  4. Komme nicht mehr an meine Skripte ran [gelöst]
31 Beiträge 7 Kommentatoren 1.8k Aufrufe 6 Beobachtet
  • E einfachprima
    pi@iobroker:/opt/iobroker $ iob update
    Used repository: stable
    Adapter    "admin"        : 5.3.8    , installed 5.3.8
    Adapter    "backitup"     : 2.4.9    , installed 2.4.9
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
    Adapter    "email"        : 1.1.3    , installed 1.1.3
    Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
    Adapter    "javascript"   : 5.7.0    , installed 6.0.0
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "plex"         : 0.9.1    , installed 0.9.1
    Adapter    "smartthings"  : 0.0.3    , installed 0.0.3
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
    pi@iobroker:/opt/iobroker $ iob upgrade javascript@5.7.0
    BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to downgrade javascript from @6.0.0 to @5.7.0 now? [(y)es, (n)o]: y
    Update javascript from @6.0.0 to @5.7.0
    NPM version: 8.11.0
    Installing iobroker.javascript@5.7.0... (System call)
    host.iobroker Cannot install iobroker.javascript@5.7.0: 217
    @einfachprima sagte in Komme nicht mehr an meine Skripte ran (tab.html not found):
    iob upgrade javascript@5.7.0 --debug
    E 1 Antwort Letzte Antwort
      einfachprima
      pi@iobroker:/opt/iobroker $ iob upgrade javascript@5.7.0 --debug
      NPM version: 8.11.0
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
      npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
      npm ERR!     /home/iobroker/.npm/_logs/2022-07-31T12_56_13_958Z-debug-0.log
      • E einfachprima
        NPM version: 8.11.0
        npm ERR! errno -39
        @einfachprima
        cd /opt/iobroker/node_modules
        for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
        EXAKTENSTESNT GENAUSO eingeben, am besten kopieren.
          @einfachprima
          einfachprima
          Ich hab jetzt das Löschen durchgeführt, und den Downgrade auf javascript 5.7.0 nochmal angestoßen.
          Der Raspi reagiert gerade extrem langsam, ich warte jetzt einfach mal ab ...
          • E einfachprima
            einfachprima
            Fürchte, mein Raspi 3 hat ein thermisches Problem (werde mal ein besseres Gehäuse suchen), jetzt etwas gekühlt und die Installation lief weiter:
            pi@iobroker:/opt/iobroker/node_modules $ iob upgrade javascript@5.7.0
            NPM version: 8.11.0
             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
             States database error: connect ECONNREFUSED 127.0.0.1:9000
            added 6 packages, removed 651 packages, and changed 5 packages in 2h
            45 packages are looking for funding
              run `npm fund` for details
            Cannot set system.adapter.javascript: DB closed
             Cannot find view "system" for search "instance" : Connection is closed.
            Cannot upgrade: Cannot find view "system"
            Trotz Meldungen scheint der Downgrade auf 5.7.0 aber geklappt zu haben, juhu!
            pi@iobroker:/opt/iobroker/node_modules $ iob update
            Adapter    "javascript"   : 5.7.0    , installed 5.7.0
            In der Admin-GUI wird aber unter Skripte noch immer nichts angezeigt:
            paul53P Meister MopperM 2 Antworten Letzte Antwort
            • E einfachprima
              NPM version: 8.11.0
              @einfachprima sagte: nichts angezeigt:
              Prüfe mal, ob die Datei tab.html wirklich nicht vorhanden ist:
              ls -l /opt/iobroker/node_modules/iobroker.javascript/admin
              • E einfachprima
                NPM version: 8.11.0
                Meister MopperM Offline
                Meister Mopper
                @einfachprima
                Wenn die Datei tatsächlich fehlt, würde ich versuchen, den admin-Adapter zu löschen und neu zu installieren?
                iobroker del admin
                iobroker add admin
                Proxmox und HA ...
                  @einfachprima
                  iobroker del admin
                  iobroker add admin
                  einfachprima
                  pi@iobroker:/opt/iobroker/node_modules $ ls -l /opt/iobroker/node_modules/iobroker.javascript/admin
                  total 192
                  -rw-rw-r--+ 1 iobroker iobroker 34618 Jul 31 15:02 adminWords.js
                  -rw-rw-r--+ 1 iobroker iobroker  1151 Jul 31 15:02 asset-manifest.json
                  -rw-rw-r--+ 1 iobroker iobroker 90022 Jul 31 15:02 favicon.ico
                  drwxrwxr-x+ 5 iobroker iobroker  4096 Jul 31 15:02 google-blockly
                  -rw-rw-r--+ 1 iobroker iobroker 24554 Jul 31 15:02 index_m.html
                  -rw-rw-r--+ 1 iobroker iobroker  4026 Jul 31 15:02 javascript.png
                  -rw-rw-r--+ 1 iobroker iobroker   306 Jul 31 15:02 manifest.json
                  -rw-rw-r--+ 1 iobroker iobroker  1486 Jul 31 15:02 pin.png
                  drwxrwxr-x+ 2 iobroker iobroker  4096 Jul 31 15:02 plugins
                  drwxrwxr-x+ 5 iobroker iobroker  4096 Jul 31 15:02 static
                  -rw-rw-r--+ 1 iobroker iobroker 10361 Jul 31 15:02 tab.html
                  drwxrwxr-x+ 6 iobroker iobroker  4096 Jul 31 15:02 vs
                  tab.html wird mir angezeigt. Aber:
                  pi@iobroker:/opt/iobroker/node_modules $ more tab.html
                  more: cannot open tab.html: No such file or directory
                  Da ist wohl der Wurm drin, lesbar sollte sie ja für jeden sein ...
                  • E einfachprima
                    total 192
                    @einfachprima
                    Du musst schon den richtigen Pfad angeben.
                    more iobroker.javascript/admin/tab.html
                    wenn der aktuelle Pfad /opt/iobroker/node_modules ist.
                      @einfachprima
                      einfachprima
                      Oh je, schön doof von mir ...
                      tab.html ist vorhanden, lässt sich öffnen, der Inhalt sieht auch ok und vollständig aus.
                      • E einfachprima
                        @einfachprima sagte: tab.html ist vorhanden, lässt sich öffnen, der Inhalt sieht auch ok und vollständig aus.
                        Dann muss die Ursache eine andere sein. Funktionieren die anderen Tabs vom Admin?
                          einfachprima
                          Alle anderen Tabs (Übersicht, Adapter, Instanzen, Objekte, Aufzählungen, Protokolle, Benutzer, Hosts, Dateien, Backup) funktionieren einwandfrei.
                          Ich kann jetzt nicht mehr genau sagen, seit wann sich die Skripte nicht mehr öffnen. Es lief jetzt alles 2-3 Monate störungsfrei, gestern wollte ich die Skripte erweitern, hab davor gesehen, dass neue Adapterversionen existieren und hab die aktualisiert. Vielleicht ein Fehler.
                          E HomoranH 2 Antworten Letzte Antwort
                          • E einfachprima
                            einfachprima
                            Ansonsten läuft noch influxdb und Grafana.
                            Aktive Adapter-Instanzen sind:
                            • admin.0
                            • backitup.0
                            • influxdb.0
                            • javascript.0
                            • sonoff.0
                            • whatsapp-cmb.0
                            • E einfachprima
                              @einfachprima mal Browser Cache geleert?
                              • E einfachprima
                                • admin.0
                                • backitup.0
                                • influxdb.0
                                • javascript.0
                                • sonoff.0
                                • whatsapp-cmb.0
                                Meister Mopper
                                @einfachprima
                                Oder anderen Browser ausprobiert?
                                Proxmox und HA ...
                                • E Offline
                                  einfachprima
                                  Ja, Browser Cache in Chrome gelöscht, hat leider nichts gebracht. Inkognito-Modus hilft auch nicht.
                                  Und diesen seltsamen Edge-Browser probiert, gleiches Ergebnis :(
                                  Thomas BraunT E 2 Antworten Letzte Antwort
                                  • E einfachprima
                                    @einfachprima
                                    Steht der Admin villeicht noch auf 'Alte Oberfläche'?
                                    • E einfachprima
                                      einfachprima
                                      "Erweitertes Safe Browsing" in Google Chrome hatte ich kürzlich aktiviert und nun wieder deaktiviert, an dem liegt es nicht.
                                      Auch Pi-hole ist aktuell nicht aktiviert, aber das sollte in lokalen Netz eh nichts tun. Und Adblock ist auch aus.
                                        @einfachprima
                                        einfachprima
                                        Nein, steht nicht auf "alte Oberfläche".
                                        Kannte den Schalter noch gar nicht, hab's testweise kurz umgestellt, gleiches Resultat.
                                        • E einfachprima
                                          einfachprima
                                          Auf Dauer ist das unschön, wenn man keine Skripte mehr bearbeiten kann.
                                          Was ist denn die empfohlene Vorgehensweise zum Neuaufsetzen?
                                          • Kann ich influxdb und Grafana auf dem Raspi behalten oder ist es besser, alles komplett neu zu installieren?
                                          • Wie entferne ich iobroker sauber und wie installiere ich es anschließend neu?
                                          • Muss man beim Einspielen der iobroker Sicherung was beachten?
                                          • Was beinhaltet die iobroker Sicherung? Nur die Einstellungen oder auch alle Adapter etc.? Sind die javascript-Skripte in der Sicherung enthalten?
