  4. Problem beim Löschen von Node Red
    5.8k
56 Beiträge 6 Kommentatoren 7.2k Aufrufe 9 Beobachtet
  • GlasfaserG Glasfaser
    @guitardoc sagte in Problem beim Löschen von Node Red:
    Jetzt ist der Adapter immer noch installiert, es wird mir ein Update dafür angezeigt,
    sudo reboot
    was ist dann !?
    guitardoc
    @glasfaser
    Hat leider nichts gebracht - Adapter ist immer noch da und beim Entfernen sagt der ioBroker:
    $ iobroker del node-red
    Delete adapter "node-red"
    host.raspberrypi object node-red deleted
    host.raspberrypi object node-red.admin deleted
    Error deleting adapter node-red from disk: host.raspberrypi: Cannot uninstall iobroker.node-red: 217You might have to delete it yourself!
    Process exited with code 0
    • G guitardoc
      @glasfaser
      Zuerst hab ich das hier gemacht:
      This upgrade of "node-red" will introduce the following changes:
      -> 4.0.0:
      IMPORTANT: Node.js 14.x now needed at least
      Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
      Correctly escape backslashes when writing setting file on Windows
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
      Update node-red from @3.3.1 to @4.0.0
      NPM version: 8.15.0
      Installing iobroker.node-red@4.0.0... (System call)
      host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
      Dann wollte ich wenigstens auf die schon bestehende Version zurück:
      i@raspberrypi:~ $ npm install iobroker.node-red@3.3.1
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated multer@1.4.4: Multer 1.x is affected by CVE-2022-24434. This is fixed in v1.4.4-lts.1 which drops support for versions of Node.js before 6. Please upgrade to at least Node.js 6 and version 1.4.4-lts.1 of Multer. If you need support for older versions of Node.js, we are open to accepting patches that would fix the CVE on the main 1.x release line, whilst maintaining compatibility with Node.js 0.10.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm WARN deprecated axios@0.27.0: Formdata complete broken, incorrect build size
      npm ERR! code EACCES
      npm ERR! syscall open
      npm ERR! path /home/pi/package.json
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, open '/home/pi/package.json'
      npm ERR!  [Error: EACCES: permission denied, open '/home/pi/package.json'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'open',
      npm ERR!   path: '/home/pi/package.json'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/pi/.npm/_logs/2022-08-19T14_11_02_986Z-debug-0.log
      Und dann dachte ich mir, dass ich Node Red sowieso nie gebraucht hab, also weg damit (jetzt über :8081, das ging Dank deiner Hilfe ja dann wieder):
      host.raspberrypi
      2022-08-19 16:33:25.069	info	iobroker exit 0
      host.raspberrypi
      2022-08-19 16:33:24.030	error	iobroker You might have to delete it yourself!
      host.raspberrypi
      2022-08-19 16:33:24.028	error	iobroker Error deleting adapter node-red from disk: host.raspberrypi: Cannot uninstall iobroker.node-red: 217
      host.raspberrypi
      2022-08-19 16:33:14.861	info	iobroker host.raspberrypi object node-red.admin deleted
      host.raspberrypi
      2022-08-19 16:33:14.855	info	iobroker host.raspberrypi object node-red deleted
      host.raspberrypi
      2022-08-19 16:33:12.792	info	iobroker Delete adapter "node-red"
      host.raspberrypi
      2022-08-19 16:33:10.688	info	iobroker del node-red
      @guitardoc
      Du springst da in den falschen Verzeichnissen herum.
      • G guitardoc
        @glasfaser
        -> 4.0.0:
        NPM version: 8.15.0
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        host.raspberrypi
        GlasfaserG Offline
        GlasfaserG Offline
        pi@raspberrypi:~ $ npm install iobroker.node-red@3.3.1
        Das meint Thomas
        cd /opt/iobroker
        dann
        G 1 Antwort Letzte Antwort
          Das meint Thomas
          cd /opt/iobroker
          dann
          guitardoc
          @glasfaser
          Bringt leider nichts. Hab es ausgeführt, dann reboot. Dann im Admin noch mal den Adapter gelöscht:
          GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
          • G guitardoc
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @guitardoc
            Die Ausgabe sagt gelöscht Code 0
            Browser refresh !?
            • G guitardoc
              @glasfaser
              Bitte vollständige Ein- und Ausgabezeilen zeigen. Damit man evtl. sehen kann warum 'es nichts bringt'.
                guitardoc
                pi@raspberrypi:~ $ cd /opt/iobroker
                pi@raspberrypi:/opt/iobroker $ npm install iobroker.node-red@3.3.1
                up to date in 10s
                117 packages are looking for funding
                  run `npm fund` for details
                63D1BCCA-320B-432B-B9A7-0F04D5869468.png D66B47E9-7870-441F-A493-59D3FC2A5B81.png
                • G guitardoc
                  up to date in 10s
                  @guitardoc
                  Was hast du eigentlich jetzt genau vor? node-red installieren? node-red deinstallieren?
                    @guitardoc
                    guitardoc
                    Eigentlich deinstallieren.
                    • G guitardoc
                      @guitardoc
                      iob update -i
                        @guitardoc
                        iob update -i
                        guitardoc
                        i@raspberrypi:/opt/iobroker $ iob update -i
                        Used repository: Latest
                        Adapter    "admin"        : 6.2.17   , installed 6.2.17
                        Adapter    "backitup"     : 2.4.12   , installed 2.4.12
                        Adapter    "cloud"        : 4.2.1    , installed 4.2.1
                        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
                        Adapter    "email"        : 1.1.3    , installed 1.1.3
                        Adapter    "eusec"        : 0.9.4    , installed 0.9.4
                        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                        Adapter    "flot"         : 1.11.0   , installed 1.11.0
                        Adapter    "info"         : 1.9.19   , installed 1.9.19
                        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
                        Controller "js-controller": 4.0.23   , installed 4.0.23
                        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                        Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
                        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                        Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
                        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                        Adapter    "socketio"     : 6.1.8    , installed 6.1.8
                        Adapter    "sql"          : 2.1.8    , installed 2.1.8
                        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                        Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
                        Adapter    "web"          : 5.2.4    , installed 5.2.4
                        Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                        Adapter    "ws"           : 2.1.3    , installed 2.1.3
                        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                        • G guitardoc
                          @guitardoc
                          iobroker stop node-red.0
                            @guitardoc
                            guitardoc
                            pi@raspberrypi:/opt/iobroker $ iobroker del node-red
                            • G guitardoc
                              GlasfaserG Offline
                              GlasfaserG Offline
                              iobroker del node-red --debug
                              • G guitardoc
                                G GlasfaserG 2 Antworten Letzte Antwort
                                  guitardoc
                                  pi@raspberrypi:/opt/iobroker $ iobroker del node-red --debug
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    ist der gleich Käse wie hier :
                                    https://forum.iobroker.net/topic/57172/ich-kann-nichts-mehr-installieren-updaten/15?_=1660922486510
                                    EDIT :
                                    Ergebnis zum Schluss
                                    @fiso sagte in Ich kann nichts mehr installieren / updaten:
                                    Ich glaubs kaum, Node-Red ließ sich jetzt wieder installieren.....
                                      EDIT :
                                      guitardoc
                                      @glasfaser
                                      Naja, da hat der TE aber irgendwie wild rumgefrickelt und dabei an irgendeiner Stelle vermutlich irgendwas richtig gemacht - wobei zwischendurch das System kurz vorm Verschrotten war. Ich würde gern herausfinden, was der eine richtige Befehl war ohne mein System dabei zu zerschießen… :-)
                                      Danke übrigens auch an euch beide dass ihr mir hier helft, das ist bei Weitem nicht selbstverständlich!
                                      • G guitardoc
                                        @glasfaser
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @guitardoc
                                        iobroker upgrade node-red@3.3.1 --debug
                                        • G guitardoc
                                          @glasfaser
                                          @guitardoc
                                          Versuch mal node-red upzugraden, vielleicht kommt da mehr ums Eck.
                                          iobroker upgrade node-red --debug
