  4. Node-Red
  5. Slider auf null stellen
    6.5k
14 Beiträge 4 Kommentatoren 1.7k Aufrufe 4 Beobachtet
  • N neuling321
    @ Hallo
    Sorry war heute morgen wohl noch nicht ganz wach, ja waren doch etwas zu wenig Infos.
    Es geht wie frankyboy73 schon richtig gesagt hat, um node-red.
    Leider funktioniert das alles irgendwie nicht, hier mal das was ich bisher habe und was auch funktioniert, nur
    das null Stellen des Sliders beim aufrufen oder verlassen der Webseite klappt nicht.
            "id": "2403138cd6adc1e5",
            "type": "inject",
            "z": "93e0029b8d6617ea",
            "name": "",
            "props": [
                    "p": "topic",
                    "v": "0",
                    "vt": "num"
            "repeat": "",
            "crontab": "",
            "once": true,
            "onceDelay": 0.1,
            "topic": "",
            "x": 90,
            "y": 100,
            "wires": [
                    "d0b0ed28374d6acd"
            "id": "d0b0ed28374d6acd",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "0",
                    "tot": "num"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 230,
            "y": 200,
            "wires": [
                    "e2a11196ba92e0d1"
            "id": "e2a11196ba92e0d1",
            "type": "ui_slider",
            "name": "",
            "label": "slider",
            "tooltip": "",
            "group": "8249f6de3bc04b8f",
            "order": 2,
            "width": 0,
            "height": 0,
            "passthru": false,
            "outs": "all",
            "topic": "topic",
            "topicType": "msg",
            "min": "0",
            "max": "50",
            "step": 1,
            "className": "",
            "x": 390,
            "y": 120,
            "wires": [
                    "0e9d557add63b1f5",
                    "52b6ecf315b5317a"
            "id": "0e9d557add63b1f5",
            "type": "ui_gauge",
            "name": "",
            "order": 3,
            "width": 0,
            "height": 0,
            "gtype": "gage",
            "title": "Speedometer",
            "label": "units",
            "format": "",
            "min": "0",
            "max": "50",
            "colors": [
                "#00b500",
                "#e6e600",
                "#ca3838"
            "seg1": "",
            "seg2": "",
            "className": "",
            "x": 640,
            "y": 160,
            "wires": []
            "id": "52b6ecf315b5317a",
            "type": "range",
            "minin": "0",
            "maxin": "50",
            "minout": "0",
            "maxout": "100",
            "action": "scale",
            "round": true,
            "property": "payload",
            "name": "",
            "x": 620,
            "y": 100,
            "wires": [
                    "d04b7cfce1455716"
            "id": "d04b7cfce1455716",
            "type": "rpi-gpio out",
            "name": "LED",
            "pin": "12",
            "set": "",
            "level": "0",
            "freq": "100",
            "out": "pwm",
            "bcm": true,
            "x": 790,
            "y": 100,
            "wires": []
            "id": "8249f6de3bc04b8f",
            "type": "ui_group",
            "name": "Slider",
            "tab": "2c5a2c732f2cb639",
            "order": 1,
            "disp": true,
            "width": 7,
            "collapse": false,
            "className": ""
            "id": "2c5a2c732f2cb639",
            "type": "ui_tab",
            "name": "Steuerung",
            "icon": "dashboard",
            "order": 1,
            "disabled": false,
            "hidden": false
    Irgendwie mache ich da wohl noch was falsch.
    mickymM Offline
    mickymM Offline
    mickym
    @neuling321
    Wo ist das Problem .- wie @frankyboy73 sagte die ui_control vorne dran setzen. Ich habs mal auch nur für den Steuerungstab gefiltert und natürlich im slider die Nachricht durchgeschleift.
           "type": "inject",
           "z": "a9604a18f9eb47cc",
           "name": "",
           "props": [
                   "p": "topic",
                   "v": "0",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": true,
           "onceDelay": 0.1,
           "topic": "",
           "x": 310,
           "y": 180,
           "wires": [
                   "d0b0ed28374d6acd"
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "0",
                   "tot": "num"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 570,
           "y": 280,
           "wires": [
                   "e2a11196ba92e0d1"
           "name": "",
           "label": "slider",
           "tooltip": "",
           "order": 2,
           "width": 0,
           "height": 0,
           "passthru": true,
           "outs": "all",
           "topic": "topic",
           "topicType": "msg",
           "min": "0",
           "max": "50",
           "step": 1,
           "className": "",
           "x": 730,
           "y": 280,
           "wires": [
                   "0e9d557add63b1f5",
                   "52b6ecf315b5317a"
           "type": "ui_gauge",
           "name": "",
           "order": 3,
           "width": 0,
           "height": 0,
           "gtype": "gage",
           "label": "units",
           "format": "",
           "min": "0",
           "max": "50",
           "colors": [
               "#00b500",
               "#e6e600",
               "#ca3838"
           "seg1": "",
           "seg2": "",
           "className": "",
           "x": 900,
           "y": 300,
           "wires": []
           "type": "range",
           "minin": "0",
           "maxin": "50",
           "minout": "0",
           "maxout": "100",
           "action": "scale",
           "round": true,
           "name": "",
           "x": 880,
           "y": 260,
           "wires": [
           "id": "a64d054a38d84c38",
           "type": "ui_ui_control",
           "name": "",
           "events": "change",
           "x": 140,
           "y": 280,
           "wires": [
                   "7664e297e66023da"
           "id": "7664e297e66023da",
           "type": "switch",
           "name": "name = Steuerung?",
           "property": "name",
           "propertyType": "msg",
           "rules": [
                   "t": "eq",
                   "v": "Steuerung",
                   "vt": "str"
           "checkall": "true",
           "repair": false,
           "outputs": 1,
           "x": 330,
           "y": 280,
           "wires": [
                   "d0b0ed28374d6acd"
           "type": "ui_group",
           "name": "Slider",
           "order": 1,
           "disp": true,
           "width": 7,
           "collapse": false,
           "className": ""
           "type": "ui_tab",
           "order": 1,
           "disabled": false,
           "hidden": false
    Wenn es beim Verlassen des tabs auch auf 0 gestellt werden soll, dann halt den Filter weglassen.
    Die slider Node gibt aber nichts aus, wenn sie schon auf 0 war.
    F 1 Antwort Letzte Antwort
    • N neuling321
      @ Hallo
              "type": "inject",
              "name": "",
              "props": [
                      "p": "topic",
                      "v": "0",
                      "vt": "num"
              "repeat": "",
              "crontab": "",
              "once": true,
              "onceDelay": 0.1,
              "topic": "",
              "x": 90,
              "y": 100,
              "wires": [
                      "d0b0ed28374d6acd"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "0",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 230,
              "y": 200,
              "wires": [
                      "e2a11196ba92e0d1"
              "name": "",
              "label": "slider",
              "tooltip": "",
              "order": 2,
              "width": 0,
              "height": 0,
              "passthru": false,
              "outs": "all",
              "topic": "topic",
              "topicType": "msg",
              "min": "0",
              "max": "50",
              "step": 1,
              "className": "",
              "x": 390,
              "y": 120,
              "wires": [
                      "0e9d557add63b1f5",
                      "52b6ecf315b5317a"
              "type": "ui_gauge",
              "name": "",
              "order": 3,
              "width": 0,
              "height": 0,
              "gtype": "gage",
              "label": "units",
              "format": "",
              "min": "0",
              "max": "50",
              "colors": [
                  "#00b500",
                  "#e6e600",
                  "#ca3838"
              "seg1": "",
              "seg2": "",
              "className": "",
              "x": 640,
              "y": 160,
              "wires": []
              "type": "range",
              "minin": "0",
              "maxin": "50",
              "minout": "0",
              "maxout": "100",
              "action": "scale",
              "round": true,
              "name": "",
              "x": 620,
              "y": 100,
              "wires": [
                      "d04b7cfce1455716"
              "name": "LED",
              "pin": "12",
              "set": "",
              "level": "0",
              "freq": "100",
              "out": "pwm",
              "bcm": true,
              "x": 790,
              "y": 100,
              "wires": []
              "type": "ui_group",
              "name": "Slider",
              "order": 1,
              "disp": true,
              "width": 7,
              "collapse": false,
              "className": ""
              "type": "ui_tab",
              "order": 1,
              "disabled": false,
              "hidden": false
      frankyboy73
      schrieb am zuletzt editiert von frankyboy73
      @neuling321 Hi, da fehlt die ui-control. Aus der kommt der Name raus den du über einen Switch auswerten kannst. Also mal die Debug Ausgabe anschauen wenn du die Seite / Tab aufrufst und den Namen in die Switch Node eintragen.
              "type": "change",
              "z": "9e1c0edb.e6d2d",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "0",
                      "tot": "num"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 490,
              "y": 2660,
              "wires": [
                      "e2a11196ba92e0d1"
              "name": "",
              "label": "slider",
              "tooltip": "",
              "order": 2,
              "width": 0,
              "height": 0,
              "passthru": false,
              "outs": "all",
              "topic": "topic",
              "topicType": "msg",
              "min": "0",
              "max": "50",
              "step": 1,
              "className": "",
              "x": 670,
              "y": 2640,
              "wires": [
                      "0e9d557add63b1f5",
                      "52b6ecf315b5317a"
              "type": "ui_gauge",
              "name": "",
              "order": 3,
              "width": 0,
              "height": 0,
              "gtype": "gage",
              "label": "units",
              "format": "",
              "min": "0",
              "max": "50",
              "colors": [
                  "#00b500",
                  "#e6e600",
                  "#ca3838"
              "seg1": "",
              "seg2": "",
              "className": "",
              "x": 920,
              "y": 2680,
              "wires": []
              "type": "range",
              "minin": "0",
              "maxin": "50",
              "minout": "0",
              "maxout": "100",
              "action": "scale",
              "round": true,
              "name": "",
              "x": 900,
              "y": 2620,
              "wires": [
              "id": "f30e16aa84098d4f",
              "name": "",
              "events": "change",
              "x": 380,
              "y": 2540,
              "wires": [
                      "58ae926d0a8d4f68",
                      "b7951df2b2cbc185"
              "id": "58ae926d0a8d4f68",
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "statusType": "auto",
              "x": 750,
              "y": 2480,
              "wires": []
              "id": "b7951df2b2cbc185",
              "type": "switch",
              "name": "",
              "property": "name",
              "rules": [
                      "t": "eq",
                      "v": "Start",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 450,
              "y": 2600,
              "wires": [
                      "d0b0ed28374d6acd"
              "type": "ui_group",
              "name": "Slider",
              "order": 1,
              "disp": true,
              "width": 7,
              "collapse": false,
              "className": ""
              "type": "ui_tab",
              "order": 1,
              "disabled": false,
              "hidden": false
      Im Code fehlt die letzte Node, die musste ich zum testen löschen, weil ich die nicht benutze.
      Edit: Da war @mickym mal wieder schneller.👍
      Edit 2: Warum hast du eigentlich im Slider die Range 0-50 und änderst das dann auf 0-100? Warum nicht gleich im Slider 0-100?
      Schöne Grüße Frank
      • N Offline
        N Offline
        neuling321
        @all
        Cool,
        wieder einiges gelernt.
        Klappt hervorragend.
        Vielen Dank
        • mickymM mickym
          @neuling321
                 "type": "inject",
                 "name": "",
                 "props": [
                         "p": "topic",
                         "v": "0",
                         "vt": "num"
                 "repeat": "",
                 "crontab": "",
                 "once": true,
                 "onceDelay": 0.1,
                 "topic": "",
                 "x": 310,
                 "y": 180,
                 "wires": [
                         "d0b0ed28374d6acd"
                 "type": "change",
                 "name": "",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "0",
                         "tot": "num"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 570,
                 "y": 280,
                 "wires": [
                         "e2a11196ba92e0d1"
                 "name": "",
                 "label": "slider",
                 "tooltip": "",
                 "order": 2,
                 "width": 0,
                 "height": 0,
                 "passthru": true,
                 "outs": "all",
                 "topic": "topic",
                 "topicType": "msg",
                 "min": "0",
                 "max": "50",
                 "step": 1,
                 "className": "",
                 "x": 730,
                 "y": 280,
                 "wires": [
                         "0e9d557add63b1f5",
                         "52b6ecf315b5317a"
                 "type": "ui_gauge",
                 "name": "",
                 "order": 3,
                 "width": 0,
                 "height": 0,
                 "gtype": "gage",
                 "label": "units",
                 "format": "",
                 "min": "0",
                 "max": "50",
                 "colors": [
                     "#00b500",
                     "#e6e600",
                     "#ca3838"
                 "seg1": "",
                 "seg2": "",
                 "className": "",
                 "x": 900,
                 "y": 300,
                 "wires": []
                 "type": "range",
                 "minin": "0",
                 "maxin": "50",
                 "minout": "0",
                 "maxout": "100",
                 "action": "scale",
                 "round": true,
                 "name": "",
                 "x": 880,
                 "y": 260,
                 "wires": [
                 "name": "",
                 "events": "change",
                 "x": 140,
                 "y": 280,
                 "wires": [
                         "7664e297e66023da"
                 "type": "switch",
                 "property": "name",
                 "rules": [
                         "t": "eq",
                         "v": "Steuerung",
                         "vt": "str"
                 "checkall": "true",
                 "repair": false,
                 "outputs": 1,
                 "x": 330,
                 "y": 280,
                 "wires": [
                         "d0b0ed28374d6acd"
                 "type": "ui_group",
                 "name": "Slider",
                 "order": 1,
                 "disp": true,
                 "width": 7,
                 "collapse": false,
                 "className": ""
                 "type": "ui_tab",
                 "order": 1,
                 "disabled": false,
                 "hidden": false
          frankyboy73
          @mickym sagte in Slider auf null stellen:
          Ah, ok, das wusste ich auch noch nicht. Dann kann man sich ja auch ausversehen keine Schleife erstellen. Oder gilt das nur für 0?
          Schöne Grüße Frank
          • F frankyboy73
            mickymM Offline
            mickymM Offline
            mickym
            @frankyboy73 Ich habs nicht ausprobiert - vielleicht auch nur bei geänderten Werten. ;) Hab den Testflow schon wieder gelöscht. ;)
            • N Offline
              N Offline
              neuling321
              Peinlich aber nun habe ich ein paar fragen zum Flow von mickym.
              ui Control -> von welchem Tab komme ich -> das ist klar
              switch -> wenn der Name stimmt gehe über Pin 1 weiter -> auch klar
              inject -> wer triggert das?
              Change -> kann der inject das nicht direkt an den Slider senden ?
              Gruss Sascha
              mickymM F 2 Antworten Letzte Antwort
              • mickymM mickym
                frankyboy73
                @mickym Da hast du recht, habs getestet, wenn Input und letzter Wert gleich, wird nichts ausgegeben.👍
                Schöne Grüße Frank
                • N neuling321
                  Gruss Sascha
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @neuling321 Ich habs mir ehrlich gesagt nicht so genau angeschaut, die Inject stammt ja aus Deinem Flow zu initialisieren gehe ich mal davon aus. Die ChangeNode schmeisst grundsätzlich alles weg - woher es kommt und setzt die payload auf 0.
                  Du willst ja nicht das was aus der ui_control Node kommt in Deinem slider haben. Insofern hast Du Recht, dass Du die Inject Node auch direkt mit Deinem Slider verbindest und nur die Change NOde für den ui_control Input verwendest.
                  • N neuling321
                    Gruss Sascha
                    frankyboy73
                    @neuling321 Hi, der Injekt ist eigentlich nur zum testen, man kann mit der Node allerdings auch zu bestimmten Zeiten oder Intervallen Sachen auslösen.
                    Die Change brauchst du, weil der Trigger aus der ui-control kommt, aber da steht ja nicht die richtige msg (msg.payload = number 0) drin, deshalb die change um die Nachricht die aus der ui-control rauskommt zu ändern, in "msg.payload, number 0"
                    Wenn du das mal richtig nachverfolgen willst, was der Flow macht, dann häng doch mal hinter alle Nodes ne Debug Node und stelle in den Debug Nodes ein Volles Nachrichten Objekt ausgeben, damit kannst du dann sehen was wo ausgegeben und umgewandelt wird.
                    Schöne Grüße Frank
                    • N Offline
                      N Offline
                      neuling321
                      Willen Dank für die Erklärungen werde das am WE mal testen.
                      Aber ich bin schon wieder etwas schlauer geworden.
