,
                    André
                    • andreA Offline
                      andreA Offline
                      andre
                      #155
                      @Artem82:
                      Please add to iob container 'cifs-utils'
                      Thx!!! `
                      I'm sorry. As long as no Adapter requires this package, I will not add this to the image.
                      But you can install it manually as you want using "apt-get install" at the commandline of the container.
                      If you wannt to mount folders between the container and diskstation there is a described way using the docker webinterface of the synology diskstation. Maybe it is also possible to share the mounted diskstation folder to access it from the network…
                      regards,
                      André
                        Artem82
                        #156
                        @andre:
                        @Artem82:
                        Thx!!! `
                        regards,
                        André `
                        ~~![](</s><URL url=)http://prntscr.com/fllf8w" />
                        After this command:
                        Unable to apply new capability set.~~
                        • andreA Offline
                          andreA Offline
                          andre
                          #157
                          @Artem82:
                          @andre:
                          @Artem82:
                          Thx!!! `
                          regards,
                          André `
                          After this command:
                          Unable to apply new capability set.~~ ` ~~I'm sorry, can't help u with that.
                          Try to find something at google. It gives me a lot of results when i use:````
                          unable to apply new capability set cifs docker
                          regards,
                          André~~
                            afunk
                            #158
                            wollte einfach mal DANKE für dieses coole Docker-Paket sagen :-)
                            afunk
                            • andreA Offline
                              andreA Offline
                              andre
                              #159
                              @afunk:
                              afunk `
                              Das freut mich. :) Hat sich die Arbeit ja gelohnt.
                              MfG,
                              André
                              • E Offline
                                ehome
                                #160
                                Hallo Andre,
                                habe gestern mal eine Test-Migration meiner iobroker Installation auf Docker gemacht. Deine Anleitung hat mir
                                sehr geholfen - auch wenn ich es auf meiner QNAP gemacht habe.
                                Der Adapter "phantomjs" lässt sich zwar installieren, funktioniert aber nicht richtig. Die Fehlermeldung findest du weiter unten.
                                So richtig schlau werde ich nicht aus den Fehlermeldungen - aber vielleicht kannst du damit was anzufangen.
                                Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                                phantomjs.0	2017-08-09 11:18:01.078	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281067, q=0, from=system.adapter.phantomjs.0, lc=1502270281067
                                phantomjs.0	2017-08-09 11:18:01.074	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270281066, q=0, from=system.adapter.phantomjs.0, lc=1502270281066
                                phantomjs.0	2017-08-09 11:18:01.058	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281054, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.049	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281046, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.046	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281041, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.034	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281030, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.022	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281016, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.012	debug	inMem message phantomjs.0.* phantomjs.0.working val=false, ack=true, ts=1502270281007, q=0, from=system.adapter.phantomjs.0, lc=1502270281007
                                phantomjs.0	2017-08-09 11:18:01.010	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:01.010	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:01.010	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/stromverbrauch_woche.png 1010px*315px 90000ms
                                phantomjs.0	2017-08-09 11:18:01.007	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/stromverbrauch_woche.png'
                                phantomjs.0	2017-08-09 11:18:01.000	info	Create 1010px*315px in 90000ms - 'http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff'
                                phantomjs.0	2017-08-09 11:18:00.998	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280939, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.997	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280930, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.996	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280917, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.995	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280907, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.994	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280887, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.992	debug	inMem message phantomjs.0.* phantomjs.0.working val=true, ack=true, ts=1502270280874, q=0, from=system.adapter.phantomjs.0, lc=1502270280874
                                phantomjs.0	2017-08-09 11:18:00.990	debug	inMem message messagebox.system.adapter.phantomjs.0 messagebox.system.adapter.phantomjs.0 command=send, url=http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff, output=stromverbrauch_woche.png, width=1010, height=315, renderTime=90000, online=true, from=system.adapter.javascript.0, url=http://iobroker:8082/flot/index.html?relativeEnd=now&range=2880&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=300&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.Strom.power_hausanschluss&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23ff0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bname%5D=Hausanschluss+gesamt&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Byaxe%5D=leftColor&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bsmoothing%5D=1&l%5B0%5D%5Bfill%5D=0.3&l%5B1%5D%5Bid%5D=wrapper.0.Strom.power_waschmaschine&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%239d9d9d&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bname%5D=Waschmaschine&l%5B1%5D%5Byaxe%5D=rightColor&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=0&l%5B2%5D%5Bid%5D=wrapper.0.Strom.power_it-schrank&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=0&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=IT-Schrank&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=2&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bpoints%5D=false&l%5B3%5D%5Bid%5D=wrapper.0.Strom.power_schreibtisch-olli&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=Schreibtisch+Olli&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=off&l%5B3%5D%5BcommonYAxis%5D=2&l%5B3%5D%5BafterComma%5D=0&l%5B4%5D%5Bid%5D=wrapper.0.Strom.power_trockner&l%5B4%5D%5Binstance%5D=sql.0&l%5B4%5D%5Boffset%5D=0&l%5B4%5D%5Baggregate%5D=minmax&l%5B4%5D%5Bcolor%5D=%23FF00FF&l%5B4%5D%5Bmin%5D=0&l%5B4%5D%5Bthickness%5D=3&l%5B4%5D%5Bshadowsize%5D=3&l%5B4%5D%5Bname%5D=Trockner&l%5B4%5D%5Byaxe%5D=off&l%5B4%5D%5Bxaxe%5D=off&l%5B4%5D%5BcommonYAxis%5D=2&l%5B4%5D%5BafterComma%5D=0&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&live=300&_vis_refts=1492630530729&grid_color=%23ffffff, output=stromverbrauch_woche.png, width=1010, height=315, renderTime=90000, online=true, id=8, ack=false, time=1502270280785, _id=36062398
                                phantomjs.0	2017-08-09 11:18:00.980	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.979	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.979	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_za&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_zj&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&l%5B2%5D%5Bid%5D=wrapper.0.Temperatur.temp_zl&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=average&l%5B2%5D%5Bcolor%5D=%230000FF&l%5B2%5D%5Bmin%5D=15&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B2%5D%5BcommonYAxis%5D=1&l%5B2%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/kinder_woche.png 414px*249px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.978	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/kinder_woche.png'
                                phantomjs.0	2017-08-09 11:18:00.976	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.976	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.976	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=2y&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=count&aggregateSpan=3600&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25d.%25m.%25y&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.ManuelleDaten.strom-verbrauch-monat&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%233B3DA5&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=900&l%5B0%5D%5Bthickness%5D=4&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=kWh&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bname%5D=Strom+in+kWh&l%5B0%5D%5Bfill%5D=30&l%5B0%5D%5Bpoints%5D=true&l%5B0%5D%5BafterComma%5D=2&l%5B1%5D%5Bid%5D=wrapper.0.ManuelleDaten.gas-verbrauch-monat&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1100&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=m%C2%B3&l%5B1%5D%5Bname%5D=Gas+in+m%C2%B3&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5BignoreNull%5D=true&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bfill%5D=30&l%5B1%5D%5Bpoints%5D=true&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&grid_color=%23ffffff&barFontColor=%23ffffff&titleColor=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/energie_gas_strom.png 1010px*300px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.975	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/energie_gas_strom.png'
                                phantomjs.0	2017-08-09 11:18:00.967	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.966	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.966	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_bo&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_fo&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/flure_woche.png 976px*334px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.965	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/flure_woche.png'
                                phantomjs.0	2017-08-09 11:18:00.965	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.964	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.964	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_wk&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_fu&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/erdgeschoss_woche.png 674px*301px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.964	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/erdgeschoss_woche.png'
                                phantomjs.0	2017-08-09 11:18:00.963	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.962	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.962	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=10080&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_bo&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5Bmin%5D=15&l%5B0%5D%5BafterComma%5D=1&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=wrapper.0.Temperatur.temp_wz&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=15&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=1&l%5B1%5D%5BafterComma%5D=1&timeType=relative&zoom=false&noedit=true&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&_vis_refts=1500482247515 /opt/iobroker/node_modules/iobroker.phantomjs/dachgeschoss_woche.png 941px*334px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.962	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/dachgeschoss_woche.png'
                                phantomjs.0	2017-08-09 11:18:00.960	debug	sendTo 'send' to system.adapter.javascript.0 from system.adapter.phantomjs.0
                                phantomjs.0	2017-08-09 11:18:00.958	error	/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs: error while loading shared libraries: libfontconfig.so.1: cannot open shared object file: No such file or directory
                                phantomjs.0	2017-08-09 11:18:00.958	error	Error: Command failed: /opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js http://iobroker:8082/flot/index.html?relativeEnd=now&range=1440&live=900&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=step&aggregateSpan=3600&noBorder=noborder&hoverDetail=false&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&useComma=true&l%5B0%5D%5Bid%5D=wrapper.0.Temperatur.temp_ab&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5BcommonYAxis%5D=1&l%5B0%5D%5Baggregate%5D=max&timeType=relative&zoom=false&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff /opt/iobroker/node_modules/iobroker.phantomjs/aussen_tag.png 720px*401px 90000ms
                                phantomjs.0	2017-08-09 11:18:00.957	info	and save to '/opt/iobroker/node_modules/iobroker.phantomjs/aussen_tag.png'
                                phantomjs.0	2017-08-09 11:18:00.932	info	Create 1010px*300px in 90000ms - 'http://iobroker:8082/flot/index.html?relativeEnd=now&range=2y&start=2015-10-01&start_time=00%3A00%3A00&end=2016-10-01&end_time=00%3A00%3A00&aggregateType=count&aggregateSpan=3600&noBorder=noborder&titlePos=bottom%3A5%3Bleft%3A65&timeFormat=%25d.%25m.%25y&useComma=false&l%5B0%5D%5Bid%5D=wrapper.0.ManuelleDaten.strom-verbrauch-monat&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bcolor%5D=%233B3DA5&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=900&l%5B0%5D%5Bthickness%5D=4&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=kWh&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Baggregate%5D=average&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bname%5D=Strom+in+kWh&l%5B0%5D%5Bfill%5D=30&l%5B0%5D%5Bpoints%5D=true&l%5B0%5D%5BafterComma%5D=2&l%5B1%5D%5Bid%5D=wrapper.0.ManuelleDaten.gas-verbrauch-monat&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=average&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1100&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=m%C2%B3&l%5B1%5D%5Bname%5D=Gas+in+m%C2%B3&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5BignoreNull%5D=true&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bfill%5D=30&l%5B1%5D%5Bpoints%5D=true&timeType=relative&legend=nw&hoverDetail=true&zoom=true&noedit=false&animation=0&x_labels_color=%23ffffff&y_labels_color=%23ffffff&grid_color=%23ffffff&barFontColor=%23ffffff&titleColor=%23ffffff'
                                Olli
                                • andreA Offline
                                  andreA Offline
                                  andre
                                  #161
                                  @ehome:
                                  Hallo Andre,
                                  Olli ` Hallo,
                                  danke für das Feedback. Sieht aus alsob libfontconfig im Container fehlt. Mach mal im Container ein "apt-get install libfontconfig"
                                  Dann sollte der Adapter funktionieren.
                                  Schau mir das mal an wenn ich wieder daheim bin.
                                  MfG,
                                  André
                                  Gesendet von Unterwegs mit Tapatalk
                                  • R Offline
                                    RalfR72
                                    #162
                                    Habe den Beitrag mit der Advanced Docker Installation nun mehrmals gelesen. Das meiste ist mir auch klar. Nur wie bekomme ich das ioBroker Verzeichniss aus meinem Container raus? Wie komm ich da ran?
                                    Seh nirgends in meiner Diskstation das Biobroker Verzeichnis.
                                    Geht das mit einem Terminal Befehl? Wenn ja wie lautet der Befehl?
                                    Würd mich über Hilfe freuen.
                                    Danke für die Hilfestellungen, Gruss Ralf
                                    Landkreis Esslingen/BW
                                    CCU2, Synology NAS 916+, ioBroker auf Pi3, Hue, Bose Soundtouch, iMac5k, Harmony Hub, Mediola aioCreator, Alexa Echo Dot.
                                    • andreA Offline
                                      andreA Offline
                                      andre
                                      #163
                                      @RalfR72:
                                      Würd mich über Hilfe freuen. `
                                      Hallo Ralf,
                                      sorry, dass ich dir auf deine pn noch nicht geantwortet hab. :)
                                      Du kannst von deinem Container aus über ein gemountetes Verzeichnis auf Ordner der DS zugreifen. Ich bin aktuell gerade dabei ein ausführliches Tutorial zum ganzen Synology und iobroker Thema zu schreiben. Gestern habe ich genau dein Thema beschrieben :) Ist leider noch nicht veröffentlicht. Wenn ich es morgen an den PC schaffe, schicke ich dir schonmal meinen Entwurf per pn. Das sollte deine Frage dann beantworten.
                                      MfG,
                                      André
                                      Gesendet von iPad mit Tapatalk
                                      • R Offline
                                        RalfR72
                                        #164
                                        @andre:
                                        @RalfR72:
                                        Hallo Ralf,
                                        MfG,
                                        André
                                        Gesendet von iPad mit Tapatalk `
                                        Ok , danke erstmal. Da bin ich ja gespannt ;-).
                                        Hoffe damit dann den "Umzug" vom ioBroker im Container auf ein Synology Verzeichnis hin zu bekommen.
                                        • andreA Offline
                                          andreA Offline
                                          andre
                                          #165
                                          Sozusagen zum 1000 Download meines Docker Images habe ich heute eine neue Version auf den Weg gebracht. Mit dabei ein paar Änderungen die es in Zukunft leichter machen sollten, eine bestehende ioBroker Installation auf die DS umzuziehen, sowie ein neuerlicher Versuch das Startup-Problem zu fixen.
                                          Würde mich über Tester freuen. :) Bei mir läuft bereits alles ohne Probleme produktiv.
                                          MfG,
                                          André
                                          P.S.: Ein ausführliches Tutorial zu meinem Docker Image steht kurz vor der Fertigstellung. Ich hoffe, dass dann vielleicht noch mehr Leute den Vorzug der Installation unter Docker auf der Diskstation erkennen, bzw. sich dort ran trauen. ;)
