  4. Ich kann nichts mehr installieren / updaten
    6.7k
80 Beiträge 6 Kommentatoren 12.4k Aufrufe 5 Beobachtet
  • F FISO
    Ich glaub mein System ist nun schrott...
    pi@iobroker-master:/home/iobroker $ sudo iobroker update        node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module 'graceful-fs'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-                                             extra/lib/fs/index.js:5:12)
        at Module._compile (node:internal/modules/cjs/loader:1105:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        at Module.require (node:internal/modules/cjs/loader:1005:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/fs/index.js'                                             ,
        '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/fs-extra/lib/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Ist das system noch rettbar?
    GlasfaserG Offline
    GlasfaserG Offline
    @fiso sagte in Ich kann nichts mehr installieren / updaten:
    Kein SUDO vor iobroker Befehle !!!!
    F 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      FISO
      @glasfaser ok, aber das Modul graceful-fs kann er immer noch net finden
      • F FISO
        @fiso
        Finger weg von sudo! Warum ist diese Unart immer noch so verbreitet?
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
          @fiso
          cd /opt/iobroker
          FISO
          erstmal vielen Dank euch beiden für eure Hilfe! Ist ja nicht selbstverständlich....
          Langsam aber sicher hab ich das Gefühl, ich werd vom "System" verarscht....
          Langsam breitet sich bei mir der Frust aus.....
          • F FISO
            Das kommt vom löschen des modules-Verzeichnis, würde ich sagen.
            Und die angemeckerten Verzeichnisse kommen von der Verwendung von 'sudo iobroker', würde ich sagen.
              FISO
              @thomas-braun Der Witz ist eigentlich, ich hab das Modul-Verzeichnis nichtmal gelöscht. Ich hab eigentlich nur die Verzeichnisse umbenannt die beim update des SQL Adapters angekreidet wurden,....
              • F FISO
                @fiso
                Was immer alles so gemacht wird...
                Deswegen werden die ja auch gelöscht und nicht umbenannt.
                  @fiso
                  FISO
                  @thomas-braun Ich hab den ganzen Ordner Modules mal platt gemacht. Interessanterweise konnte ich dann den JS-Controller installieren.... Daraufhin konnte iobroker wieder starten. Jetzt versuch ich grad den SQL Adapter upzugraden... bin gespannt ;)
                  So, er hat doch tatsächlich den Adapter installiert... bin einerseits begeistert, andererseits verärgert weil ich gut 6h damit verblödet habe... Oh mann.. Ich danke dir auf jedenfall für deine Mühe, euch beiden!
                  • F FISO
                    HomoranH Offline
                    HomoranH Offline
                    das hast du doch schon vor 2 Stunden!?
                      FISO
                      @homoran nein, hab nur die Module, die er "angekreidet hat", umbenannt.....
                      • F Offline
                        FISO
                        schrieb am zuletzt editiert von FISO
                        Ich glaubs kaum, Node-Red ließ sich jetzt wieder installieren..... Meine "Flows" sind dort auch drin.... Es ist jetzt wie vor 2 Tagen, also läuft.... :)
                        naja, ich hab jetzt ein aktualisiertes System und NPM ist auch auf Version 8.17^^
                        • F FISO
                          Was nicht die passende Version ist. Scheinst aber insgesamt ja gerne irgendwie wild herumzufrickeln.
                          • F Offline
                            FISO
                            @thomas-braun normal nein, mein Motto lautet eigentlich "Never change a running system". Der Auslöser war halt das gestrige Ereignis.....
                            wäre node 16 nicht empfohlen worden damals, wäre ich heute noch auf 14. Aber da gabs doch massive Probleme...... deswegen wurde doch npm 8.x und node 16 als standard vom iobroker team gesetzt.
                            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                            • F FISO
                              @fiso
                              Und warum installierst du dann nodejs und npm nicht ordentlich?
                              Version 	   Date 	V8 	        npm
                              Node.js 18.7.0 	   2022-07-26 	10.2.154.13 	8.15.0
                              Node.js 16.17.0    2022-08-16 	9.4.146.26 	8.15.0
                              • F FISO
                                Das ist ja auch kein Motto, das ist Blödsinn.
                                reindeer-webR 1 Antwort Letzte Antwort
                                • F FISO
                                  HomoranH Offline
                                  HomoranH Offline
                                  äääähhhhhmmmm.
                                  Step by step!
                                  deine jetzigen Probleme kommen von dem Blödsinn mit never change.... . irgendwann werden die Sprünge so groß dass es zu Problemen kommt. Ständig up to date wäre einfacher
                                  npm 8.17 gehört zu node 18. Damit kannst du dir schon wieder Probleme einhandeln. Insbesondere je nachdem wie du es installiert hast.
                                  wo gab es Probleme mit node 14?
                                  wahrscheinlich auch nur mit nicht passendem npm
                                  Die Entwicklung geht immer weiter, irgendwann wirdxauch node 18, dann node 20 empfohlen werden.
                                  Diese Empfehlung kann aber erst dann ausgesprochen werden, wenn iobroker daran angepasst wurde
                                    äääähhhhhmmmm.
                                    Step by step!
                                    FISO
                                    pi@iobroker-master:~ $ npm -v
                                    8.15.0
                                    so, sollte nun passen ;)
                                      reindeer-webR Offline
                                      reindeer-web
                                      Kannst du mir vielleicht bei der Behebung dieser Fehler behilflich sein?
                                      root@iobroker:/opt/iobroker# npm -v
                                      8.18.0
                                      root@iobroker:/opt/iobroker# npm ls | grep -E 'github.com|ERR'
                                      ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#8e2b16fdbe6bc210ecc7a6ed2aa648bc12af6ab8)
                                      ├── iobroker.homepilot20@0.0.32 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#a56acd4b7a5b2498201de8a2b6976e8f0e49de1b)
                                      npm ERR! code ELSPROBLEMS
                                      npm ERR! extraneous: array.prototype.findindex@2.2.0 /opt/iobroker/node_modules/array.prototype.findindex
                                      npm ERR! extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                      npm ERR! extraneous: cli@0.4.5 /opt/iobroker/node_modules/cli
                                      npm ERR! extraneous: cliff@0.1.10 /opt/iobroker/node_modules/cliff
                                      npm ERR! extraneous: decimal.js@10.4.0 /opt/iobroker/node_modules/decimal.js
                                      npm ERR! extraneous: es-abstract@1.20.1 /opt/iobroker/node_modules/es-abstract
                                      npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                      npm ERR! extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                      npm ERR! extraneous: eventemitter3@3.1.2 /opt/iobroker/node_modules/eventemitter3
                                      npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
                                      npm ERR! extraneous: function.prototype.name@1.1.5 /opt/iobroker/node_modules/function.prototype.name
                                      npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                      npm ERR! extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                      npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                      npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                      npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
                                      npm ERR! extraneous: has-tostringtag@1.0.0 /opt/iobroker/node_modules/has-tostringtag
                                      npm ERR! extraneous: homebridge-plugin-wrapper@2.3.0 /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                      npm ERR! extraneous: internal-slot@1.0.3 /opt/iobroker/node_modules/internal-slot
                                      npm ERR! invalid: iobroker.node-red@3.3.1 /opt/iobroker/node_modules/iobroker.node-red
                                      npm ERR! missing: iobroker.telegram@1.13.0, required by iobroker.inst@3.0.0
                                      npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                      npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                      npm ERR! extraneous: is-callable@1.2.4 /opt/iobroker/node_modules/is-callable
                                      npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                      npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                      npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                      npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                      npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                      npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                      npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                      npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                      npm ERR! extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                      npm ERR! extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                      npm ERR! extraneous: node-telegram-bot-api@0.57.0 /opt/iobroker/node_modules/node-telegram-bot-api
                                      npm ERR! extraneous: pkginfo@0.3.1 /opt/iobroker/node_modules/pkginfo
                                      npm ERR! extraneous: pseudomap@1.0.2 /opt/iobroker/node_modules/pseudomap
                                      npm ERR! extraneous: regexp.prototype.flags@1.4.3 /opt/iobroker/node_modules/regexp.prototype.flags
                                      npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                      npm ERR! extraneous: string-argv@0.3.1 /opt/iobroker/node_modules/string-argv
                                      npm ERR! extraneous: string.prototype.trimend@1.0.5 /opt/iobroker/node_modules/string.prototype.trimend
                                      npm ERR! extraneous: string.prototype.trimstart@1.0.5 /opt/iobroker/node_modules/string.prototype.trimstart
                                      npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                      npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                      npm ERR!     /opt/iobroker/.npm/_logs/2022-08-31T09_48_00_014Z-debug-0.log
                                      • reindeer-webR reindeer-web
                                        8.18.0
                                        HomoranH Offline
                                        HomoranH Offline
                                        @reindeer-web sagte in Ich kann nichts mehr installieren / updaten:
                                        bitte mehr Infos zu deinem System.
                                        Außerdem warum du
                                        root@iobroker:/op
                                        als root unterwegs bist un warum und wie du auf
                                        npm -v 8.18.0
                                        kommst, auch in Verbindung mit welcher node Version
                                          Außerdem warum du
                                          root@iobroker:/op
                                          npm -v 8.18.0
                                          reindeer-web
                                          iobroker läuft in einem Container auf einem qnap NAS.
                                          Ich greife darauf mit der console vom portainer zu.
                                          Diese Infos liefert die admin-Oberfläche vom iobroker.
                                          Plattform: docker
                                          RAM: 7.6 GB
                                          Node.js: v16.17.0
                                          NPM: v8.18.0
                                          In der console werden übrigens die gleichen Versionen angezeigt.
                                          Wie könnte ich mich denn mit einem Benutzer in putty einloggen?
