  4. Problem beim Löschen von Node Red
    5.8k
56 Beiträge 6 Kommentatoren 7.2k Aufrufe 9 Beobachtet
    @guitardoc
    iob update -i
    guitardoc
    i@raspberrypi:/opt/iobroker $ iob update -i
    Used repository: Latest
    Adapter    "admin"        : 6.2.17   , installed 6.2.17
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "cloud"        : 4.2.1    , installed 4.2.1
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "eusec"        : 0.9.4    , installed 0.9.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.0.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
    Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "socketio"     : 6.1.8    , installed 6.1.8
    Adapter    "sql"          : 2.1.8    , installed 2.1.8
    Adapter    "telegram"     : 1.14.1   , installed 1.14.1
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
    Adapter    "web"          : 5.2.4    , installed 5.2.4
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.1.3    , installed 2.1.3
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    pi@raspberrypi:/opt/iobroker $
    • G guitardoc
      @guitardoc
      iobroker stop node-red.0
      iobroker del node-red
      G 1 Antwort Letzte Antwort
        @guitardoc
        guitardoc
        pi@raspberrypi:/opt/iobroker $ iobroker del node-red
        Delete adapter "node-red"
        host.raspberrypi object node-red deleted
        host.raspberrypi object node-red.admin deleted
        Error deleting adapter node-red from disk: host.raspberrypi: Cannot uninstall iobroker.node-red: 217
        You might have to delete it yourself!
        GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
        • G guitardoc
          GlasfaserG Offline
          GlasfaserG Offline
          @guitardoc sagte in Problem beim Löschen von Node Red:
          iobroker del node-red --debug
          • G guitardoc
            G GlasfaserG 2 Antworten Letzte Antwort
              guitardoc
              pi@raspberrypi:/opt/iobroker $ iobroker del node-red --debug
                GlasfaserG Offline
                GlasfaserG Offline
                ist der gleich Käse wie hier :
                https://forum.iobroker.net/topic/57172/ich-kann-nichts-mehr-installieren-updaten/15?_=1660922486510
                EDIT :
                Ergebnis zum Schluss
                @fiso sagte in Ich kann nichts mehr installieren / updaten:
                Ich glaubs kaum, Node-Red ließ sich jetzt wieder installieren.....
                • GlasfaserG Glasfaser
                  EDIT :
                  guitardoc
                  @glasfaser
                  Naja, da hat der TE aber irgendwie wild rumgefrickelt und dabei an irgendeiner Stelle vermutlich irgendwas richtig gemacht - wobei zwischendurch das System kurz vorm Verschrotten war. Ich würde gern herausfinden, was der eine richtige Befehl war ohne mein System dabei zu zerschießen… :-)
                  Danke übrigens auch an euch beide dass ihr mir hier helft, das ist bei Weitem nicht selbstverständlich!
                  • G guitardoc
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @guitardoc
                    iobroker upgrade node-red@3.3.1 --debug
                    • G guitardoc
                      @glasfaser
                      @guitardoc
                      Versuch mal node-red upzugraden, vielleicht kommt da mehr ums Eck.
                      iobroker upgrade node-red --debug
                      • G Offline
                        guitardoc
                        pi@raspberrypi:/opt/iobroker $ iobroker upgrade node-red --debug
                        This upgrade of "node-red" will introduce the following changes:
                        -> 4.0.0:
                        IMPORTANT: Node.js 14.x now needed at least
                        Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
                        Correctly escape backslashes when writing setting file on Windows
                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                        Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
                        Update node-red from @3.3.1 to @4.0.0
                        NPM version: 8.15.0
                        Installing iobroker.node-red@4.0.0... (System call)
                        npm ERR! code ENOTEMPTY
                        npm ERR! syscall rename
                        npm ERR! path /opt/iobroker/node_modules/addressparser
                        npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                        npm ERR! errno -39
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-19T15_50_47_992Z-debug-0.log
                        host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
                        Ich sehe schon, da müssen die Verzeichnisse gelöscht werden, richtig?
                        rm -rf /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                        • G guitardoc
                          -> 4.0.0:
                          NPM version: 8.15.0
                          npm ERR! errno -39
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @guitardoc
                          Jippp :)
                          • G guitardoc
                            -> 4.0.0:
                            NPM version: 8.15.0
                            npm ERR! errno -39
                            Geht am schnellsten mit dem 'Lösch-Einzeiler', ausgeführt im jeweiligen Verzeichnis:
                            cd /opt/iobroker/node_modules
                            for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                              guitardoc
                              schrieb am zuletzt editiert von guitardoc
                              Arrrghhh - ich hab die alle per Hand gelöscht jetzt… :-) Es hat zwar ein bisschen was gebracht, aber noch nicht komplett - der Adapter ist wohl jetzt auf 4.0.0, aber er lässt sich nicht löschen:
                              P i@raspberrypi:~ $ iobroker update
                              Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                              pi@raspberrypi:~ $ iobroker del node-red --debug
                              pi@raspberrypi:~ $ iobroker upgrade node-red --debug
                              Adapter "node-red"       is up to date.
                              pi@raspberrypi:~ $
                              EDIT: reboot hatte ich schon gemacht vorher.
                              • G guitardoc
                                pi@raspberrypi:~ $
                                @guitardoc
                                Stopp den node-red-Adapter.
                                Dann
                                iobroker stop
                                iobroker fix
                                cd /opt/iobroker
                                sudo -H -u iobroker npm uninstall iobroker.node-red
                                  @guitardoc
                                  Dann
                                  iobroker stop
                                  iobroker fix
                                  cd /opt/iobroker
                                  guitardoc
                                  In den Instanzen ist er nicht mehr zu finden.
                                  Dann kommt:
                                  pi@raspberrypi:~ $ cd /opt/iobroker
                                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm uninstall iobroker.node-red
                                  npm ERR! path /opt/iobroker/node_modules/acorn
                                  npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-19T16_43_43_723Z-debug-0.log
                                  Ich vermute, die Verzeichnisse müssen wieder gelöscht werden?
                                  • G guitardoc
                                    Dann kommt:
                                    npm ERR! errno -39
                                    Ja. Wo auch immer die jetzt wieder herkommen.
                                    Aber mit dem Einzeiler ist das nicht mehr viel arbeit.
                                    G R 2 Antworten Letzte Antwort
                                      guitardoc
                                      @thomas-braun Jetzt erscheint der Adapter unter iobroker update nicht mehr. Dafür komme ich jetzt bei :8081 nicht mehr auf den Admin - URL kann nicht angezeigt werden…
                                      • G guitardoc
                                        @guitardoc
                                        iobroker update
                                        iobroker list adapters
                                        iobroker list instances
                                          @guitardoc
                                          iobroker update
                                          guitardoc
                                          pi@raspberrypi:~ $ iobroker update
                                          pi@raspberrypi:~ $ iobroker list adapters
                                          system.adapter.admin                   : admin          - v6.2.17
                                          system.adapter.backitup                : backitup       - v2.4.12
                                          system.adapter.cloud                   : cloud          - v4.2.1
                                          system.adapter.deconz                  : deconz         - v1.3.21
                                          system.adapter.discovery               : discovery      - v3.0.5
                                          system.adapter.email                   : email          - v1.1.3
                                          system.adapter.eusec                   : eusec          - v0.9.4
                                          system.adapter.feiertage               : feiertage      - v1.1.0
                                          system.adapter.flot                    : flot           - v1.11.0
                                          system.adapter.info                    : info           - v1.9.19
                                          system.adapter.javascript              : javascript     - v6.0.0
                                          system.adapter.logparser               : logparser      - v1.1.0
                                          system.adapter.nanoleaf-lightpanels    : nanoleaf-lightpanels - v1.2.0
                                          system.adapter.ping                    : ping           - v1.4.12
                                          system.adapter.scenes                  : scenes         - v2.3.9
                                          system.adapter.shelly                  : shelly         - v6.0.0
                                          system.adapter.shuttercontrol          : shuttercontrol - v1.4.14
                                          system.adapter.simple-api              : simple-api     - v2.7.0
                                          system.adapter.socketio                : socketio       - v6.1.8
                                          system.adapter.sql                     : sql            - v2.1.8
                                          system.adapter.telegram                : telegram       - v1.14.1
                                          system.adapter.terminal                : terminal       - v0.1.2
                                          system.adapter.vis                     : vis            - v1.4.15
                                          system.adapter.vis-map                 : vis-map        - v1.0.4
                                          system.adapter.vis-materialdesign      : vis-materialdesign - v0.5.9
                                          system.adapter.vw-connect              : vw-connect     - v0.0.51
                                          system.adapter.web                     : web            - v5.2.4
                                          system.adapter.wiffi-wz                : wiffi-wz       - v2.2.1
                                          system.adapter.ws                      : ws             - v2.1.3
                                          system.adapter.yahka                   : yahka          - v0.13.1
                                          pi@raspberrypi:~ $ iobroker list instances
                                            system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                            system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                                            system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                            system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                                            system.adapter.eusec.0                  : eusec                 : raspberrypi                              - disabled
                                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                            system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                            system.adapter.javascript.1             : javascript            : raspberrypi                              - disabled
                                            system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                                            system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                            system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                                            system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
                                            system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
                                            system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
                                            system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.wiffi-wz.0               : wiffi-wz              : raspberrypi                              -  enabled
                                            system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                          + instance is alive
                                          pi@raspberrypi:~ $
