  4. Parser-Adapter funktioniert nicht mehr
28 Beiträge 3 Kommentatoren 2.3k Aufrufe 2 Beobachtet
    @gregors
    Dann lösch die Dinger im jeweiligen Verzeichnis mit dieser for-Schleife:
    Hier also
    cd /opt/iobroker/node_modules/jsonwebtoken/node_modules/
    for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
    GregorSG Offline
    GregorSG Offline
    GregorS
    Ist nun durchgelaufen.
    WARN kann ich ignorieren?
    Was ist mit den ERR
    pi@TinkerboardS:/opt/iobroker$ npm prune
    npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm ERR! code ENOMEM
    npm ERR! syscall spawn
    npm ERR! errno -12
    npm ERR! spawn ENOMEM
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Was ist mit den ERR
      npm ERR! errno -12
      @gregors sagte in Parser-Adapter funktioniert nicht mehr:
      spawn ENOMEM
      RAM ist aus!
      • GregorSG GregorS
        Was ist mit den ERR
        npm ERR! errno -12
        I.d.R. schon. Ich würde mir aber den sourceanalytix nochmal anschauen. Der scheint noch aus git zu kommen. Installier den aus dem Beta-Repository.
        GregorSG 1 Antwort Letzte Antwort
          GregorSG Offline
          GregorSG Offline
          GregorS
          ok. werde ich machen.
          Den alten voher entsorgen, oder drüber bügeln?
          • GregorSG GregorS
            @gregors
            Versuch mal
            iobroker upgrade sourceanalytix@0.4.14 --debug
              @gregors
              Versuch mal
              GregorSG Offline
              GregorSG Offline
              GregorS
              Klappt nicht.
              Would you like to upgrade sourceanalytix from @0.4.8 to @0.4.14 now? [(y)es, (n)o]: y
              Update sourceanalytix from @0.4.8 to @0.4.14
              NPM version: 8.11.0
              Installing iobroker.sourceanalytix@0.4.14... (System call)
              npm ERR! code ENOTEMPTY
              npm ERR! syscall rename
              npm ERR! path /opt/iobroker/node_modules/abab
              npm ERR! dest /opt/iobroker/node_modules/.abab-bvmibCm3
              npm ERR! errno -39
              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abab' -> '/opt/iobroker/node_modules/.abab-bvmibCm3'
              Versuche jetzt mal wieder alle . Verzeichnisse zu löschen.
              • GregorSG GregorS
                Klappt nicht.
                NPM version: 8.11.0
                npm ERR! errno -39
                Warum ist der überhaupt in so einer alten Version installiert? Der hätte schon längst per regulärem Update auf die aktuelle Version hochgezogen worden sein.
                GregorSG 2 Antworten Letzte Antwort
                  GregorSG Offline
                  GregorSG Offline
                  GregorS
                  Ich habe meine Adapter immer zeitnah aktualisiert.
                  Bis auf den VIS-Adapter. da ich noch 2 ältere Tabletts nutze.
                  Wenn ich auf "Beta" umstelle, bekomme ich 20 Adapter zum updaten angeboten
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    schrieb am zuletzt editiert von GregorS
                    Du schreibst in deinem How-To Teil 2, Teil 2: Installationen geradeziehen
                    Nach upgrade auf nodeJS16 / npm 8 können keine Adapter mehr installiert werden und bei einer Installation mit aktivierter --debug Option werden diverse Verzeichnisse zum umbenennen vorgeschlagen
                    Ist das ein Bug?
                    Sollte ich wenn es geht wieder downgraden?
                    Habe gerade mal versucht über "Adapter" ein Upgrade des Parsers auszuführen. Ist mit dem üblichen Fehler abgebrochen.
                    Das Upgrade wurde mir in der Stable angeboten (+4 Weitere)
                    iobroker upgrade parser@1.1.8 --debug
                    Es kommt wie Üblich
                    Installing iobroker.parser@1.1.8... (System call)
                    npm ERR! path /opt/iobroker/node_modules/acorn
                    npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
                    npm ERR! errno -39
                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
                    Hbe mir dann mal die Log-Datei angeschaut:
                    2022-08-20T05_34_08_125Z-debug-0.log
                    Wenn ich das richtig interpretiere, dann muss ich ja noch unzählige Verzeichnisse händisch löschen.
                    Vor dem Upgrade von Node und NPM hat alles funktioniert.
                    • GregorSG GregorS
                      Ist das ein Bug?
                      Es kommt wie Üblich
                      npm ERR! errno -39
                      Ist das ein Bug?
                      Nein.
                      Lösch die Verzeichnisse und gut ist.
                      • GregorSG Offline
                        GregorSG Offline
                        GregorS
                        Mache ich, aber ich habe das ja bei jeder Installation und Upgrade
                        Ist sehr Zeitintensiv.
                        Überlege, ob ich das System neu aufsetzen soll
                        • GregorSG GregorS
                          @gregors Kannst auch Mal probieren das kompletten node_modules Verzeichnis zu löschen.
                            GregorSG Offline
                            GregorSG Offline
                            GregorS
                            Wie bekomme ich es danach wieder neu installiert?
                            • GregorSG GregorS
                              @gregors
                              Das sollte sich dann wieder von alleine aufbauen bei einem Start des iobrokers.
                              • GregorSG Offline
                                GregorSG Offline
                                GregorS
                                Dann versuche ich es mal.
                                Muss aber erst noch ein Image erstellen um den alten Stand zurücklesen zu können.
                                Mit welchem Befehl kann ich das Verzeichnis löschen, oder soll ich es mit FTP löschen?
                                • GregorSG GregorS
                                  @gregors
                                  Mit
                                  rm -rf /opt/iobroker/node_modules/*
                                  Wie soll das per FTP gehen? Das ist ein Protokoll, kein Kommando.
                                    @gregors
                                    Mit
                                    GregorSG Offline
                                    GregorSG Offline
                                    GregorS
                                    Sorry, falsch ausgedrückt.
                                    Meinte FTP-Client Filezilla
