  4. Test Adapter Betriebsstundenzähler
101 Beiträge 19 Kommentatoren 20.0k Aufrufe 21 Beobachtet
  • Ben1983B Ben1983
    Aktuelle Test Version 0.0.1
    Veröffentlichungsdatum 17.08.2022
    Github Link operating-hours
    Mag jemand meinen Betriebsstundenzähler testen?
    Er zählt die Betriebsstunden, nach Aktivierung des enableCounting states
    Chrille1507
    @ben1983 Also ich würde es gerne testen, bekomme aber folgende Meldung:
    host.ioBrokerMaster
    2022-08-17 17:50:06.833	error	startInstance system.adapter.operating-hours.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "5.3.8", required ">=6.2.14"!
    host.ioBrokerMaster
    2022-08-17 17:50:04.838	info	iobroker exit 0
    host.ioBrokerMaster
    2022-08-17 17:50:03.793	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0 created
    host.ioBrokerMaster
    2022-08-17 17:50:03.778	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.logLevel created
    host.ioBrokerMaster
    2022-08-17 17:50:03.772	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.sigKill created
    host.ioBrokerMaster
    2022-08-17 17:50:03.766	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.eventLoopLag created
    host.ioBrokerMaster
    2022-08-17 17:50:03.760	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.outputCount created
    host.ioBrokerMaster
    2022-08-17 17:50:03.754	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.inputCount created
    host.ioBrokerMaster
    2022-08-17 17:50:03.747	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.uptime created
    host.ioBrokerMaster
    2022-08-17 17:50:03.741	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.memRss created
    host.ioBrokerMaster
    2022-08-17 17:50:03.733	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.memHeapTotal created
    host.ioBrokerMaster
    2022-08-17 17:50:03.727	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.memHeapUsed created
    host.ioBrokerMaster
    2022-08-17 17:50:03.720	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.cputime created
    host.ioBrokerMaster
    2022-08-17 17:50:03.713	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.cpu created
    host.ioBrokerMaster
    2022-08-17 17:50:03.707	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.compactMode created
    host.ioBrokerMaster
    2022-08-17 17:50:03.701	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.connected created
    host.ioBrokerMaster
    2022-08-17 17:50:03.695	info	iobroker host.ioBrokerMaster object system.adapter.operating-hours.0.alive created
    host.ioBrokerMaster
    2022-08-17 17:50:03.686	info	iobroker host.ioBrokerMaster create instance operating-hours
    host.ioBrokerMaster
    2022-08-17 17:50:02.703	info	iobroker add operating-hours auto --host ioBrokerMaster
    DJMarc75D BananaJoeB 2 Antworten Letzte Antwort
    • C Chrille1507
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      host.ioBrokerMaster
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @chrille1507 sagte in Test Adapter Betriebsstundenzähler:
      Das braucht den Latest Admin !
      Lehrling seit 1975 !!!
      • C Chrille1507
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        host.ioBrokerMaster
        BananaJoeB Offline
        BananaJoeB Offline
        BananaJoe
        host.ioBrokerMaster
        Sollte @Ben1983 vielleicht dazu schreiben das der Adapter erst ab Admin 6.2.14 funktioniert ...
        C 1 Antwort Letzte Antwort
        • BananaJoeB BananaJoe
          host.ioBrokerMaster
          Chrille1507
          @bananajoe said in Test Adapter Betriebsstundenzähler:
          Danke. Darauf wollte ich mit meinem Post hinaus.
          Ben1983B 2 Antworten Letzte Antwort
          • C Chrille1507
            Ben1983B Offline
            Ben1983B Offline
            Ben1983
            @chrille1507 Sorry.
            Hatte gewisse Fuktionen in der jsconconfig drin, die erst ab 6.2.3 funktionierten.
            Habe es sicherheitshalber auf den latest gesetzt.
            • C Chrille1507
              Ben1983B Offline
              Ben1983B Offline
              Ben1983
              @chrille1507 Würde es helfen, wenn ich die dependencies runter setze?
              Bei >= 6.2.3 geht es nur um eine sortierung und hinzufügen in einer Table.
              Wenn man das nicht nutzt geht der Adapter auch mit 5.x.x.
              • Ben1983B Ben1983
                Chrille1507
                @ben1983 said in Test Adapter Betriebsstundenzähler:
                Also mir würde das sehr helfen.
                • C Chrille1507
                  Ben1983B Offline
                  Ben1983B Offline
                  Ben1983
                  schrieb am zuletzt editiert von Ben1983
                  @chrille1507 Was brauchst DU für eine Version?
                  Ich habe es jetzt auch die letzte stable 5.3.8 gesetzt.
                  • Ben1983B Ben1983
                    Chrille1507
                    schrieb am zuletzt editiert von Chrille1507
                    @ben1983 Das passt so. Ich werde es jetzt testen.
                    Ich bekomme jetzt folgende Meldungen:
                    operating-hours.0
                    	2022-08-18 10:02:26.442	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    operating-hours.0
                    	2022-08-18 10:02:26.442	info	terminating
                    operating-hours.0
                    	2022-08-18 10:02:26.440	error	Cannot read property 'administrative' of undefined
                    operating-hours.0
                    	2022-08-18 10:02:26.440	error	TypeError: Cannot read property 'administrative' of undefined at OperatingHours.onStateChange (/opt/iobroker/node_modules/iobroker.operating-hours/main.js:307:54) at OperatingHours.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5379:53) at processImmediate (internal/timers.js:464:21)
                    operating-hours.0
                    	2022-08-18 10:02:26.439	error	uncaught exception: Cannot read property 'administrative' of undefined
                    operating-hours.0
                    	2022-08-18 10:02:02.397	info	starting. Version 0.0.6 (non-npm: BenAhrdt/ioBroker.operating-hours#b5612e887b4c8dc5f7ef7196b85a1c022b583f5b) in /opt/iobroker/node_modules/iobroker.operating-hours, node: v14.20.0, js-controller: 4.0.23
                    operating-hours.0
                    	2022-08-18 10:01:47.076	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    operating-hours.0
                    	2022-08-18 10:01:47.075	info	terminating
                    operating-hours.0
                    	2022-08-18 10:01:47.071	error	Cannot read property 'administrative' of undefined
                    operating-hours.0
                    	2022-08-18 10:01:47.071	error	TypeError: Cannot read property 'administrative' of undefined at OperatingHours.onStateChange (/opt/iobroker/node_modules/iobroker.operating-hours/main.js:307:54) at OperatingHours.emit (events.js:400:28) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5379:53) at processImmediate (internal/timers.js:464:21)
                    operating-hours.0
                    	2022-08-18 10:01:47.069	error	uncaught exception: Cannot read property 'administrative' of undefined
                    operating-hours.0
                    	2022-08-18 10:01:21.535	info	starting. Version 0.0.6 (non-npm: BenAhrdt/ioBroker.operating-hours#b5612e887b4c8dc5f7ef7196b85a1c022b583f5b) in /opt/iobroker/node_modules/iobroker.operating-hours, node: v14.20.0, js-controller: 4.0.23
                    operating-hours.0
                    	2022-08-18 10:01:17.579	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    operating-hours.0
                    	2022-08-18 10:01:17.579	info	terminating
                    operating-hours.0
                    	2022-08-18 10:01:17.578	info	Got terminate signal TERMINATE_YOURSELF
                    operating-hours.0
                    	2022-08-18 10:00:14.812	info	starting. Version 0.0.6 (non-npm: BenAhrdt/ioBroker.operating-hours#b5612e887b4c8dc5f7ef7196b85a1c022b583f5b) in /opt/iobroker/node_modules/iobroker.operating-hours, node: v14.20.0, js-controller: 4.0.23
                    Vielleicht stelle ich mich auch zu dumm an. Könntest du zu dem Adapter etwas mehr schreiben und erklären?
                    • Ben1983B Ben1983
                      David G.D Online
                      David G.D Online
                      David G.
                      @ben1983
                      Würde auch mal testen.
                      Allerdings darf ich die Einstellungen nicht speichern.
                      Oder habe ich was falsch ausgefüllt?
                      • Ben1983B Ben1983
                        sigi234S Online
                        sigi234S Online
                        @ben1983
                        Läuft. Teste weiter.
                        • sigi234S sigi234
                          @ben1983
                          Ben1983B Offline
                          Ben1983B Offline
                          Ben1983
                          @sigi234 Danke für die Info.
                          Welche Adamin Version hast Du denn?
                          Ich glaube vielleicht liegt es bei den Anderen doch daran, dass noch etwas verwendet wird, was eine höhere Version benötigt.
                          • Ben1983B Ben1983
                            sigi234S Online
                            sigi234S Online
                            @ben1983 sagte in Test Adapter Betriebsstundenzähler:
                            Plattform: Windows
                            RAM: 16 GB
                            NODE.JS: V16.17.0
                            NPM: 8.11.0
                            JS Controller: 4.0.23
                            Admin: 6.2.14
                            • Ben1983B Ben1983
                              sigi234S Online
                              sigi234S Online
                              @ben1983
                              Wünsche:
                              • Eigene Benennung der Geräte in den Einstellungen
                              • Liste der Geräte als Json Table
                              • C Chrille1507
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                operating-hours.0
                                Ben1983B Offline
                                Ben1983B Offline
                                Ben1983
                                @chrille1507 Kann ich mir jetzt gerade nicht erklären.
                                habe nochmal eine änderung eingespielt. (Betrifft das jetzt nicht direkt, aber vielleicht maldrüber spielen.
                                Welchen Admin hast Du?
                                • Ben1983B Ben1983
                                  sigi234S Online
                                  sigi234S Online
                                  Das hatte ich auch wenn ein Falscher DP eingefügt wurde.
                                  • sigi234S sigi234
                                    Ben1983B Offline
                                    Ben1983B Offline
                                    Ben1983
                                    @sigi234 Was bedeutet ein falscher?
                                    Man kann in den Text eintragen was man will.... der schaut auf keinen DP.
                                    • Ben1983B Ben1983
                                      sigi234S Online
                                      sigi234S Online
                                      Aha, gerade gesehen, dann zählt er nur durch die Aktivierung des DP enableCounting
                                      • sigi234S sigi234
                                        Ben1983B Offline
                                        Ben1983B Offline
                                        Ben1983
                                        @sigi234 ganz genau. Sollte ganz simple gehalten werden und ist somit an keinen dp gebunden… aber wann bekommst du den Fehler?
                                        C sigi234S 2 Antworten Letzte Antwort
                                        • Ben1983B Ben1983
                                          Chrille1507
                                          @ben1983 Gut zu wissen.
                                          Ich bin davon ausgegangen, dass ein DP genutzt werden muss.
