  4. Test Withings v0.0.x
555 Beiträge 53 Kommentatoren 168.6k Aufrufe 47 Beobachtet
  • T tombox
    @esp8266 Sollte nur beim ersten start passieren
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    #348
    @tombox , hier die Abstände, gerade erst um 10:45 wieder:
    Log-Größe: 2.4 KB
    Zeit
    Nachricht
    withings.0
    	2022-08-12 10:45:56.899	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
    withings.0
    	2022-08-12 10:45:56.491	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
    backitup.0
    	2022-08-12 09:52:54.409	info	[iobroker] backup was activated at 02:00 every 1 day(s)
    backitup.0
    	2022-08-12 09:52:54.260	info	starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.20.0, js-controller: 4.0.23
    backitup.0
    	2022-08-12 09:52:14.165	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0
    	2022-08-12 09:52:14.163	info	terminating
    backitup.0
    	2022-08-12 09:52:14.161	info	cleaned everything up...
    backitup.0
    	2022-08-12 09:52:14.145	info	Got terminate signal TERMINATE_YOURSELF
    admin.0
    	2022-08-12 09:49:33.864	info	==> Connected system.user.admin from ::ffff:192.XXXXXXXX
    withings.0
    	2022-08-12 07:45:56.661	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
    withings.0
    	2022-08-12 07:45:56.421	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
    admin.0
    	2022-08-12 06:04:49.702	info	Repository received successfully.
    • ESP8266E ESP8266
      Log-Größe: 2.4 KB
      Zeit
      Nachricht
      withings.0
      withings.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      admin.0
      withings.0
      withings.0
      admin.0
      tombox
      #349
      @esp8266 auch nach einem adapter Neustart
      ESP8266E 2 Antworten Letzte Antwort
      • T tombox
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        #350
        @tombox , Adapter Restart:
        withings.0
        	2022-08-12 10:58:12.871	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v14.20.0, js-controller: 4.0.23
        withings.0
        	2022-08-12 10:58:06.643	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
        withings.0
        	2022-08-12 10:58:06.536	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        withings.0
        	2022-08-12 10:58:06.533	info	terminating
        Die Meldung kommt alle 3 Stunden.
        v6.2.14
        Log-Größe: 3.1 KB
        Zeit
        Nachricht
        withings.0
        withings.0
        withings.0
        withings.0
        withings.0
        	2022-08-12 10:58:06.530	info	Got terminate signal TERMINATE_YOURSELF
        withings.0
        withings.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        backitup.0
        admin.0
        	2022-08-12 09:49:33.864	info	==> Connected system.user.admin from ::ffff:192.XXXXXXXXX
        withings.0
        withings.0
        admin.0
        admin.0
        	2022-08-12 06:04:42.068	info	Request actual repository...
        admin.0
        	2022-08-12 06:04:14.748	info	Adapter rating updated
        withings.0
        	2022-08-12 04:45:56.549	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
        withings.0
        	2022-08-12 04:45:56.351	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
        iot.0
        	2022-08-12 04:29:26.686	error	Error by device connection: "read ECONNRESET"
        withings.0
        	2022-08-12 01:45:56.641	warn	State "withings.0.info.connection" has no existing object, this might lead to an error in future versions
        • ESP8266E ESP8266
          withings.0
          withings.0
          withings.0
          withings.0
          v6.2.14
          Log-Größe: 3.1 KB
          Zeit
          Nachricht
          withings.0
          withings.0
          withings.0
          withings.0
          withings.0
          withings.0
          withings.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          backitup.0
          admin.0
          withings.0
          withings.0
          admin.0
          admin.0
          admin.0
          withings.0
          withings.0
          iot.0
          withings.0
          Marc BergM Online
          Marc BergM Online
          Marc Berg
          #351
          @esp8266 sagte in Test Withings v0.0.x:
          Diese Fehlermeldungen hatte ich auch, erst nach dem zweiten Adapter-Restart wurde der Datenpunkt angelegt und die Meldungen sind nun weg. Etwas seltsam.
          Marc
          ESP8266E 1 Antwort Letzte Antwort
          • Marc BergM Marc Berg
            Marc
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            #352
            @marc-berg ,muss irgenwas sein, wass nach 180 Min etwas anschiebt.
            Ich habe den Adapter nur geupgradet. Nichts neu angelegt etc.
            • ESP8266E ESP8266
              Marc BergM Online
              Marc BergM Online
              Marc Berg
              #353
              Ja, genau wie bei mir. Gestern den Adapter auf die Version 0.0.10 gebracht, heute früh die "...connection..."-Meldungen gesehen, die alle 3h erschienen sind, danach den Adapter neu gestartet. Daraufhin erschien die Fehlermeldung wieder. Erst nach einem zweiten Neustart sind die Meldungen nun weg.
              • T tombox
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                #354
                @tombox , Meldungen scheinen weg zu sein. 10:58 Uhr was die letzte.
                • MassiveAttackM Offline
                  MassiveAttack
                  #355
                  hallo!
                  jedes mal wenn ich den adapter starten möchte, bekomme ich ein mail mit einem temporären login code. was mache ich falsch? mein login in der app funktioniert ja mit user/pw.
                  • MassiveAttackM MassiveAttack
                    hallo!
                    tombox
                    #356
                    @massiveattack Ist leider ein Manko den man so hinnehmen muss
                    MassiveAttackM 1 Antwort Letzte Antwort
                    • T tombox
                      MassiveAttack
                      schrieb am zuletzt editiert von MassiveAttack
                      #357
                      @tombox
                      würde ich, wenn der adapter starten würde :)
                      withings.0
                      	1346	2022-08-18 13:09:56.349	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                      withings.0
                      	1346	2022-08-18 13:09:56.347	info	terminating
                      withings.0
                      	1346	2022-08-18 13:09:56.322	error	resultArray is not iterable
                      withings.0
                      	1346	2022-08-18 13:09:56.321	error	TypeError: resultArray is not iterable at Withings.login (/opt/iobroker/node_modules/iobroker.withings/main.js:226:26) at processTicksAndRejections (node:internal/process/task_queues:96:5) at Withings.onReady (/opt/iobroker/node_modules/iobroker.withings/main.js:69:5)
                      withings.0
                      	1346	2022-08-18 13:09:56.315	error	unhandled promise rejection: resultArray is not iterable
                      withings.0
                      	1346	2022-08-18 13:09:56.314	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      withings.0
                      	1346	2022-08-18 13:09:56.311	error	{"errors":[{"message":"redirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback url"}]}
                      withings.0
                      	1346	2022-08-18 13:09:53.479	info	starting. Version 0.0.10 in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.0, js-controller: 4.0.23
                        @tombox
                        withings.0
                        withings.0
                        withings.0
                        withings.0
                        withings.0
                        withings.0
                        withings.0
                        withings.0
                        tombox
                        #358
                        @massiveattack callback url stimmt anscheinend nicht hast du wie vorgegeben Callback URI: http://localhost
                        • T tombox
                          MassiveAttack
                          #359
                          @tombox said in Test Withings v0.0.x:
                          http://localhost
                          peinlich, hatte wohl https geschrieben 🙄
                          danke, funktioniert jetzt
                          • Pr3mut05P Offline
                            Pr3mut05P Offline
                            Pr3mut05
                            schrieb am zuletzt editiert von Pr3mut05
                            #360
                            Ich bekomme ständig E-Mails mit dem temporären Passwort
                            Wie kann ich denn das abschalten :/
                            OK - Wurde zwei Kommentare davor beantwortet ;)
                            https://www.bavarian-geek.de
                            • Pr3mut05P Pr3mut05
                              ESP8266E Offline
                              ESP8266E Offline
                              ESP8266
                              #361
                              @tombox , es fängt wieder an.
                              Kaum ein Upgrade gefahren, kann er sich nicht wieder einloggen.
                              Auf der Seite habe ich alles bestätigt.
                              Zurück zu 0.0.10 und geht wieder.
                              • ESP8266E ESP8266
                                tombox
                                #362
                                @esp8266 War noch ein Fehler danke für den Hinweis ist mit 0.0.13 behoben
                                • T tombox
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  #363
                                  @tombox , das Problem besteht weiterhin. Auch ein Neustart behebt es nicht.
                                  Mom...du schreibst 0.0.13 dann ist installiere ich mal vom Github.
                                  Alles gut, lüppt.
                                    MrLee
                                    #364
                                    Moin!
                                    Bin auf der .13 von Github und habe leider das selbe Problem...mache ich was falsch (erste Installation des Adapters)
                                    withings.0
                                    2022-10-23 16:02:25.302	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                    withings.0
                                    2022-10-23 16:02:25.191	warn	Please check username and password
                                    • M MrLee
                                      Moin!
                                      withings.0
                                      withings.0
                                      ESP8266E Offline
                                      ESP8266E Offline
                                      ESP8266
                                      #365
                                      @mrlee , Adapter neu starten.
                                      • ESP8266E ESP8266
                                        MrLee
                                        #366
                                        @esp8266
                                        Moin, dank für die Info...
                                        passiert aber leider genau das Selbe im log und Adapter bleibt gelb.
                                        withings.0
                                        2022-10-24 08:35:28.460	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                        withings.0
                                        2022-10-24 08:35:28.349	warn	Please check username and password
                                        withings.0
                                        2022-10-24 08:35:25.260	info	starting. Version 0.0.13 (non-npm: TA2k/ioBroker.withings) in /opt/iobroker/node_modules/iobroker.withings, node: v16.17.1, js-controller: 4.0.23
                                        withings.0
                                        2022-10-24 08:35:24.709	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        host.iobroker_host-neu
                                        2022-10-24 08:35:21.479	info	instance system.adapter.withings.0 started with pid 15809
                                        2022-10-24 08:35:18.817	info	instance system.adapter.withings.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-10-24 08:35:18.197	info	stopInstance system.adapter.withings.0 send kill signal
                                        withings.0
                                        2022-10-24 08:35:18.170	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        withings.0
                                        2022-10-24 08:35:18.167	info	terminating
                                        withings.0
                                        2022-10-24 08:35:18.161	info	Got terminate signal TERMINATE_YOURSELF
                                        2022-10-24 08:35:18.154	info	stopInstance system.adapter.withings.0 (force=false, process=true)
                                        2022-10-24 08:35:08.695	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2022-10-24 08:35:00.051	info	instance system.adapter.dwd.0 started with pid 15780
                                        withings.0 2022-10-24 08:34:09.785	error	{"status":503,"error":"Invalid Params: Missing [refresh_token]"}
                                        withings.0 2022-10-24 08:34:09.673	warn	Please check username and password
                                        Bekomme auch jedesmal wenn ich den Adapter starte eine Mail von withings
                                        Hier ist Ihr vorläufiger Anmeldecode
                                        Habe ich bei Withinhgs was falsch eingestellt?
                                        bis denne
                                        Mr.Lee
                                        stony2kS 1 Antwort Letzte Antwort
                                        • M MrLee
                                          @esp8266
                                          withings.0
                                          withings.0
                                          withings.0
                                          withings.0
                                          withings.0
                                          withings.0
                                          withings.0
                                          bis denne
                                          Mr.Lee
                                          stony2kS Offline
                                          stony2kS Offline
                                          stony2k
                                          schrieb am zuletzt editiert von stony2k
                                          #367
                                          seit dem Updates des Adapter wird die Zeit von total_sleep_time anders angegeben. Sind das nun Sekunden? Wobei das dann komischerweise nicht mit den Angaben in der App übereinstimmt.
                                          Beispiel: aktuell hat der Datenpunkt den Wert 24300, was 6,7 h sein müssten. Laut der App sind es aber nur 6:45 Min
                                          @mrlee sagte in Test Withings v0.0.x:
                                          bis denne
                                          Mr.Lee
                                          Die Mail bekomme ich auch, ist in meinen Augen einfach zu ignorieren
                                          oberfraggerO 1 Antwort Letzte Antwort
