  4. Problem beim Löschen von Node Red
    5.8k
56 Beiträge 6 Kommentatoren 7.2k Aufrufe 9 Beobachtet
    @guitardoc
    Was hast du eigentlich jetzt genau vor? node-red installieren? node-red deinstallieren?
    guitardoc
    Eigentlich deinstallieren.
    • G guitardoc
      @guitardoc
      iob update -i
      G 1 Antwort Letzte Antwort
        @guitardoc
        iob update -i
        guitardoc
        i@raspberrypi:/opt/iobroker $ iob update -i
        Used repository: Latest
        Adapter    "admin"        : 6.2.17   , installed 6.2.17
        Adapter    "backitup"     : 2.4.12   , installed 2.4.12
        Adapter    "cloud"        : 4.2.1    , installed 4.2.1
        Adapter    "deconz"       : 1.3.21   , installed 1.3.21
        Adapter    "discovery"    : 3.0.5    , installed 3.0.5
        Adapter    "email"        : 1.1.3    , installed 1.1.3
        Adapter    "eusec"        : 0.9.4    , installed 0.9.4
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "javascript"   : 6.0.0    , installed 6.0.0
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
        Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
        Adapter    "shuttercontrol": 1.4.14  , installed 1.4.14
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 6.1.8    , installed 6.1.8
        Adapter    "sql"          : 2.1.8    , installed 2.1.8
        Adapter    "telegram"     : 1.14.1   , installed 1.14.1
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.51   , installed 0.0.51
        Adapter    "web"          : 5.2.4    , installed 5.2.4
        Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
        Adapter    "ws"           : 2.1.3    , installed 2.1.3
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        pi@raspberrypi:/opt/iobroker $
        • G guitardoc
          @guitardoc
          iobroker stop node-red.0
          iobroker del node-red
            @guitardoc
            guitardoc
            pi@raspberrypi:/opt/iobroker $ iobroker del node-red
            Delete adapter "node-red"
            host.raspberrypi object node-red deleted
            host.raspberrypi object node-red.admin deleted
            Error deleting adapter node-red from disk: host.raspberrypi: Cannot uninstall iobroker.node-red: 217
            You might have to delete it yourself!
            GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
            • G guitardoc
              GlasfaserG Offline
              GlasfaserG Offline
              @guitardoc sagte in Problem beim Löschen von Node Red:
              iobroker del node-red --debug
              • G guitardoc
                G GlasfaserG 2 Antworten Letzte Antwort
                  guitardoc
                  pi@raspberrypi:/opt/iobroker $ iobroker del node-red --debug
                    GlasfaserG Offline
                    GlasfaserG Offline
                    ist der gleich Käse wie hier :
                    https://forum.iobroker.net/topic/57172/ich-kann-nichts-mehr-installieren-updaten/15?_=1660922486510
                    EDIT :
                    Ergebnis zum Schluss
                    @fiso sagte in Ich kann nichts mehr installieren / updaten:
                    Ich glaubs kaum, Node-Red ließ sich jetzt wieder installieren.....
                    • GlasfaserG Glasfaser
                      EDIT :
                      guitardoc
                      @glasfaser
                      Naja, da hat der TE aber irgendwie wild rumgefrickelt und dabei an irgendeiner Stelle vermutlich irgendwas richtig gemacht - wobei zwischendurch das System kurz vorm Verschrotten war. Ich würde gern herausfinden, was der eine richtige Befehl war ohne mein System dabei zu zerschießen… :-)
                      Danke übrigens auch an euch beide dass ihr mir hier helft, das ist bei Weitem nicht selbstverständlich!
                      • G guitardoc
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @guitardoc
                        iobroker upgrade node-red@3.3.1 --debug
                        • G guitardoc
                          @glasfaser
                          @guitardoc
                          Versuch mal node-red upzugraden, vielleicht kommt da mehr ums Eck.
                          iobroker upgrade node-red --debug
                          • G Offline
                            guitardoc
                            pi@raspberrypi:/opt/iobroker $ iobroker upgrade node-red --debug
                            This upgrade of "node-red" will introduce the following changes:
                            -> 4.0.0:
                            IMPORTANT: Node.js 14.x now needed at least
                            Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
                            Correctly escape backslashes when writing setting file on Windows
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
                            Update node-red from @3.3.1 to @4.0.0
                            NPM version: 8.15.0
                            Installing iobroker.node-red@4.0.0... (System call)
                            npm ERR! code ENOTEMPTY
                            npm ERR! syscall rename
                            npm ERR! path /opt/iobroker/node_modules/addressparser
                            npm ERR! dest /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/addressparser' -> '/opt/iobroker/node_modules/.addressparser-qF9vtHFg'
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-19T15_50_47_992Z-debug-0.log
                            host.raspberrypi Cannot install iobroker.node-red@4.0.0: 217
                            Ich sehe schon, da müssen die Verzeichnisse gelöscht werden, richtig?
                            rm -rf /opt/iobroker/node_modules/.addressparser-qF9vtHFg
                            • G guitardoc
                              -> 4.0.0:
                              NPM version: 8.15.0
                              npm ERR! errno -39
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @guitardoc
                              Jippp :)
                              • G guitardoc
                                -> 4.0.0:
                                NPM version: 8.15.0
                                npm ERR! errno -39
                                Geht am schnellsten mit dem 'Lösch-Einzeiler', ausgeführt im jeweiligen Verzeichnis:
                                cd /opt/iobroker/node_modules
                                for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                                  guitardoc
                                  schrieb am zuletzt editiert von guitardoc
                                  Arrrghhh - ich hab die alle per Hand gelöscht jetzt… :-) Es hat zwar ein bisschen was gebracht, aber noch nicht komplett - der Adapter ist wohl jetzt auf 4.0.0, aber er lässt sich nicht löschen:
                                  P i@raspberrypi:~ $ iobroker update
                                  Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                                  pi@raspberrypi:~ $ iobroker del node-red --debug
                                  pi@raspberrypi:~ $ iobroker upgrade node-red --debug
                                  Adapter "node-red"       is up to date.
                                  pi@raspberrypi:~ $
                                  EDIT: reboot hatte ich schon gemacht vorher.
                                  • G guitardoc
                                    pi@raspberrypi:~ $
                                    @guitardoc
                                    Stopp den node-red-Adapter.
                                    Dann
                                    iobroker stop
                                    iobroker fix
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm uninstall iobroker.node-red
                                      @guitardoc
                                      Dann
                                      iobroker stop
                                      iobroker fix
                                      cd /opt/iobroker
                                      guitardoc
                                      In den Instanzen ist er nicht mehr zu finden.
                                      Dann kommt:
                                      pi@raspberrypi:~ $ cd /opt/iobroker
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm uninstall iobroker.node-red
                                      npm ERR! path /opt/iobroker/node_modules/acorn
                                      npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
                                      npm ERR! errno -39
                                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-19T16_43_43_723Z-debug-0.log
                                      Ich vermute, die Verzeichnisse müssen wieder gelöscht werden?
                                      • G guitardoc
                                        Dann kommt:
                                        npm ERR! errno -39
                                        Ja. Wo auch immer die jetzt wieder herkommen.
                                        Aber mit dem Einzeiler ist das nicht mehr viel arbeit.
                                        G R 2 Antworten Letzte Antwort
                                          guitardoc
                                          @thomas-braun Jetzt erscheint der Adapter unter iobroker update nicht mehr. Dafür komme ich jetzt bei :8081 nicht mehr auf den Admin - URL kann nicht angezeigt werden…
