  4. Wemo nicht erreichbar
    5.8k
34 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
  • T t4cn
    @glasfaser
    2022-08-18 16:30:14.943	debug	Homebridge Wrapper Bridge publish {"username":"FF:FF:FF:FF:FF:FF","port":0,"pincode":"0","category":2,"addIdentifyingMaterial":true}
    ham-wemo.0
    2022-08-18 16:30:14.939 debug [18.8.2022, 16:30:14] Loading 1 platforms...
    ham-wemo.0
    2022-08-18 16:30:14.939 debug [18.8.2022, 16:30:14] ---
    ham-wemo.0
    2022-08-18 16:30:14.938 debug [18.8.2022, 16:30:14] Registering platform 'homebridge-wemo.Wemo'
    ham-wemo.0
    2022-08-18 16:30:14.936 debug [18.8.2022, 16:30:14] Loaded plugin: homebridge-wemo@5.0.3
    ham-wemo.0
    2022-08-18 16:30:13.150 debug [18.8.2022, 16:30:13] ---
    ham-wemo.0
    2022-08-18 16:30:13.148 debug [18.8.2022, 16:30:13] Loaded 0 cached accessories from cachedAccessories.
    ham-wemo.0
    2022-08-18 16:30:13.095 debug [18.8.2022, 16:30:13] Loaded config.json with 0 accessories and 1 platforms.
    ham-wemo.0
    2022-08-18 16:30:13.033 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.032 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.031 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.030 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.029 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.028 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.027 debug Remember existing Accessory XXXX
    ham-wemo.0
    ham-wemo.0
    2022-08-18 16:30:13.026 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.025 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.024 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:13.023 debug Remember existing Accessory XXXX
    ham-wemo.0
    2022-08-18 16:30:12.511 info Adapter uses Wrapper mode
    ham-wemo.0
    2022-08-18 16:30:12.509 info No additional Libraries to install ...
    ham-wemo.0
    2022-08-18 16:30:12.474 info starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.ham-wemo, node: v16.17.0, js-controller: 4.0.23
    ham-wemo.0
    2022-08-18 16:30:12.331 debug States connected to redis: 127.0.0.1:9000
    ham-wemo.0
    2022-08-18 16:30:12.318 debug States create User PubSub Client
    ham-wemo.0
    2022-08-18 16:30:12.316 debug States create System PubSub Client
    ham-wemo.0
    2022-08-18 16:30:12.307 debug Redis States: Use Redis connection: 127.0.0.1:9000
    ham-wemo.0
    2022-08-18 16:30:12.279 debug Objects connected to redis: 127.0.0.1:9001
    ham-wemo.0
    2022-08-18 16:30:12.270 debug Objects client initialize lua scripts
    ham-wemo.0
    2022-08-18 16:30:12.247 debug Objects create User PubSub Client
    ham-wemo.0
    2022-08-18 16:30:12.245 debug Objects create System PubSub Client
    ham-wemo.0
    2022-08-18 16:30:12.243 debug Objects client ready ... initialize now
    ham-wemo.0
    2022-08-18 16:30:12.203 debug Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.raspberrypi
    2022-08-18 16:30:10.676 info instance system.adapter.ham-wemo.0 started with pid 5155
    host.raspberrypi
    2022-08-18 16:30:08.215 info instance system.adapter.ham-wemo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    ham-wemo.0
    2022-08-18 16:30:07.580 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ham-wemo.0
    2022-08-18 16:30:07.577 info terminating
    ham-wemo.0
    2022-08-18 16:30:07.566 info cleaned everything up...
    host.raspberrypi
    2022-08-18 16:30:07.563 info stopInstance system.adapter.ham-wemo.0 send kill signal
    ham-wemo.0
    2022-08-18 16:30:07.562 info Got terminate signal TERMINATE_YOURSELF
    meinst du das?
    @t4cn sagte in Wemo nicht erreichbar:
    meinst du das?
    wenn du es jetzt in code-tags setzt kann man das erkennen
    • GlasfaserG Glasfaser
      @t4cn
      Steht etwas im ioBroker Log ... besser bei der Instanz die Logstufe auf DEBUG stellen , dann sieht man mehr .
      zusätzlich habe ich den iobroker und den raspberry pi aktualisiert, gefixt und neugestartet,
      Zeigen !
      Ein/ und Ausgabe davon in Code-Tags </> hier einstellen
      cd /opt/iobroker
      npm ls | grep -E 'github.com|ERR'
      iobroker update -i
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      GlasfaserG Offline
      GlasfaserG Offline
      @glasfaser sagte in Wemo nicht erreichbar:
      @t4cn
      Zeigen !
      cd /opt/iobroker
      iobroker update -i
      Ist das Geheim ... frage schon zum dritten mal !!!
        @t4cn
        Zeigen !
        cd /opt/iobroker
        iobroker update -i
        t4cn
        @glasfaser said in Wemo nicht erreichbar:
        iobroker update -i
        Used repository: stable
        Adapter "admin" : 5.3.8 , installed 5.3.8
        Adapter "backitup" : 2.4.10 , installed 2.4.10
        Adapter "discovery" : 3.0.5 , installed 3.0.5
        Adapter "fullcalendar" : 1.2.0 , installed 1.2.0
        Adapter "ham" : 4.0.2 , installed 4.0.2
        Adapter "ham-wemo" : 3.0.0 , installed 3.0.0
        Adapter "info" : 1.9.19 , installed 1.9.19
        Adapter "javascript" : 6.0.0 , installed 5.7.0 [Updatable]
        Controller "js-controller": 4.0.23 , installed 4.0.23
        Adapter "netatmo" : 1.7.1 , installed 1.7.1
        Adapter "scenes" : 2.3.9 , installed 2.3.9
        Adapter "simple-api" : 2.7.0 , installed 2.7.0
        Adapter "socketio" : 4.2.0 , installed 4.2.0
        Adapter "telegram" : 1.13.0 , installed 1.13.0
        Adapter "vis" : 1.4.15 , installed 1.4.15
        Adapter "web" : 4.3.0 , installed 4.3.0
        Adapter "ws" : 1.3.0 , installed 1.3.0
        Adapter "yahka" : 0.13.1 , installed 0.13.1
        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
        armv7l
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.0
        v16.17.0
        8.15.0
        pi
        /opt/iobroker
        apt 1.8.2.3 (armhf)
        Aufruf: apt [Optionen] befehl
        besser?
        sorry, bin noch relativ neu mit iobroker...
          meinst du das?
          GlasfaserG Offline
          GlasfaserG Offline
          @t4cn
          @homoran sagte in Wemo nicht erreichbar:
          meinst du das?
          Dazu .. siehe hier
          T 2 Antworten Letzte Antwort
            @t4cn
            meinst du das?
            Dazu .. siehe hier
            t4cn
            schrieb am zuletzt editiert von t4cn
            @glasfaser @Homoran
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            host.raspberrypi
            host.raspberrypi
            ham-wemo.0
            ham-wemo.0
            ham-wemo.0
            host.raspberrypi
            ham-wemo.0
            host.raspberrypi
            2022-08-18 16:30:07.549	info	stopInstance system.adapter.ham-wemo.0 (force=false, process=true)
            besser?
              @t4cn
              meinst du das?
              Dazu .. siehe hier
              t4cn
              @glasfaser
              das kam auch gerade noch:
              ham-wemo.0
              2022-08-18 17:12:02.386	info	Error setting value for Abluft-XXXX.Abluft-XXXX.On: id Abluft-XXXX.Abluft-XXXX.On not known on setValue
              ham-wemo.0
              2022-08-18 17:12:02.386	debug	Set value true for lookup id Abluft-XXXX.Abluft-XXXX.On
              ham-wemo.0
              2022-08-18 17:12:02.385	info	stateChange ham-wemo.0.Abluft-XXXX.Abluft-XXXX.On {"val":true,"ack":false,"ts":1660835522382,"q":0,"c":"script.js.common.1_XXXX.XXXX_Lueftung_CO2","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1660833559397}
              • T t4cn
                @glasfaser @Homoran
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                host.raspberrypi
                host.raspberrypi
                ham-wemo.0
                ham-wemo.0
                ham-wemo.0
                host.raspberrypi
                ham-wemo.0
                host.raspberrypi
                besser?
                GlasfaserG Offline
                GlasfaserG Offline
                Mache mal in der Konsole :
                iobroker upload all
                Danach
                sudo reboot
                auch deswegen :
                Wenn während eines Schreibvorgangs der Strom ausfällt misslingt dieser Vorgang.
                won einer fehlenden Information bis hin zum vollständig geschrotteten Dateisystem ist jetzt alles möglich.
                  iobroker upload all
                  Danach
                  sudo reboot
                  auch deswegen :
                  t4cn
                  @glasfaser
                  habe es probiert, hat leider nicht geholfen... :-(
                  ich mache ja mit backitup jeden tag ein backup von iobroker und yahka, wäre es einen versuch wert, dass backup von vorgestern (vorm Stromausfall) wiederherzustellen?
                  • T t4cn
                    @glasfaser @Homoran
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    host.raspberrypi
                    host.raspberrypi
                    ham-wemo.0
                    ham-wemo.0
                    ham-wemo.0
                    host.raspberrypi
                    ham-wemo.0
                    host.raspberrypi
                    besser?
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Laut log ist er angemeldet .
                    Ich kenne so den Adapter nicht !?
                    Kann man die Geräte auch per Handy App Steuern !?
                      t4cn
                      ja, die Steckdosen kann man per wemo app steuern, funktioniert einwandfrei. auch über die home app sind die Steckdosen ansprechbar, nur nicht im iobroker bzw. der wemo Instanz...
                      habe übrigens gerade mal das backup wiederhergestellt, hilft leider auch nichts...
                        t4cn
                        @glasfaser
                        weisst du evtl. was das bedeutet:
                        ham-wemo.0
                        2022-08-18 18:25:19.217	info	Error setting value for Abluft-XXXX.Abluft-XXXX.On: id Abluft-XXXX.Abluft-XXXX.On not known on setValue
                        ham-wemo.0
                        2022-08-18 18:25:19.215	info	stateChange ham-wemo.0.Abluft-XXXX.Abluft-XXXX.On {"val":false,"ack":false,"ts":1660839919210,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1660839919210}
                        das ist jedenfalls nach wie vor die Fehlermeldung im Protokoll, wenn ich in den Objekten die jeweilige Steckdose per true/false ein- bzw. ausschalten will...
                        • T t4cn
                          iobroker update -i
                          armv7l
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v16.17.0
                          v16.17.0
                          8.15.0
                          pi
                          /opt/iobroker
                          apt 1.8.2.3 (armhf)
                          besser?
                          v16.17.0
                          8.15.0
                          @Glasfaser mir schwant da was
                          T GlasfaserG 2 Antworten Letzte Antwort
                            v16.17.0
                            8.15.0
                            t4cn
                            @homoran said in Wemo nicht erreichbar:
                            v16.17.0
                            8.15.0
                            da wäre ich aber auch neugierig?! 😉 was schwant dir da?
                              v16.17.0
                              8.15.0
                              GlasfaserG Offline
                              GlasfaserG Offline
                              v16.17.0
                              8.15.0
                              Alles gut ... ist richtig .. und auch aktuell
                              • T t4cn
                                @glasfaser
                                ham-wemo.0
                                ham-wemo.0
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @t4cn
                                Frage ,
                                holt der Adapter selbstständig alle Geräte die über die APP angelernt sind , selbstständig in die Datenpunkte / erzeugt Sie ,
                                oder muß man Sie über den Adapter anlernen !?
                                  t4cn
                                  noch ne kurze frage:
                                  ham-wemo.0
                                  2022-08-18 18:51:00.170	debug	Set value true for lookup id Abluft-XXXX.Abluft-XXXX.On
                                  heisst das, dass ich das Objekt auf true setzen soll, damit ich die lookup id herausfinde?
                                  und was ist die lookup id bzw. wo finde ich die?
                                  ham-wemo.0
                                  2022-08-18 18:51:00.171	info	Error setting value for Abluft-XXXX.Abluft-XXXX.On: id Abluft-XXXX.Abluft-XXXX.On not known on setValue
                                  weil er hier sagt, dass er den wert nicht setzen kann, da er die ID für den "setValue" nicht kennt?
                                  was ist "setValue" und wo würde ich das finden?
                                  oder bin ich komplett auf dem Holzweg?
                                  ich versuche halt nur die Fehlermeldung zu verstehen... ;-)
                                    @t4cn
                                    Frage ,
                                    t4cn
                                    @t4cn
                                    Frage ,
                                    also soweit ich mich erinnere, hat sich der adapter alle infos selber geholt bzw. wüsste ich nicht, dass ich da irgendwas anlernen musste... ist aber auch schon ne weile her, wo ich das alles installiert habe...
                                    • T t4cn
                                      @t4cn
                                      Frage ,
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @t4cn
                                      Teste mal
                                      Adapter Stoppen ,
                                      ein Gerät löschen bzw. die Datenpunkte dazu löschen in ioBroker.
                                      Gerät mit der App abmelden und neu anlernen und dann den Adapter starten , ob die Datenpunkte dazu wieder erzeugt werden , bzw. auch dort wieder schalten lassen
                                        @t4cn
                                        Teste mal
                                        Adapter Stoppen ,
                                        t4cn
                                        @glasfaser
                                        ich hab gerade mal den kompletten wemo adapter deinstalliert und neu installiert, jetzt scheint es zu funzen... einen moment...
                                        • T t4cn
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Einen Moment nur funktioniert ... oder soll ich warten !?
